path: root/arch/arm/configs
2006-02-08[ARM] 3306/1: S3C24XX - update defconfigBen Dooks
Patch from Ben Dooks Bring s3c2410 defconfig up to date Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3302/1: make pci=firmware the default for ixp2000Lennert Buytenhek
Patch from Lennert Buytenhek Most ixp2000 boards don't actually work if pci=firmware isn't used, so the defconfig isn't really the right place to specify this. Instead of specifying it in the defconfigs, make the relevant board code take care of setting pci=firmware. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-08[ARM] 3301/1: remove unnecessary clock default from ixdp2801 defconfigLennert Buytenhek
Patch from Lennert Buytenhek The ixdp2x01_clock is already 50MHz by default, so no need to override it with 50MHz in the ixdp2801 defconfig as is done now, which is confusing as well. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-03[ARM] Remove ARCH_CAMELOT from at91 defconfigsRussell King
ARCH_CAMELOT (excalibur) got removed; remove it from the AT91 defconfigs Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-19[ARM] Remove CONFIG_BROKEN=y from defconfigsRussell King
Remove CONFIG_BROKEN=y from the ARM defconfigs, and update with the appropriate changes. This results in only some unselected configuration symbols being removed - hence no material effect on the configuration. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-18[PATCH] e1000: Added disable packet split capabilityJesse Brandeburg
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-10[ARM] 3247/1: AT91RM9200 support for 2.6 (Cogent CSB337 & CSB637 boards) (PatchAndrew Victor
#3244) Patch from Andrew Victor This patch adds support to the 2.6 kernel series for the Atmel AT91RM9200 processor. This patch is the support for the Cogent CSB337 and CSB637 boards. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-10[ARM] 3243/2: AT91RM9200 support for 2.6 (Atmel DK & EK boards)Andrew Victor
Patch from Andrew Victor This patch adds support to the 2.6 kernel series for the Atmel AT91RM9200 processor. This patch is the support for Atmel's DK and EK boards. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-09[ARM] Remove CONFIG_ARCH_CAMELOT from defconfigsRussell King
EPXA10DB has gone, no need to keep the symbol in the defconfigs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[ARM] Remove EPXA10DB machine supportRussell King
EPXA10DB seems to be uncared for: - the "PLD" code has never been merged - no one has reported that this platform has been broken since at least 2.6.10 - interest seems to have dried up around March 2003. Therefore, remove EPXA10DB support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3221/1: Update IXP4xx defconfigDeepak Saxena
Patch from Deepak Saxena Add NAS 100d to machine build list and update to new 2.6.15 options. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> --- Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-01[ARM] 3188/1: Add missing i2c dependency for AkitaRichard Purdie
Patch from Richard Purdie Akita requires inbuilt kernel i2c support for its GPIOs. Add this requirement to Kconfig and update the defconfig to match. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-28[ARM] 3180/1: Update Zaurus defconfigsRichard Purdie
Patch from Richard Purdie This updates the Zaurus defconfigs. Poodle gets merged into corgi_defconfig and support for tosa and akita is enabled. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-16[ARM] 3162/1: S3C2410 - updated defconfigBen Dooks
Patch from Ben Dooks Minor changes, including add SysRq, selecting the DM9000 as a built-in driver, not as a module, and selecting the framebuffer. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-11[ARM] 3147/1: update ixp2000 defconfigs to 2.6.14-git13Lennert Buytenhek
Patch from Lennert Buytenhek Update the ixp2000 defconfigs to 2.6.14-git13. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3144/1: OMAP 5/5: Update omap H2 defconfigTony Lindgren
Patch from Tony Lindgren This patch updates omap H2 defconfig. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04[PATCH] ARM: Reverted 2918/1: [update] Base port of Comdial MP1000 platfromRussell King
No longer maintained
2005-11-03[ARM] Fix IXDP2x01 config filesDeepak Saxena
