[ Upstream commit a99897f550de96841aecb811455a67ad7a4e39a7 ]
Odroid HC1 board has built-in JMicron USB to SATA bridge, which supports
UAS protocol. Compile-in support for it (instead of enabling it as module)
to make sure that all built-in storage devices are available for rootfs.
The bridge itself also supports fallback to standard USB Mass Storage
protocol, but USB Mass Storage class doesn't bind to it when UAS is
compiled as module and modules are not (yet) available.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
exynos_defconfig, beside serving as a reference config for Exynos-based
devices, is used by developers during regular development work.
Enabling options responsible for locking tests allows to discover bugs
in drivers and mach code earlier.
This enables:
1. Detection of sleeping in atomic sections (DEBUG_ATOMIC_SLEEP),
2. Full lockdep (DEBUG_LOCK_ALLOC and PROVE_LOCKING which makes other
lock debug entries unneeded),
3. Detection of soft, kernel lockups (SOFTLOCKUP_DETECTOR).
Reviewed-by: Anand Moon <linux.amoon@gmail.com>
Enable useful, but not essential components:
- NLS_UTF8, it might be used for accessing Microsoft-FS based storages,
- popular crypto algorithms and transformations as modules.
Enable useful, but not essential, stacks and drivers as modules:
- Bluetooth,
- mac80211,
- NFC,
- some USB network adapters,
- USB storage,
- additional USB devices (printers etc).
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/defconfig
Pull "ARM defconfig cleanup" from Krzysztof Kozłowski:
1. Remove old Kconfig options from all ARM configs,
2. Update Samsung defconfigs to bring back options over time got disabled
for some reason (configs were not updated along with the code),
3. Save defconfigs for Samsung.
* tag 'samsung-defconfig-4.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: tct_hammer_defconfig: Save defconfig
ARM: s5pv210_defconfig: Save defconfig
ARM: s3c6400_defconfig: Save defconfig
ARM: mini2440_defconfig: Save defconfig
ARM: s3c2410_defconfig: Save defconfig
ARM: exynos_defconfig: Save defconfig
ARM: s5pv210_defconfig: Bring back lost (but wanted) options
ARM: s3c6400_defconfig: Bring back lost (but wanted) options
ARM: s3c2410_defconfig: Bring back lost (but wanted) options
ARM: tct_hammer_defconfig: Bring back lost (but wanted) options
ARM: mini2440_defconfig: Bring back lost (but wanted) options
ARM: defconfig: samsung: Re-order entries to match savedefconfig
ARM: defconfig: Cleanup from old Kconfig options
Generate new defconfig to get rid of obsolete Kconfig entries:
- RFKILL_REGULATOR is gone;
- COMMON_CLK_MAX77802 was merged into COMMON_CLK_MAX77686;
Re-order entries just like savedefconfig would do so it will be easier
to review the changes before actual savedefconfig.
Enable the new Exynos pseudo random number generator driver and
user-space API to access crypto algorithms and devices (not only RNG).
Current CMA size of 64 Mbytes is right on the edge of being small when
several drivers need to allocate large CMA buffers.
For example, if the s5p-mfc driver needs to pre-allocate CMA memory to
decode a H.264 1080p video, then there won't be enough CMA memory left
for other drivers, such as the exynos-drm driver that may need to
allocate GEM buffers for the display manager.
Increasing CMA size to 96 Mbytes in exynos_defconfig addresses use-cases
such as these.
Suggested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
DYNAMIC_DEBUG is quite useful for debugging kernels and should not cause
noticeable performance regressions. It makes the kernel bigger (around 4%)
but this difference should not impact typical developer and reference
usage of this defconfig.
Sizes:
zImage-old: 4641496 bytes
zImage-new: 4811384 bytes
7031229 2570916 327016 9929161 9781c9 vmlinux-old
7205921 2800052 327016 10332989 9dab3d vmlinux-new
Additionally, remove the EXT3_FS symbol because it is entirely replaced
by EXT4_FS.
Pull ARM SoC defconfig updates from Arnd Bergmann:
"Defconfig additions, removals, etc. Almost all of them just turn on
drivers that we want on some platform, usually after the driver has
been merged into mainline.
