path: root/arch/arm/configs
2013-01-23ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfigNicolas Ferre
Reported-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-01-23ARM: at91/at91_dt_defconfig: remove memory specification to cmdlineNicolas Ferre
No need for this cmdline option as we are using DT. Moreover this defconfig is targeted to multiple SoC/boards: this option was nonsense. Reported-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-01-06arm: mvebu: Use dw-apb-uart instead of ns16650 as UART driverGregory CLEMENT
The UART controller used in the Armada 370 and Armada XP SoCs is the Synopsys DesignWare 8250 (aka Synopsys DesignWare ABP UART). The improper use of the ns16550 can lead to a kernel oops during boot if a character is sent to the UART before the initialization of the driver. The DW APB has an extra interrupt that gets raised when writing to the LCR when busy. This explains why we need to use dw-apb-uart driver to handle this. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-12-30Merge tag 'omap-late-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM cleanups for omap from Olof Johansson: "From Tony Lindgren: Here are few more patches to finish the omap changes for multiplatform conversion that are not strictly fixes, but were too complex to do with the dependencies during the merge window. Those are to move of serial-omap.h to platform_data, and the removal of remaining cpu_is_omap macro usage outside mach-omap2. Then there are several trivial fixes for typos and few minimal omap2plus_defconfig updates." * tag 'omap-late-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arch/arm/mach-omap2/dpll3xxx.c: drop if around WARN_ON OMAP2: Fix a typo - replace regist with register. ARM/omap: use module_platform_driver macro ARM: OMAP2+: PMU: Remove unused header ARM: OMAP4: remove duplicated include from omap_hwmod_44xx_data.c ARM: OMAP2+: omap2plus_defconfig: enable twl4030 SoC audio ARM: OMAP2+: omap2plus_defconfig: Add tps65217 support ARM: OMAP2+: enable devtmpfs and devtmpfs automount ARM: OMAP2+: omap_twl: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER ARM: OMAP2+: Drop plat/cpu.h for omap2plus ARM: OMAP: Split fb.c to remove last remaining cpu_is_omap usage MAINTAINERS: Add an entry for omap related .dts files
2012-12-23ARM: multi_v7_defconfig: Add ARCH_SUNXIMaxime Ripard
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2012-12-19Merge tag 'for-linus-20121219' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from David Woodhouse: - Various cleanups especially in NAND tests - Add support for NAND flash on BCMA bus - DT support for sh_flctl and denali NAND drivers - Kill obsolete/superceded drivers (fortunet, nomadik_nand) - Fix JFFS2 locking bug in ENOMEM failure path - New SPI flash chips, as usual - Support writing in 'reliable mode' for DiskOnChip G4 - Debugfs support in nandsim * tag 'for-linus-20121219' of git://git.infradead.org/linux-mtd: (96 commits) mtd: nand: typo in nand_id_has_period() comments mtd: nand/gpio: use io{read,write}*_rep accessors mtd: block2mtd: throttle writes by calling balance_dirty_pages_ratelimited. mtd: nand: gpmi: reset BCH earlier, too, to avoid NAND startup problems mtd: nand/docg4: fix and improve read of factory bbt mtd: nand/docg4: reserve bb marker area in ecclayout mtd: nand/docg4: add support for writing in reliable mode mtd: mxc_nand: reorder part_probes to let cmdline override other sources mtd: mxc_nand: fix unbalanced clk_disable() in error path mtd: nandsim: Introduce debugfs infrastructure mtd: physmap_of: error checking to prevent a NULL pointer dereference mtg: docg3: potential divide by zero in doc_write_oob() mtd: bcm47xxnflash: writing support mtd: tests/read: initialize buffer for whole next page mtd: at91: atmel_nand: return bit flips for the PMECC read_page() mtd: fix recovery after failed write-buffer operation in cfi_cmdset_0002.c mtd: nand: onfi need to be probed in 8 bits mode mtd: nand: add NAND_BUSWIDTH_AUTO to autodetect bus width mtd: nand: print flash size during detection mted: nand_wait_ready timeout fix ...
