Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
There where some defconfigs missed in the commit with the same name
before, correct that.
No options where added or removed in this commit. A simple
make (apalis|colibri)*_defconfig
make savedefconfig
cp defconfig arch/arm/boot/(apalis|colibri)*_defconfig
For iptables filtering to work we need the NF_FILTER kernel module.
The device tree got changed to use the simple card driver, so enable it
in the defconfig.
While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver.
While at it remove the unused ESAI driver.
While at it remove the unused CS42XX8_I2C codec driver.
Disable regulator framework debug messages by default again.
Disable regulator framework debug messages by default.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Signed-off-by: Daniel Kochmanski <dkochmanski@antmicro.com>
(cherry picked from commit 0bd6f13290225efd486da3c5521a458589c0bcf1)
(cherry picked from commit 1bc66f0fb5882f76e8aa9c9893b2274d27db8c13)
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
(cherry picked from commit 7dab0a33abd6c0dfcad045adce704f877f4a9aee)
(cherry picked from commit d2c6b6bc0634afbcd1e9f9c9433827595d78d137)
This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
commit 015664d15270a112c2371d812f03f7c579b35a73 upstream.
The Rio500 kernel driver has not been used by Rio500 owners since 2001
not long after the rio500 project added support for a user-space USB stack
through the very first versions of usbdevfs and then libusb.
Support for the kernel driver was removed from the upstream utilities
in 2008:
https://gitlab.freedesktop.org/hadess/rio500/commit/943f624ab721eb8281c287650fcc9e2026f6f5db
Cc: Cesar Miquel <miquel@df.uba.ar>
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/6251c17584d220472ce882a3d9c199c401a51a71.camel@hadess.net
Enable more kernel configs to support AWS Greengrass.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
i.MX7ULP EVKB board use GOODIX 911 touch chip, so default build in
the GOODIX touch driver.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
The Driver IC 'RM68191' is used in the MIPI panel
'RK055IQH042' whose default mode is '540x960@60Hz'.
So this commit adds a new FBDEV driver for 'RM68191'
and enables the 'RK055IQH042' panel on IMX7ULP1-EVKB
platform with Northwest MIPI DSI controller.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
The Driver IC 'RM68200' is used in the MIPI panel
'RK055AHD042' whose default mode is '720x1280@60Hz'.
So this commit adds a new FBDEV driver for 'RM68200'
and enables the 'RK055AHD042' panel on IMX7ULP1-EVKB
Add spi slave mode and enable spi slave time/system control
functions.
Example for SPI slave time:
SLAVE: # echo spi-slave-time > /sys/class/spi_slave/spi0/slave
MASTER: # spidev_test -D /dev/spidev0.0 -p dummy-8B -v
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
RX | 00 00 04 6D 00 09 5B BB __ __ __ __ __ __ __ _...
seconds microseconds
Example for SPI slave system control:
SLAVE: # echo spi-slave-system-control >
BOTH: # reboot='\x7c\x50'
BOTH: # poweroff='\x71\x3f'
BOTH: # halt='\x38\x76'
BOTH: # suspend='\x1b\x1b'
MASTER: # spidev_test -D /dev/spidev0.0 -p $suspend
or $reboot, $poweroff, $halt
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
Port imx_4.9.y vivante drm driver to 4.14 kernel.
Date: Jul 13, 2018
Signed-off-by Yong Gan <yong.gan@ncp.com>
Upstream added i2c-mux-gpio to imx6qdl-sabreauto and CONFIG_I2C_MUX_GPIO
to imx_v6_v7_defconfig. We need to copy this to imx_v7_defconfig or
several devices won't probe.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
Enable regulatory rules database config:
CONFIG_CFG80211_INTERNAL_REGDB
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Reviewed-by: Haibo Chen <haibo.chen@nxp.com>
set GPU baseAddress with 256M on IMX6Q and iMX6QP,
add reserved cma in DTB to support different size,
the default cma size is 320M on all imx6 boards.
integrated patches from imx_4.9.y:
1.MGS-955 GPU:Integrate GPU module
commit: 73183c14a20d4f1d02317f80db3d90b3be1546fc
2.MGS-1211 gpu: add GPU for 6sl,6sx,6dl
commit: 80a8994c47cbb97fb31ef0efab92ddb29002448e
3.MGS-1087 gpu: Move the GPU reserved memory to DTS file
commit: ea0111da6892b52c790da607a3d91140d1ebf936
4.MGS-2540 [#ccc] Need set baseAddress with RAM start address on IMX6Q
commit: de838d99d9264884cbaaa601ab323a70b62634d9
Signed-off-by: Xianzhong <xianzhong.li@nxp.com>
Enable the AHCI_IMX defaultly in imx_v7_defconfig
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Add rpmsg input config enable for i.MX7ULP.