There is now a new defconfig file for tango4"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits)
ARM: multi_v7_defconfig: enable pstore configs
ARM: multi_v7_defconfig: enable some newly added crypto modules
ARM: davinci_all_defconfig: enable SATA modules
arm64: defconfig: enable CONFIG_MTD_NAND and CONFIG_MTD_NAND_DENALI_DT
arm64: defconfig: enable CONFIG_MTD_BLOCK
ARM: Import tango4_defconfig
ARM: omap2plus_defconfig: Enable support for RTC M41T80
ARM: omap2plus_defconfig: Enable support for micrell phys
ARM: vf610m4: defconfig: enable EXT4 filesystem
ARM: omap2plus_defconfig: Fix probe errors on UARTs 5 and 6
arm64: defconfig: Enable NUMA and NUMA_BALANCING
arm64: defconfig: enable SMMUv3 config
ARM: davinci_all_defconfig: enable iio
ARM: Keystone: Enable ARCH_HAS_RESET_CONTROLLER
ARM: configs: stm32: Add RTC support in STM32 defconfig
ARM: defconfig: qcom: add APQ8060 DragonBoard devices
ARM: qcom_defconfig: enable thermal sensors
ARM: qcom_defconfig: add ahci configs
ARM: qcom_defconfig: add pcie and atl1c ethernet configs
ARM: qcom_defconfig: add usb related configs
This doesn't have any benefit apart from saving a small amount of memory
when it is disabled. The ifdef hackery in the code makes it dirty
unnecessarily.
Clean it up by removing the Kconfig option completely. Few defconfigs
are also updated and CONFIG_CPU_FREQ_STAT_DETAILS is replaced with
CONFIG_CPU_FREQ_STAT now in them, as users wanted stats to be enabled.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Prior to Nikolay's commit dcd87999d, libnss-mdns (eg. to resolve
"foo.local" on the LAN using mDNS) worked without CONFIG_IP_MULTICAST
defined, but dcd87999d caused it to stop working without having
CONFIG_IP_MULTICAST defined explicitly.
Since exynos_defconfig did not previously define CONFIG_IP_MULTICAST,
mDNS used to work for users building with just exynos_defconfig, but
stopped working from dcd87999d.
Define CONFIG_IP_MULTICAST explicitly in exynos_defconfig as it appears
essential anyway.
Signed-off-by: Robie Basak <robie@justgohome.co.uk>
Exynos5 SoCs have a General SCALER (GSCALER) IP block that can be used
to do video streams scaling and color space conversions by hardware.
Enable support for its driver as a module so the GSCALER can be tested.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
"Main changes:
- amba-cldc: DT backlight support, Nomadik support, Versatile
improvements, fixes
- efifb: fix fbcon RGB565 palette
- exynos: remove unused DSI driver"
* tag 'fbdev-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (42 commits)
video: smscufx: remove unused variable
matroxfb: fix size of memcpy
fbdev: ssd1307fb: fix a possible NULL dereference
fbdev: ssd1307fb: constify the device_info pointer
simplefb: Disable and release clocks and regulators in destroy callback
video: fbdev: constify fb_fix_screeninfo and fb_var_screeninfo structures
matroxfb: constify local structures
video: fbdev: i810: add in missing white space in error message text
video: fbdev: add missing \n at end of printk error message
ARM: exynos_defconfig: Remove old non-working MIPI driver
video: fbdev: exynos: Remove old non-working MIPI driver
omapfb: fix return value check in dsi_bind()
MAINTAINERS: update fbdev entries
video: fbdev: offb: Call pci_enable_device() before using the PCI VGA device
fbdev: vfb: simplify memory management
fbdev: vfb: add option for video mode
fbdev: vfb: add description to module parameters
video: fbdev: intelfb: remove impossible condition
fb: adv7393: off by one in probe function
video: fbdev: pxafb: add missing of_node_put() in of_get_pxafb_mode_info()
The Exynos MIPI driver does not work anymore (it is board file only) so
it is removed. Remove also config options.
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Donghwa Lee <dh09.lee@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The schedutil cpufreq governor will be switched from tristate to bool. Fix
defconfigs.
The schedutil CPUFreq governor could be built as a module but the change
"cpufreq / sched: Pass flags to cpufreq_update_util()" made it
non-modular so attempting to enable as module leads to a warning:
warning: symbol value 'm' invalid for CPU_FREQ_GOV_SCHEDUTIL
Systemd already supports seccomp. It seems some distros are building
systemd with seccomp, e.g. Arch on ARM, thus leading to boot errors:
systemd-logind.service: Failed at step SECCOMP spawning /usr/lib/systemd/systemd-logind: Invalid argument
PM_DEBUG and PM_ADVANCED_DEBUG bring some information useful for
development and they should not cause any significant overhead. Enable
them in default configuration so debugging would be slightly easier.
