The rtc isl1208 driver is used by mx6 nitrogen board, so let's enable it by
default.
The fsl sai driver is used by the vf610-twr board, so let's enable it by
default.
simple-audio-card driver is used by the vf610-twr board, so let's enable it by
default.
Generated this patch by doing:
- make imx_v6_v7_defconfig
- make menuconfig and manually select options
- make savedefconfig
- cp defconfig arch/arm/configs/imx_v6_v7_defconfig
,which results in some additional cleanups.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The imx weim driver is used by some mx27/mx1 boards, so let's enable it by
default.
- make imx_v4_v5_defconfig
- make menuconfig and manually select CONFIG_IMX_WEIM
- cp defconfig arch/arm/configs/imx_v4_v5_defconfig
mx1ads.c can be replaced with devicetree equivalent: imx1-ads.dts,
so remove the board file.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
pcm970-baseboard.c and mach-pcm038.c can be replaced with their
devicetree equivalents: imx27-phytec-phycore-rdk.dts and
imx27-phytec-phycore-som.dtsi respectively, so remove the board files.
eukrea_mbimx27-baseboard.c and mach-cpuimx27.c can be replaced with their
devicetree equivalents: imx27-eukrea-mbimxsd27-baseboard.dts and
imx27-eukrea-cpuimx27.dtsi respectively, so remove the board files.
Acked-by: Eric Bénard <eric@eukrea.com>
Pull ARM SoC defconfig updates from Olof Johansson:
"We broke this out in a separate branch since some defconfigs now are
shared between maintainers, and having them merged in through separate
topics (drivers/soc/etc) is a recipe for conflicts.
Most of this is removal of two defconfigs:
- Kirkwood, now folded into mvebu/multi_v5
- Renesas genmai, removed platform
- major defconfig refresh for exynos
- various updates on the other multi-defconfigs and others (tegra,
socfpga, shmobile):
* tag 'defconfig-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: multi_v7_defconfig: Enable TI PIPE3 PHY driver
ARM: config: enable ARCH_HIX5HD2
ARM: multi_v7_defconfig: Enable MiPHY365x - ST's Generic (SATA & PCIe) PHY
ARM: multi_v7_defconfig: Enable ST's (S)ATA driver
ARM: multi_v7_defconfig: add ST Keyscan driver
ARM: update multi_v7_defconfig for STI
ARM: multi_v7_defconfig: Configure in ST's Thermal Controller
ARM: exynos_defconfig: Update exynos_defconfig
ARM: shmobile: defconfig: Remove MACH_GENMAI
ARM: mvebu: update mvebu_v7_defconfig with cpufreq support
ARM: mvebu: defconfig: enable cpuidle support in mvebu_v7_defconfig
ARM: shmobile: genmai: remove defconfig
ARM: socfpga: Update socfpga_defconfig
ARM: Kirkwood: Remove kirkwood_defconfig
ARM: mvebu: enable Armada 375 network driver in mvebu_v7_defconfig
ARM: shmobile: Enable R-Car Gen 2 PCIe in shmobile_defconfig
ARM: mvebu: add devtmpfs to mvebu_v5_defconfig
ARM: mvebu: add appended DTB support in mvebu_v5_defconfig
ARM: multi_v7: enable igb, stmpe, lm95245, pwm leds
ARM: multi_v7_defconfig: Enable ST's I2C driver
Pull ARM SoC driver changes from Olof Johansson:
"A handful of driver-related changes. We've had a bunch of them going
in through other branches as well, so it's only a part of what we
really have this release.
Larger pieces are:
- Removal of a now unused PWM driver for atmel
[ This includes AVR32 changes that have been appropriately acked ]
- Performance counter support for the arm CCN interconnect
- OMAP mailbox driver cleanups and consolidation
- PCI and SATA PHY drivers for SPEAr 13xx platforms
- Redefinition (with backwards compatibility!) of PCI DT bindings for
Tegra to better model regulators/power"
Note: this merge also fixes up the semantic conflict with the new
calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy:
core: Let node ptr of PHY point to PHY and not of PHY provider") that
came in through Greg's USB tree.
Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through
the next tree.
* tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
bus: arm-ccn: Fix error handling at event allocation
mailbox/omap: add a parent structure for every IP instance
mailbox/omap: remove the private mailbox structure
mailbox/omap: consolidate OMAP mailbox driver
mailbox/omap: simplify the fifo assignment by using macros
mailbox/omap: remove omap_mbox_type_t from mailbox ops
mailbox/omap: remove OMAP1 mailbox driver
mailbox/omap: use devm_* interfaces
bus: ARM CCN: add PERF_EVENTS dependency
bus: ARM CCN PMU driver
PCI: spear: Remove spear13xx_pcie_remove()
PCI: spear: Fix Section mismatch compilation warning for probe()
ARM: tegra: Remove legacy PCIe power supply properties
PCI: tegra: Remove deprecated power supply properties
PCI: tegra: Implement accurate power supply scheme
ARM: SPEAr13xx: Update defconfigs
ARM: SPEAr13xx: Add pcie and miphy DT nodes
ARM: SPEAr13xx: Add bindings and dt node for misc block
ARM: SPEAr13xx: Fix static mapping table
phy: Add drivers for PCIe and SATA phy on SPEAr13xx
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
Pull ARM SoC platform changes from Olof Johansson:
"This is the bulk of new SoC enablement and other platform changes for
3.17:
- Samsung S5PV210 has been converted to DT and multiplatform
- Clock drivers and bindings for some of the lower-end i.MX 1/2
platforms
- Kirkwood, one of the popular Marvell platforms, is folded into the
mvebu platform code, removing mach-kirkwood
- Hwmod data for TI AM43xx and DRA7 platforms
- More additions of Renesas shmobile platform support
- Removal of plat-samsung contents that can be removed with S5PV210
being multiplatform/DT-enabled and the other two old platforms
being removed
New platforms (most with only basic support right now):
- Hisilicon X5HD2 settop box chipset is introduced
- Mediatek MT6589 (mobile chipset) is introduced
- Broadcom BCM7xxx settop box chipset is introduced
+ as usual a lot other pieces all over the platform code"
* tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits)
ARM: hisi: remove smp from machine descriptor
power: reset: move hisilicon reboot code
ARM: dts: Add hix5hd2-dkb dts file.
ARM: debug: Rename Hi3716 to HIX5HD2
ARM: hisi: enable hix5hd2 SoC
ARM: hisi: add ARCH_HISI
MAINTAINERS: add entry for Broadcom ARM STB architecture
ARM: brcmstb: select GISB arbiter and interrupt drivers
ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs
ARM: configs: enable SMP in bcm_defconfig
ARM: add SMP support for Broadcom mobile SoCs
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
Pull ARM SoC cleanups from Olof Johansson:
"This merge window brings a good size of cleanups on various platforms.
Among the bigger ones:
- Removal of Samsung s5pc100 and s5p64xx platforms. Both of these
have lacked active support for quite a while, and after asking
around nobody showed interest in keeping them around. If needed,
they could be resurrected in the future but it's more likely that
we would prefer reintroduction of them as DT and
multiplatform-enabled platforms instead.
- OMAP4 controller code register define diet. They defined a lot of
registers that were never actually used, etc.
- Move of some of the Tegra platform code (PMC, APBIO, fuse,
powergate) to drivers/soc so it can be shared with 64-bit code.
This also converts them over to traditional driver models where
possible.
- Removal of legacy gpio-samsung driver, since the last users have
been removed (moved to pinctrl)
Plus a bunch of smaller changes for various platforms that sort of
dissapear in the diffstat for the above. clps711x cleanups, shmobile
header file refactoring/moves for multiplatform friendliness, some
misc cleanups, etc"
* tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits)
drivers: CCI: Correct use of ! and &
video: clcd-versatile: Depend on ARM
video: fix up versatile CLCD helper move
MAINTAINERS: Add sdhci-st file to ARCH/STI architecture
ARM: EXYNOS: Fix build breakge with PM_SLEEP=n
MAINTAINERS: Remove Kirkwood
ARM: tegra: Convert PMC to a driver
soc/tegra: fuse: Set up in early initcall
ARM: tegra: Always lock the CPU reset vector
ARM: tegra: Setup CPU hotplug in a pure initcall
soc/tegra: Implement runtime check for Tegra SoCs
soc/tegra: fuse: fix dummy functions
soc/tegra: fuse: move APB DMA into Tegra20 fuse driver
soc/tegra: Add efuse and apbmisc bindings
soc/tegra: Add efuse driver for Tegra
ARM: tegra: move fuse exports to soc/tegra/fuse.h
ARM: tegra: export apb dma readl/writel
ARM: tegra: Use a function to get the chip ID
ARM: tegra: Sort includes alphabetically
ARM: tegra: Move includes to include/soc/tegra
This driver is needed by SATA, PCIe and USB modules on TI SoCs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Since both ARCH_HI3xxx and ARCH_HIX5HD2 are based on Cortex A9 & they're
using similiar kernel features, make them share the hi3xxx_config.
