path: root/arch/arm/common
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2014-01-23Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "In this set, we have: - Refactoring of some of the old StrongARM-1100 GPIO code to make things simpler by Dmitry Eremin-Solenikov - Read-only and non-executable support for modules on ARM from Laura Abbot - Removal of unnecessary set_drvdata() calls in AMBA code - Some non-executable support for kernel lowmem mappings at the 1MB section granularity, and dumping of kernel page tables via debugfs - Some improvements for the timer/clock code on Footbridge platforms, and cleanup some of the LED code there - Fix fls/ffs() signatures to match x86 to prevent build warnings, particularly where these are used with min/max() macros - Avoid using the bootmem allocator on ARM (patches from Santosh Shilimkar) - Various asid/unaligned access updates from Will Deacon" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (51 commits) ARM: SMP implementations are not supposed to return from smp_ops.cpu_die() ARM: ignore memory below PHYS_OFFSET Fix select-induced Kconfig warning for ZBOOT_ROM ARM: fix ffs/fls implementations to match x86 ARM: 7935/1: sa1100: collie: add gpio-keys configuration ARM: 7932/1: bcm: Add DEBUG_LL console support ARM: 7929/1: Remove duplicate SCHED_HRTICK config option ARM: 7928/1: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU ARM: 7927/1: dcache: select DCACHE_WORD_ACCESS for big-endian CPUs ARM: 7926/1: mm: flesh out and fix the comments in the ASID allocator ARM: 7925/1: mm: keep track of last ASID allocation to improve bitmap searching ARM: 7924/1: mm: don't bother with reserved ttbr0 when running with LPAE ARM: PCI: add legacy IDE IRQ implementation ARM: footbridge: cleanup LEDs code ARM: pgd allocation: retry on failure ARM: footbridge: add one-shot mode for DC21285 timer ARM: footbridge: add sched_clock implementation ARM: 7922/1: l2x0: add Marvell Tauros3 support ARM: 7877/1: use built-in byte swap function ARM: 7921/1: mcpm: remove redundant dsb instructions prior to sev ...
2013-12-29ARM: 7921/1: mcpm: remove redundant dsb instructions prior to sevWill Deacon
sync_cache_w already includes a dsb, so we can just use sev() directly then following a cache-sync. Acked-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-29ARM: 7918/1: clean up cache handling in core codeNicolas Pitre
We have a handy macro to replace open coded __cpuc_flush_dcache_area(() and outer_clean_range() sequences. Let's use it. No functional change. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-11arm/PCI: Use dev_is_pci() to identify PCI devicesYijing Wang
Use dev_is_pci() instead of checking bus type directly. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-06Merge branch 'soc/sched_clock' into next/socKevin Hilman
From Stephen Boyd: * soc/sched_clock: ARM: versatile: Switch to sched_clock_register() ARM: orion: Switch to sched_clock_register() ARM: OMAP: Switch to sched_clock_register() ARM: iop: Switch to sched_clock_register() ARM: u300: Switch to sched_clock_register() ARM: sa1100: Switch to sched_clock_register() ARM: pxa: Switch to sched_clock_register() ARM: OMAP2+: Switch to sched_clock_register() ARM: OMAP1: Switch to sched_clock_register() ARM: msm: Switch to sched_clock_register() ARM: mmp: Switch to sched_clock_register() ARM: IXP4xx: Switch to sched_clock_register() ARM: integrator: Switch to sched_clock_register() ARM: imx: Switch to sched_clock_register() ARM: davinci: Switch to sched_clock_register() ARM: clps711x: Switch to sched_clock_register() ARM: timer-sp: Switch to sched_clock_register() Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-11-21ARM: timer-sp: Switch to sched_clock_register()Stephen Boyd
The 32 bit sched_clock interface now supports 64 bits. Upgrade to the 64 bit function to allow us to remove the 32 bit registration interface. Also mark the read function notrace since we're here and failure to do so would cause ftrace to break. Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-11-20Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine changes from Vinod Koul: "This brings for slave dmaengine: - Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as dmaengine can only transfer and not verify validaty of dma transfers - Bunch of fixes across drivers: - cppi41 driver fixes from Daniel - 8 channel freescale dma engine support and updated bindings from Hongbo - msx-dma fixes and cleanup by Markus - DMAengine updates from Dan: - Bartlomiej and Dan finalized a rework of the dma address unmap implementation. - In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus [Walleij] for their review. - Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. - Some minor fixes / cleanups to mv_xor and ioatdma" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits) dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers dma: mv_xor: Remove unneeded NULL address check ioat: fix ioat3_irq_reinit ioat: kill msix_single_vector support raid6test: add new corner case for ioatdma driver ioatdma: clean up sed pool kmem_cache ioatdma: fix selection of 16 vs 8 source path ioatdma: fix sed pool selection ioatdma: Fix bug in selftest after removal of DMA_MEMSET. dmatest: verbose mode dmatest: convert to dmaengine_unmap_data dmatest: add a 'wait' parameter dmatest: add basic performance metrics dmatest: add support for skipping verification and random data setup dmatest: use pseudo random numbers dmatest: support xor-only, or pq-only channels in tests dmatest: restore ability to start test at module load and init dmatest: cleanup redundant "dmatest: " prefixes dmatest: replace stored results mechanism, with uniform messages Revert "dmatest: append verify result to results" ...