Acked-by: Kukjin Kim <kgene@kernel.org>
This patch enables the bus frequency scaling driver with devfreq and
devfreq-event framework. Devfreq is already supported on Odroid U3/XU3,
Trats2 and Rinato/Monk boards.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[k.kozlowski: Don't enable symbols already selected, adjust commit msg]
Pull ARM SoC defconfig updates from Olof Johansson:
Most of these are small changes adding the options for newly
upstreamed drivers, or drivers needed for new board support.
- removed Broadcom bcm_defconfig, targets are all covered in
multi_v7_defconfig
- new defconfig: multi_v4t_defconfig"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
ARM: multi_v7_defconfig: enable STMicroelectronics DRM Support
ARM: multi_v7_defconfig: enable STMicroelectronics BDISP 2D blitter driver
ARM: omap2plus_defconfig: Fix USB selection to keep Ethernet working
ARM: configs: lpc18xx: enable adc and dac iio drivers
ARM: config: Add a multi_v4t_defconfig
ARM: multi_v7_defconfig: add ACT8945A
ARM: at91/defconfig: Add ACT8945A driver
ARM: imx_v6_v7_defconfig: Select ADS7846 support
ARM: configs: qualcomm: Add MDM9615 missing defconfigs
ARM: multi_v7_defconfig: Enable vivid driver as a module
ARM: exynos_defconfig: Enable vivid driver as a module
ARM: defconfig: enable the MSM8660 pin controller
ARM: imx_v6_v7_defconfig: enable USB FFS gadget
ARM: socfpga: enable PL330 DMA in socfpga_defconfig
ARM: socfpga: add PCIe to socfpga_defconfig
ARM: multi_v7_defconfig: defconfig: Enable r8a7792 SoC
ARM: shmobile: defconfig: Enable r8a7792 SoC
ARM: Remove bcm_defconfig
ARM: multi_v7_defconfig: Enable Broadcom Kona watchdog
ARM: multi_v7_defconfig: Enable Broadcom STB PWM
The Virtual Video Test Driver can be used to emulate video capture and
output devices so it's very useful for testing. Since is not necessary
to boot, can be enabled as module to avoid increasing the kernel size.
Save defconfig on next-20160602. Most of changes are just re-ordering of
symbols. Removed symbols:
- FHANDLE (default y),
- THERMAL, EXYNOS_THERMAL (selected by ARCH_EXYNOS),
- CHROME_PLATFORMS (selected by MFD_CROS_EC),
- EXT4_FS (selected by EXT3_FS)
- SND_SOC_ODROIDX2 (obsolete since commit ee12a817bb4b ("ASoC: samsung:
Remove unused Odroid x2/u3 machine driver"), replaced with
SND_SIMPLE_CARD).
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into fixes
Two fixes for v4.7 cycle for build issues:
1. Fix samsung-keypad build error if INPUT is selected as module.
The error though depends on some uncommon build settings so it
is not as easy to trigger.
2. Get rid of 'samsung_device_dma_mask' defined but not used warning.
* tag 'samsung-fixes-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: exynos: don't select keyboard driver
ARM: samsung: improve static dma_mask definition
Exynos SoCs have a Multi Format Video Hardware Codec (MFC) IP block that
can be used to {en,de}code video streams by hardware. Enable support for
its driver as a module so the MFC can be tested.
There are a bunch of media platform drivers under drivers/media/platform/
that are for Samsung SoCs but are not being built with exynos_defconfig.
This patch enables them as a module to improve build coverage for these
drivers and also to allow people use them with proper hardware if modules
are installed. The S5P MFC driver wasn't enabled since it fails to probe.
Only the boolean Kconfig symbols are enabled as built-in, since drivers
are not critical and also to keep the kernel binary image size as small
as possible.
Disable big.LITTLE switcher in order to allow automatic usage of
cpufreq-dt driver on Exynos542x/Exynos5800 SoCs based boards.