And add it into multi_v7_defconfig too.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
[olof: also turn on ARCH_HISI in multi_v7]
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/drivers
Merge "late omap mailbox clean-up, driver parts" from Tony Lindgren:
Driver specific omap mailbox cleanup. Mostly to remove
broken legacy code for omap1 and move things towards
device tree.
These patches were posted a while back, but I did not
realize I was supposed to merge the driver related
parts too. So apologies for a late pull request on
these changes.
* tag 'omap-for-v3.17/mailbox-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
There are no existing users for OMAP1 mailbox driver
in kernel. Commit ab6f775 "Removing dead OMAP_DSP"
has cleaned up all the dead code related to the only
possible user, including the creation of the mailbox
platform device.
Remove this stale driver so that the OMAP mailbox
driver can be simplified and streamlined better for
converting to mailbox framework.
Signed-off-by: Suman Anna <s-anna@ti.com>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Merge "ARM: mach-bcm: soc updates for 3.17" from Matt Porter:
- BCM Mobile SMP support
- BRCM STB platform support
* tag 'for-3.17/bcm-soc' of git://github.com/broadcom/mach-bcm:
The BCM7xxx series of Broadcom SoCs are used primarily in set-top boxes.
This patch adds machine support for the ARM-based Broadcom SoCs.
Signed-off-by: Marc Carino <marc.ceeeee@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Matt Porter <mporter@linaro.org>
Also explicitly set CONFIG_NR_CPUS to 2, limiting it to the most we
currently need.
Signed-off-by: Ray Jui <rjui@broadcom.com>
Signed-off-by: Alex Elder <elder@linaro.org>
'v3.16-rc6' into next/soc
The following samsung branches are based on these cleanups,
which are already in mainline before this branch gets pulled.
git://git.stlinux.com/devel/kernel/linux-sti into next/defconfig
Merge "ARM: STi: defconfig changes for v3.17" from Maxime Coquelin:
STi defconfig updates for v3.17
- Enable ST's Thermal controller driver
- Enable ST's Keyscan driver
- Enable ST's MiPHY365 Phy driver for STiH416 SATA & PCIe
- Enable ST's AHCI driver.
* tag 'sti-defconfig-for-v3.17-1' of git://git.stlinux.com/devel/kernel/linux-sti:
+ Linux 3.16-rc6
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
This patch adds KEYBOARD_ST_KEYSCAN config
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
This patch enables SDHCI STI platform driver.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Ajit Pal Singh <ajitpal.singh@st.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
Merge "Samsung exynos cpuidle update for v3.17" from Kukjin Kim:
- add callbacks exynos_suspend() and exynos_powered_up()
for support cpuidle through mcpm
- skip exynos_cpuidle for exynos5420 because is uses
cpuidle-big-liggle generic cpuidle driver
- add generic functions to calculate cpu number is used
for pmu and this is required for exynos5420 multi-cluster
- add of_device_id structure for big.LITTLE cpuidle and
add "samsung,exynos5420" compatible string for exynos5420
* tag 'exynos-cpuidle' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: EXYNOS: populate suspend and powered_up callbacks for mcpm
ARM: EXYNOS: do not allow cpuidle registration for exynos5420
cpuidle: big.LITTLE: init driver for exynos5420
cpuidle: big.LITTLE: Add ARCH_EXYNOS entry in config
ARM: EXYNOS: add generic function to calculate cpu number
cpuidle: big.LITTLE: add of_device_id structure
+ Linux 3.16-rc5
Removed outdated configs. Enabled most of the configs used on latest
Exynos based platforms. This will provide a reference for users trying
to verify and test various features on Exynos based platforms and also
help in detecting breakages by widening the build coverage.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
[arun.kk@samsung.com: on Snow, Pit, Pi chromebooks]
Tested-by: Arun Kumar K <arun.kk@samsung.com>
Tested-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
into next/defconfig
Merge "ARM: mvebu: defconfig changes for v3.17 (round 2)" from Jason Cooper:
"Here's all the defconfig changes we have for mvebu this time around. The
big one is the removal of kirkwood_defconfig, corresponding to the
mach-kirkwood/ removal in mvebu/soc."
- mvebu
* Add appended_dtb support
* Add devtmpfs support
* Add 375 network driver
* Add cpuidle support
* Add cpufreq support
- kirkwood
* Remove kirkwood_defconfig
* tag 'mvebu-defconfig-3.17-2' of git://git.infradead.org/linux-mvebu:
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/defconfig
Merge "ARM: tegra: defconfig updates for 3.17" from Theirry Reding:
This set of patches update the tegra_defconfig by first regenerating on
top of v3.16-rc1 to prune all non-existent symbols or symbols which are
now selected by default.