Reviewed-by: Elven Wang <elven.wang@nxp.com>
Add wireless HOSTAP config enable for i.MX7ULP Murata 1PJ (Qca9377-3).
Reviewed-by: Gao Pan <pandy.gao@nxp.com>
To enable SIMv2 for imx6ul/imx7d, both CONFIG_MXC_SIMv2
and CONFIG_ARCH_MXC have to be enabled.
This patch enables these two config in imx_v7_defconfig for
SIMv2 support.
Signed-off-by: Gao Pan <pandy.gao@nxp.com>
Reviewed-by: Andy Duan <fugang.duan@nxp.com>
Enable rpmsg rtc by default.
Reviewed-by: Bai Ping <ping.bai@nxp.com>
Default enable PSCI and TEE.
If no psci optee node in dts, it works as before.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Enable CONFIG_GPIO_IMX_RPMSG to support rpmsg gpio driver in default.
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Robin Gong <yibin.gong@nxp.com>
Commit 556fa2d7d7e9 ("ENGR00318895-9: mtd: spi-nor: add more read
transfer flags for n25q256a") was incompletely cherry-picked, leaving
out the removal of the SECT_4K flag:
"From the datasheet, the chip support the 64K sector erase operation.
So remove the SECT_4K for the chip which makes the flash_erase
faster."
However, the above statement is not entirely correct. Using SECT_4K
can result in faster erase operations, if the block to erase is
smaller. The documentation in spi-nor.c also states:
"All newly added entries should describe *hardware* and should use
SECT_4K (or SECT_4K_PMC) if hardware supports erasing 4 KiB
sectors. For usage scenarios excluding small sectors there is config
option that can be disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS. For
historical (and compatibility) reasons (before we got above config)
some old entries may be missing 4K flag."
Unfortunately, using SECT_4K means that ubifs will fail, because it
needs a minimum LBE of 15K.
Based on the above comments, it looks like the best way to handle the
ubifs issue is to disable CONFIG_MTD_SPI_NOR_USE_4K_SECTORS instead of
removing SECT_4K for the particular n25q256a chip. This approach also
has the advantage that will make ubifs work with any chip that has the
SECT_4K flag.
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Reviewed-by: Han Xu <han.xu@nxp.com>
Signed-off-by: Radu Solea <radu.solea@nxp.com>
Add rpmsg-keys driver on i.mx7ulp-evk board since vol+/vol- keys
are connected on m4 side and have to get the status of keys by
rpmsg.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
[Irina: updated for 4.9 APIs]
Signed-off-by: Irina Tirdea <irina.tirdea@nxp.com>
Add build support for ADV7535 kernel driver.
(cherry picked from commit 124ff1d4de5bc93d5bd2c68ac0fcb4f414b199ef)
Enable TPM PWM driver in default config.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
add focaltech touch screen support
(cherry-pick from 595cefbee5586e77ceb9ad900c256177a98367c7)
Enable cpufreq support for i.MX7ULP in defconfig.
built in rpmsg audio driver
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Acked-by: Robin Gong <yibin.gong@nxp.com>
Add 'FB_MXC_OVERLAY' config to control overlay framebuffer
feature. And also add this config to defconfig.
controller
Add kernel build support the NorthWest Logic MIPI DSI module
on the imx7ulp-evk board.
(cherry picked from commit 4f6d2b2e57c357b015b1f88f77b8af6da74d0df6)
It is used for imx7ulp evk which uses GPIO for USB dual-role switch
function.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
driver
enable pf1550-regulator-rpmsg driver by default.
Enable wdog driver in defconfig.
Enable i.MX7ULP SoC by default.
