commit a21b4c10c7bf5b58112afa20d6fa829e8d74e3e6 upstream.
Without this tag, we get a build warning:
WARNING: modpost: missing MODULE_LICENSE() in arch/arm/common/bL_switcher_dummy_if.o
For completeness, I'm also adding author and description fields.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Pull ARM updates from Russell King:
- Correct ARMs dma-mapping to use the correct printk format strings.
- Avoid defining OBJCOPYFLAGS globally which upsets lkdtm rodata
testing.
- Cleanups to ARMs asm/memory.h include.
- L2 cache cleanups.
- Allow flat nommu binaries to be executed on ARM MMU systems.
- Kernel hardening - add more read-only after init annotations,
including making some kernel vdso variables const.
- Ensure AMBA primecell clocks are appropriately defaulted.
- ARM breakpoint cleanup.
- Various StrongARM 11x0 and companion chip (SA1111) updates to bring
this legacy platform to use more modern APIs for (eg) GPIOs and
interrupts, which will allow us in the future to reduce some of the
board-level driver clutter and elimate function callbacks into board
code via platform data. There still appears to be interest in these
platforms!
- Remove the now redundant secure_flush_area() API.
- Module PLT relocation optimisations. Ard says: This series of 4
patches optimizes the ARM PLT generation code that is invoked at
module load time, to get rid of the O(n^2) algorithm that results in
pathological load times of 10 seconds or more for large modules on
certain STB platforms.
- ARMv7M cache maintanence support.
- L2 cache PMU support
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (35 commits)
ARM: sa1111: provide to_sa1111_device() macro
ARM: sa1111: add sa1111_get_irq()
ARM: sa1111: clean up duplication in IRQ chip implementation
ARM: sa1111: implement a gpio_chip for SA1111 GPIOs
ARM: sa1111: move irq cleanup to separate function
ARM: sa1111: use devm_clk_get()
ARM: sa1111: use devm_kzalloc()
ARM: sa1111: ensure we only touch RAB bus type devices when removing
ARM: 8611/1: l2x0: add PMU support
ARM: 8610/1: V7M: Add dsb before jumping in handler mode
ARM: 8609/1: V7M: Add support for the Cortex-M7 processor
ARM: 8608/1: V7M: Indirect proc_info construction for V7M CPUs
ARM: 8607/1: V7M: Wire up caches for V7M processors with cache support.
ARM: 8606/1: V7M: introduce cache operations
ARM: 8605/1: V7M: fix notrace variant of save_and_disable_irqs
ARM: 8604/1: V7M: Add support for reading the CTR with read_cpuid_cachetype()
ARM: 8603/1: V7M: Add addresses for mem-mapped V7M cache operations
ARM: 8602/1: factor out CSSELR/CCSIDR operations that use cp15 directly
ARM: kernel: avoid brute force search on PLT generation
ARM: kernel: sort relocation sections before allocating PLTs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
Provide a nicer to_sa1111_device macro to convert a struct device to a
sa1111_dev. We will need this for drivers when converting them to
dev_pm_ops, or removing shutdown methods.
Add a helper function to get the irq number for a device.
Clean up the duplication in the IRQ chip implementation - we can compute
the register address from the interrupt number rather than duplicating
the code for each register.
Add a gpio_chip instance for SA1111 GPIOs. This allows us to use
gpiolib to lookup and manipulate SA1111 GPIOs.
Move the SA1111 interrupt cleanup to a separate function, so it can be
re-used in the probe error cleanup path.
Convert sa1111 to use devm_clk_get() to get its clock resource, and
strip out the clk_put() calls. This simplifies the error handling
a little.
Use devm_kzalloc() to allocate our driver data, so we can eliminate its
kfree() from the device removal and error cleanup paths.
When removing a SA1111 device, we try to remove all child devices.
However, we must only remove our own RAB bus typed devices from the
tree, there may be other devices present which should not be touched.
This is necessary before we introduce gpiochip to SA1111 to avoid
incorrectly trying to remove the gpiochip device, leading to an oops
in __release_resource().
