These options are needed for multiple PDP context support
bug 926236
Change-Id: I2a7149ca829d015375132b1f882924cab825d945
signed-off-by: Stephane Dion <sdion@nvidia.com>
Reviewed-on: http://git-master/r/85533
Reviewed-by: Jean-Marc Guiraudet <jguiraudet@nvidia.com>
Change-Id: I93e6380f3c9f838ecbe29de5ad9d14bab442d7d3
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-on: http://git-master/r/84797
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 937953
Change-Id: I779b73199b271449c4fd28c8b09e7b410b1ba63b
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/83387
Change-Id: I69a074eef0613cc18b09f43021a887495757b9a5
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/83658
Enable config variable for the tps62360 regulator
which is from linux mainline and remove the driver
tps6236x which is duplicate of above driver.
Change-Id: Ic5e0ba18a4f3088c407ee8ad70b5da39ffc79ec9
Reviewed-on: http://git-master/r/78414
This CL includes following changes
- BCM4329 CSCAN functionality has been moved to a
new Kconfig option; we will preserve the expected
behavior (option enabled) for existing users
- remove dangling reference to BCM4329 Kconfig
option
Change-Id: I5876c33ef6f25309bcb0bedb3b1808d6bfb87b65
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/82862
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Invensense defcfg files for MPU6050. MPL version 4.1.1.
Bug 825602
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/70374
(cherry picked from commit 50c19aa98126290cfc9ef69a89b4130e97a7b3a4)
Change-Id: I1923853ed71456a06079b13f9d7c01acc03e5617
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82718
Enable ALC5639 audio codec configuration.
Bug 931371
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/77955
(cherry picked from commit f04d6d7c5deb81ec41ccc357cec69e033d9b4877)
Change-Id: I1a774dd69c4f74d68dda05136a3437a55c35b490
Reviewed-on: http://git-master/r/82734
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
defconfig change to enable smb349 charger driver
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/78291
(cherry picked from commit add6b9791b0dca26f7034d12b7e72d8cdd3161ce)
Change-Id: Id3ec77fbd3d7979f13ce269b9e269ead5515747a
Reviewed-on: http://git-master/r/79984
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
defconfig change to enable max17048 driver
Reviewed-on: http://git-master/r/78288
(cherry picked from commit d3224bc1d960c38472cafbd1cd48d4d24236ca5c)
Change-Id: I395bd3af953edd7f0e73161528e10afec0171b78
Reviewed-on: http://git-master/r/79983
enable CONFIG_NFC and CONFIG_PN544_NFC to support pn544.
Bug 932798
Change-Id: I411edc7dbf97afd050cfe4f68991a2f132886773
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/78689
Bug 926128
Reviewed-on: http://git-master/r/75252
Change-Id: I7f9928ab1efdb82ab73eea595c2a8590057b8c72
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-on: http://git-master/r/78436
Enable Snaptics SPI touch driver which is used for DirectTouch
purposes.
bug 912775
Reviewed-on: http://git-master/r/76379
Change-Id: I2a2bc4dd68c09039dd36b6c8786b8d16ecb35c80
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/77776
Enable Raydium touch touch driver which is used for
DirectTouchpurposes.
bug 832605
Reviewed-on: http://git-master/r/76385
Change-Id: I633291cf5e11d66709f224292d02e211cca051fd
Reviewed-on: http://git-master/r/77728
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-on: http://git-master/r/74496
Change-Id: Icc6316ddddd1e6a7e9634a6539ae48cbbcd87607
Reviewed-on: http://git-master/r/77297
Bug 926128
Change-Id: I326e3806a429e031bea78a3e051c22518e705f86
Reviewed-on: http://git-master/r/74973
Reviewed-on: http://git-master/r/75889
Bug 921207
Change-Id: Id58bb2c144645a3105a3111ef7ed4eb3da528644
Reviewed-on: http://git-master/r/73719
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-on: http://git-master/r/73967
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
IDT ICS932S401 is not used by Tegra3 reference board.
