path: root/arch/arm/configs/at91sam9260ek_defconfig
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-14[ARM] 5390/1: AT91: Watchdog fixesAndrew Victor
The recently merged AT91SAM9 watchdog driver uses the AT91SAM9X_WATCHDOG config variable, whereas the original version of the driver (and the platform support code) used AT91SAM9_WATCHDOG. This causes the watchdog platform_device to never be registered, and therefore the driver not to be initialized. This patch: - updates the platform support code to use AT91SAM9X_WATCHDOG. - includes <linux/io.h> to fix compile error (same fix as was applied to at91rm9200_wdt.c) - fixes comment regarding watchdog clock-rates in at91rm9200. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-08-01Fix rename of at91_nand -> atmel_nandPieter du Preez
Structs called at91_nand_data where renamed to atmel_nand_data and configs called *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL*. This was unfortunately not done consistently, causing NAND chips not being initialised on several ARM boards. I am aware that the author of the original change did not rename MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example. All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order to keep naming consistency. This patch was only tested on a MACH_SAM9_L9260, as this is the only ARM board I have to my disposal. Before this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 105 $ git-ls-files |xargs grep at91_nand |wc -l 4 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 8 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 47 After this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 109 $ git-ls-files |xargs grep at91_nand |wc -l 0 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 55 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 0 Signed-off-by: Pieter du Preez <pdupreez@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-05-12[ARM] dyntick: Remove obsolete and unused ARM dyntick supportRussell King
dyntick is superseded by the clocksource/clockevent infrastructure, using the NO_HZ configuration option. No one implements dyntick on ARM anymore, so it's pointless keeping it around. Remove dyntick support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-10[ARM] 4914/1: AT91: Update defconfigs (Part 1)Andrew Victor
Update the default configuration for the following AT91-based boards: Atmel AT91RM9200 DK Atmel AT91RM9200 EK Atmel AT91SAM9260 EK Atmel AT91SAM9261 EK Atmel AT91SAM9263 EK Atmel AT91SAM9RL EK Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4084/1: Remove CONFIG_DEBUG_WAITQAndrew Victor
Remove the legacy CONFIG_DEBUG_WAITQ from the SAM9260-EK and SAM9261-EK default configuration files. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-01[ARM] 3962/1: AT91: Support for Atmel AT91SAM9260-EK boardAndrew Victor
This patch adds support for the Atmel AT91SAM9260-EK board. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