2013-11-14Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this series are: 1. BE8 (modern big endian) changes for ARM from Ben Dooks 2. big.Little support from Nicolas Pitre and Dave Martin 3. support for LPAE systems with all system memory above 4GB 4. Perf updates from Will Deacon 5. Additional prefetching and other performance improvements from Will. 6. Neon-optimised AES implementation fro Ard. 7. A number of smaller fixes scattered around the place. There is a rather horrid merge conflict in tools/perf - I was never notified of the conflict because it originally occurred between Will's tree and other stuff. Consequently I have a resolution which Will forwarded me, which I'll forward on immediately after sending this mail. The other notable thing is I'm expecting some build breakage in the crypto stuff on ARM only with Ard's AES patches. These were merged into a stable git branch which others had already pulled, so there's little I can do about this. The problem is caused because these patches have a dependency on some code in the crypto git tree - I tried requesting a branch I can pull to resolve these, and all I got each time from the crypto people was "we'll revert our patches then" which would only make things worse since I still don't have the dependent patches. I've no idea what's going on there or how to resolve that, and since I can't split these patches from the rest of this pull request, I'm rather stuck with pushing this as-is or reverting Ard's patches. Since it should "come out in the wash" I've left them in - the only build problems they seem to cause at the moment are with randconfigs, and since it's a new feature anyway. However, if by -rc1 the dependencies aren't in, I think it'd be best to revert Ard's patches" I resolved the perf conflict roughly as per the patch sent by Russell, but there may be some differences. Any errors are likely mine. Let's see how the crypto issues work out.. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits) ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h" ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg(). ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h ARM: 7871/1: amba: Extend number of IRQS ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise() ARM: 7872/1: Support arch_irq_work_raise() via self IPIs ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode ARM: 7878/1: nommu: Implement dummy early_paging_init() ARM: 7876/1: clear Thumb-2 IT state on exception handling ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}() ARM: footbridge: fix build warnings for netwinder ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu ARM: fix misplaced arch_virt_to_idmap() ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation ARM: 7869/1: remove unused XSCALE_PMU Kconfig param ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments ARM: 7862/1: pcpu: replace __get_cpu_var_uses ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code ...
