path: root/arch/arm/configs/netwinder_defconfig
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