2012-12-17ARM: OMAP2+: omap2plus_defconfig: enable twl4030 SoC audioJavier Martinez Canillas
Many TI OMAP SoC based boards that uses twl4030 as codec have been updated to use the unified audio driver (omap-twl4030) since they have similar audio setup. So, is good to have it built to add audio support to these boards. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-17ARM: OMAP2+: omap2plus_defconfig: Add tps65217 supportAnilKumar Chimata
TPS65217 is described in arch/arm/boot/dts/am335x-bone.dts but doesn't enabled in arch/arm/configs/omap2plus_defconfig. Enable TPS65217 support in omap2plus_defconfig. Signed-off-by: Igor Mazanov <i.mazanov@gmail.com> Signed-off-by: AnilKumar Ch <anilkumar@ti.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-17ARM: OMAP2+: enable devtmpfs and devtmpfs automountJavier Martinez Canillas
Since udev-182, udev no longer creates device nodes under /dev and this has to be managed by the kernel devtmpfs filesystem. This means that a kernel built with the current OMAP2+ config will not boot on a system with a recent udev. Also, it is good to have /dev automatically mounted since some non-initramfs based setups assumes this and don't manually mount it. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Santosh Shilimkar<santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-12-14Merge tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM Soc updates, take 2, from Olof Johansson: "This is the second batch of SoC updates for the 3.8 merge window, containing parts that had dependencies on earlier branches such that we couldn't include them with the first branch. These are general updates for Samsung Exynos, Renesas/shmobile and a topic branch that adds SMP support to Altera's socfpga platform." Fix up conflicts mostly as per Olof. * tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: EXYNOS: Clock settings for SATA and SATA PHY ARM: EXYNOS: Add ARM down clock support ARM: EXYNOS: Fix i2c suspend/resume for legacy controller ARM: EXYNOS: Add aliases for i2c controller ARM: EXYNOS: Setup legacy i2c controller interrupts sh: clkfwk: fixup unsed variable warning Revert "ARM: shmobile: r8a7779: Replace modify_scu_cpu_psr with scu_power_mode" Revert "ARM: shmobile: sh73a0: Replace modify_scu_cpu_psr with scu_power_mode" Revert "ARM: shmobile: emev2: Replace modify_scu_cpu_psr with scu_power_mode" ARM: highbank: use common debug_ll_io_init ARM: shmobile: sh7372: sh7372_fsiXck_clk become non-global ARM: shmobile: sh7372: remove fsidivx clock ARM: socfpga: mark secondary_trampoline as cpuinit socfpga: map uart into virtual address space so that early_printk() works ARM: socfpga: fix build break for allyesconfig ARM: socfpga: Enable SMP for socfpga ARM: EXYNOS: Add dp clock support for EXYNOS5 ARM: SAMSUNG: call clk_get_rate for debugfs rate files ARM: SAMSUNG: add clock_tree debugfs file in clock
2012-12-14ARM: arm-soc: Merge branch 'next/smp' into next/soc2Olof Johansson
Merging in the smp-on-socfpga branch into soc2 since the topics are similar and it's a short branch in the first place. * next/smp: ARM: socfpga: mark secondary_trampoline as cpuinit socfpga: map uart into virtual address space so that early_printk() works ARM: socfpga: fix build break for allyesconfig ARM: socfpga: Enable SMP for socfpga Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-13Merge tag 'boards2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board updates, take 2 from Olof Johansson: "This branch contains board updates for shmobile that had dependencies on earlier branches past the first driver branch, and thus are merged separately. Most of these are to enable audio and USB on shmobile. They contain a dependent ASoC branch that has been coordinated with Mark Brown." * tag 'boards2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: shmobile: mackerel: Add FLCTL IRQ resource ARM: shmobile: use FSI driver's audio clock on ap4evb ARM: shmobile: use FSI driver's audio clock on mackerel ARM: shmobile: use FSI driver's audio clock on armadillo800eva ARM: shmobile: mackerel: enable DMAEngine on USB Host ARM: shmobile: marzen: add USB OHCI driver support ARM: shmobile: marzen: add USB EHCI driver support ARM: shmobile: marzen: add USB phy support ASoC: fsi: add master clock control functions ASoC: fsi: care fsi_hw_start/stop() return value ASoC: fsi: fsi_set_master_clk() was called from fsi_hw_xxx() only ASoC: fsi: use devm_request_irq() ASoC: fsi: fixup channels_min/max