2013-11-12Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/include/asm/atomic.h arch/arm/include/asm/hardirq.h arch/arm/kernel/smp.c
2013-11-11Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.13. Qualcomm msm targets had a bunch of code removal for legacy non-DT platforms. Nomadik saw more device tree conversions and cleanup of old code. Tegra has some code refactoring, etc. One longish patch series from Sebastian Hasselbarth changes the init_time hooks and tries to use a generic implementation for most platforms, since they were all doing more or less the same things. Finally the "shark" platform is removed in this release. It's been abandoned for a while and nobody seems to care enough to keep it around. If someone comes along and wants to resurrect it, the removal can easily be reverted and code brought back. Beyond this, mostly a bunch of removals of stale content across the board, etc" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (79 commits) ARM: gemini: convert to GENERIC_CLOCKEVENTS ARM: EXYNOS: remove CONFIG_MACH_EXYNOS[4, 5]_DT config options ARM: OMAP3: control: add API for setting IVA bootmode ARM: OMAP3: CM/control: move CM scratchpad save to CM driver ARM: OMAP3: McBSP: do not access CM register directly ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock ARM: OMAP2: CM/PM: remove direct register accesses outside CM code MAINTAINERS: Add patterns for DTS files for AT91 ARM: at91: remove init_machine() as default is suitable ARM: at91/dt: split sama5d3 peripheral definitions ARM: at91/dt: split sam9x5 peripheral definitions ARM: Remove temporary sched_clock.h header ARM: clps711x: Use linux/sched_clock.h MAINTAINERS: Add DTS files to patterns for Samsung platform ARM: EXYNOS: remove unnecessary header inclusions from exynos4/5 dt machine file ARM: tegra: fix ARCH_TEGRA_114_SOC select sort order clk: nomadik: fix missing __init on nomadik_src_init ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUP ARM: S3C64XX: Kill CONFIG_PLAT_S3C64XX ASoC: samsung: Use CONFIG_ARCH_S3C64XX to check for S3C64XX support ...
2013-11-07ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}()Tushar Behera
Commit 6dedcca610c6 ("hotplug, powerpc, x86: Remove cpu_hotplug_driver_lock())" removes the the definition of cpu_hotplug_driver_{lock,unlock} APIs, thereby causing a build error. Replace these calls with {lock,unlock}_device_hotplug(). Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-31Merge branch 'dma_complete' into nextVinod Koul
2013-10-30Merge branch 'baserock/bjdooks/312-rc4/be/core-v3' of ↵Russell King
git://git.baserock.org/delta/linux into devel-stable Conflicts: arch/arm/kernel/head.S This series has been well tested and it would be great to get this merged now. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-30dmanengine: fix edma driver to not define DMA_COMPLETEVinod Koul
edma header defines DMA_COMPLETE, this causes issues as commit adfedd9a32e4 move DMA_SUCCESS to DMA_COMPLETE. edma should properly namespace its defines and needs a future fix Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-29ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdownDave Martin
CPU hotplug and kexec rely on smp_ops.cpu_kill(), which is supposed to wait for the CPU to park or power down, and perform the last rites (such as disabling clocks etc., where the platform doesn't do this automatically). kexec in particular is unsafe without performing this synchronisation to park secondaries. Without it, the secondaries might not be parked when kexec trashes the kernel. There is no generic way to do this synchronisation, so a new mcpm platform_ops method power_down_finish() is added by this patch. The new method is mandatory. A platform which provides no way to detect when CPUs are parked is likely broken. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-29ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translationDave Martin
This patch factors the logical-to-physical CPU translation out of mcpm_boot_secondary(), so that it can be reused elsewhere. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-29ARM: 7856/1: timer-sp: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch proposes to remove the use of the IRQF_DISABLED flag It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-28Merge tag 'omap-for-v3.13/cm-scm-cleanup-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Paul Walmsley <paul@pwsan.com> via Tony Lindgren: Move some of the OMAP2+ CM and System Control Module direct register accesses into CM- and System Control Module-specific "drivers" underneath arch/arm/mach-omap2/. This is a prerequisite for moving this code out of arch/arm/mach-omap2/ into drivers/. Basic test logs are available here: http://www.pwsan.com/omap/testlogs/cm_scm_cleanup_a_v3.13/20131019101809/ * tag 'omap-for-v3.13/cm-scm-cleanup-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP3: control: add API for setting IVA bootmode ARM: OMAP3: CM/control: move CM scratchpad save to CM driver ARM: OMAP3: McBSP: do not access CM register directly ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock ARM: OMAP2: CM/PM: remove direct register accesses outside CM code + Linux 3.12-rc4 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-19ARM: mcpm: fix big endian issue in mcpm startup codeVictor Kamensky