Accidentally booting Collie on Assabet reveals that the locomo driver
incorrectly overwrites gpio-sa1100's chip data for its parent interrupt,
leading to oops in sa1100_gpio_unmask() and sa1100_update_edge_regs()
when "gpio: sa1100: convert to use IO accessors" is applied. Fix locomo
to use the handler data rather than chip data for its parent interrupt.
SA1111 forgets to call clk_disable() in the probe error cleanup path.
Add the necessary call.
SA1111 PCMCIA was broken when PCMCIA switched to using dev_pm_ops for
the PCMCIA socket class. PCMCIA used to handle suspend/resume via the
socket hosting device, which happened at normal device suspend/resume
time.
However, the referenced commit changed this: much of the resume now
happens much earlier, in the noirq resume handler of dev_pm_ops.
However, on SA1111, the PCMCIA device is not accessible as the SA1111
has not been resumed at _noirq time. It's slightly worse than that,
because the SA1111 has already been put to sleep at _noirq time, so
suspend doesn't work properly.
Fix this by converting the core SA1111 code to use dev_pm_ops as well,
and performing its own suspend/resume at noirq time.
This fixes these errors in the kernel log:
pcmcia_socket pcmcia_socket0: time out after reset
pcmcia_socket pcmcia_socket1: time out after reset
and the resulting lack of PCMCIA cards after a S2RAM cycle.
Fixes: d7646f7632549 ("pcmcia: use dev_pm_ops for class pcmcia_socket_class")
The polarity of the high IRQs was being calculated using
SA1111_IRQMASK_HI(), but this assumes a Linux interrupt number, not a
hardware interrupt number. Hence, the resulting mask was incorrect.
Fix this.
Ensure that we propagate the platform_get_irq() error code out of the
probe function. This allows probe deferrals to work correctly should
platform_get_irq() not be able to resolve the interrupt in a DT
environment at probe time.
Many modules call misc_register and misc_deregister in its module init
and exit methods without any additional code. This ends up being
boilerplate. This patch adds helper macro module_misc_device(), that
replaces module_init()/ module_exit() with template functions.
This patch also converts drivers to use new macro.
Change since v1:
Add device.h include in miscdevice.h as module_driver macro was not
available from other include files in some architectures.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
"Another mixture of changes this time around:
- Split XIP linker file from main linker file to make it more
maintainable, and various XIP fixes, and clean up a resulting
macro.
- Decompressor cleanups from Masahiro Yamada
- Avoid printing an error for a missing L2 cache
- Remove some duplicated symbols in System.map, and move
vectors/stubs back into kernel VMA
- Various low priority fixes from Arnd
- Updates to allow bus match functions to return negative errno
values, touching some drivers and the driver core. Greg has acked
these changes.
- Virtualisation platform udpates form Jean-Philippe Brucker.
- Security enhancements from Kees Cook
- Rework some Kconfig dependencies and move PSCI idle management code
out of arch/arm into drivers/firmware/psci.c
- ARM DMA mapping updates, touching media, acked by Mauro.
- Fix places in ARM code which should be using virt_to_idmap() so
that Keystone2 can work.
- Fix Marvell Tauros2 to work again with non-DT boots.