This change should not cause any problems as arm_big_little[_dt]
driver (which is using big.LITTLE switcher support to do the "real"
big.LITTLE switching work) is not used on any Exynos SoC based
board currently.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Tested-by: Markus Reichl <m.reichl@fivetechno.de>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Anand Moon <linux.amoon@gmail.com>
The samsung-keypad driver is implicitly selected by ARCH_EXYNOS4 (why?),
but this fails if CONFIG_INPUT is a loadable module:
drivers/input/built-in.o: In function `samsung_keypad_remove':
drivers/input/keyboard/samsung-keypad.c:461: undefined reference to `input_unregister_device'
drivers/input/built-in.o: In function `samsung_keypad_irq':
drivers/input/keyboard/samsung-keypad.c:137: undefined reference to `input_event'
include/linux/input.h:389: undefined reference to `input_event'
drivers/input/built-in.o: In function `samsung_keypad_probe':
drivers/input/keyboard/samsung-keypad.c:358: undefined reference to `devm_input_allocate_device'
drivers/input/built-in.o:(.debug_addr+0x34): undefined reference to `input_set_capability'
This removes the 'select' as suggested by Krzysztof Kozlowski and
instead enables the driver from the defconfig files.
The problem does not happen on mainline kernels, as we don't normally
build built-in input drivers when CONFIG_INPUT=m, but I am experimenting
with a patch to change this, and the samsung keypad driver showed up
as one example that was silently broken before.
Link: https://lkml.org/lkml/2016/2/14/55
Currently only the ondemand and performance CPUFreq policy governors are
enabled in the Exynos defconfig. But the other governors are also useful
for some cases, enable them to allow users change the default if needed.
The options are enabled as module to keep the kernel image size minimal.
The Exynos4412-based Trats2 board has Asahi Kasei AK 3-Axis
Magnetometer, CM36651 proximity/ambient light sensor, MMS114 touchscreen
and Wolfson Microelectronics WM1811 CODEC. Enable them in defconfig to
get some testing coverage and use its features.
The driver has been removed so the Kconfig symbol is not valid anymore.
Reviewed-by: Andi Shyti <andi.shyti@samsung.com>
The Exynos SoC provides a Security SubSystem block for accelerating some
cryptographic operations. Enable the driver for it - s5p-secss to
utilize the hardware acceleration.
Currently the s5p-secss driver supports AES in CBC and ECB modes.
However on Odroid XU4 (Exynos5422) and Trats2 (Exynos4412) boards this
change introduces one booting error (because of unaligned buffers):
alg: skcipher: encryption failed on chunk test 1 for ecb-aes-s5p: ret=22
The cbc-aes-s5p properly registers itself and passes self-tests.
Enable the kernel NEON mode and asm/NEON accelerated crypto algorithms
which should bring performance benefits on Exynos SoCs. Enable these as
modules because they are optional, not essential anyhow for platform
booting nor related directly to Exynos Soc. All accelerated algorithms
pass booting self-tests on Odroid XU4 (Exynos5422) and Trats2 (Exynos4412).
Additionally enable cpufreq statistics as they are useful for debugging.
Set following options to a value recommended by systemd (which also
matches the multi_v7 deconfig):
1. Enable AUTOFS4_FS - for systemd.automount [0];
2. Enable BLK_DEV_BSG - SG v4 for recend udev [0][1];
3. Disable UEVENT_HELPER_PATH - legacy hook for hotplug, forked for each
uevent, slows down booting [0];
[0] http://cgit.freedesktop.org/systemd/systemd/tree/README
[1] http://patchwork.ozlabs.org/patch/47921/
NFS client is already enabled (NFS_FS) and by default it enables clients
for version 2 and 3. Enable explicitly the version 4 client to utilize
the newer protocol.
The NFS client is especially useful for testing kernel in automated
environments (network boot with network file system).
This patch enables drivers needed to get Exynos 4210 Universal C210 board
working: MAX8998 MFD and regulators, GPIO-based bit-bang SPI, Exynos DRM
FIMD parallel output and Samsung LD9040 RGB panel.
Enable support for:
1. Haptic motor driver on Trats2 board (Maxim 77693) and Note 4
(Maxim 77843);
2. LED driver on Trats2 board (Maxim 77693).
Enable support for Maxim 8997 Multi Functional Device present on Trats and
Origen boards by toggling on drivers: charger, haptic motor,
LED, RTC and extcon.
This allows to test and usage of these boards with exynos config.
"Defconfig updates are kept separate from other branches mostly to
avoid conflicts between the different categories (driver branch
enabling something that has context conflict with SoC options, etc).
A lot of this again is scattered across the various hardware
platforms. multi_v7_defconfig, our "generic" config for most 32-bit
platforms has been gone through by Marvell Berlin maintainers and
added most options they need to run on their hardware. Broadcom NSP
is also added there, and the new Atmel SAMA5D2 (added last release).
Rockchip also has display and other devices supported in that config.
