Fed up with all that fancy new 64bit HW? Look no further!
Get your NetWinder out of the closet (or in my case, the tip) and
run -next on it!
All it takes is a small defconfig change to be able to take
the parameters from the bootloader...
26-bit ARM support was removed a long time ago, and this symbol has
been defined to be 'y' ever since. As it's never disabled anymore,
we can kill it without any side effects.
DEBUG_WAITQ appears to have been removed by others, but no one
removed the configuration option from ARM. Remote it from both
Kconfig.debug and all default configurations.
EPXA10DB has gone, no need to keep the symbol in the defconfigs.
infrastructure for it.
Let it rip!