IXDP2401 config file has wrong baudrate and both boards have 3 UARTs. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-03[ARM] Add Realview default configuration fileRussell King
2005-11-01[ARM] 3081/1: Remove GTWX5715 from ixp4xx_defconfigDeepak Saxena
Patch from Deepak Saxena CONFIG_MACH_GTWX5715 hardcodes the machine type in head-xscale.S so we can no longer boot on any other machine types. The proper fix would be to remove the hardcoding, but that machine is an off-the-shelf system and most users won't have access to the bootloader. :( Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-30[ARM] fix ixp2x00 defconfig NR_UARTS optionsDeepak Saxena
IXDP2[48]00 have only 1 UART on the board. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2918/1: [update] Base port of Comdial MP1000 platfromJon Ringle
Patch from Jon Ringle Updated 2898/1 per comments: - Removed fixup - Moved code in mach-mp1000/ to mach-clps711x/ - Cleaned up code in mp1000-seprom.c. Eliminated code that displayed the contents of the eeprom Please comment. Signed-off-by: Jon Ringle Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2968/1: defconfig for the ARM Collie platformVincent Sanders
Patch from Vincent Sanders Add a defconfig for the ARM Collie platform Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2967/1: defconfig for the ARM Corgi platformVincent Sanders
Patch from Vincent Sanders Add a defconfig for the ARM Corgi Zarus platform Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2966/1: defconfig for the ARM Poodle platformVincent Sanders
Patch from Vincent Sanders Add a defconfig for the ARM Poodle Zarus platform Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2965/1: defconfig for the ARM Spitz platformVincent Sanders
Patch from Vincent Sanders Add a defconfig for the ARM Spitz Zarus platform Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-26[ARM] 2936/1: ixp4xx default config fixesVincent Sanders
Patch from Vincent Sanders A recent patch which made IXP4xx mach_desc's depend on config options had the effect of not building the kernel for several machines it possibly could be, this patch updates the default config to ensure all possible machines are built for by default. Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-15[ARM] 2905/1: enable the ixp2000 i2c bus driver in ixp2000 defconfigsLennert Buytenhek
Patch from Lennert Buytenhek It's silly to have I2C enabled in all ixp2000 defconfigs but not to have the ixp2000 bus driver enabled in any of them. This patch enables CONFIG_I2C_IXP2000 for all in-tree ixp2000 boards. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-15[ARM] 2904/1: update ixp2000 defconfigs to 2.6.13Lennert Buytenhek
Patch from Lennert Buytenhek Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[ARM] 2891/1: S3C2410 - update s3c2410_defconfig for 2.6.13Ben Dooks
Patch from Ben Dooks Updated the s3c2410_defconfig for the 2.6.13-git8 kernel release, as well as adding the Anubis board to the list of boards built. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2880/1: OMAP 4/4: Update H2 defconfigTony Lindgren
Patch from Tony Lindgren This patch updates H2 defconfig Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-18[PATCH] ARM: 2818/1: BAST - Use platform device for SuperIO 16550sBen Dooks
Patch from Ben Dooks Use platform device for the 16500 UARTs in the onboard SuperIO controller. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-16[PATCH] ARM: 2815/1: Shark: new defconfig, fixes with __io and serial portsAlexander Schulz
Patch from Alexander Schulz This patch brings a new default config file for the shark and fixes a compilation issue with io addressing and a runtime problem with the serial ports, where I corrected a wrong regshift value. These are all shark specific files so I hope it is ok to put them in one patch. Signed-off-by: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2805/1: OMAP update 10/11: Update H2 defconfigTony Lindgren
Patch from Tony Lindgren This patch updates H2 defconfig. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2795/1: update ixp2000 defconfigsLennert Buytenhek
Patch from Lennert Buytenhek Update the ixp2000 defconfigs from 2.6.12-git6 to 2.6.13-rc2. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-01[PATCH] ARM: 2783/1: Remove omnimeter_defconfig as there is no kernel supportBen Dooks