- Provide a delay timer for ARM Orion platforms"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (45 commits)
ARM: 8546/1: dma-mapping: refactor to fix coherent+cma+gfp=0
ARM: 8547/1: dma-mapping: store buffer information
ARM: 8543/1: decompressor: rename suffix_y to compress-y
ARM: 8542/1: decompressor: merge piggy.*.S and simplify Makefile
ARM: 8541/1: decompressor: drop redundant FORCE in Makefile
ARM: 8540/1: decompressor: use clean-files instead of extra-y to clean files
ARM: 8539/1: decompressor: drop more unneeded assignments to "targets"
ARM: 8538/1: decompressor: drop unneeded assignments to "targets"
ARM: 8532/1: uncompress: mark putc as inline
ARM: 8531/1: turn init_new_context into an inline function
ARM: 8530/1: remove VIRT_TO_BUS
ARM: 8537/1: drop unused DEBUG_RODATA from XIP_KERNEL
ARM: 8536/1: mm: hide __start_rodata_section_aligned for non-debug builds
ARM: 8535/1: mm: DEBUG_RODATA makes no sense with XIP_KERNEL
ARM: 8534/1: virt: fix hyp-stub build for pre-ARMv7 CPUs
ARM: make the physical-relative calculation more obvious
ARM: 8512/1: proc-v7.S: Adjust stack address when XIP_KERNEL
ARM: 8411/1: Add default SPARSEMEM settings
ARM: 8503/1: clk_register_clkdev: remove format string interface
ARM: 8529/1: remove 'i' and 'zi' targets
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for kernel v4.6. There is quite a
lot of interesting stuff going on.
The patches to other subsystems and arch-wide are ACKed as far as
possible, though I consider things like per-arch <asm/gpio.h> as
essentially a part of the GPIO subsystem so it should not be needed.
Core changes:
- The gpio_chip is now a *real device*. Until now the gpio chips
were just piggybacking the parent device or (gasp) floating in
space outside of the device model.
We now finally make GPIO chips devices. The gpio_chip will create
a gpio_device which contains a struct device, and this gpio_device
struct is kept private. Anything that needs to be kept private
from the rest of the kernel will gradually be moved over to the
gpio_device.
- As a result of making the gpio_device a real device, we have added
resource management, so devm_gpiochip_add_data() will cut down on
overhead and reduce code lines. A huge slew of patches convert
almost all drivers in the subsystem to use this.
- Building on making the GPIO a real device, we add the first step of
a new userspace ABI: the GPIO character device. We take small
steps here, so we first add a pure *information* ABI and the tool
"lsgpio" that will list all GPIO devices on the system and all
lines on these devices.
We can now discover GPIOs properly from userspace. We still have
not come up with a way to actually *use* GPIOs from userspace.
- To encourage people to use the character device for the future, we
have it always-enabled when using GPIO. The old sysfs ABI is still
opt-in (and can be used in parallel), but is marked as deprecated.
We will keep it around for the foreseeable future, but it will not
be extended to cover ever more use cases.
Cleanup:
- Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h>
includes.
This dates back to when GPIO was an opt-in feature and no shared
library even existed: just a header file with proper prototypes was
provided and all semantics were up to the arch to implement. These
patches make the GPIO chip even more a proper device and cleans out
leftovers of the old in-kernel API here and there.
Still some cruft is left but it's very little now.
- There is still some clamping of return values for .get() going on,
but we now return sane values in the vast majority of drivers and
the errorpath is sanitized. Some patches for powerpc, blackfin and
unicore still drop in.
- We continue to switch the ARM, MIPS, blackfin, m68k local GPIO
implementations to use gpiochip_add_data() and cut down on code
lines.
- MPC8xxx is converted to use the generic GPIO helpers.
- ATH79 is converted to use the generic GPIO helpers.
New drivers:
- WinSystems WS16C48
- Acces 104-DIO-48E
- F81866 (a F7188x variant)
- Qoric (a MPC8xxx variant)
- TS-4800
- SPI serializers (pisosr): simple 74xx shift registers connected to
SPI to obtain a dirt-cheap output-only GPIO expander.
- Texas Instruments TPIC2810
- Texas Instruments TPS65218
- Texas Instruments TPS65912
- X-Gene (ARM64) standby GPIO controller"
* tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits)
Revert "Share upstreaming patches"
gpio: mcp23s08: Fix clearing of interrupt.