In big endian mode mcpm_entry_point is first function that called on secondaries CPU. First it should switch CPU into big endian code. [ben.dooks@codethink.co.uk: merge fix patch from Victor into this] Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
2013-10-14Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Some more ARM fixes, nothing particularly major here. The biggest change is to fix the SMP_ON_UP code so that it works with TI's Aegis cores" * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7851/1: check for number of arguments in syscall_get/set_arguments() ARM: 7846/1: Update SMP_ON_UP code to detect A9MPCore with 1 CPU devices ARM: 7845/1: sharpsl_param.c: fix invalid memory access for pxa devices ARM: 7843/1: drop asm/types.h from generic-y ARM: 7842/1: MCPM: don't explode if invoked without being initialized first
2013-10-03ARM: 7845/1: sharpsl_param.c: fix invalid memory access for pxa devicesAndrea Adami
This fixes a regression for kernels after v3.2 After commit 72662e01088394577be4a3f14da94cf87bea2591 ARM: head.S: only include __turn_mmu_on in the initial identity mapping Zaurus PXA devices call sharpsl_save_param() during fixup and hang on boot because memcpy refers to physical addresses no longer valid if the MMU is setup. Zaurus collie (SA1100) is unaffected (function is called in init_machine). The code was making assumptions and for PXA the virtual address should have been used before. Signed-off-by: Marko Katic <dromede@gmail.com> Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-03ARM: 7842/1: MCPM: don't explode if invoked without being initialized firstNicolas Pitre
Currently mcpm_cpu_power_down() and mcpm_cpu_suspend() trigger BUG() if mcpm_platform_register() is not called beforehand. This may occur for many reasons such as some incomplete device tree passed to the kernel or the like. Let's be nicer to users and avoid killing the kernel if that happens by logging a warning and returning to the caller. The mcpm_cpu_suspend() user is already set to deal with this situation, and so is cpu_die() invoking mcpm_cpu_die(). The problematic case would have been the B.L switcher's usage of mcpm_cpu_power_down(), however it has to call mcpm_cpu_power_up() first which is already set to catch an error resulting from a missing mcpm_platform_register() call. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-09-30ARM: edma: Fix clearing of unused list for DT DMA resourcesJoel Fernandes
HWMOD removal for MMC is breaking edma_start as the events are being manually triggered due to unused channel list not being clear. The above issue is fixed by reading the "dmas" property from the DT node if it exists and clearing the bits in the unused channel list if the dma controller used by any device is EDMA. For this purpose we use the of_* helpers to parse the arguments in the dmas phandle list. Also introduced is a minor clean up of a checkpatch error in old code. Reviewed-by: Sekhar Nori <nsekhar@ti.com> Reported-by: Balaji T K <balajitk@ti.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Olof Johansson <olof@lixom.net> Cc: Nishanth Menon <nm@ti.com> Cc: Pantel Antoniou <panto@antoniou-consulting.com> Cc: Jason Kridner <jkridner@beagleboard.org> Cc: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-23ARM: bL_switcher: Add query interface to discover CPU affinitiesDave Martin
When the switcher is active, there is no straightforward way to figure out which logical CPU a given physical CPU maps to. This patch provides a function bL_switcher_get_logical_index(mpidr), which is analogous to get_logical_index(). This function returns the logical CPU on which the specified physical CPU is grouped (or -EINVAL if unknown). If the switcher is inactive or not present, -EUNATCH is returned instead. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: bL_switcher/trace: Add kernel trace trigger interfaceDave Martin
This patch exports a bL_switcher_trace_trigger() function to provide a means for drivers using the trace events to get the current status when starting a trace session. Calling this function is equivalent to pinging the trace_trigger file in sysfs. Signed-off-by: Dave Martin <dave.martin@linaro.org>
2013-09-23ARM: bL_switcher/trace: Add trace trigger for trace bootstrappingDave Martin
When tracing switching, an external tracer needs a way to bootstrap its knowledge of the logical<->physical CPU mapping. This patch adds a sysfs attribute trace_trigger. A write to this attribute will generate a power:cpu_migrate_current event for each online CPU, indicating the current physical CPU for each logical CPU. Activating or deactivating the switcher also generates these events, so that the tracer knows about the resulting remapping of affected CPUs. Signed-off-by: Dave Martin <dave.martin@linaro.org>
