arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Enable building b43 driver as a module to demo Broadcom AirForce
BCM4311 based mini-PCIe Wi-Fi 802.11a/b/g module.
enable /dev mount with ACL
Bug 1225372
Bug 1219372
Change-Id: I3b80012e97c3a5ec8358285f81c5111a30ed19f8
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/196206
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested on early prototype Apalis T30 V1.0a module.
Known issues:
- ADC not integrated yet.
- HDA not integrated yet.
- CEC not integrated yet.
- IrDA not integrated yet.
- Keys not integrated yet therefore no way to wake from suspend.
- 8-bit MMC1 slot card detection interrupt not working despite
detection GPIO successfully being tested with GPIOConfig.
Note: even 8-bit cards work fine if already plugged-in during boot.
- PCIe limited to internal Gigabit Ethernet chip for now due to our
proprietary way of resetting other ports which requires further
integration into NVIDIA's driver.
Get rid of obsolete NAND aka Colibri T30 v1.0a prototype handling.
Clean-up kernel configuration and bring it more in line with Colibri T20.
Do not use P2P, as it does not fit well with
network manager.
Bug 1199933
Change-Id: I355515574baabeace7c48932c52007c1fe0c3d5f
Reviewed-on: http://git-master/r/171551
Tested-by: Matthew Pedro <mapedro@nvidia.com>
- select RT5640 ASoC support in Cardhu machine Kconfig
- enable RT5640 ASoC driver in tegra3_defconfig
- select RT5639 ASoC codec when selecting RT5640, othwise kernel
linking will fail
Bug 1190823
Change-Id: I1046c30667d4ca8276080f1b3174eccd0b25328c
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/168884
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
There are some classes of devices that are controlled entirely from
user space. Userspace consumer driver provides ability to control power
supplies for such devices. Enable this configuration option to be more
in line with the T30.
If the console is locked while the system is rebooted, the messages in
the temporary log buffer would not have propagated to all the console
drivers. This option forces the console lock to be released if it
failed to be acquired, which will cause all the pending messages to be
flushed. Enable this configuration option to be more in line with the
T30.
Get rid of the 2G/2G user/kernel memory split configuration in order to
use the default 3G/1G user/kernel memory split. This is more in line
with the T30 and avoids issues trying to run Android.
- enable couple of HID devices
- modify couple of BT options
Bug 1178960
Change-Id: Id9377edff2189d8a63f624d5d4e388e54658482f
Reviewed-on: http://git-master/r/167541
required for bluetooth
Bug 1033671
Change-Id: Ibc45eaf344ef7a5eea88e7df5747f8dcdcbf202d
Reviewed-on: http://git-master/r/166347
Enable CONFIG_SATA_AHCI_TEGRA
Bug 1171138
Change-Id: Id0cf3679a0fb0b85e20cd83c94135bf2aab2dd71
Original-author: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/143985
(cherry picked from commit 6830e27f86e0f3a2f1e3bad51ee2bf6855dc99b7)
Reviewed-on: http://git-master/r/166838
GVS: Gerrit_Virtual_Submit
Hack to force WIRELESS_EXT required to build Redpine Signals LiteFi driver.
Enable kernel configuration for USB audio.
As Colibris are usually self powered default drawn VBUS to 2 mA rather
than demanding 500 mA. This should fix it running from not self powered
USB hubs as well.
Activate Android rather than mass storage gadget driver to support
multiple USB functions. The functions can be configured via a board
file and may be enabled and disabled dynamically. E.g. the following
enables regular Ethernet aka RNDIS functionality once booted:
echo rndis > /sys/class/android_usb/android0/functions
echo 1 > /sys/class/android_usb/android0/enable
Activate Colibri rather than Tegra USB OTG driver as used on
Colibri T20 as well.
Add default kernel configuration in order to run oe-core on any of the
Colibri PXA series modules. So far no further platform data additions
have been committed meaning only older PXA270 v1.x, PXA300/310 v1.x or
PXA320 v1.x modules as anyway supported in mainline will work.
USB hubs as well.