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Change-Id: I019bad552880aed79d4aaddecca4ebdf2cbb4696
Reviewed-on: http://git-master/r/72080
bug 902137
Change-Id: I1d92a579672ad5bd93e033000a366b6e5d6b27d9
Signed-off-by: venu byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/70212
Bug 886459
Change-Id: I9ffce0e0186cace45c403ae6880f3460ed3ede47
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Reviewed-on: http://git-master/r/68307
Bug 886459
Change-Id: Id6efa14da2de776208fba2fe58624c79cca809ed
Reviewed-on: http://git-master/r/68285
Pcie powermanagement issues are yet to be resolved,
so modifying the defconfig to not to enable the
driver by default
bug: 878874
Change-Id: Ie8787342b1ccf9e22486129633d15d566d50e4e0
Signed-off-by: Krishna Kishore <kthota@nvidia.com>
Reviewed-on: http://git-master/r/64772
Enable CONFIG_TEGRA_NVHDCP
Bug 912422
Change-Id: I43e27094eca00a445340b62644e76d664d8e65ab
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/68743
Bug 886459
(cherry picked from commit 80b35eff76334a1a62192aa99c9d5dcb8c1ba76b)
Change-Id: I7f7914eeff30001ce6c56ecd26d1c61e6e981df1
Reviewed-on: http://git-master/r/68559
CONFIG_USB_EHCI_ONOFF_FEATURE is removed. Dynamic add/removel of
hcd driver can be used instead of this feature.
BUG 787720
Change-Id: I325d870b0d2242b97273eff40cfb228d5c965682
Reviewed-on: http://git-master/r/68394
Enable conservative gov config for early suspend in K39
Change-Id: Ia78766c45e4666e2f0dc4ef3311300783c220687
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/62782
Enable bcmdhd driver as a module to load at boot time.
Change-Id: I69990a1d705955092c6da0a344311bd2eb5a7254
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/68233
Enabled CONFIG_THERMAL option so that Linux Thermal Sysfs
frameowkr files can be compiled.
bug 877539
Change-Id: Ia3b94c20b99f72f8d35e41de58a5f6ec2a6a1aaf
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/68031
Bug 825602
Bug 834422
Bug 843573
Change-Id: I1ac992bfde9a63bf70bff88d5b9cb3b147f31bdf
Reviewed-on: http://git-master/r/66085
bug 816608
Change-Id: Ib25479b052ca2010182b5df0ecb4432baf584f74
Reviewed-on: http://git-master/r/68045
Enable SUSPEND_TIME config.
Enables few debug logs during suspend cycle.
Bug 907612
Change-Id: Iee7496fffba7d0dca48adb240205de072992e2a1
Reviewed-on: http://git-master/r/67772
xt_qtaguid is kernel iptables module to track stats for packets based on user tags.
Enable CONFIG_NETFILTER_XT_MATCH_QTAGUID
and set its dependencies:
enable CONFIG_NETFILTER_TPROXY
enable CONFIG_NETFILTER_XT_MATCH_SOCKET
enable CONFIG_IP_NF_MANGLE
disable CONFIG_NETFILTER_XT_MATCH_OWNER
also enable CONFIG_IP6_NF_IPTABLES for compiling this module
bug 905524
bug 906714
bug 906281
Change-Id: I8f41190afd5b846fa6141a3a438aba4243bfff2a
Reviewed-on: http://git-master/r/67144
Enable HDA power save mode for Tegra30 and set default power save
timeout value as 10 secs.
Bug 904530
Change-Id: I124d1efcf4ee22c42707d7a9817a0e4349dea995
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/66977
Restricted PLLM usage to modules capable to divide maximum PLLM
output frequency at minimum core voltage.
Ported commit ea16f938334dcdb04a16495bbe6f37cf2a714e9c
Bug 884419
Change-Id: Ic4bfcdb84e9b629071aa81228848ed41ff56b423
Reviewed-on: http://git-master/r/66532
Include bcmdhd driver as a part of kernel image
Change-Id: I88406d856300183bc86db45850955fd0dd245a01
Reviewed-on: http://git-master/r/67422
Enable profiling support by default in Tegra kernels, to facilitate
usage of tools such as Perf and OProfile.
Bug 899639
Change-Id: Idf346136ca618bd2a23e549792948f287e0045aa
Signed-off-by: Ryan V. Bissell <rbissell@nvidia.com>
Reviewed-on: http://git-master/r/66231
Rebase-Id: R82bb98d845d11b57a34fd44589e7a2c8081cbe27
Enable XMM modem power driver.
