Enable Atmel ARMv5 platforms in multi_v5
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Pull ARM SoC defconfig updates from Arnd Bergmann:
"As usual, a bunch of commits, mostly adding drivers and other options
to defconfigs.
We are adding three new defconfig files for the newly added 32-bit
machines (aspeed and mps2), the rest is mainly housekeeping.
The changes outside of arch/arm/config/ are for a Kconfig symbol that
got renamed"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (63 commits)
ARM: aspeed: adapt defconfigs for new CONFIG_PRINTK_TIME
ARM: u8500_defconfig: update sensor config
ARM: u8500_defconfig: remove staging from defconfig
ARM: multi_v7_defconfig: Remove unused Kconfig option MACH_UX500_DT
ARM: at91/defconfig: sama5: add CONFIG_FHANDLE
arm/configs: Add Aspeed defconfig
arm/configs/multi_v5: Add Aspeed ast2400
ARM: at91: sama5: Update defconfig
ARM: imx_v6_v7_defconfig: add CONFIG_MICREL_PHY
ARM: imx_v6_v7_defconfig: add CONFIG_I2C_GPIO
ARM: multi_v7: Enable Tegra XUSB controller in defconfig
ARM: tegra: Enable XUSB controller in defconfig
ARM: omap2plus_defconfig: Enable PWM and ir-rx51 as loadable modules
ARM: multi_v7_defconfig: add the Atmel sama5d2-compatible ADC driver
ARM: multi_v7_defconfig: add the Atmel Audio microphone interface PDMIC
ARM: multi_v7_defconfig: add Atmel ISI (Image Sensor Interface) driver
ARM: multi_v7_defconfig: add Atmel watchdog timers
ARM: multi_v7_defconfig: add HLCDC drivers as modules
ARM: at91/defconfig: add PDMIC driver to sama5_defconfig
ARM: at91/defconfig: add HLCDC driver to sama5_defconfig
next/defconfig
Merge "aspeed defconfig for 4.7" from Joel Stanley:
This adds configurations used for testing Aspeed BMC SoCs, as well as adding
the v5 part to the multi defconfig.
* tag 'aspeed-for-4.7-defconfig' of https://github.com/shenki/linux:
Now that all drivers support the same set of functions and the same
setup code, drop every model-specific DSA switch driver and replace them
with a common mv88e6xxx driver.
This merges the info tables into one, removes the function exports, the
model-specific files, and update the defconfigs.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
This adds the Aspeed ast2400 BMC SoC to the build.
The SoC has six UARTs so we need to enable the appropriate options for
SERIAL_8250
Signed-off-by: Joel Stanley <joel@jms.id.au>
Enable FHANDLE, CGROUPS, BLK_DEV_BSG and DEVTMPFS as recommended by
systemd (which also matches the multi_v7 defconfig). Also enable IPV6,
which defaults to 'y' by now.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Although the SoC support was already enabled, the drivers and machines
were missing.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
to defconfigs.
The realview_smp_defconfig and realview_defconfig got merged into one,
so we are now down to 110 files.
For stm32, we have now added a Kconfig fragment, the first such file
on arch/arm. The purpose here is to have a shared defconfig file that
works for all boards, while the DRAM offset has to be hardwired on
NOMMU machines at compile time.
The Exynos defconfig changes depend on changes in the RTC tree, so
this is pulled in here, but has already been merged into 4.6 now"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits)
ARM: imx_v4_v5_defconfig: Enable initramfs support
ARM: imx_v4_v5_defconfig: Cleanup imx_v4_v5_defconfig
ARM: multi_v7_defconfig: Enable LP872x regulator support
ARM: omap2plus_defconfig: Enable LP872x regulator support
ARM: mxs_defconfig: Enable initramfs support
ARM: mxs_defconfig: Cleanup mxs_defconfig
ARM: multi_v5_defconfig: Enable initramfs support
ARM: multi_v5_defconfig: Cleanup multi_v5_defconfig
ARM: multi_v7_defconfig: enable useful configurations for Vybrid
ARM: multi_v7_defconfig: add MACH_ARTPEC6
ARM: omap2plus_defconfig: Enable AT24 eeprom
ARM: omap2plus_defconfig: Enable TI TVP5150 video decoder support
ARM: omap2plus_defconfig: Enable ISP support and dependencies
ARM: omap2plus_defconfig: Enable OMAP IOMMU support
ARM: socfpga_defconfig: enable support for initramfs/initrd support
ARM: at91/defconfig: add sama5d2 adc support in sama5_defconfig
ARM: multi_v7_defconfig: Enable BCM283x
ARM: bcm2835_defconfig: Enable RPi power domain driver
ARM: bcm2835_defconfig: Enable RPi firmware driver
ARM: bcm2835_defconfig: enable ARMv7 support
All the drivers support multiple chips, but mv88e6123_61_65 is the
only one that reflects this in its naming. Change it to be consistent
with the other drivers.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
This makes it possible to automatically boot-test this defconfig with
kernelci.org.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Regenerate multi_v5_defconfig by running:
make multi_v5_defconfig
make savedefconfig
mv defconfig arch/arm/configs/multi_v5_defconfig
Now that Orion5x is part of the v5 multiarch kernel enable it in the
multi_v5_defconfig.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
DSA now depends on switchdev. Enable it, and re-enable DSA and its
drivers, which were removed when multi_v5_defconfig was regenerated.
Dues the Kconfig changes, multi_v5_defconfig needs regenerating.
As there is no more mx25 board files, we can turn mx25 into a dt-only platform.
Rename imx25-dt.c to mach-imx25.c to be consistent with the other i.MX SoCs.
Enable building of the switch chip driver and the wireless driver
needed by the DLINK DIR665
Cc: arm@kernel.org
Link: https://lkml.kernel.org/r/1414793613-11798-5-git-send-email-andrew@lunn.ch
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Enable building LaCie 2Big and 5Big Network v2 in the multi v5 kernel.
Link: https://lkml.kernel.org/r/1401132591-26305-5-git-send-email-andrew@lunn.ch
Enable simple-card and the CODEC.
Link: https://lkml.kernel.org/r/1399141819-23924-10-git-send-email-andrew@lunn.ch
A couple of lines in multi_v5_defconfig appear twice,
causing a harmless Kconfig warning. This removes one
of the two copies.
The HP T5325 has a PCI based VGA controller. Add the frame buffer
driver, and frame buffer support to the defconfig's. Additionally
add the soc audio framework and the necessary codec.
To allow regression build testing of multi v5 systems, add a
multi_v5_defconfig, similar to the multi_v7_defconfig. This is based
on kirkwood_defconfig, but with a few other boards added which claim
to be MULTI_v5.
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