Activate Android rather than Ethernet gadget driver to support multiple
USB functions. The functions can be configured via a board file and may
be enabled and disabled dynamically. E.g. the following enables regular
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Backlight PWM now runs at 1 kHZ rather than 500kHz.
Make PWM B, C, D accessible from userspace. e.g as /sys/class/leds/pwm_b.
Make PWM A or C a led PWM depending on MECS_TELLURIUM.
To avoid the following systemd failure and as recommended we activate
IPv6 kernel configuration straight from NVIDIA's tegra_defconfig.
[ 21.532106] systemd[1]: could not find module by name='ipv6'
[ 21.555061] systemd[1]: Failed to insert 'ipv6'
Bug 1029792
Change-Id: I8ee7190ccd50863f6f0f1aa216035afbae57ebcf
Reviewed-on: http://git-master/r/141631
CFG80211 is needed for WFD. So, use CFG80211,
instead of, WEXT in bcmdhd driver.
Bug 1029792
Bug 1029733
Change-Id: I81d99a821429f3be8400355faa5bee14904c0944
Reviewed-on: http://git-master/r/141630
Integrate ALSA SoC SGTL5000 codec on Toradex Colibri T30.
Tested on early prototype Colibri T30 V1.0a eMMC module.
Known issues:
- spurious boot hang after following kernel message
[ 5.595219] Timed out waiting for lock bit on pll pll_a
- no audio (SGTL5000) support integrated yet
- NAND detection/support disabled for now due to boot hang
- USB OTG support disabled for now due to boot hang
- trying to spawn L4T R16 X driver seems to hang
Note: requires uImage with adjusted entry point/load address as follows
mkimage -A arm -C none -O linux -T kernel -a 0x82008000 -e 0x82008000 -n 'Linux-3.1.10-colibri_t30' -d zImage uImage
Incorporate L4T R16 changes from NVIDIA Ventana.
Note: USB OTG port not functional as of yet.
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Re-enable USB Ethernet gadget.
Clean-up USB platform data.
Bug 1002637
Change-Id: I33d38ab3a5395f85564ef9a3282db152b4d79113
Signed-off-by: Seema Khowala <seemaj@nvidia.com>
Reviewed-on: http://git-master/r/127974
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Enable LP1 Core voltage settings to 950mV
The feature is added in the below change.
Refer to http://git-master/r/#change,124135 for more details.
Bug 1035684
Change-Id: I922efff17797f4666fd6ed069a8523c164445842
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
(cherry picked from commit 0f5d34db547ca6bfb9c0bae0b0048f58ba71c833)
Reviewed-on: http://git-master/r/124781
Enable TI TLV320AIC326X audio codec configuration.
Bug 1034241
Change-Id: I5997c365f6ae3fde12e40f3a157421b655bb054e
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125261
Reviewed-by: Simone Willett <swillett@nvidia.com>
Android jb need ip filters to be enabled
to track data uses.
Bug 1019233
Change-Id: I8073643a4a7c34e428c02682a3afc5a23fbcf344
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/122051
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Add a defconfig file for E1853 board
Bug 966833
Bug 1018258
Signed-off-by: Ashwin Joshi <asjoshi@nvidia.com>
Change-Id: I7cbde666acbe13fcaca2f56d877e0b4872756c17
Reviewed-on: http://git-master/r/118281
Tested-by: Ashwin Joshi <asjoshi@nvidia.com>
Reviewed-by: Bhavesh Parekh <bparekh@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
(cherry picked from commit 465ba7c85429964a7937a6683376d72e396ebe47)
Reviewed-on: http://git-master/r/119650
Enabling boost CPU frequency for tegra gadget
to improve USB performance.
Bug 1020850
Change-Id: Ic36686399f8ebd84c24f9d3cb73792ce3bef90be
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/120351
Enable device tree support for tegra2/tegra3 based android
platforms.
Bug 1001225
Change-Id: I5caf6302b88d30cca66bfdb957c5b4f1a575a634
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/110204
Enabling ISO9660 file system (and its JOLIET extension) support in
kernel.
Bug 1018276.
