kernel.h
Issue manifests as:
In file included from arch/arm/mach-pxa/include/mach/hardware.h:62,
from arch/arm/mach-pxa/include/mach/gpio.h:28,
from /home/jic23/src/kernel/temp-remove/arch/arm/include/asm/gpio.h:5,
from include/linux/gpio.h:7,
from drivers/staging/iio/gyro/adis16080_core.c:8:
/home/jic23/src/kernel/temp-remove/arch/arm/include/asm/cputype.h:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'read_cpuid_id'
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
arch/arm/kernel/return_address.c:37:6: warning: symbol 'return_address' was not declared. Should it be static?
arch/arm/kernel/setup.c:76:14: warning: symbol 'processor_id' was not declared. Should it be static?
arch/arm/kernel/traps.c:259:1: warning: symbol 'die_lock' was not declared. Should it be static?
arch/arm/vfp/vfpmodule.c:156:6: warning: symbol 'vfp_raise_sigfpe' was not declared. Should it be static?
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
This adds the TCM interface to Linux, when active, it will
detect and report TCM memories and sizes early in boot if
present, introduce generic TCM memory handling, provide a
generic TCM memory pool and select TCM memory for the U300
platform.
See the Documentation/arm/tcm.txt for documentation.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
CPU id is changed in Marvell chip. So update the code in cpu_is_xsc3().
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
ARMv7 SMP hardware can handle the TLB maintenance operations
broadcasting in hardware so that the software can avoid the costly IPIs.
This patch adds the necessary checks (the MMFR3 CPUID register) to avoid
the broadcasting if already supported by the hardware.
(this patch is based on the work done by Tony Thompson @ ARM)
Add asm/cputype.h, moving functions and definitions from asm/system.h
there. Convert all users of 'processor_id' to the more efficient
read_cpuid_id() function.
