[ Upstream commit ca70ea43f80c98582f5ffbbd1e6f4da2742da0c4 ]
MCPM does a soft reset of the CPUs and uses common cpu_resume() routine to
perform low-level platform initialization. This results in a try to install
HYP stubs for the second time for each CPU and results in false HYP/SVC
mode mismatch detection. The HYP stubs are already installed at the
beginning of the kernel initialization on the boot CPU (head.S) or in the
secondary_startup() for other CPUs. To fix this issue MCPM code should use
a cpu_resume() routine without HYP stubs installation.
This change fixes HYP/SVC mode mismatch on Samsung Exynos5422-based Odroid
XU3/XU4/HC1 boards.
Fixes: 3721924c8154 ("ARM: 8081/1: MCPM: provide infrastructure to allow for MCPM loopback")
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Anand Moon <linux.amoon@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit a21b4c10c7bf5b58112afa20d6fa829e8d74e3e6 upstream.
Without this tag, we get a build warning:
WARNING: modpost: missing MODULE_LICENSE() in arch/arm/common/bL_switcher_dummy_if.o
For completeness, I'm also adding author and description fields.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Same behavior, less code duplication.
And instead wire it up as method for all the dma_map_ops instances.
Note that the code seems a little fishy for dmabounce and iommu, but
for now I'd like to preserve the existing behavior 1:1.
DMA_ERROR_CODE is going to go away, so don't rely on it.
cpu_power_down
Commit 9da5ac236de6 ("ARM: soft-reboot into same mode that we entered
the kernel") added support to enter the new kernel in the same processor
mode as the previous one when we soft-reboot from one kernel into
another by pass a flag to cpu_reset() so it knows what to do exactly.
However it missed to make similar changes in MCPM code. Due to the
missing flag, the CPUs enter HYP mode which is not supported with MCPM.
MCPM works only in secure mode as it manages CCI.
This patch aligns the cpu_reset call in MCPM with other changes in the
above mentioned commit by making phys_reset_t to follow the prototype
of cpu_reset().
Fixes: 9da5ac236de6 ("ARM: soft-reboot into same mode that we entered the kernel")
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
This moves the ICST clock divider helper library from
arch/arm/common to drivers/clk/versatile so it is maintained
with the other clock drivers.
We keep the structure as a helper library intact and do not
fuse it with the clk-icst.c Versatile ICST clock driver: there
may be other users out there that need to use this library for
their clocking, and then it will be helpful to keep the
library contained. (The icst.[c|h] files could just be moved
to drivers/clk/lib or a similar location to share the library.)
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<uapi/linux/sched/types.h>
We are going to move scheduler ABI details to <uapi/linux/sched/types.h>,
which will be used from a number of .c files.
Create empty placeholder header that maps to <linux/types.h>.
Include the new header in the files that are going to need it.
Pull ARM updates from Russell King:
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Most dma_map_ops structures are never modified. Constify these
structures such that these can be write-protected. This patch
has been generated as follows:
git grep -l 'struct dma_map_ops' |
xargs -d\\n sed -i \
-e 's/struct dma_map_ops/const struct dma_map_ops/g' \
-e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \
-e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \
-e 's/const const struct dma_map_ops /const struct dma_map_ops /g';
sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops intel_dma_ops');
sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc);
sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \
-e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \
-e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \
drivers/pci/host/*.c
sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c
sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c
sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: x86@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
The use of DMA_ATTR_SKIP_CPU_SYNC was not consistent across all of the
DMA APIs in the arch/arm folder. This change is meant to correct that
so that we get consistent behavior.
Link: http://lkml.kernel.org/r/20161110113424.76501.2715.stgit@ahduyck-blue-test.jf.intel.com
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Install the callbacks via the state machine.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: rt@linuxtronix.de
Link: http://lkml.kernel.org/r/20161117183541.8588-15-bigeasy@linutronix.de
- Correct ARMs dma-mapping to use the correct printk format strings.
- Avoid defining OBJCOPYFLAGS globally which upsets lkdtm rodata
testing.
- Cleanups to ARMs asm/memory.h include.
- L2 cache cleanups.
- Allow flat nommu binaries to be executed on ARM MMU systems.
- Kernel hardening - add more read-only after init annotations,
including making some kernel vdso variables const.
- Ensure AMBA primecell clocks are appropriately defaulted.
