path: root/arch/arm/configs/lpc18xx_defconfig
2016-07-07ARM: configs: lpc18xx: enable adc and dac iio driversJoachim Eastwood
Enable ADC and DAC IIO drivers for LPC18xx/43xx SoCs. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-14ARM: configs: lpc18xx: enable EEPROM NVMEM driverAriel D'Alessandro
Enable NVMEM driver for NXP LPC18xx EEPROM, which can be found in NXP LPC185x/3x and LPC435x/3x/2x/1x devices. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-12-14ARM: configs: lpc18xx: enable mma7455 IIO driverJoachim Eastwood
MMA7455 is 3-axis accelerometer that can be found on Embedded Artists' LPC4357 Developer's Kit. Signed-off-by: Joachim Eastwood <manabian@gmail.com>
2015-11-10Merge tag 'armsoc-defconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC defconfig updates from Olof Johansson: "Defconfig updates are kept separate from other branches mostly to avoid conflicts between the different categories (driver branch enabling something that has context conflict with SoC options, etc). A lot of this again is scattered across the various hardware platforms. multi_v7_defconfig, our "generic" config for most 32-bit platforms has been gone through by Marvell Berlin maintainers and added most options they need to run on their hardware. Broadcom NSP is also added there, and the new Atmel SAMA5D2 (added last release). Rockchip also has display and other devices supported in that config. In addition to that, the usual small churn of new options being added here and there" * tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits) ARM: multi_v7_defconfig: enable UniPhier I2C drivers ARM: multi_v7_defconfig: Enable rtl8152 ethernet driver for Odroid-XU4 ARM: exynos_defconfig: Enable rtl8152 ethernet driver for Odroid-XU4 ARM: exynos_defconfig: Enable WiFi-Ex as a module instead built-in ARM: exynos_defconfig: Disable simplefb support ARM: exynos_defconfig: Enable LEDS for Odroid-XU3/XU4 ARM: multi_v7_defconfig: Enable DWC2 USB driver and USB ethernet gadget ARM: exynos_defconfig: Enable DWC2 USB driver and USB ethernet gadget ARM: exynos_defconfig: Enable USB Video Class support ARM: multi_v7_defconfig: improve multi_v7_defconfig support for Berlin ARM: tegra: Update multi_v7_defconfig ARM: multi_v7_defconfig: Add Atmel SDHCI device ARM: multi_v7_defconfig: Add Atmel Flexcom device ARM: multi_v7_defconfig: Add Atmel SAMA5D2 SoC ARM: at91/defconfig: add sama5d2 and its new devices to sama5 defconfig ARM: at91/defconfig: update at91_dt defconfig ARM: at91/defconfig: update sama5 defconfig ARM: configs: Enable FIXED_PHY in multi_v7 defconfig ARM: configs: update lpc18xx defconfig ARM: socfpga_defconfig: enable fpga manager ...
2015-10-26arm: lpc18xx_defconfig: remove CONFIG_MMC_DW_IDMACShawn Lin
DesignWare MMC Controller's transfer mode should be decided at runtime instead of compile-time. So we remove this config option and read dw_mmc's register to select DMA master. Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Acked-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2015-10-15ARM: configs: update lpc18xx defconfigJoachim Eastwood
- Enable SPIFI Flash and JFFS2 to support rootfs on Flash memory - Enable USB Phy, mass storage and SCSI to support USB memory - Enable PCF857x and JC42 I2C devices found on Hitex board - Enable PL172 to support memory mapped NOR Flash - New LPC18xx drivers: I2C, Watchdog, SCT PWM and RTC Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29ARM: lpc18xx: remove DEBUG_LL_UART_8250 from defconfigJoachim Eastwood
Remove the generic 8250 config option so that the LPC18xx specific option gets picked instead. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-22ARM: add ARM_SINGLE_ARMV7M in ARMv7-M defconfigsStefan Agner
Select ARM_SINGLE_ARMV7M in defconfigs of the converted ARMv7-M platforms. [arnd: moved the efm32_defconfig change to the patch that originally introduces the symbol, to avoid intermittent regression] Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-15ARM: lpc18xx: add kernel configJoachim Eastwood
Kernel configuration for NXP LPC18xx and LPC43xx devices. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