Change-Id: Ie0598b6ee9200ce1fea96dc4d7b5fcc7b6364523
Reviewed-on: http://git-master/r/65991
Rebase-Id: R5e160a41e5e376397dd5c95ea5a0c022dc22c8b4
Enabling CONFIG_MMC_UNSAFE_RESUME, and
Disabling CONFIG_MMC_BLOCK_DEFERRED_RESUME
Bug 895672
Change-Id: Idc7d3c11dab5cce6fe170a493e8dbef129c235c6
Reviewed-on: http://git-master/r/65972
Rebase-Id: R9a716e05ede823bd924a5b49b8b87be30fe90bcd
Bug 890392
Change-Id: I5a79cd7cb90a6fa516be691270e3a1a9eb6a48ea
Signed-off-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-on: http://git-master/r/66441
Rebase-Id: R507dde5de4175cffdfcc17480cefc640266a3583
Change-Id: I942bfca76a7a4bc454fc2bdbc0096828a1d7d3c9
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/66297
Rebase-Id: R610b177beec1da6d4d91c857b86701ae3754de8a
- Disable debug features in kernel
Bug 903783
Change-Id: I50cdf867858b056620ff638d89446c00bbb20788
Reviewed-on: http://git-master/r/65720
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Rebase-Id: R62d3a9fae307adbc54ae58e3b8f36111fe0abeff
Enabling MAX77663 MFD, Regulator and RTC drivers.
Bug 849360
Change-Id: I3df9a85e4eaeb9beb939814a724ca9a108bc6a72
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/64403
Rebase-Id: R0114e0eb5dd74dd43b0cbcb033152a0c3e5d9273
Bug 872652
Change-Id: Ic5e75350f50cc15e0eb536f787d4b1bedc98b5d2
Reviewed-on: http://git-master/r/59507
Rebase-Id: R67f49942409080f8a79fe52f8fbcc038aebb1f36
Enabling ricoh583 based pmic mfd and regulator driver.
Change-Id: I84aff73389ef3481e84672f896d54ea5d06f8c36
Reviewed-on: http://git-master/r/62973
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: Rc0f1f76925ceb84fc36bec449828a24a3c4b595b
Fix the SD Card suspend/Resume issue
Bug 897433
Change-Id: I3bbc0ca63715ca01d5bde7d43447a86e33ac9527
Reviewed-on: http://git-master/r/62444
Rebase-Id: R671be5031aa416e8437fa300c710a144fef7a51c
1. Enable BCMDHD driver as a module
2. Enable CFG80211
3. Enable Out Of Band Interrupt for BCMDHD driver
Bug 820860
Change-Id: Ie6eaf3f2a96c12a5e4792d42f2815bb5fd6bd420
Reviewed-on: http://git-master/r/60222
Rebase-Id: R331585bea14337943f7c82c186d00052cd267ab1
- Raise the number of mmc minors per block device to 16
Bug 870221
Reviewed-on: http://git-master/r/59769
(cherry picked from commit 183f279210b797da859229ae83e81f25fdf2f86e)
Reviewed-on: http://git-master/r/62346
(cherry picked from commit ba3b07a5e471c51119cd2bd474197bd2f930a666)
Change-Id: I229451d74b94ee9db03a34ed9d2d2bc99480d83e
Reviewed-on: http://git-master/r/63097
Rebase-Id: Ra529f8b9adb381dfd10af02be0b6bea0054f2dfa
Enable NFC and interface driver configuration variables
Bug 846684
Bug 873017
Change-Id: Ifbf2e0534296b699b690d891ba612838fd7c66f2
Reviewed-on: http://git-master/r/62741
Rebase-Id: R266223fbfcb30fb80f27dfc93f9c06af16ba6ed2
Enabling gpadc driver of tps80031 for enterprise.
bug 872697
Reviewed-on: http://git-master/r/52635
Change-Id: Ice87808844274f73e9be0d2c8fe2405881ffde7e
Reviewed-on: http://git-master/r/61861
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Tested-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Rebase-Id: R74048a6696b68b6b9540058d9216db8d70596d3f
Enabling tegra usb modem power management for enterprise.
Bug 854339
Reviewed-on: http://git-master/r/51383
(cherry picked from commit 71ab0de20805bab13e9508d4df4bf60720546c7e)
Change-Id: I6fab9d727581a415502c56c0e591909e6590e2e0
Reviewed-on: http://git-master/r/60317
Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
Rebase-Id: Rf9e0c311e8005e1ac01ea86c1874181ed5febe75
