path: root/arch/arm/configs/orion5x_defconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-10ARM: reduce defconfigsUwe Kleine-König
2010-02-05[ARM] orion5x: update defconfigNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-05[ARM] Orion: Add Buffalo Linkstation LS-HGL supportZhu Qingsen
Signed-off-by: Zhu Qingsen <zhuqs@cn.fujitsu.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-12-18ARM: Kill CONFIG_CPU_32Russell King
26-bit ARM support was removed a long time ago, and this symbol has been defined to be 'y' ever since. As it's never disabled anymore, we can kill it without any side effects. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-07[ARM] orion5x: update defconfigNicolas Pitre
2009-06-03[ARM] orion: add hwrng timeriomem hook to TS-78xxAlexander Clouter
Add hook so that the HW RNG source on the TS-78xx is available. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-05-04[ARM] orion5x: update defconfigNicolas Pitre
2009-02-25[ARM] orion5x: ts78xx add NAND support via plat_nandAlexander Clouter
ts78xx add NAND support via plat_nand Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@cam.org>
2009-02-19Merge branch 'for-np' of git://git.wormnet.eu/alex/ts78xx into orion/masterNicolas Pitre
2009-02-06[ARM] orion5x: add rtc-m48t86 to orion5x_defconfigAlexander Clouter
The TS-7800 can have a M48T86 RTC onboard Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-10-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
Merge branch 'orion-devel' into devel
2008-09-25[ARM] Orion: Add Buffalo Linkstation Mini supportAlexey Kopytko
This patch adds support for Buffalo Linkstation Mini board. Signed-off-by: Alexey Kopytko <alexey@kopytko.ru> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-09-25[ARM] Orion: add RD88F6183AP-GE supportLennert Buytenhek
The RD88F6183AP-GE is an access point reference design for the 88F6183 SoC, with a 88E6161 six-port gigabit ethernet switch with five PHYs (providing 1 WAN and 4 LAN ports and an interface to the CPU), and a mini-PCIe slot for a wireless card. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-09-25[ARM] Orion: add LaCie Ethernet Disk mini V2 supportChristopher Moore
This patch adds support for the LaCie Ethernet Disk mini V2. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Signed-off-by: Christopher Moore <moore@free.fr> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-22[ARM] orion5x: update defconfig to v2.6.27-rc4Nicolas Pitre
2008-08-21[ARM] Orion: activate lm75 driver on DNS-323Martin Michlmayr
The lm75 driver was recently converted to the new-style binding, so now it can be loaded from the DNS-323 support code. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Tested-by: Tobias Poschwatta <tp@fonz.de> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: enable CONFIG_RTC_DRV_S35390A in the defconfg for QNAP devicesMartin Michlmayr
The QNAP TS-109/TS-209 and TS-409 devices need RTC_DRV_S35390A. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: enable RTC_DRV_PCF8563 in the defconfig for HP mv2120Martin Michlmayr
Enable RTC_DRV_PCF8563 in the Orion defconfig since this driver is needed by the HP mv2120. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: enable KEYBOARD_GPIO in the defconfgMartin Michlmayr
Enable KEYBOARD_GPIO in the Orion defconfig because a number of Orion devices, such as the HP mv2120, define gpio-keys buttons. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-07-07[ARM] Orion: LED support for HP mv2120Martin Michlmayr
The HP mv2120 has several LEDs that are controlled through gpio. Export the health LED, the red SATA LEDs as well as two gpios that control the brightness of _all_ LEDs to userland. The Ethernet and power LEDs can't be controlled through gpio and the blue SATA LEDs are handled via the SATA driver. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-06-30[ARM] Orion: enable all currently supported boards in defconfigImre Kaloz
Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-06-22[ARM] Orion: update defconfig to 2.6.26-rc4Nicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-03-27Orion: orion -> orion5x renameLennert Buytenhek
Do a global s/orion/orion5x/ of the Orion 5x-specific bits (i.e. not the plat-orion bits.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Reviewed-by: Tzachi Perelstein <tzachi@marvell.com> Acked-by: Saeed Bishara <saeed@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