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board updates from Olof Johansson: "This branch contains a set of various board updates for ARM platforms. A few shmobile platforms that are stale have been removed, some defconfig updates for various boards selecting new features such as pinctrl subsystem support, and various updates enabling peripherals, etc." Fix up conflicts mostly as per Olof. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits) ARM: S3C64XX: Add dummy supplies for Glenfarclas LDOs ARM: S3C64XX: Add registration of WM2200 Bells device on Cragganmore ARM: kirkwood: Add Plat'Home OpenBlocks A6 support ARM: Dove: update defconfig ARM: Kirkwood: update defconfig for new boards arm: orion5x: add DT related options in defconfig arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device Tree arm: orion5x: basic Device Tree support arm: orion5x: mechanical defconfig update ARM: kirkwood: Add support for the MPL CEC4 arm: kirkwood: add support for ZyXEL NSA310 ARM: Kirkwood: new board USI Topkick ARM: kirkwood: use gpio-fan DT binding on lsxl ARM: Kirkwood: add Netspace boards to defconfig ARM: kirkwood: DT board setup for Network Space Mini v2 ARM: kirkwood: DT board setup for Network Space Lite v2 ARM: kirkwood: DT board setup for Network Space v2 and parents leds: leds-ns2: add device tree binding ARM: Kirkwood: Enable the second I2C bus ARM: mmp: select pinctrl driver ...
2012-12-12Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates from Olof Johansson: "This contains the bulk of new SoC development for this merge window. Two new platforms have been added, the sunxi platforms (Allwinner A1x SoCs) by Maxime Ripard, and a generic Broadcom platform for a new series of ARMv7 platforms from them, where the hope is that we can keep the platform code generic enough to have them all share one mach directory. The new Broadcom platform is contributed by Christian Daudt. Highbank has grown support for Calxeda's next generation of hardware, ECX-2000. clps711x has seen a lot of cleanup from Alexander Shiyan, and he's also taken on maintainership of the platform. Beyond this there has been a bunch of work from a number of people on converting more platforms to IRQ domains, pinctrl conversion, cleanup and general feature enablement across most of the active platforms." Fix up trivial conflicts as per Olof. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits) mfd: vexpress-sysreg: Remove LEDs code irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids irq: versatile: delete dangling variable ARM: sunxi: add missing include for mdelay() ARM: EXYNOS: Avoid early use of of_machine_is_compatible() ARM: dts: add node for PL330 MDMA1 controller for exynos4 ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412 ARM: EXYNOS: add UART3 to DEBUG_LL ports ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers ARM: sunxi: Add missing sun4i.dtsi file pinctrl: samsung: Do not initialise statics to 0 ARM i.MX6: remove gate_mask from pllv3 ARM i.MX6: Fix ethernet PLL clocks ARM i.MX6: rename PLLs according to datasheet ARM i.MX6: Add pwm support ARM i.MX51: Add pwm support ARM i.MX53: Add pwm support ARM: mx5: Replace clk_register_clkdev with clock DT lookup ...
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-12-12Merge tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC Header cleanups from Olof Johansson: "This is a collection of header file cleanups, mostly for OMAP and AT91, that keeps moving the platforms in the direction of multiplatform by removing the need for mach-dependent header files used in drivers and other places." Fix up mostly trivial conflicts as per Olof. * tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits) ARM: OMAP2+: Move iommu/iovmm headers to platform_data ARM: OMAP2+: Make some definitions local ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h ARM: OMAP2+: Move iopgtable header to drivers/iommu/ ARM: OMAP: Merge iommu2.h into iommu.h atmel: move ATMEL_MAX_UART to platform_data/atmel.h ARM: OMAP: Remove omap_init_consistent_dma_size() arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig ARM: OMAP: Remove NEED_MACH_GPIO_H ARM: OMAP: Remove unnecessary mach and plat includes ...
