Synchronize the defconfigs with changes done in meta-toradex-nxp.
Normalize the defconfigs by
make ..._defconfig
make savedevconig
cp defconfig arch/arm/configs/..._defconfig
Enable atmel mxt multi-touch controller driver to be built as a module.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Prepare for snapd integration.
Follow commit 0a0778946a4fd433de7f1ce7dd9da6bfefed5e17 to stay in sync.
The CAAM Secure Memory Keystore Test/Example driver is not used by
most customers and dumps a lot of keys, add it as a module by
default.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Enable ADV7280 decoder for iMX6 modules. ADV7280 and ADV7180 have
same addresses viz. 0x21 respectively, changing the ADV7280 address
to 0x20 would result in a conflict with MAX9526. As a result enable
ADV7280 by default and disable ADV7180.
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
(cherry picked from commit b7798ad9dccd6b1f54a0c1bbbfa3290934dc5d9b)
Compile USB device classes such as WDM and CDC ACM as modules.
Enable FTDI USB-to-serial adapter chips and serial console which
allows to use USB serial device drivers as a serial console at
boot time. Compile USB driver for GSM and CDMA modems (Option and
others) as a module.
(cherry picked from commit f8515e706120de1f34a97d263cebbd17b0eaea73)
Enable RTL8192CU driver to support LM006 USB WiFi adapter.
(cherry picked from commit bc45801b17dbf13b5139ad1a5bb1375b85c04933)
Newer systemd variants need network namespace support for various
services such as systemd-hostnamed or systemd-localed.
(cherry picked from commit 4bb3acd58f8d2074cd8e7a6ddb914a0954d0906a)
(cherry picked from commit 65cd6dd5b198f9ca2fab48dc5c7db283db19b58c)
Remove duplicate CONFIG_STMPE_ADC from both defconfigs.
While at it also remove obsolete commented out
CONFIG_NET_VENDOR_ATHEROS being not set on Colibri iMX6.
(cherry picked from commit 2bc238c55974901ca3078a8e39edaeaa4d9b3d62)
(cherry picked from commit 0c697fcc38f28912cbe33326d1df85d4bd268094)
(cherry picked from commit 47c017b98ce9359f890363b4095c87235a6f81d6)
(cherry picked from commit f7da5aba0ed4edea7bd0e228d54732e18e4f056d)
(cherry picked from commit 237e4f7e572a4849fb04582b1616b11573abfe1c)
Enable extcon USB GPIO support in the default kernel configuration.
(cherry picked from commit 818344f016b75ca24e904ff5f9a8f4b2235b31e1)
(cherry picked from commit c093025bb91521b3fac593457f1ab88e81d22c7c)