2013-09-23ARM: bL_switcher: Basic trace events supportDave Martin
This patch adds simple trace events to the b.L switcher code to allow tracing of CPU migration events. To make use of the trace events, you will need: CONFIG_FTRACE=y CONFIG_ENABLE_DEFAULT_TRACERS=y The following events are added: * power:cpu_migrate_begin * power:cpu_migrate_finish each with the following data: u64 timestamp; u32 cpu_hwid; power:cpu_migrate_begin occurs immediately before the switcher-specific migration operations start. power:cpu_migrate_finish occurs immediately when migration is completed. The cpu_hwid field contains the ID fields of the MPIDR. * For power:cpu_migrate_begin, cpu_hwid is the ID of the outbound physical CPU (equivalent to (from_phys_cpu,from_phys_cluster)). * For power:cpu_migrate_finish, cpu_hwid is the ID of the inbound physical CPU (equivalent to (to_phys_cpu,to_phys_cluster)). By design, the cpu_hwid field is masked in the same way as the device tree cpu node reg property, allowing direct correlation to the DT description of the hardware. The timestamp is added in order to minimise timing noise. An accurate system-wide clock should be used for generating this (hopefully getnstimeofday is appropriate, but it could be changed). It could be any monotonic shared clock, since the aim is to allow accurate deltas to be computed. We don't necessarily care about accurate synchronisation with wall clock time. In practice, each switch takes place on a single logical CPU, and the trace infrastructure should guarantee that events are well-ordered with respect to a single logical CPU. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: bL_switcher: wait until inbound is alive before performing a switchNicolas Pitre
In some cases, a significant delay may be observed between the moment a request for a CPU to come up is made and the moment it is ready to start executing kernel code. This is especially true when a whole cluster has to be powered up which may take in the order of miliseconds. It is therefore a good idea to let the outbound CPU continue to execute code in the mean time, and be notified when the inbound is ready before performing the actual switch. This is achieved by registering a completion block with the appropriate IPI callback, and programming the sending of an IPI by the early assembly code prior to entering the main kernel code. Once the IPI is delivered to the outbound CPU, the completion block is "completed" and the switcher thread is resumed. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: mcpm: add a simple poke mechanism to the early entry codeNicolas Pitre
This allows to poke a predetermined value into a specific address upon entering the early boot code in bL_head.S. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: bL_switcher: synchronize the outbound with the inboundNicolas Pitre
Let's wait for the inbound CPU to come up and snoop some of the outbound CPU cache before bringing the outbound CPU down. That should be more efficient than going down right away. Possible improvements might involve some monitoring of the CCI event counters. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: bL_switcher: Add switch completion callback for bL_switch_request()Dave Martin
There is no explicit way to know when a switch started via bL_switch_request() is complete. This can lead to unpredictable behaviour when the switcher is controlled by a subsystem which makes dynamic decisions (such as cpufreq). The CPU PM notifier is not really suitable for signalling completion, because the CPU could get suspended and resumed for other, independent reasons while a switch request is in flight. Adding a whole new notifier for this seems excessive, and may tempt people to put heavyweight code on this path. This patch implements a new bL_switch_request_cb() function that allows for a per-request lightweight callback, private between the switcher and the caller of bL_switch_request_cb(). Overlapping switches on a single CPU are considered incorrect if they are requested via bL_switch_request_cb() with a callback (they will lead to an unpredictable final state without explicit external synchronisation to force the requests into a particular order). Queuing requests robustly would be overkill because only one subsystem should be attempting to control the switcher at any time. Overlapping requests of this kind will be failed with -EBUSY to indicate that the second request won't take effect and the completer will never be called for it. bL_switch_request() is retained as a wrapper round the new function, with the old, fire-and-forget semantics. In this case the last request will always win. The request may still be denied if a previous request with a completer is still pending. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2013-09-23ARM: bL_switcher: Add runtime control notifierDave Martin