* tag 'tegra-for-3.17-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
ARM: tegra: enable igb, stmpe, i2c chardev, lm95245, pwm leds
ARM: tegra: rebuild tegra_defconfig
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
Merge "ARM: imx: device tree updates for 3.17" from Shawn Guo:
The i.MX device tree updates for 3.17:
- Add device tree sources and pin function header for i.MX6SX SoC
- Initial imx6sx-sdb board support with FEC, MMC, USB, PMIC, Audio
and GPIO key enabled
- New board support: mbimxsd25 and mbimxsd27 from Eukrea, aristainetos
imx6dl boards, Rex Pro and Basic, Ka-Ro TX6
- Restructure imx6qdl-wandboard.dtsi for new rev C1 board
- Split M28EVK and M53EVK into SoM and EVK parts
- A few correction around SDMA, SSI and SATA device nodes
- Add eSATA support for Cubox-i board
- Updates on edmqmx6 to enable PCIe, I2C and CAN
- Use DT macro for clock ID for imx27 and imx6qdl
- Add FlexCAN support for VF610 SoC
* tag 'imx-dt-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (125 commits)
ARM: dts: vf610: add FlexCAN node
ARM: dts: add initial Rex Basic board support
ARM: dts: add initial Rex Pro board support
ARM: dts: mx5: Split M53EVK into SoM and EVK parts
ARM: dts: imx6: RIoTboard explicitly define pad settings
ARM: dts: vf610: fix length of eshdc1 register property
ARM: dts: Restructure imx6qdl-wandboard.dtsi for new rev C1 board.
ARM: dts: imx53: correct clock-names of SATA node
ARM: imx6: Align ssi nodes between mx6 variants
ARM: i.MX27 clk: dts: Use clock defines in DTS files
ARM: dts: imx: correct sdma compatbile for imx6sl and imx6sx
ARM: dts: imx6sx-sdb: Add audio support
ARM: dts: imx6sx: Pass the fsl,fifo-depth property
ARM: dts: imx6sx: Fix sdma node
ARM: dts: imx6: edmqmx6: Add can bus
ARM: dts: imx6: edmqmx6: Add two other i2c buses
ARM: dts: imx6: edmqmx6: Add PCIe support
ARM: dts: imx25-pdk: Add USB OTG support
ARM: dts: i.MX53: add aipstz nodes
ARM: dts: mxs: Split M28EVK into SoM and EVK parts
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/defconfig
Merge "Fourth Round of Renesas ARM Based SoC Defconfig Updates for v3.17" from
Simon Horman:
The genmai board code is going away so remove:
- The genmai defconfig
- MACH_GENMAI from shmobile defconfig
* tag 'renesas-defconfig4-for-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Merge "omap dts changes for v3.17 merge window, part1" from Tony Lindgren:
First set of .dts changes for omaps for v3.17 merge window:
- Enable irqchip crossbar interrupt mapping. These changes
are based on an immutable irqchip branch set up by Jason
Cooper to make it easier to merge the related .dts changes.
- Removal of omap2 related static clock data that now comes
from device tree.
- Enabling of PHY regulators for various omaps
- Enabling of PCIe for dra7
- Add support for am437x starterkit
- Enable audio for for omap5
- Enable display and am335x-evmsk
* tag 'omap-for-v3.17/dt-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (43 commits)
ARM: DTS: omap5-uevm: Enable basic audio (McPDM <-> twl6040)
ARM: DTS: omap5-uevm: Add node for twl6040 audio codec
ARM: DTS: omap5-uevm: Enable palmas clk32kgaudio clock
ARM: dts: dra7: Add dt data for PCIe controller
ARM: dts: dra7: Add dt data for PCIe PHY
ARM: dts: dra7: Add dt data for PCIe PHY control module
ARM: dts: dra7xx-clocks: Add missing clocks for second PCIe PHY instance
ARM: dts: dra7xx-clocks: rename pcie clocks to accommodate second PHY instance
ARM: dts: dra7xx-clocks: Add missing 32KHz clocks used for PHY
ARM: dts: dra7xx-clocks: Change the parent of apll_pcie_in_clk_mux to dpll_pcie_ref_m2ldo_ck
ARM: dts: dra7xx-clocks: Add divider table to optfclk_pciephy_div clock
ARM: dts: dra7-evm: Add regulator information to USB2 PHYs
ARM: omap2plus_defconfig: enable TPS65218 configs
ARM: dts: AM437x: Add TPS65218 device tree nodes
ARM: dts: AM437x: Fix i2c nodes indentation
ARM: dts: AM43x: Add TPS65218 device tree nodes
ARM: dts: Add devicetree for Gumstix Pepper board
ARM: dts: dra7: add crossbar device binding
ARM: dts: dra7: add routable-irqs property for gic node
ARM: OMAP24xx: clock: remove legacy clock data
support
The board has no insufficient support to be fully functional and seems
has no users. This patch removes support for this board.
