arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
bug 865816
Adapted from x86 change_page_attr() implementation
Change-Id: I398c9d460b841484de4fcfcac10ffffdf49a4a5a
Reviewed-on: http://git-master/r/56769
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Rebase-Id: Rddeccf358c948ba84af52316f084814ae53dca5e
We can't be holding the mmap_sem while calling flush_cache_user_range
because the flush can fault. If we fault on a user address, the
page fault handler will try to take mmap_sem again. Since both places
acquire the read lock, most of the time it succeeds. However, if another
thread tries to acquire the write lock on the mmap_sem (e.g. mmap) in
between the call to flush_cache_user_range and the fault, the down_read
in do_page_fault will deadlock.
Also, since we really can't be holding the mmap_sem while calling
flush_cache_user_range AND vma is actually unused by the flush itself,
get rid of vma as an argument.
Change-Id: If55409bde41ad1060fa4fe7cbd4ac530d4d9a106
Signed-off-by: Dima Zavin <dima@android.com>
arch/arm/include/asm/cacheflush.h
arch/arm/include/asm/proc-fns.h
arch/arm/mm/Kconfig
This allows the cache/processor/fault glue to be more easily used
from assembler code. Tested on Assabet and Tegra 2.
Tested-by: Colin Cross <ccross@android.com>
The v6 cache call optimization was disabled to allow the optional block
cache operations to be subsituted on CPUs which supported those
operations. However, as that functionality was removed, we no longer
need to prevent this optimization being taken advantage of.
The v7 cache call optimization was just a copy of the v6, so also fix
that too.
Tested-by: Will Deacon <will.deacon@arm.com>
Introduce a CPU_V6K configuration option for platforms to select if they
have a V6K CPU core. This allows us to identify whether we need to
support ARMv6 CPUs without the V6K SMP extensions at build time.
Currently CPU_V6K is just an alias for CPU_V6, and all places which
reference CPU_V6 are replaced by (CPU_V6 || CPU_V6K).
Select CPU_V6K from platforms which are known to be V6K-only.
Tested-by: Sourav Poddar <sourav.poddar@ti.com>
'st-ux' and 'unwind' into devel
Do this by adding flush_icache_all to cache_fns for ARMv6 and 7.
As flush_icache_all may neeed to be called from flush_kern_cache_all,
add it as the first entry in the cache_fns.
Note that now we can remove the ARM_ERRATA_411920 dependency
to !SMP so it can be selected on UP ARMv6 processors, such
as omap2.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Since page cache pages are now considered 'dirty' by default, the cache
flushing is handled via __flush_dcache_page() when a page gets mapped to
user space. Highmem pages on VIVT systems are flushed during kunmap()
and flush_kernel_dcache_page() was already a no-op in this case.
ARCH_HAS_FLUSH_KERNEL_DCACHE_PAGE is still defined since ARM needs
specific implementations for flush_kernel_vmap_range() and
invalidate_kernel_vmap_range().
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
There are places in Linux where writes to newly allocated page cache
pages happen without a subsequent call to flush_dcache_page() (several
PIO drivers including USB HCD). This patch changes the meaning of
PG_arch_1 to be PG_dcache_clean and always flush the D-cache for a newly
mapped page in update_mmu_cache().
The patch also sets the PG_arch_1 bit in the DMA cache maintenance
function to avoid additional cache flushing in update_mmu_cache().
Tested-by: Rabin Vincent <rabin.vincent@stericsson.com>
The standard I-cache Invalidate All (ICIALLU) and Branch Predication
Invalidate All (BPIALL) operations are not automatically broadcast to
the other CPUs in an ARMv7 MP system. The patch adds the Inner Shareable
variants, ICIALLUIS and BPIALLIS, if ARMv7 and SMP.
To avoid #include collisions with subsequent patches in the series, this
patch moves the outer_cache definitions to a separate asm/outercache.h
file.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/xfs-vipt:
xfs: fix xfs to work with Virtually Indexed architectures
sh: add mm API for DMA to vmalloc/vmap areas
arm: add mm API for DMA to vmalloc/vmap areas
parisc: add mm API for DMA to vmalloc/vmap areas
mm: add coherence API for DMA to vmalloc/vmap areas
'pending-dma-streaming', 'u300' and 'umc' into devel
This patch fix the below build error for arm1026ej-s processor (IntegratorCP/arm1026ej-s board).
CC init/main.o
In file included from include/linux/highmem.h:8,
from include/linux/pagemap.h:10,
from include/linux/mempolicy.h:62,
from init/main.c:52:
arch/arm/include/asm/cacheflush.h:134:2: error: #error Unknown cache maintainence model
make[1]: *** [init/main.o] Erreur 1
make: *** [init] Erreur 2
Signed-off-by: Abdoulaye Walsimou Gaye <walsimou@walsimou.com>
These are now unused, and so can be removed.
Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
ARM cannot prevent cache movein, so this patch implements both the
flush and invalidate pieces of the API.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
and V7 comments
The comments in cacheflush.h should follow what's in
struct cpu_cache_fns. The comments for V6 and V7 are
unnecessary.