Change-Id: I1acaf5dc3a571b75a81860485d3c668ea82d822c
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/117372
Tested-by: Vishal Singh <vissingh@nvidia.com>
(cherry picked from commit c35638147c3fa9d56f124b4d6c0435aadad53d97)
bug 1025348
Change-Id: I0206c273af45b51fdd67e94c80f915a33950a929
Signed-off-by: Amlan Kundu <akundu@nvidia.com>
Even though config option is enabled, the fault injection is not
enabled by default. It need to be enabled through debugfs interface
during test.
Change-Id: Iaba52d27a97bc4ecdc04e79e29ab25e03438bbc0
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/116851
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
(cherry picked from commit 892f0239562de8cd5a6a93deeaec826e45b368b0)
Reviewed-on: http://git-master/r/118192
CONFIG_TEGRA_CBUS_CLOCK_DIVIDER=1
* Disabled CONFIG_TEGRA_SE_ON_CBUS
So that se clock can be derived from clocks
other than which are driving cbus.
* Changed CONFIG_TEGRA_CBUS_CLOCK_DIVIDER=1
So that pllc can run at same frequency as
cbus is running at.
Bug 978870
Change-Id: I66898e3f16adad3625efb1a484b438c168419a68
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/117995
(cherry picked from commit b5d42b0432119ddebcc38f6f40761e3dea3d9f6d)
Reviewed-on: http://git-master/r/117312
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This is a copy of p1852 defconfig with usb support disabled
Bug 989824
Change-Id: I40089049a35c18782b2e211b63d20fafe8fb9ee8
Reviewed-on: http://git-master/r/114138
Tested-by: Sanjay Sancheti <sasancheti@nvidia.com>
Reviewed-by: Amlan Kundu <akundu@nvidia.com>
(cherry picked from commit a147ad51d486d4aea9a73a11d4c14a13ad2121bb)
Reviewed-on: http://git-master/r/118011
Enable regualtor REGULATOR_TPS51632 which is used
for cpu regulator.
Change-Id: I5ba78608e6c5480e8b0d8d54ee59c9bba0b58428
Reviewed-on: http://git-master/r/117602
Enables the IrDA support on E1198 and E1186 platforms.
This will enable the access to the IrDA transceiver through
(/dev/ttyHS1) UARTB of verbier (E1240).
Bug 999895
Change-Id: Ib2b8391facddf12b3b48d319e11f548d9f963712
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/114952
Optimise kernel configuration in the following areas:
- limit CGROUP options
- OPTIMIZE_FOR_SIZE
- no more HARMONY, VENTANA, KAEN, PAZ00, TRIMSLICE, WARIO or WHISTLER specific HW support
- ARM_ERRATA_752520
- VMSPLIT_2G
- no more IP_MULTICAST, IP_PNP_BOOTP, IP_PNP_RARP, TCP_CONG_ADVANCED or IPV6 support
- no more NETFILTER_XT support
- support Ambicom WL250N-USB Wireless 802.11b/g/n (V1.0a) with Ralink RT3070 chipset (Note: proprietary rt2870.bin firmware required)
- UBI support
- no more CONFIG_MD or CONFIG_DM support
- no more CONFIG_PPP_FILTER or CONFIG_PPP_SYNC_TTY support
- no more legacy joystick and PS/2 keyboard/mouse support
- provision for external octal UART support
- provision for analog input support
- no more CONFIG_TEGRA_CAMERA or CONFIG_TEGRA_DTV support
- no more CONFIG_TEGRA_DSI or CONFIG_TEGRA_NVHDCP support
- no more CONFIG_LCD_CLASS_DEVICE support
- CONFIG_HIDRAW and CONFIG_USB_HIDDEV required for Toradex Oak
- CONFIG_USB_SERIAL_GENERIC instead of CONFIG_USB_SERIAL_OPTION
- CONFIG_USB_ETH failed to build
- no more CONFIG_MMC_TEST support
- no more CONFIG_MSDOS_FS support
- no more CONFIG_LOCKUP_DETECTOR, CONFIG_DEBUG_SLAB, CONFIG_DEBUG_MUTEXES or CONFIG_DEBUG_SG support
- no more CONFIG_CRYPTO_TEST support
Change-Id: I6b6348ec3b604bbf9b8e40fe551023cf94b0b153
Reviewed-on: http://git-master/r/117083