- ARM breakpoint cleanup.
- Various StrongARM 11x0 and companion chip (SA1111) updates to bring
this legacy platform to use more modern APIs for (eg) GPIOs and
interrupts, which will allow us in the future to reduce some of the
board-level driver clutter and elimate function callbacks into board
code via platform data. There still appears to be interest in these
platforms!
- Remove the now redundant secure_flush_area() API.
- Module PLT relocation optimisations. Ard says: This series of 4
patches optimizes the ARM PLT generation code that is invoked at
module load time, to get rid of the O(n^2) algorithm that results in
pathological load times of 10 seconds or more for large modules on
certain STB platforms.
- ARMv7M cache maintanence support.
- L2 cache PMU support
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (35 commits)
ARM: sa1111: provide to_sa1111_device() macro
ARM: sa1111: add sa1111_get_irq()
ARM: sa1111: clean up duplication in IRQ chip implementation
ARM: sa1111: implement a gpio_chip for SA1111 GPIOs
ARM: sa1111: move irq cleanup to separate function
ARM: sa1111: use devm_clk_get()
ARM: sa1111: use devm_kzalloc()
ARM: sa1111: ensure we only touch RAB bus type devices when removing
ARM: 8611/1: l2x0: add PMU support
ARM: 8610/1: V7M: Add dsb before jumping in handler mode
ARM: 8609/1: V7M: Add support for the Cortex-M7 processor
ARM: 8608/1: V7M: Indirect proc_info construction for V7M CPUs
ARM: 8607/1: V7M: Wire up caches for V7M processors with cache support.
ARM: 8606/1: V7M: introduce cache operations
ARM: 8605/1: V7M: fix notrace variant of save_and_disable_irqs
ARM: 8604/1: V7M: Add support for reading the CTR with read_cpuid_cachetype()
ARM: 8603/1: V7M: Add addresses for mem-mapped V7M cache operations
ARM: 8602/1: factor out CSSELR/CCSIDR operations that use cp15 directly
ARM: kernel: avoid brute force search on PLT generation
ARM: kernel: sort relocation sections before allocating PLTs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
Provide a nicer to_sa1111_device macro to convert a struct device to a
sa1111_dev. We will need this for drivers when converting them to
dev_pm_ops, or removing shutdown methods.
Add a helper function to get the irq number for a device.
Clean up the duplication in the IRQ chip implementation - we can compute
the register address from the interrupt number rather than duplicating
the code for each register.
Add a gpio_chip instance for SA1111 GPIOs. This allows us to use
gpiolib to lookup and manipulate SA1111 GPIOs.
Move the SA1111 interrupt cleanup to a separate function, so it can be
re-used in the probe error cleanup path.
Convert sa1111 to use devm_clk_get() to get its clock resource, and
strip out the clk_put() calls. This simplifies the error handling
a little.
Use devm_kzalloc() to allocate our driver data, so we can eliminate its
kfree() from the device removal and error cleanup paths.
When removing a SA1111 device, we try to remove all child devices.
However, we must only remove our own RAB bus typed devices from the
tree, there may be other devices present which should not be touched.
This is necessary before we introduce gpiochip to SA1111 to avoid
incorrectly trying to remove the gpiochip device, leading to an oops
in __release_resource().
Accidentally booting Collie on Assabet reveals that the locomo driver
incorrectly overwrites gpio-sa1100's chip data for its parent interrupt,
leading to oops in sa1100_gpio_unmask() and sa1100_update_edge_regs()
when "gpio: sa1100: convert to use IO accessors" is applied. Fix locomo
to use the handler data rather than chip data for its parent interrupt.
SA1111 forgets to call clk_disable() in the probe error cleanup path.
Add the necessary call.
SA1111 PCMCIA was broken when PCMCIA switched to using dev_pm_ops for
the PCMCIA socket class. PCMCIA used to handle suspend/resume via the
socket hosting device, which happened at normal device suspend/resume
time.
However, the referenced commit changed this: much of the resume now
happens much earlier, in the noirq resume handler of dev_pm_ops.
However, on SA1111, the PCMCIA device is not accessible as the SA1111
has not been resumed at _noirq time. It's slightly worse than that,
because the SA1111 has already been put to sleep at _noirq time, so
suspend doesn't work properly.
