With the SA1100 and PXA RTC drivers be mutually exclusive and no
longer sharing hardware, PXA27x/PXA3xx platforms must use the PXA RTC
driver as the SA1100 platform device is no longer registered.
This change should be almost transparent to userspace. Former users of
pxa-rtc should be aware that 2 RTCs will be available on their kernels,
rtc0 being sa1100-rtc and rtc1 being pxa-rtc. Any userspace relying on
the fact that rtc0 was pxa-rtc should be fixed.
As a consequence:
- the first reboot after the switch will have the wrong time,
- on dual boot platform where the other OS programs some logic into the
sa1100 rtc IP, a lack of fix in userspace, ie. a kernel changing
sa1100-rtc thinking it is pxa-rtc could have dire consequence, such
as wiping the other OS data partition.
(Thanks to Robert Jarmik for help on the above commit text.)
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The File-backed Storage Gadget (g_file_storage) is being removed, since
it has been replaced by Mass Storage Gadget (g_mass_storage). This commit
changes defconfigs point to the new gadget.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> (AT91)
Acked-by: Tony Lindgren <tony@atomide.com> (OMAP1)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> (AVR32)
Signed-off-by: Felipe Balbi <balbi@ti.com>
The bq24022 on these machines is a very simple regulator using gpios.
One provides the on/off functionality and a second one is used to
change the current between 100 and 500 mA.
This functionality can also be provided by the more generic gpio-regulator.
Therefore convert both machines which makes it possible to remove the
bq24022 driver later on.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Since CONFIG_USB_GADGET_PXA27X and other macros are renamed to
CONFIG_USB_PXA27X. Update them in arch/arm/mach-pxa and arch/arm/configs
to keep consistent.
Cc: stable@kernel.org
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
26-bit ARM support was removed a long time ago, and this symbol has
been defined to be 'y' ever since. As it's never disabled anymore,
we can kill it without any side effects.
I'm not going to maintain separate defconfigs for magician and hx4700.
This should probably be renamed to htcpxa_defconfig.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
With this patch, the bq24022 battery charger is controlled by the USB
gadget framework (via gpio_vbus) when connected to USB.
To compile, this patch depends on the "regulator: Allow init data to be
supplied for bq24022" patch (queued for next in the regulator tree) to
add the init_data field to struct bq24022_mach_info.
It also depends on the "add optional OTG transceiver and voltage
regulator support to pda_power" patch (queued for next in the power
supply tree) to enable charging when connected to the AC charger.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
arch/arm/configs/magician_defconfig
This patch depends on otg_transceiver support in pxa27x_udc
(which is queued via linux-usb) to work.
It compiles also without it.
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Magician uses the generic PWM backlight driver,
so select HAVE_PWM.
This is the touched up result of make magician_defconfig in 2.6.29-rc2.
- Enabled USB host and bluetooth: magician has a CSR BlueCore3 connected
to the PXA27x OHCI internally.
- Made I2C built-in.
This patch enables LEDs and the 1-wire bus (connected to
a DS2760 battery monitor) on the magician.
physmap-flash and JFFS2
This enables rootfs on StrataFlash if the bootloader supplies the
partition list.
needed for power management (audio, BT, charging, GSM, LCD, SD), GSM, flash and SD operation and audio routing.
