This enables the wifi driver for Raspberry Pi Zero W. We need
to build this as a module otherwise the drivers tries to load the
firmware before the root partition is mounted.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Eric Anholt <eric@anholt.net>
The VC4 needs more memory than the default setting:
cma: cma_alloc: alloc failed, req-size: 4096 pages, ret: -12
vc4-drm soc:gpu: failed to allocate buffer with size 16777216
So increase the value to 32 MB and fix this issue.
Since pl011 is connected to the BT chip, we need to enable the Mini
UART for serial console.
In order to use the serial and ethernet USB gadget support on
Raspberry Zero, we also need to enable the PHY driver, kernel module
and OTG support.
We need to enable this controller so that we can switch the SD card's
pinmux over to it by default, which will improve storage performance.
Read access (dd with 64k blocks on rpi2):
CONFIG_MMC_SDHCI_IPROC: 11-12 MB/s
CONFIG_MMC_BCM2835: 19-20 MB/s
Differences on write access are pretty much in the noise.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Currently bcm2835_defconfig has CMA disabled which makes the
HDMI output on a Raspberry Pi 1 stop working during boot:
fb: switching to vc4drmfb from simple
Console: switching to colour dummy device 80x30
[drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] Driver supports precise vblank timestamp query.
vc4-drm soc:gpu: failed to allocate buffer with size 9216000
vc4-drm soc:gpu: Failed to set initial hw configuration.
So enable CMA and DMA_CMA in bcm2835_defconfig.
Fixes: 4400d9ac05ee ("ARM: bcm2835: Enable the VC4 graphics driver in the defconfig")
Add the thermal driver to list of compiled modules in the default
config for bcm2835.
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
This is also present in multi_v7_defconfig, and means that I can test
the pi1 with the 2835 defconfig in my normal environment.
Combined with the queued DT changes, we now get HDMI and 3D support.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The power domain driver we've enabled doesn't actually do anything
without it, and we need it to do its job for VC4 to initialize
successfully.
This approximately triples write performance for the SD card. My card
is too full of important data to collect very reliable numbers, but I
see 271.361% +/- 166.742% improvement (n=3 before, 6 after), for 'dd
if=/dev/zero of=/boot/asdf bs=1M count=3 oflag=dsync,direct'. Read
performance appears to be unaffected.
After enabling the Raspberry Pi firmware driver which allow us to handle
power domains for USB or graphics.
This enables the Raspberry Pi driver for GPU specific features.
This makes the RPi2 work; it has an ARMv7 CPU.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
This way the kernel works on both RPi0/1 and RPi2 even with earlyprintk
in the kernel cmdline; the two hardware platforms use different physical
addresses for peripherals, so the same DEBUG_LL configuration won't work
on both. If someone needs DEBUG_LL support, they can enable it locally.
This separates explicit changes desired in later patches from "automatic"
or irrelevant changes caused solely by Kconfig changes.
make ARCH=arm bcm2835_defconfig
make ARCH=arm savedefconfig
mv defconfig arch/arm/configs/bcm2835_defconfig
add the auxiliary spi driver to the default config
Rebuild bcm2835_defconfig using "make bcm2835_defconfig;
make savedefconfig", and enable manually the following features:
* all bcm2835-relevant drivers (MBOX, WDT, DMA, PWM, SND)
* enable regular stackprotector because CONFIG_CC_STACKPROTECTOR
disappear
* enable some new dependencies in order to keep LED heartbeat
( CONFIG_NEW_LEDS, CONFIG_LEDS_CLASS, CONFIG_LEDS_TRIGGERS )
The following options were removed, because they are enabled implicit:
CONFIG_RD_BZIP2, CONFIG_RD_LZMA, CONFIG_RD_XZ, CONFIG_RD_LZO,
CONFIG_USB_DWC2_HOST, CONFIG_EXT4_FS, CONFIG_EXT4_FS_POSIX_ACL
These options became obsolete:
CONFIG_RESOURCE_COUNTERS, CONFIG_SCSI_MULTI_LUN
It broke when host was moved into a separate module, in 47a1685 ("usb:
dwc2/s3c-hsotg: move s3c-hsotg into dwc2 directory"),
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Move the bcm2835 board file into the mach-bcm directory. This allows us
to get rid of the mach-bcm2835 directory with the associated Kconfig
and Makefile.
Signed-off-by: Markus Mayer <markus.mayer@linaro.org>
[swarren, adjust defconfig so ARCH_BCM2835 still gets enabled]
make savedefconfig", and add the following features:
* Enable the DWC2 USB controller present in the BCM2835 SoC.