Some subsystems will need to respond synchronously to runtime enabling and disabling of the switcher. This patch adds a dedicated notifier interface to support such subsystems. Pre- and post- enable/disable notifications are sent to registered callbacks, allowing safe transition of non-b.L- transparent subsystems across these control transitions. Notifier callbacks may veto switcher (de)activation on pre notifications only. Post notifications won't revert the action. If enabling or disabling of the switcher fails after the pre-change notification has been sent, subsystems which have registered notifiers can be left in an inappropriate state. This patch sends a suitable post-change notification on failure, indicating that the old state has been reestablished. For example, a failed initialisation will result in the following sequence: BL_NOTIFY_PRE_ENABLE /* switcher initialisation fails */ BL_NOTIFY_POST_DISABLE It is the responsibility of notified subsystems to respond in an appropriate way. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-23ARM: bL_switcher: Add synchronous enable/disable interfaceDave Martin
Some subsystems will need to know for sure whether the switcher is enabled or disabled during certain critical regions. This patch provides a simple mutex-based mechanism to discover whether the switcher is enabled and temporarily lock out further enable/disable: * bL_switcher_get_enabled() returns true iff the switcher is enabled and temporarily inhibits enable/disable. * bL_switcher_put_enabled() permits enable/disable of the switcher again after a previous call to bL_switcher_get_enabled(). Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-09-17Merge branch 'iks_for_rmk' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable Nicolas Pitre writes: This is the first part of the patch series adding IKS (In-Kernel Switcher) support for big.LITTLE system architectures. This consists of the core patches only. Extra patches to come later will introduce various optimizations and tracing support. Those patches were posted on the list a while ago here: http://news.gmane.org/group/gmane.linux.ports.arm.kernel/thread=253942
2013-09-17ARM: delete mach-sharkLinus Walleij
The Shark machine sub-architecture (also known as DNARD, the DIGITAL Network Appliance Reference Design) lacks a maintainer able to apply and test patches to modernize the architecture. It is suspected that the current kernel, while it compiles, does not even boot on this machine. The listed maintainer has expressed that he will not be able to spend any time on the maintenance for the coming year. So let's delete it from the kernel for now. It can always be resurrected with git revert if maintenance is resumed. As the VIA82c505 PCI adapter was only used by this architecture, that gets deleted too. Cc: arm@kernel.org Cc: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-16Merge branch 'timers/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer code update from Thomas Gleixner: - armada SoC clocksource overhaul with a trivial merge conflict - Minor improvements to various SoC clocksource drivers * 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding clocksource: armada-370-xp: Get reference fixed-clock by name clocksource: armada-370-xp: Replace WARN_ON with BUG_ON clocksource: armada-370-xp: Fix device-tree binding clocksource: armada-370-xp: Introduce new compatibles clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE clocksource: armada-370-xp: Simplify TIMER_CTRL register access clocksource: armada-370-xp: Use BIT() ARM: timer-sp: Set dynamic irq affinity ARM: nomadik: add dynamic irq flag to the timer clocksource: sh_cmt: 32-bit control register support clocksource: em_sti: Convert to devm_* managed helpers
2013-09-10Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This pull brings: - Andy's DW driver updates - Guennadi's sh driver updates - Pl08x driver fixes from Tomasz & Alban - Improvements to mmp_pdma by Daniel - TI EDMA fixes by Joel - New drivers: - Hisilicon k3dma driver - Renesas rcar dma driver - New API for publishing slave driver capablities - Various fixes across the subsystem by Andy, Jingoo, Sachin etc..." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits) dma: edma: Remove limits on number of slots dma: edma: Leave linked to Null slot instead of DUMMY slot dma: edma: Find missed events and issue them ARM: edma: Add function to manually trigger an EDMA channel dma: edma: Write out and handle MAX_NR_SG at a given time dma: edma: Setup parameters to DMA MAX_NR_SG at a time dmaengine: pl330: use dma_set_max_seg_size to set the sg limit dmaengine: dma_slave_caps: remove sg entries dma: replace devm_request_and_ioremap by devm_ioremap_resource dma: ste_dma40: Fix potential null pointer dereference dma: ste_dma40: Remove duplicate const dma: imx-dma: Remove redundant NULL check dma: dmagengine: fix function names in comments dma: add driver for R-Car HPB-DMAC dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap() dma: imx-sdma: Staticize sdma_driver_data structures pch_dma: Add MODULE_DEVICE_TABLE dmaengine: PL08x: Add cyclic transfer support dmaengine: PL08x: Fix reading the byte count in cctl dmaengine: PL08x: Add support for different maximum transfer size ...