However, the support may be added in the future by using the devicetree.
Add EDMA for DMA support for Vybrid SoCs. Also add printk time.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Silvio Fricke <silvio.fricke@gmail.com>
Enable STMPE gpio support as this is used on MX6 Data Modul edm-qmx6
board.
Allow USB device to work by default.
has no users. This patch removes support for this board. However, the
Let mx6sx be built by default.
CONFIG_FHANDLE=y is needed when running systemd with version >=210, so that it
can spawn a serial tty via getty.
Since i.MX51 becomes DT only now, we can drop option MACH_IMX51_DT and
just use SOC_IMX51 instead. While at it, rename imx51-dt.c to
mach-imx51.c to align with the name schema of other IMX DT only
platforms.
Because of the removal of the scsi_tgt kernel module, the kbuild variables
CONFIG_SCSI_TGT, CONFIG_SCSI_SRP_TGT_ATTRS and CONFIG_SCSI_FC_TGT_ATTRS
are obsolete. This patch removes these variables. This patch is the result
of the following command:
find -name '*defconfig' | while read f; do grep -vwE 'CONFIG_SCSI_TGT|CONFIG_SCSI_SRP_TGT_ATTRS|CONFIG_SCSI_FC_TGT_ATTRS|CONFIG_SRP' $f >/tmp/t && mv /tmp/t $f; done
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
The CONFIG_MACH_GENMAI is scheduled for removal so remove it from
shmobile_defconfig.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
[horms+renesas@verge.net.au: revised changelog for updated commit order]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Now that the Armada XP supports dynamic CPU frequency scaling, it
makes sense to enable the cpufreq subsystem in mvebu_v7_defconfig, as
well as the cpufreq-generic driver used on Armada XP.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1404920715-19834-7-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The Marvell EBU SoCs such as Armada 370, Armada XP or Armada 38x now
support cpuidle, so this commit enables the appropriate Kconfig
options in mvebu_v7_defconfig.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1404913221-17343-18-git-send-email-thomas.petazzoni@free-electrons.com
The genmai board code is scheduled for removal and once
that occurs the defconfig will be of no use. Remove it.
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
CONFIG_PM=y
CONFIG_SUSPEND=y
CONFIG_MMC_UNSAFE_RESUME=y
CONFIG_DWMAC_SOCFPGA=y
CONFIG_USB=y
CONFIG_USB_DWC2=y
CONFIG_USB_DWC2_HOST=y
CONFIG_USB_DWC2_PLATFORM=y
CONFIG_FHANDLE=y
CONFIG_I2C=y
CONFIG_I2C_DESIGNWARE_CORE=y
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_CHARDEV=y
CONFIG_CAN=y
CONFIG_CAN_RAW=y
CONFIG_CAN_BCM=y
CONFIG_CAN_GW=y
CONFIG_CAN_DEV=y
CONFIG_CAN_CALC_BITTIMING=y
CONFIG_CAN_C_CAN=y
CONFIG_CAN_C_CAN_PLATFORM=y
CONFIG_WATCHDOG=y
CONFIG_DW_WATCHDOG=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_DWAPB=y
CONFIG_PPS=y
CONFIG_NETWORK_PHY_TIMESTAMPING=y
CONFIG_PTP_1588_CLOCK=y
CONFIG_VLAN_8021Q=y
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_GARP=y
CONFIG_IPV6=y
CONFIG_HOTPLUG=y
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
Signed-off-by: Alan Tull <atull@altera.com>
Signed-off-by: Thor Thayer <tthayer@altera.com>
Signed-off-by: Dinh Nguyen <dinguyen@altear.com>
Enable PCIe, EABI, VFP and NFS configs in default configuration file for
SPEAr13xx.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Mohit Kumar <mohit.kumar@st.com>
[viresh: fixed logs/cclist]
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
This is no longer needed now that kirkwood lives inside mach-mvebu.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1405028192-9623-3-git-send-email-andrew@lunn.ch
Now that the Armada 375 network driver has been pushed, let's enable it
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Link: https://lkml.kernel.org/r/1405021936-28658-5-git-send-email-ezequiel.garcia@free-electrons.com
Merge "Third Round of Renesas ARM Based SoC Defconfig Updates for v3.17" from
Simon Horman:
- Enable R-Car Gen 2 PCIe in shmobile_defconfig
* tag 'renesas-defconfig3-for-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