2012-12-12Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management update from Zhang Rui: "Highlights: - Introduction of thermal policy support, together with three new thermal governors, including step_wise, user_space, fire_share. - Introduction of ST-Ericsson db8500_thermal driver and ST-Ericsson db8500_cpufreq_cooling driver. - Thermal Kconfig file and Makefile refactor. - Fixes for generic thermal layer, generic cpucooling, rcar thermal driver and Exynos thermal driver." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (36 commits) Thermal: Fix DEFAULT_THERMAL_GOVERNOR Thermal: fix a NULL pointer dereference when generic thermal layer is built as a module thermal: rcar: add rcar_zone_to_priv() macro thermal: rcar: fixup the unit of temperature thermal: cpu cooling: allow module builds thermal: cpu cooling: use const parameter while registering Thermal: Add ST-Ericsson DB8500 thermal properties and platform data. Thermal: Add ST-Ericsson DB8500 thermal driver. drivers/thermal/Makefile refactor Exynos: Add missing dependency Refactor drivers/thermal/Kconfig thermal: cpu_cooling: Make 'notify_device' static Thermal: Remove the cooling_cpufreq_list. Thermal: fix bug of counting cpu frequencies. Thermal: add indent for code alignment. thermal: rcar_thermal: remove explicitly used devm_kfree/iounap() thermal: user_space: Add missing static storage class specifiers thermal: fair_share: Add missing static storage class specifiers thermal: step_wise: Add missing static storage class specifiers Thermal: Fix oops and unlocking in thermal_sys.c ...
2012-12-11Merge tag 'usb-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big set of USB patches for 3.8-rc1. Lots of USB host driver cleanups in here, and a bit of a reorg of the EHCI driver to make it easier for the different EHCI platform drivers to all work together nicer, which was a reduction in overall code. We also deleted some unused firmware files, and got rid of the very old file_storage usb gadget driver that had been broken for a long time. This means we ended up removing way more code than added, always a nice thing to see: 310 files changed, 3028 insertions(+), 10754 deletions(-) Other than that, the usual set of new device ids, driver fixes, gadget driver and controller updates and the like. All of these have been in the linux-next tree for a number of weeks. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (228 commits) USB: mark uas driver as BROKEN xhci: Add Lynx Point LP to list of Intel switchable hosts uwb: fix uwb_dev_unlock() missed at an error path in uwb_rc_cmd_async() USB: ftdi_sio: Add support for Newport AGILIS motor drivers MAINTAINERS: remove drivers/block/ub.c USB: chipidea: fix use after free bug ezusb: add dependency to USB usb: ftdi_sio: fixup BeagleBone A5+ quirk USB: cp210x: add Virtenio Preon32 device id usb: storage: remove redundant memset() in usb_probe_stor1() USB: option: blacklist network interface on Huawei E173 USB: OHCI: workaround for hardware bug: retired TDs not added to the Done Queue USB: add new zte 3g-dongle's pid to option.c USB: opticon: switch to generic read implementation USB: opticon: refactor reab-urb processing USB: opticon: use usb-serial bulk-in urb USB: opticon: increase bulk-in size USB: opticon: use port as urb context USB: opticon: pass port to get_serial_info USB: opticon: make private data port specific ...
2012-11-26Merge tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux ↵Olof Johansson
into next/dt From Jason Cooper: orion dt for v3.8 - ehci-orion dt binding - gpio-poweroff - use dt regulators - move mpp to DT/pinctrl Depends on: - orion/boards - merge conflicts - keep all 'select's in Kconfig - remove all #includes in board-*.c - pinctrl/devel up to: - 06763c7 pinctrl: mvebu: move to its own directory * tag 'orion_dt_for_3.8' of git://git.infradead.org/users/jcooper/linux: (211 commits) ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ARM: Kirkwood: Convert dnskw to pinctrl ARM: Kirkwood: Convert iConnect to pinctrl. ARM: Kirkwood: Convert TS219 to pinctrl. ARM: Kirkwood: Add DTSI files for pinctrl ARM: Kirkwood: Make use of mvebu pincltl and gpio drivers ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-26Merge tag 'orion_boards_for_3.8' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into next/boards From Jason Cooper: orion boards for v3.8 - mach-orion5x/ joins the dark side! (devicetree) - Lacie Network Space family - Lacie Ethernet Disk mini v2 - USI TopKick - ZyXEL NSA310 - MPL CEC4 - Plat'Home OpenBlocks A6 (kirkwood, AX3-4 is armada xp) * tag 'orion_boards_for_3.8' of git://git.infradead.org/users/jcooper/linux: ARM: kirkwood: Add Plat'Home OpenBlocks A6 support ARM: Dove: update defconfig ARM: Kirkwood: update defconfig for new boards arm: orion5x: add DT related options in defconfig arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device Tree arm: orion5x: basic Device Tree support arm: orion5x: mechanical defconfig update ARM: kirkwood: Add support for the MPL CEC4 arm: kirkwood: add support for ZyXEL NSA310 ARM: Kirkwood: new board USI Topkick ARM: kirkwood: use gpio-fan DT binding on lsxl ARM: Kirkwood: add Netspace boards to defconfig ARM: kirkwood: DT board setup for Network Space Mini v2 ARM: kirkwood: DT board setup for Network Space Lite v2 ARM: kirkwood: DT board setup for Network Space v2 and parents leds: leds-ns2: add device tree binding ARM: Kirkwood: Enable the second I2C bus
2012-11-25Merge tag 'imx-defconfig' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Olof Johansson
next/boards From Sascha Hauer: ARM i.MX specific defconfig updates * tag 'imx-defconfig' of git://git.pengutronix.de/git/imx/linux-2.6: ARM: imx: configs: Enable CONFIG_MEDIA_CAMERA_SUPPORT ARM: imx_v6_v7_defconfig: Add DA9052 regulator support
2012-11-22ARM: kirkwood: Add Plat'Home OpenBlocks A6 supportNobuhiro Iwamatsu
Add support for Plat'Home OpenBlocks A6 using the device tree where possible. This commit supports SATA, USB, ether and serial console. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-22Merge tag 'marvell-openblocks-i2c-sata-for-3.8' of ↵Jason Cooper
git://github.com/MISL-EBU-System-SW/mainline-public into mvebu/everything Marvell SATA and I2C enabling for OpenBlocks AX3-4
2012-11-21ARM: mvebu: update defconfig with I2C and RTC supportThomas Petazzoni
Now that we have support for the I2C busses on Armada 370/XP, and support for the RTC on the OpenBlocks AX3-4 platform, include the necessary options in mvebu_defconfig. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-21ARM: Dove: update defconfigSebastian Hesselbarth
It has been a while since dove_defconfig was updated to recent development. This patch adds all currently available Dove boards, including a DT-enabled machine. DT support requires to allow ATAGS passed by boot loader as most of them are not yet capable of passing DT blobs. Also OF_SERIAL is enabled to actually see the bootlog. Finally, sdhci driver for Dove, mv_cesa, GPIO LEDs, and highmem support is added. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: Kirkwood: update defconfig for new boardsJason Cooper
MPLCEC4_DT is relocated because it had been added manually. Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21arm: orion5x: add DT related options in defconfigThomas Petazzoni
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21arm: orion5x: mechanical defconfig updateThomas Petazzoni
This commit is a simple mechanical update of the orion5x_defconfig file to the current kernel (i.e, just 'make orion5x_defconfig; make savedefconfig'). Doing this update allows to more easily separate DT-related configuration changes in the following patches. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: kirkwood: Add support for the MPL CEC4Stefan Peter
Signed-off-by: Stefan Peter <s.peter@mpl.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: Kirkwood: new board USI TopkickJason Cooper
This is a new kirkwood box made by Universal Scientific Industrial, Inc. The product description is here: http://www.usish.com/english/products_topkick1281p2.php It is very similar to the dreamplug and other plug devices, with the exception that it has room for a 2.5" SATA HDD internally. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2012-11-21ARM: Kirkwood: add Netspace boards to defconfigJason Cooper
2012-11-21Merge tag 'marvell-armadaxp-smp-for-3.8' of ↵Jason Cooper
git://github.com/MISL-EBU-System-SW/mainline-public into mvebu/everything SMP support for Armada XP The purpose of this series is to add the SMP support for the Armada XP SoCs. Beside the SMP support itself brought by the last 3 commits, this series also adds the support for the coherency fabric unit and the power management service unit. The coherency fabric is responsible for ensuring hardware coherency between all CPUs and between CPUs and I/O masters. This unit is also available for Armada 370 and will be used in an incoming patch set for hardware I/O cache coherency. The power management service unit is responsible for powering down and waking up CPUs and other SOC units.