2013-09-04ARM: edma: Add function to manually trigger an EDMA channelJoel Fernandes
Manual trigger for events missed as a result of splitting a scatter gather list and DMA'ing it in batches. Add a helper function to trigger a channel incase any such events are missed. Signed-off-by: Joel Fernandes <joelf@ti.com> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-22ARM: timer-sp: Set dynamic irq affinityViresh Kumar
When a cpu goes to a deep idle state where its local timer is shutdown, it notifies the time frame work to use the broadcast timer instead. Unfortunately, the broadcast device could wake up any CPU, including an idle one which is not concerned by the wake up at all. This implies, in the worst case, an idle CPU will wake up to send an IPI to another idle cpu. This patch fixes this for ARM platforms using timer-sp, by setting CLOCK_EVT_FEAT_DYNIRQ feature. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2013-08-12ARM: mcpm: use -st dsb option prior to sev instructionsWill Deacon
In a similar manner to our spinlock implementation, mcpm uses sev to wake up cores waiting on a lock when the lock is unlocked. In order to ensure that the final write unlocking the lock is visible, a dsb instruction is executed immediately prior to the sev. This patch changes these dsbs to use the -st option, since we only require that the store unlocking the lock is made visible. Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Dave Martin <dave.martin@arm.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-08-05ARM: bL_switcher: add a simple /dev user interface for debugging purposesNicolas Pitre
Only the basic call to aid debugging. *** NOT FOR PRODUCTION *** Usage: echo <cpuid>,<clusterid> > /dev/b.L_switcher where <cpuid> is the logical CPU number, and <clusterid> is 0 for the first cluster and 1 for the second cluster. Signed-off-by: nicolas Pitre <nico@linaro.org>
2013-08-05ARM: bL_switcher: filter CPU hotplug requests when the switcher is activeNicolas Pitre
Trying to support both the switcher and CPU hotplug at the same time is tricky due to ambiguous semantics. So let's at least prevent users from messing around with those logical CPUs the switcher has removed and those which were not active when the switcher was activated. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-08-04ARM: bL_switcher: remove assumptions between logical and physical CPUsNicolas Pitre
Up to now, the logical CPU was somehow tied to the physical CPU number within a cluster. This causes problems when forcing the boot CPU to be different from the first enumerated CPU in the device tree creating a discrepancy between logical and physical CPU numbers. Let's make the pairing completely independent from physical CPU numbers. Let's keep only those logical CPUs with same initial CPU cluster to create a uniform scheduler profile without having to modify any of the probed topology and compute capacity data. This has the potential to create a non contiguous CPU numbering space when the switcher is active with potential impact on buggy user space tools. It is however better to fix those tools rather than making the switcher code more intrusive. Signed-off-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2013-07-30ARM: bL_switcher: add kernel cmdline param to disable the switcher on bootNicolas Pitre
By adding no_bL_switcher to the kernel cmdline string, the switcher won't be activated automatically at boot time. It is still possible to activate it later with: echo 1 > /sys/kernel/bL_switcher/active Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-07-30ARM: bL_switcher: ability to enable and disable the switcher via sysfsNicolas Pitre
The /sys/kernel/bL_switcher/enable file allows to enable or disable the switcher by writing 1 or 0 to it respectively. It is still enabled by default on boot. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-07-30ARM: bL_switcher: do not hardcode GIC IDs in the codeNicolas Pitre
Currently, GIC IDs are hardcoded making the code dependent on the 4+4 b.L configuration. Let's allow for GIC IDs to be discovered upon switcher initialization to support other b.L configurations such as the 1+1 one, or 2+3 as on the VExpress TC2. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-07-30ARM: bL_switcher: hot-unplug half of the available CPUsNicolas Pitre
In a regular kernel configuration, all the CPUs are initially available. But the switcher execution model uses half of them at any time. Instead of hacking the DTB to remove half of the CPUs, let's remove them at run time and make sure we still have a working switcher configuration. This way, the same DTB can be used whether or not the switcher is used. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-07-30ARM: bL_switcher: simplify stack isolationNicolas Pitre
We now have a dedicated thread for each logical CPU. That's plenty of stack space for our needs. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-07-30ARM: bL_switcher: move to dedicated threads rather than workqueuesNicolas Pitre
The workqueues are problematic as they may be contended. They can't be scheduled with top priority either. Also the optimization in bL_switch_request() to skip the workqueue entirely when the target CPU and the calling CPU were the same didn't allow for bL_switch_request() to be called from atomic context, as might be the case for some cpufreq drivers. Let's move to dedicated kthreads instead. Signed-off-by: Nicolas Pitre <nico@linaro.org>