Patch from Ben Dooks The omnimeter_defconfig does not define any machines and seems to have no other support in the current kernel. This patch removes the config file, as this is the only thing currently mentioning the ominmeter. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2752/1: disable ixp2000 PCI I/O software workaround on chips ↵Lennert Buytenhek
that don't need it Patch from Lennert Buytenhek The later ixp2000 models don't need the PCI I/O workaround that we currently perform. Add a config option to disable the workaround, and panic on boot if a kernel without the workaround is booted on a buggy chip. As only pre-production ixp2000s need the workaround, the default is for it not to be configured in. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2749/1: update ixp2000 defconfigs to 2.6.12-git6Lennert Buytenhek
Patch from Lennert Buytenhek Update the defconfigs for the ixp2000 platforms to 2.6.12-git6. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] ARM: 2730/1: S3C2410 default configuration updateBen Dooks
Patch from Ben Dooks Add support for the DM9000 and bring default configuration up-to-date with the latest 2.6.12 kernel release Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-20[PATCH] ARM: 2719/1: enable module support in ixp2000 defconfigs by defaultLennert Buytenhek
Patch from Lennert Buytenhek The ixp2000 defconfigs are among the few that do not enable module support by default. I keep enabling module support by hand for every new kernel version, so let's just make this change upstream. Signed-off-by: Lennert Buytenhek Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-09[PATCH] ARM: 2708/1: Fix hackkit CPU Frequency build faliureVincent Sanders
Patch from Vincent Sanders This fixes the "multiple definitions of cpufreq_get" build faliure on the hackkit SA1100 platform. Signed-off-by: Vincent Sanders Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-09[PATCH] ARM: 2707/2: Fix badge4 CPU Frequency build faliureVincent Sanders
Patch from Vincent Sanders This fixes the "multiple definitions of cpufreq_get" build faliure on the Badge4 SA1100 platform. Signed-off-by: Vincent Sanders Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-09[PATCH] ARM: 2706/1: Fix compile on SA-based iPAQs and remove stale CREDITS infoDave Neuer
Patch from Dave Neuer This fixes the "multiple definitions of cpufreq_get" errors on StrongARM-based iPAQs. Signed-off-by: Dave Neuer Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-29[PATCH] ARM: 2660/2: fix ixdp2800 boot and pci initLennert Buytenhek
Patch from Lennert Buytenhek The IXDP2800 is an evalution platform for the IXP2800 processor that has two IXP2800s connected to the same PCI bus. This is problematic as both CPUs will try to configure the PCI bus as they boot linux. Contrary to on the other IXP2000 platforms, the boot loader on the IXDP2800 doesn't configure the PCI bus properly, so we do want the linux instance on one of the CPUs to do that. Making one of the CPUs ignore the PCI bus (and thus act like a pure PCI slave device) is not an option because there is a 82559 NIC on the PCI bus for each of the CPUs. The chosen solution is to have the master CPU configure the PCI bus while the slave is kept in a quiescent state, and then to have the slave CPU scan the PCI bus (without assigning resources) while the master is kept in a quiescent state. After this ritual, the master deletes the slave NIC from its PCI device list, the slave deletes the master NIC from its device list, and (almost) all is well. There's still one little problem: each of the CPUs has a 1G SDRAM BAR, but the IXP2000 only has 512M of outbound PCI memory window. We solve this by hand-assigning the master and slave SDRAM BARs to a location outside each of the IXP's outbound PCI windows, and by having the rest of the BARs autoconfigured in the outbound PCI windows, in the range [e0000000..ffffffff], so that there is a 1:1 pci:phys mapping between them. Even with this patch, a number of issues still remain -- just imagine what happens if one of the CPUs is rebooted, by watchdog or by hand, but the other one isn't. But those issues are not easily fixable given the strange PCI layout of this board and the behavior of the boot loader shipped with the platform. Signed-off-by: Lennert Buytenhek Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