Fix this by converting the core SA1111 code to use dev_pm_ops as well,
and performing its own suspend/resume at noirq time.
This fixes these errors in the kernel log:
pcmcia_socket pcmcia_socket0: time out after reset
pcmcia_socket pcmcia_socket1: time out after reset
and the resulting lack of PCMCIA cards after a S2RAM cycle.
Fixes: d7646f7632549 ("pcmcia: use dev_pm_ops for class pcmcia_socket_class")
The polarity of the high IRQs was being calculated using
SA1111_IRQMASK_HI(), but this assumes a Linux interrupt number, not a
hardware interrupt number. Hence, the resulting mask was incorrect.
Fix this.
Ensure that we propagate the platform_get_irq() error code out of the
probe function. This allows probe deferrals to work correctly should
platform_get_irq() not be able to resolve the interrupt in a DT
environment at probe time.
Many modules call misc_register and misc_deregister in its module init
and exit methods without any additional code. This ends up being
boilerplate. This patch adds helper macro module_misc_device(), that
replaces module_init()/ module_exit() with template functions.
This patch also converts drivers to use new macro.
Change since v1:
Add device.h include in miscdevice.h as module_driver macro was not
available from other include files in some architectures.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
"Another mixture of changes this time around:
- Split XIP linker file from main linker file to make it more
maintainable, and various XIP fixes, and clean up a resulting
macro.
- Decompressor cleanups from Masahiro Yamada
- Avoid printing an error for a missing L2 cache
- Remove some duplicated symbols in System.map, and move
vectors/stubs back into kernel VMA
- Various low priority fixes from Arnd
- Updates to allow bus match functions to return negative errno
values, touching some drivers and the driver core. Greg has acked
these changes.
- Virtualisation platform udpates form Jean-Philippe Brucker.
- Security enhancements from Kees Cook
- Rework some Kconfig dependencies and move PSCI idle management code
out of arch/arm into drivers/firmware/psci.c
- ARM DMA mapping updates, touching media, acked by Mauro.
- Fix places in ARM code which should be using virt_to_idmap() so
that Keystone2 can work.
- Fix Marvell Tauros2 to work again with non-DT boots.
- Provide a delay timer for ARM Orion platforms"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (45 commits)
ARM: 8546/1: dma-mapping: refactor to fix coherent+cma+gfp=0
ARM: 8547/1: dma-mapping: store buffer information
ARM: 8543/1: decompressor: rename suffix_y to compress-y
ARM: 8542/1: decompressor: merge piggy.*.S and simplify Makefile
ARM: 8541/1: decompressor: drop redundant FORCE in Makefile
ARM: 8540/1: decompressor: use clean-files instead of extra-y to clean files
ARM: 8539/1: decompressor: drop more unneeded assignments to "targets"
ARM: 8538/1: decompressor: drop unneeded assignments to "targets"
ARM: 8532/1: uncompress: mark putc as inline
ARM: 8531/1: turn init_new_context into an inline function
ARM: 8530/1: remove VIRT_TO_BUS
ARM: 8537/1: drop unused DEBUG_RODATA from XIP_KERNEL
ARM: 8536/1: mm: hide __start_rodata_section_aligned for non-debug builds
ARM: 8535/1: mm: DEBUG_RODATA makes no sense with XIP_KERNEL
ARM: 8534/1: virt: fix hyp-stub build for pre-ARMv7 CPUs
ARM: make the physical-relative calculation more obvious
ARM: 8512/1: proc-v7.S: Adjust stack address when XIP_KERNEL
ARM: 8411/1: Add default SPARSEMEM settings
ARM: 8503/1: clk_register_clkdev: remove format string interface
ARM: 8529/1: remove 'i' and 'zi' targets
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for kernel v4.6. There is quite a
lot of interesting stuff going on.
The patches to other subsystems and arch-wide are ACKed as far as
possible, though I consider things like per-arch <asm/gpio.h> as
essentially a part of the GPIO subsystem so it should not be needed.
Core changes:
- The gpio_chip is now a *real device*. Until now the gpio chips
were just piggybacking the parent device or (gasp) floating in
space outside of the device model.
We now finally make GPIO chips devices. The gpio_chip will create
a gpio_device which contains a struct device, and this gpio_device
struct is kept private. Anything that needs to be kept private
from the rest of the kernel will gradually be moved over to the
gpio_device.