In addition to that, the usual small churn of new options being added
here and there"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits)
ARM: multi_v7_defconfig: enable UniPhier I2C drivers
ARM: multi_v7_defconfig: Enable rtl8152 ethernet driver for Odroid-XU4
ARM: exynos_defconfig: Enable rtl8152 ethernet driver for Odroid-XU4
ARM: exynos_defconfig: Enable WiFi-Ex as a module instead built-in
ARM: exynos_defconfig: Disable simplefb support
ARM: exynos_defconfig: Enable LEDS for Odroid-XU3/XU4
ARM: multi_v7_defconfig: Enable DWC2 USB driver and USB ethernet gadget
ARM: exynos_defconfig: Enable DWC2 USB driver and USB ethernet gadget
ARM: exynos_defconfig: Enable USB Video Class support
ARM: multi_v7_defconfig: improve multi_v7_defconfig support for Berlin
ARM: tegra: Update multi_v7_defconfig
ARM: multi_v7_defconfig: Add Atmel SDHCI device
ARM: multi_v7_defconfig: Add Atmel Flexcom device
ARM: multi_v7_defconfig: Add Atmel SAMA5D2 SoC
ARM: at91/defconfig: add sama5d2 and its new devices to sama5 defconfig
ARM: at91/defconfig: update at91_dt defconfig
ARM: at91/defconfig: update sama5 defconfig
ARM: configs: Enable FIXED_PHY in multi_v7 defconfig
ARM: configs: update lpc18xx defconfig
ARM: socfpga_defconfig: enable fpga manager
Pull drm updates from Dave Airlie:
"I Was Almost Tempted To Capitalise Every Word, but then I decided I
couldn't read it myself!
I've also got one pull request for the sti driver outstanding. It
relied on a commit in Greg's tree and I didn't find out in time, that
commit is in your tree now so I might send that along once this is
merged.
I also had the accidental misfortune to have access to a Skylake on my
desk for a few days, and I've had to encourage Intel to try harder,
which seems to be happening now.
Here is the main drm-next pull request for 4.4.
Highlights:
New driver:
vc4 driver for the Rasberry Pi VPU.
(From Eric Anholt at Broadcom.)
Core:
Atomic fbdev support
Atomic helpers for runtime pm
dp/aux i2c STATUS_UPDATE handling
struct_mutex usage cleanups.
Generic of probing support.
Documentation:
Kerneldoc for VGA switcheroo code.
Rename to gpu instead of drm to reflect scope.
i915:
Skylake GuC firmware fixes
HPD A support
VBT backlight fallbacks
Fastboot by default for some systems
FBC work
BXT/SKL workarounds
Skylake deeper sleep state fixes
amdgpu:
Enable GPU scheduler by default
New atombios opcodes
GPUVM debugging options
Stoney support.
Fencing cleanups.
radeon:
More efficient CS checking
nouveau:
gk20a instance memory handling improvements.
Improved PGOB detection and GK107 support
Kepler GDDR5 PLL statbility improvement
G8x/GT2xx reclock improvements
new userspace API compatiblity fixes.
virtio-gpu:
Add 3D support - qemu 2.5 has it merged for it's gtk backend.
msm:
Initial msm88896 (snapdragon 8200)
exynos:
HDMI cleanups
Enable mixer driver byt default
Add DECON-TV support
vmwgfx:
Move to using memremap + fixes.
rcar-du:
Add support for R8A7793/4 DU
armada:
Remove support for non-component mode
Improved plane handling
Power savings while in DPMS off.
tda998x:
Remove unused slave encoder support
Use more HDMI helpers
Fix EDID read handling
dwhdmi:
Interlace video mode support for ipu-v3/dw_hdmi
Hotplug state fixes
Audio driver integration
imx:
More color formats support.
tegra:
Minor fixes/improvements"
[ Merge fixup: remove unused variable 'dev' that had all uses removed in
commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from
drm_gem_mmap_obj" ]
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits)
drm/vmwgfx: Relax irq locking somewhat
drm/vmwgfx: Properly flush cursor updates and page-flips
drm/i915/skl: disable display side power well support for now
drm/i915: Extend DSL readout fix to BDW and SKL.