gpiolib: Fix comment referring to gpio_*() in gpiod_*()
gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit
gpio: xgene: Fix kconfig for standby GIPO contoller
gpio: Add generic serializer DT binding
gpio: uapi: use 0xB4 as ioctl() major
gpio: tps65912: fix bad merge
Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free"
gpio: omap: drop dev field from gpio_bank structure
gpio: mpc8xxx: Slightly update the code for better readability
gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip
gpio: mpc8xxx: Fixup setting gpio direction output
gpio: mcp23s08: Add support for mcp23s18
dt-bindings: gpio: altera: Fix altr,interrupt-type property
gpio: add driver for MEN 16Z127 GPIO controller
gpio: timberdale: Switch to devm_ioremap_resource()
gpio: ts4800: Add IMX51 dependency
gpiolib: rewrite gpiodev_add_to_list
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: arm@kernel.org
Cc: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Olof Johansson <olof@lixom.net>
This patch ensures that existing bus match callbacks don't return
negative values (which might be interpreted as potential errors in the
future) in case of positive match.
Since the dawn of time the ICST code has only supported divide
by one or hang in an eternal loop. Luckily we were always dividing
by one because the reference frequency for the systems using
the ICSTs is 24MHz and the [min,max] values for the PLL input
if [10,320] MHz for ICST307 and [6,200] for ICST525, so the loop
will always terminate immediately without assigning any divisor
for the reference frequency.
But for the code to make sense, let's insert the missing i++
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: stable@vger.kernel.org
When trying to set the ICST 307 clock to 25174000 Hz I ran into
this arithmetic error: the icst_hz_to_vco() correctly figure out
DIVIDE=2, RDW=100 and VDW=99 yielding a frequency of
25174000 Hz out of the VCO. (I replicated the icst_hz() function
in a spreadsheet to verify this.)
However, when I called icst_hz() on these VCO settings it would
instead return 4122709 Hz. This causes an error in the common
clock driver for ICST as the common clock framework will call
.round_rate() on the clock which will utilize icst_hz_to_vco()
followed by icst_hz() suggesting the erroneous frequency, and
then the clock gets set to this.
The error did not manifest in the old clock framework since
this high frequency was only used by the CLCD, which calls
clk_set_rate() without first calling clk_round_rate() and since
the old clock framework would not call clk_round_rate() before
setting the frequency, the correct values propagated into
the VCO.
After some experimenting I figured out that it was due to a simple
arithmetic overflow: the divisor for 24Mhz reference frequency
as reference becomes 24000000*2*(99+8)=0x132212400 and the "1"
in bit 32 overflows and is lost.
But introducing an explicit 64-by-32 bit do_div() and casting
the divisor into (u64) we get the right frequency back, and the
right frequency gets set.
Tested on the ARM Versatile.
Cc: linux-clk@vger.kernel.org
Cc: Pawel Moll <pawel.moll@arm.com>
Pull ARM SoC cleanups from Olof Johansson:
"A smallish number of general cleanup commits this release cycle. Some
of these are minor tweaks:
- shmobile change of binding for their GIC (using arm,pl390 now)
- ARCH_RENESAS introduction
- Misc other renesas updates
There's also a couple of treewide commits from Masahiro Yamada
cleaning up const/__initconst for SMP operation structs and a switch
to using "depends on" instead of if-constructs on most of the Kconfig
platform targets"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
staging: board: armadillo800eva: Use "arm,pl390"
staging: board: kzm9d: Use "arm,pl390"
ARM: shmobile: r8a7778 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: emev2 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r8a7740 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r7s72100 dtsi: Use "arm,pl390" for GIC
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
ARM: mvebu: remove unused mach/gpio.h
ARM: shmobile: Remove legacy mach/irqs.h
ARM: shmobile: Introduce ARCH_RENESAS
MAINTAINERS: Remove link to oss.renesas.com which is closed
As we want gpio_chip .get() calls to be able to return negative
error codes and propagate to drivers, we need to go over all
drivers and make sure their return values are clamped to [0,1].
We do this by using the ret = !!(val) design pattern.
Cc: arm@kernel.org
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Pull dmaengine updates from Vinod Koul:
"This time we have a very typical update which is mostly fixes and
updates to drivers and no new drivers.
