commit 58010fa6f71c9577922b22e46014b95a4ec80fa0 upstream.
The AES key schedule generation is mostly endian agnostic, with the
exception of the rotation and the incorporation of the round constant
at the start of each round. So implement a big endian specific version
of that part to make the whole routine big endian compatible.
Fixes: 86464859cc77 ("crypto: arm - AES in ECB/CBC/CTR/XTS modes using ARMv8 Crypto Extensions")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit f82e90b28654804ab72881d577d87c3d5c65e2bc upstream.
The AES-CTR glue code avoids calling into the blkcipher API for the
tail portion of the walk, by comparing the remainder of walk.nbytes
modulo AES_BLOCK_SIZE with the residual nbytes, and jumping straight
into the tail processing block if they are equal. This tail processing
block checks whether nbytes != 0, and does nothing otherwise.
However, in case of an allocation failure in the blkcipher layer, we
may enter this code with walk.nbytes == 0, while nbytes > 0. In this
case, we should not dereference the source and destination pointers,
since they may be NULL. So instead of checking for nbytes != 0, check
for (walk.nbytes % AES_BLOCK_SIZE) != 0, which implies the former in
non-error conditions.
Reported-by: xiakaixu <xiakaixu@huawei.com>
Flag all ARMv8 AES helper ciphers as internal ciphers to prevent
them from being called by normal users.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
This implements the ECB, CBC, CTR and XTS asynchronous block ciphers
using the AArch32 versions of the ARMv8 Crypto Extensions for AES.