... and rename the function since it no longer operates on just
pages.
There is not enough users to warrant its existence, and it is actually
an obstacle to progress with the new DMA API which cannot cover this
case properly.
To keep backward compatibility, let's perform the necessary custom
cache maintenance locally in the only driver affected.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits)
cfq-iosched: Do not access cfqq after freeing it
block: include linux/err.h to use ERR_PTR
cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit
blkio: Allow CFQ group IO scheduling even when CFQ is a module
blkio: Implement dynamic io controlling policy registration
blkio: Export some symbols from blkio as its user CFQ can be a module
block: Fix io_context leak after failure of clone with CLONE_IO
block: Fix io_context leak after clone with CLONE_IO
cfq-iosched: make nonrot check logic consistent
io controller: quick fix for blk-cgroup and modular CFQ
cfq-iosched: move IO controller declerations to a header file
cfq-iosched: fix compile problem with !CONFIG_CGROUP
blkio: Documentation
blkio: Wait on sync-noidle queue even if rq_noidle = 1
blkio: Implement group_isolation tunable
blkio: Determine async workload length based on total number of queues
blkio: Wait for cfq queue to get backlogged if group is empty
blkio: Propagate cgroup weight updation to cfq groups
blkio: Drop the reference to queue once the task changes cgroup
blkio: Provide some isolation between groups
We had two copies of the wrapper code for VIVT cache flushing - one in
asm/cacheflush.h and one in arch/arm/mm/flush.c. Reduce this down to
one common copy.
pages
Mtdblock driver doesn't call flush_dcache_page for pages in request. So,
this causes problems on architectures where the icache doesn't fill from
the dcache or with dcache aliases. The patch fixes this.
The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid
pointless empty cache-thrashing loops on architectures for which
flush_dcache_page() is a no-op. Every architecture was provided with this
flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is
equal 1 or do nothing otherwise.
See "fix mtd_blkdevs problem with caches on some architectures" discussion
on LKML for more information.
Signed-off-by: Ilya Loginov <isloginov@gmail.com>
Cc: Peter Horton <phorton@bitbox.co.uk>
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Errata 411920 indicates that any "invalidate entire instruction cache"
operation can fail if the right conditions are present. This is not
limited just to those operations in flush.c, but elsewhere. Place the
workaround in the already existing __flush_icache_all() function
instead.
Makes code futureproof against the impending change to mm->cpu_vm_mask.
It's also a chance to use the new cpumask_ ops which take a pointer
(the older ones are deprecated, but there's no hurry for arch code).
Without this, the default implementation is a no op which is completely
wrong with a VIVT cache, and usage of sg_copy_buffer() produces
unpredictable results.
Tested-by: Sebastian Andrzej Siewior <bigeasy@breakpoint.cc>
CC: stable@kernel.org
arch/arm/mm/Kconfig
Adds support for Faraday FA526 core. This core is used at least by:
Cortina Systems Gemini and Centroid family
Cavium Networks ECONA family
Grain Media GM8120
Pixelplus ImageARM
Prolific PL-1029
Faraday IP evaluation boards
v2:
- move TLB_BTB to separate patch
- update copyrights
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
"""The Marvell® PXA168 processor is the first in a family of application
processors targeted at mass market opportunities in computing and consumer
devices. It balances high computing and multimedia performance with low
power consumption to support extended battery life, and includes a wealth
of integrated peripherals to reduce overall BOM cost .... """
See http://www.marvell.com/featured/pxa168.jsp for more information.
1. Marvell Mohawk core is a hybrid of xscale3 and its own ARM core,
there are many enhancements like instructions for flushing the
whole D-cache, and so on
2. Clock reuses Russell's common clkdev, and added the basic support
for UART1/2.
3. Devices are a bit different from the 'mach-pxa' way, the platform
devices are now dynamically allocated only when necessary (i.e.
when pxa_register_device() is called). Description for each device
are stored in an array of 'struct pxa_device_desc'. Now that:
a. this array of device description is marked with __initdata and
can be freed up system is fully up
b. which means board code has to add all needed devices early in
his initializing function
c. platform specific data can now be marked as __initdata since
they are allocated and copied by platform_device_add_data()
4. only the basic UART1/2/3 are added, more devices will come later.
Signed-off-by: Jason Chagas <chagas@marvell.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
... and fix those drivers that were incorrectly relying upon
that include.
In case of non-aliasing VIPT caches, there is no need to flush the whole
cache when new mapping is created. The patch introduces this condition
check. In the non-aliasing VIPT case flush_cache_vmap() needs a DSB
since the set_pte_at() function called from vmap_pte_range() does not
have such barrier (done usually via TLB flushing functions).
Rather than pollute asm/cacheflush.h with the cache type definitions,
move them to asm/cachetype.h, and include this new header where
necessary.
Move platform independent header files to arch/arm/include/asm, leaving
those in asm/arch* and asm/plat* alone.