- the biggest change is coming from Peter for edma cleanup which even
caused some last minute regression, things seem settled now
- idma64 and dw updates
- iotdma updates
- module autoload fixes for various drivers
- scatter gather support for hdmac"
* tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits)
dmaengine: edma: Add dummy driver skeleton for edma3-tptc
Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3"
Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3"
dmaengine: dw: some Intel devices has no memcpy support
dmaengine: dw: platform: provide platform data for Intel
dmaengine: dw: don't override platform data with autocfg
dmaengine: hdmac: Add scatter-gathered memset support
dmaengine: hdmac: factorise memset descriptor allocation
dmaengine: virt-dma: Fix kernel-doc annotations
dmaengine: edma: New device tree binding
dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP
dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx
dmaengine: edma: Merge the of parsing functions
dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot
dmaengine: edma: Refactor the dma device and channel struct initialization
dmaengine: edma: Get qDMA channel information from HW also
dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq
dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_)
Move the code out from arch/arm/common and merge it inside of the dmaengine
driver.
This change is done with as minimal (if eny) functional change to the code
as possible to avoid introducing regression.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Since the driver stack no longer depends on lookup with id number in a
global array of pointers, the limitation for the number of eDMAs are no
longer needed. We can handle as many eDMAs in legacy and DT boot as we have
memory for them to allocate the needed structures.
Instead of relying on indexes pointing to edma private date in the global
pointer array, pass the private data pointer via the public API.
Merge the iomem into the 'struct edma' and change the internal (static)
functions to use pointer to the edma_cc instead of the ctlr number.
If the of_dma_controller is registered in the non dmaengine driver we could
have race condition:
the of_dma_controller has been registered, but the dmaengine driver is not
yet probed. Drivers requesting DMA channels during this window will fail
since we do not yet have dmaengine drivers registered.
Currently we have one device created to handle all (maximum 2) eDMAs in the
system.
With this change all eDMA instance will have it's own device/driver.
This change is needed for further cleanups in the eDMA driver stack since
the one device/driver to handle all eDMAs in the system was not flexible
enough and prevents the upcoming work.
Acked-by: Sekhar Nori <nsekhar@ti.com>
We no longer have users for these functions so they can be removed.
Remove also unused enums from the header file.
In case when the interrupt happened for the second eDMA the channel
number was incorrectly passed to the client driver.
CC: <stable@vger.kernel.org>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Pull ARM development updates from Russell King:
"Included in this update:
- moving PSCI code from ARM64/ARM to drivers/
- removal of some architecture internals from global kernel view
- addition of software based "privileged no access" support using the
old domains register to turn off the ability for kernel
loads/stores to access userspace. Only the proper accessors will
be usable.
- addition of early fixup support for early console
- re-addition (and reimplementation) of OMAP special interconnect
barrier
- removal of finish_arch_switch()
- only expose cpuX/online in sysfs if hotpluggable
- a number of code cleanups"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (41 commits)
ARM: software-based priviledged-no-access support
ARM: entry: provide uaccess assembly macro hooks
ARM: entry: get rid of multiple macro definitions
ARM: 8421/1: smp: Collapse arch_cpu_idle_dead() into cpu_die()
ARM: uaccess: provide uaccess_save_and_enable() and uaccess_restore()
ARM: mm: improve do_ldrd_abort macro
ARM: entry: ensure that IRQs are enabled when calling syscall_trace_exit()
ARM: entry: efficiency cleanups
ARM: entry: get rid of asm_trace_hardirqs_on_cond
ARM: uaccess: simplify user access assembly
ARM: domains: remove DOMAIN_TABLE
ARM: domains: keep vectors in separate domain
ARM: domains: get rid of manager mode for user domain
ARM: domains: move initial domain setting value to asm/domains.h
ARM: domains: provide domain_mask()