* Enable drivers for various USB-hosted devices, which make the
controller useful.
Enable CONFIG_LEDS_GPIO and all options required to enable it, or make
the option useful.
Enable the simple framebuffer driver, fbconsole, and VT support.
This patch also regenerated bcm2835_defconfig, which removes two HW_RANDOM
entries, since they're enabled by default.
Pull ARM SoC multiplatform updates from Olof Johansson:
"More multiplatform enablement for ARM platforms. The ones converted
in this branch are:
- bcm2835
- cns3xxx
- sirf
- nomadik
- msx
- spear
- tegra
- ux500
We're getting close to having most of them converted!
One of the larger platforms remaining is Samsung Exynos, and there are
a bunch of supporting patches in this merge window for it. There was
a patch in this branch to a early version of multiplatform conversion,
but it ended up being reverted due to need of more bake time. The
revert commit is part of the branch since it would have required
rebasing multiple dependent branches and they were stable by then"
* tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms
clocksource: nomadik-mtu: fix up clocksource/timer
Revert "ARM: exynos: enable multiplatform support"
ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ"
rtc: s3c: make header file local
mtd: onenand/samsung: make regs-onenand.h file local
thermal/exynos: remove unnecessary header inclusions
mmc: sdhci-s3c: remove platform dependencies
ARM: samsung: move mfc device definition to s5p-dev-mfc.c
ARM: exynos: move debug-macro.S to include/debug/
ARM: exynos: prepare for sparse IRQ
ARM: exynos: introduce EXYNOS_ATAGS symbol
ARM: tegra: build assembly files with -march=armv7-a
ARM: Push selects for TWD/SCU into machine entries
ARM: ux500: build hotplug.o for ARMv7-a
ARM: ux500: move to multiplatform
ARM: ux500: make remaining headers local
ARM: ux500: make irqs.h local to platform
ARM: ux500: get rid of <mach/[hardware|db8500-regs].h>
Enable the following new features:
* SPI controller driver.
* RNG driver.
This allows BCM2835 be included in a kernel build that supports multiple
SoCs at once, which is useful for distro kernels.
This change:
* Moves bcm2835's debug-macro.S into ARM's include/debug/, and hooks it
into the relevant menu.
* Moves bcm2835's Kconfig into its own directory, as seems typical for
multi-platform conversions.
* Removes bcm2835_soc.h, and moves the content to the files where it was
used; just one usage per define.
* Deletes some headers and Makefile.boot that aren't needed now that we
support multi-platform.
Now that we have an SDHCI driver, enable the block layer, and common
filesystems; MSDOS/VFAT for the SoC-required firmware partition, ext2/3/4
for a root partition.
Add tmpfs, NFS, file locking, file notify, networking, and NLS to support
distro expectations.
Enable GPIO_SYSFS to allow GPIO twiddling from user-space; likely a
common activity on this hardware.
Enable I2C.
Remove bogus CONFIG_DEFAULT_MMAP_MIN_ADDR so that applications running as
non-root actually work; without this, execve() immediately triggers
SIGKILL. This setting was sourced from some downstream defconfig early
during upstream Raspberry Pi support development.
Other non-semantic diffs due to rebuilding defconfig using the latest
Kconfig defaults etc.
For some reason, support for proc and sysfs is currently disabled in
the bcm2835_defconfig, even though those filesystems are quite
essential even for very basic Linux userspace. As most defconfig have
them enabled by default, enable them as well in bcm2835_defconfig.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The BCM2835 is an ARM SoC from Broadcom. This patch adds very basic
support for this SoC.
http://www.broadcom.com/products/BCM2835
http://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
Note that the documentation in the latter .pdf assumes the MMU setup
that's used on the "VideoCore" companion processor, and does not document
physical peripheral addresses. Subtract 0x5e000000 to obtain the physical
addresses. This is accounted for by the ranges property in the /soc node
in the device tree.
The BCM2835 SoC is used in the Raspberry Pi. This patch also adds a
minimal device tree for this board; enough to see some very early kernel
boot messages through earlyprintk. However, this patch does not yet
provide a useful booting system.
http://www.raspberrypi.org/.
This patch was extracted from git://github.com/lp0/linux.git branch
rpi-split from 3-4 months ago, and significantly stripped down and
modified since.
Signed-off-by: Chris Boot <bootc@bootc.net>
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Signed-off-by: Dom Cobley <popcornmix@gmail.com>
Signed-off-by: Dom Cobley <dc4@broadcom.com>