2012-11-21Merge tag 'marvell-net-xor-defconfig-for-3.8' of ↵Jason Cooper
git://github.com/MISL-EBU-System-SW/mainline-public into mvebu/everything Marvell mvebu defconfig updates for 3.8 Conflicts: arch/arm/configs/mvebu_defconfig
2012-11-21Merge branch 'clps711x/soc2' into next/socOlof Johansson
From Alexander Shiyan: The main direction of this patchset - approaching the platform to the possibility of using configurations with multiple platforms in a single kernel. Added support of the majority of the necessary kernel symbol. Also part of the driver code used only for the platform was moved to the board code and converted to the use of standard drivers. * clps711x/soc2: MAINTAINERS: Add ARM CLPS711X entry ARM: clps711x: Update defconfig due latest changes and new kernel symbols ARM: clps711x: Rename board files to match functionality ARM: clps711x: edb7211: Add support for NOR-Flash ARM: clps711x: Moving backlight controls of framebuffer driver to the board ARM: clps711x: p720t: Special driver for handling NAND memory is removed ARM: clps711x: Moving power management of framebuffer driver to the board ARM: clps711x: autcpu12: Special driver for handling NAND memory is removed ARM: clps711x: Unused empty "ACK" calls for IRQ-chips removed ARM: clps711x: Add FIQ interrupt handling ARM: clps711x: Implement usage "MULTI_IRQ_HANDLER" kernel option for a platform ARM: clps711x: Implement usage "SPARSE_IRQ" kernel option for a platform ARM: clps711x: cdb89712: Special driver for handling memory is removed ARM: clps711x: Always select AUTO_ZRELADDR for a platform ARM: clps711x: p720t: Unneeded inclusion of head-sa1100.S removed ARM: clps711x: Transform clps711x-framebuffer to platform driver and use it ARM: clps711x: p720t: Using "leds-gpio" driver for LED control ARM: clps711x: Using platform_driver for ethernet device
2012-11-21ARM: clps711x: Update defconfig due latest changes and new kernel symbolsAlexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21arm: mvebu: Add SMP support for Armada XPGregory CLEMENT
This enables SMP support on the Armada XP processor. It adds the mandatory functions to support SMP such as: the SMP initialization functions in platsmp.c, the secondary CPU entry point in headsmp.S and the CPU hotplug initial support in hotplug.c. Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Reviewed-by: Will Deacon <will.deacon@arm.com>
2012-11-21Merge tag 'bcm2835-for-3.8-defconfig' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi into next/soc From Stephen Warren: ARM: bcm2835: defconfig updates procfs and sysfs are enabled in bcm2835_defconfig. * tag 'bcm2835-for-3.8-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi: ARM: bcm2835: enable procfs and sysfs in defconfig Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-21Merge tag 'tegra-for-3.8-defconfig' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/soc From Stephen Warren: ARM: tegra: defconfig update Many new features are enabled in tegra_defconfig: * BRCMFMAC: wlan driver, enable as module. * MTD, MTD_CHAR, MTD_M25P80, SPI_TEGRA20_SLINK, CONFIG_SPI_TEGRA20_SFLASH to enable serial flash on Cardhu and TrimSlice. * PWM/backlight features for use with tegradrm. * tegradrm; Tegra's new display driver. * CMA, so that tegradrm can allocate large buffers. * SquashFS, which is used as the root filesystem on boards based on the Tamonten processor module. * tag 'tegra-for-3.8-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: ARM: tegra: defconfig updates
2012-11-20Merge tag 'marvell-net-xor-defconfig-for-3.8' of ↵Thomas Petazzoni
github.com:MISL-EBU-System-SW/mainline-public into test-the-merge Marvell mvebu defconfig updates for 3.8 Conflicts: arch/arm/configs/mvebu_defconfig Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: mvebu: update defconfig to include XOR driverThomas Petazzoni
2012-11-20arm: mvebu: update defconfig to include network driverThomas Petazzoni
2012-11-20arm: mvebu: SATA support: mvebu_defconfig updateGregory CLEMENT
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Lior Amsalem <alior@marvell.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-19Add support for generic BCM SoC chipsetsChristian Daudt