ARM: domains: switch to keeping domain value in register
ARM: 8419/1: dma-mapping: harmonize definition of DMA_ERROR_CODE
ARM: 8417/1: refactor bitops functions with BIT_MASK() and BIT_WORD()
ARM: 8416/1: Feroceon: use of_iomap() to map register base
ARM: 8415/1: early fixmap support for earlycon
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next/cleanup
Merge "ARM: Interrupt cleanups and API change preparation" from Thomas
Gleixner:
The following patch series contains the following changes:
- Consolidation of chained interrupt handler setup/removal
- Switch to functions which avoid a redundant interrupt
descriptor lookup
- Preparation of interrupt flow handlers for the 'irq' argument
removal
* 'queue/irq/arm' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM/orion/gpio: Prepare gpio_irq_handler for irq argument removal
ARM/pxa: Prepare balloon3_irq_handler for irq argument removal
ARM/pxa: Prepare *_irq_handler for irq argument removal
ARM/dove: Prepare pmu_irq_handler for irq argument removal
ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal
ARM/locomo: Prepare locomo_handler for irq argument removal
ARM, irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc
ARM/LPC32xx: Use irq_set_handler_locked()
ARM/irq: Use access helper irq_data_get_affinity_mask()
ARM/locomo: Consolidate chained IRQ handler install/remove
ARM/orion: Consolidate chained IRQ handler install/remove
Writes to /sys/.../cpuX/online fail if we determine the platform
doesn't support hotplug for that CPU. Furthermore, if the cpu_die
op isn't specified the system hangs when we try to offline a CPU
and it comes right back online unexpectedly. Let's figure this
stuff out before we make the sysfs nodes so that the online file
doesn't even exist if it isn't (at least sometimes) possible to
hotplug the CPU.
Add a new 'cpu_can_disable' op and repoint all 'cpu_disable'
implementations at it because all implementers use the op to
indicate if a CPU can be hotplugged or not in a static fashion.
With PSCI we may need to add a 'cpu_disable' op so that the
secure OS can be migrated off the CPU we're trying to hotplug.
In this case, the 'cpu_can_disable' op will indicate that all
CPUs are hotpluggable by returning true, but the 'cpu_disable' op
will make a PSCI migration call and occasionally fail, denying
the hotplug of a CPU. This shouldn't be any worse than x86 where
we may indicate that all CPUs are hotpluggable but occasionally
we can't offline a CPU due to check_irq_vectors_for_cpu_disable()
failing to find a CPU to move vectors to.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Dave Martin <Dave.Martin@arm.com>
Acked-by: Simon Horman <horms@verge.net.au> [shmobile portion]
Tested-by: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: <linux-sh@vger.kernel.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: Russell King <linux+kernel@arm.linux.org.uk>
Julia Lawall.
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we
already have a pointer to corresponding irq_desc.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the tty and serial driver patches for 4.2-rc1.
A number of individual driver updates, some code cleanups, and other
minor things, full details in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits)
Doc: serial-rs485.txt: update RS485 driver interface
Doc: tty.txt: remove mention of the BKL
MAINTAINERS: tty: add serial docs directory
serial: sprd: check for NULL after calling devm_clk_get
serial: 8250_pci: Correct uartclk for xr17v35x expansion chips
serial: 8250_pci: Add support for 12 port Exar boards
serial: 8250_uniphier: add bindings document for UniPhier UART
serial: core: cleanup in uart_get_baud_rate()
serial: stm32-usart: Add STM32 USART Driver
tty/serial: kill off set_irq_flags usage
tty: move linux/gsmmux.h to uapi
doc: dt: add documentation for nxp,lpc1850-uart
serial: 8250: add LPC18xx/43xx UART driver
serial: 8250_uniphier: add UniPhier serial driver
serial: 8250_dw: support ACPI platforms with integrated DMA engine
serial: of_serial: check the return value of clk_prepare_enable()
serial: of_serial: use devm_clk_get() instead of clk_get()
serial: earlycon: Add support for big-endian MMIO accesses
serial: sirf: use hrtimer for data rx
serial: sirf: correct the fifo empty_bit
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
Convert SA11x0 (Neponset, SA1111, and UCB1x00 code) to use the new
irq_set_chained_handler_and_data() helper.
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Link: http://lkml.kernel.org/r/E1Z4yzx-0002S6-7p@rmk-PC.arm.linux.org.uk
arch/arm/kernel/perf_event_cpu.c