- As a result of making the gpio_device a real device, we have added
resource management, so devm_gpiochip_add_data() will cut down on
overhead and reduce code lines. A huge slew of patches convert
almost all drivers in the subsystem to use this.
- Building on making the GPIO a real device, we add the first step of
a new userspace ABI: the GPIO character device. We take small
steps here, so we first add a pure *information* ABI and the tool
"lsgpio" that will list all GPIO devices on the system and all
lines on these devices.
We can now discover GPIOs properly from userspace. We still have
not come up with a way to actually *use* GPIOs from userspace.
- To encourage people to use the character device for the future, we
have it always-enabled when using GPIO. The old sysfs ABI is still
opt-in (and can be used in parallel), but is marked as deprecated.
We will keep it around for the foreseeable future, but it will not
be extended to cover ever more use cases.
Cleanup:
- Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h>
includes.
This dates back to when GPIO was an opt-in feature and no shared
library even existed: just a header file with proper prototypes was
provided and all semantics were up to the arch to implement. These
patches make the GPIO chip even more a proper device and cleans out
leftovers of the old in-kernel API here and there.
Still some cruft is left but it's very little now.
- There is still some clamping of return values for .get() going on,
but we now return sane values in the vast majority of drivers and
the errorpath is sanitized. Some patches for powerpc, blackfin and
unicore still drop in.
- We continue to switch the ARM, MIPS, blackfin, m68k local GPIO
implementations to use gpiochip_add_data() and cut down on code
lines.
- MPC8xxx is converted to use the generic GPIO helpers.
- ATH79 is converted to use the generic GPIO helpers.
New drivers:
- WinSystems WS16C48
- Acces 104-DIO-48E
- F81866 (a F7188x variant)
- Qoric (a MPC8xxx variant)
- TS-4800
- SPI serializers (pisosr): simple 74xx shift registers connected to
SPI to obtain a dirt-cheap output-only GPIO expander.
- Texas Instruments TPIC2810
- Texas Instruments TPS65218
- Texas Instruments TPS65912
- X-Gene (ARM64) standby GPIO controller"
* tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits)
Revert "Share upstreaming patches"
gpio: mcp23s08: Fix clearing of interrupt.
gpiolib: Fix comment referring to gpio_*() in gpiod_*()
gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit
gpio: xgene: Fix kconfig for standby GIPO contoller
gpio: Add generic serializer DT binding
gpio: uapi: use 0xB4 as ioctl() major
gpio: tps65912: fix bad merge
Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free"
gpio: omap: drop dev field from gpio_bank structure
gpio: mpc8xxx: Slightly update the code for better readability
gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip
gpio: mpc8xxx: Fixup setting gpio direction output
gpio: mcp23s08: Add support for mcp23s18
dt-bindings: gpio: altera: Fix altr,interrupt-type property
gpio: add driver for MEN 16Z127 GPIO controller
gpio: timberdale: Switch to devm_ioremap_resource()
gpio: ts4800: Add IMX51 dependency
gpiolib: rewrite gpiodev_add_to_list
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: arm@kernel.org
Cc: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Olof Johansson <olof@lixom.net>
This patch ensures that existing bus match callbacks don't return
negative values (which might be interpreted as potential errors in the
future) in case of positive match.
Since the dawn of time the ICST code has only supported divide
by one or hang in an eternal loop. Luckily we were always dividing
by one because the reference frequency for the systems using
the ICSTs is 24MHz and the [min,max] values for the PLL input
if [10,320] MHz for ICST307 and [6,200] for ICST525, so the loop
will always terminate immediately without assigning any divisor
for the reference frequency.
But for the code to make sense, let's insert the missing i++
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: stable@vger.kernel.org
When trying to set the ICST 307 clock to 25174000 Hz I ran into
this arithmetic error: the icst_hz_to_vco() correctly figure out
DIVIDE=2, RDW=100 and VDW=99 yielding a frequency of
25174000 Hz out of the VCO. (I replicated the icst_hz() function
in a spreadsheet to verify this.)
However, when I called icst_hz() on these VCO settings it would
instead return 4122709 Hz. This causes an error in the common
clock driver for ICST as the common clock framework will call
.round_rate() on the clock which will utilize icst_hz_to_vco()
followed by icst_hz() suggesting the erroneous frequency, and
then the clock gets set to this.