drm/i915: Do graphics device reset under forcewake
drm/i915: Skip fence installation for objects with rotated views (v4)
vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT
drm/amdgpu: group together common fence implementation
drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE
drm/amdgpu: remove now unused fence functions
drm/amdgpu: fix fence fallback check
drm/amdgpu: fix stoping the scheduler timeout
drm/amdgpu: cleanup on error in amdgpu_cs_ioctl()
drm/i915: Fix locking around GuC firmware load
drm/amdgpu: update Fiji's Golden setting
drm/amdgpu: update Fiji's rev id
drm/amdgpu: extract common code in vi_common_early_init
drm/amd/scheduler: don't oops on failure to load
drm/amdgpu: don't oops on failure to load (v2)
drm/amdgpu: don't VT switch on suspend
Mixer driver is selected by CONFIG_DRM_EXYNOS_HDMI option. Since Exynos5433
HDMI does not require Mixer. There will be separate options to select Mixer
and HDMI. Adding new option to defconfig before Kconfig will allow to keep
bisectability.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
DesignWare MMC Controller's transfer mode should be decided
at runtime instead of compile-time. So we remove this config
option and read dw_mmc's register to select DMA master.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Odroid-XU4 has a RTL8153-CG gigabit Ethernet adapter, connected over
USB 3.0.
Signed-off-by: Anand Moon <linux.amoon@gmail.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
The Marvell WiFi-Ex driver tries to load a firmware on probe. So if the
driver is built-in and probed before a firmware is available, this is
not loaded and the chip does not work.
This happens for example if an initramfs isn't used since the driver is
probed before the root filesystem is mounted.
Change the default config since the driver isn't needed for machines to
boot and is more convenient to have it enabled as a module to avoid
requiring an initramfs or to have the firmware built into the kernel.
Reviewed-by: Andreas Faerber <afaerber@suse.de>
The simplefb driver allows the kernel to render on a pre-allocated
buffer that's been initialized by firmware before the kernel boots.
This option was enabled to have display working on the Exynos5250
Snow Chromebook by commit da9d0fbf5e9a ("ARM: exynos: defconfig
update") since proper DRM/KMS support did not exist at that time.
But now that the Exynos DRM driver has support for this hardware,
there is no need to have simplefb enabled. In fact, if a user has
a u-boot that injects the simplefb dev node to the FDT before pass
it to the kernel, display won't be properly initialized and only a
blank screen will be shown since there isn't a proper handoff from
the simplefb driver to the Exynos DRM driver.
Reviewed-by: Michael Turquette <mturquette@baylibre.com>
Tested-by: Michael Turquette <mturquette@baylibre.com>
Odroid XU3 family boards come with RGB LEDs. Enabling LEDS_GPIO and
LEDS_PWM allows monitoring the board alive state (heartbeat) and
MMC/SDcard IO usage.
[k.kozlowski: Rewritten the commit message]
DWC2 (s3c-hsotg) hardware module is available on many Exynos based boards,
so enable DWC2 driver as well as the most common USB Ethernet gadget.
The Exynos5420 Peach Pit and Exynos5800 Peach Pi boards have a built-in
Silicon Motion USB UVC WebCam. Enable support for the USB Video Class
driver and its needed media Kconfig symbols so the camera is supported.
Pull late ARM SoC updates from Kevin Hilman:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The bulk of the changes are for samsung/exynos SoCs for some changes
that needed a few minor reworks so ended up a bit late. The others
are mainly for qcom SoCs: a couple fixes and some DTS updates"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits)
ARM: multi_v7_defconfig: Enable PBIAS regulator
soc: qcom: smd: Correct fBLOCKREADINTR handling
soc: qcom: smd: Use correct remote processor ID
soc: qcom: smem: Fix errant private access
ARM: dts: qcom: msm8974-sony-xperia-honami: Use stdout-path
ARM: dts: qcom: msm8960-cdp: Use stdout-path
ARM: dts: qcom: msm8660-surf: Use stdout-path
ARM: dts: qcom: ipq8064-ap148: Use stdout-path
ARM: dts: qcom: apq8084-mtp: Use stdout-path
ARM: dts: qcom: apq8084-ifc6540: Use stdout-path
ARM: dts: qcom: apq8074-dragonboard: Use stdout-path
ARM: dts: qcom: apq8064-ifc6410: Use stdout-path
ARM: dts: qcom: apq8064-cm-qs600: Use stdout-path
ARM: dts: qcom: Label serial nodes for aliasing and stdout-path
reset: ath79: Fix missing spin_lock_init
reset: Add (devm_)reset_control_get stub functions
ARM: EXYNOS: switch to using generic cpufreq driver for exynos4x12
cpufreq: exynos: Remove unselectable rule for arm-exynos-cpufreq.o
ARM: dts: add iommu property to JPEG device for exynos4
ARM: dts: enable SPI1 for exynos4412-odroidu3