In order to start upstreaming Broadcom SoC support, create a starting hierarchy, arch and dts files. The first support SoC family that is planned is the BCM281XX (BCM11130/11140/11351/28145/28155) family of dual A9 mobile SoC cores. This code is just the skeleton code for get the machine upstreamed. It has been made MULTIPLATFORM compatible. Next steps ---------- Upstream a basic set of drivers - sufficient for a console boot to ramdisk. These will includer timer, gpio, i2c drivers. After this basic set, we will proceed with a more comprehensive set of drivers for the 281XX SoC family. v2 patch mods -------- - Remove l2x0_of_init call as there were problems with the code. A separate patch will be submitted with cache init code - Rename capri files and refs to bcm281xx-based names - Add bcm281xx binding doc - various misc cleanups v3 patch mods ------------- - Remove extra #include lines - Remove remaining references to capri - dt uart chipset string added - cleaned up chip # references v4 patch mods ------------- - swap order of compatible definitions for uart - fix typo v5 patch mods ------------- - Rename bcm281xx to bcm11351 in dts+code, leaving references to bcm281xx only in help+comments. v6 patch mods ------------- - fix typo in uart 'compatible' string Signed-off-by: Christian Daudt <csd@broadcom.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-19Merge tag 'davinci-for-v3.8/defconfig' of ↵Olof Johansson
git://gitorious.org/linux-davinci/linux-davinci into next/boards From Sekhar Nori: This change enables DT related options in DA8XX defconfig. * tag 'davinci-for-v3.8/defconfig' of git://gitorious.org/linux-davinci/linux-davinci: ARM: davinci: da8xx defconfig: enable DT config options Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-16Merge tag 'mxs-dt-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo <shawn.guo@linaro.org>: It's mxs device tree changes for 3.8. The majority is device tree source updates. One timer improvement and one defconfig update are also included there. * tag 'mxs-dt-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs_defconfig: Improve USB related support ARM: mxs: apf28dev: Add I2C and SPI support ARM: mxs: Setup scheduler clock ARM: dts: mxs: Add hog pins to Crystalfontz boards ARM: dts: cfa10036: Use pinctrl for power led ARM: mxs: apf28dev: Add LCD and backlight support ARM: mxs: apf28dev: Add pinctrl and gpios ARM: dts: mxs: Add 16 bits LCD screen muxing options for I.MX28 ARM: dts: cfa10049: Add the DH2228FV DAC to the DTS ARM: mxs: Add support for the Armadeus Systems APF28Dev docking board ARM: mx28: Skip OCOTP FEC MAC setup if in DT ARM: dts: mxs: Add PWM3 muxing options for i.MX28 ARM: mxs: Add support for the Armadeus Systems APF28 module ARM: dts: cfa10049: Add FEC to the CFA-10049 expansion board ARM: dts: imx23-olinuxino: Use pinctrl for gpio-led ARM: dts: imx23-olinuxino: Remove unneeded "default-on" ARM: dts: imx28-evk: Use pinctrl for gpio-led Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16Merge tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6 into next/dtArnd Bergmann
From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX dt updates for 3.8 * tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6: Add device tree file for the armadeus apf27 ARM i.MX: Add Ka-Ro TX25 devicetree ARM i.MX25: Add devicetree ARM i.MX25: Add devicetree support ARM i.MX25: Add missing clock gates Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16Merge tag 'imx-soc' of git://git.pengutronix.de/git/imx/linux-2.6 into next/socArnd Bergmann
From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX SoC updates based on imx-multiplatform branch. * tag 'imx-soc' of git://git.pengutronix.de/git/imx/linux-2.6: ARM i.MX51 babbage: Add display support ARM i.MX6: Add IPU support ARM i.MX51: Add IPU support ARM i.MX53: Add IPU support ARM i.MX5: switch IPU clk support to devicetree bindings ARM i.MX6: fix ldb_di_sel mux ARM i.MX51: setup MIPI during startup mx2_camera: Fix regression caused by clock conversion ARM: clk-imx27: Add missing clock for mx2-camera ARM i.MX27: Fix low reference clock path ARM: dts: imx27-3ds: Remove local watchdog inclusion watchdog: Support imx watchdog on SOC_IMX53 ARM: mach-imx: Support for DryIce RTC in i.MX53 ARM : i.MX27 : split code for allocation of ressources of camera and eMMA Signed-off-by: Arnd Bergmann <arnd@arndb.de>