The error did not manifest in the old clock framework since
this high frequency was only used by the CLCD, which calls
clk_set_rate() without first calling clk_round_rate() and since
the old clock framework would not call clk_round_rate() before
setting the frequency, the correct values propagated into
the VCO.
After some experimenting I figured out that it was due to a simple
arithmetic overflow: the divisor for 24Mhz reference frequency
as reference becomes 24000000*2*(99+8)=0x132212400 and the "1"
in bit 32 overflows and is lost.
But introducing an explicit 64-by-32 bit do_div() and casting
the divisor into (u64) we get the right frequency back, and the
right frequency gets set.
Tested on the ARM Versatile.
Cc: linux-clk@vger.kernel.org
Cc: Pawel Moll <pawel.moll@arm.com>
Pull ARM SoC cleanups from Olof Johansson:
"A smallish number of general cleanup commits this release cycle. Some
of these are minor tweaks:
- shmobile change of binding for their GIC (using arm,pl390 now)
- ARCH_RENESAS introduction
- Misc other renesas updates
There's also a couple of treewide commits from Masahiro Yamada
cleaning up const/__initconst for SMP operation structs and a switch
to using "depends on" instead of if-constructs on most of the Kconfig
platform targets"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
staging: board: armadillo800eva: Use "arm,pl390"
staging: board: kzm9d: Use "arm,pl390"
ARM: shmobile: r8a7778 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: emev2 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r8a7740 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r7s72100 dtsi: Use "arm,pl390" for GIC
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
ARM: mvebu: remove unused mach/gpio.h
ARM: shmobile: Remove legacy mach/irqs.h
ARM: shmobile: Introduce ARCH_RENESAS
MAINTAINERS: Remove link to oss.renesas.com which is closed
As we want gpio_chip .get() calls to be able to return negative
error codes and propagate to drivers, we need to go over all
drivers and make sure their return values are clamped to [0,1].
We do this by using the ret = !!(val) design pattern.
Cc: arm@kernel.org
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Pull dmaengine updates from Vinod Koul:
"This time we have a very typical update which is mostly fixes and
updates to drivers and no new drivers.
- the biggest change is coming from Peter for edma cleanup which even
caused some last minute regression, things seem settled now
- idma64 and dw updates
- iotdma updates
- module autoload fixes for various drivers
- scatter gather support for hdmac"
* tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits)
dmaengine: edma: Add dummy driver skeleton for edma3-tptc
Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3"
Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3"
dmaengine: dw: some Intel devices has no memcpy support
dmaengine: dw: platform: provide platform data for Intel
dmaengine: dw: don't override platform data with autocfg
dmaengine: hdmac: Add scatter-gathered memset support
dmaengine: hdmac: factorise memset descriptor allocation
dmaengine: virt-dma: Fix kernel-doc annotations
dmaengine: edma: New device tree binding
dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP
dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx
dmaengine: edma: Merge the of parsing functions
dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot
dmaengine: edma: Refactor the dma device and channel struct initialization
dmaengine: edma: Get qDMA channel information from HW also
dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq
dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_)
Move the code out from arch/arm/common and merge it inside of the dmaengine
driver.
This change is done with as minimal (if eny) functional change to the code
as possible to avoid introducing regression.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Since the driver stack no longer depends on lookup with id number in a
global array of pointers, the limitation for the number of eDMAs are no
longer needed. We can handle as many eDMAs in legacy and DT boot as we have
memory for them to allocate the needed structures.
Instead of relying on indexes pointing to edma private date in the global
pointer array, pass the private data pointer via the public API.
Merge the iomem into the 'struct edma' and change the internal (static)
functions to use pointer to the edma_cc instead of the ctlr number.
If the of_dma_controller is registered in the non dmaengine driver we could
have race condition:
the of_dma_controller has been registered, but the dmaengine driver is not
yet probed. Drivers requesting DMA channels during this window will fail
since we do not yet have dmaengine drivers registered.
Currently we have one device created to handle all (maximum 2) eDMAs in the
system.
With this change all eDMA instance will have it's own device/driver.
This change is needed for further cleanups in the eDMA driver stack since
the one device/driver to handle all eDMAs in the system was not flexible
enough and prevents the upcoming work.
Acked-by: Sekhar Nori <nsekhar@ti.com>
