Commit 65987a8553061515b5851b472081aedb9837a391 upstream.
Split out the lookup of the processor type and associated error handling
from the rest of setup_processor() - we will need to use this in the
secondary CPU bringup path for big.Little Spectre variant 2 mitigation.
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: David A. Long <dave.long@linaro.org>
Commit f5683e76f35b4ec5891031b6a29036efe0a1ff84 upstream.
Add CPU part numbers for Cortex A53, A57, A72, A73, A75 and the
Broadcom Brahma B15 CPU.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Boot-tested-by: Tony Lindgren <tony@atomide.com>
Reviewed-by: Tony Lindgren <tony@atomide.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
commit ddc37832a1349f474c4532de381498020ed71d31 upstream.
On APQ8060, the kernel crashes in arch_hw_breakpoint_init, taking an
undefined instruction trap within write_wb_reg. This is because Scorpion
CPUs erroneously appear to set DBGPRSR.SPD when WFI is issued, even if
the core is not powered down. When DBGPRSR.SPD is set, breakpoint and
watchpoint registers are treated as undefined.
It's possible to trigger similar crashes later on from userspace, by
requesting the kernel to install a breakpoint or watchpoint, as we can
go idle at any point between the reset of the debug registers and their
later use. This has always been the case.
Given that this has always been broken, no-one has complained until now,
and there is no clear workaround, disable hardware breakpoints and
watchpoints on Scorpion to avoid these issues.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Linus Walleij <linus.walleij@linaro.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Pull KVM updates from Radim Krčmář:
"All architectures:
- move `make kvmconfig` stubs from x86
- use 64 bits for debugfs stats
ARM:
- Important fixes for not using an in-kernel irqchip
- handle SError exceptions and present them to guests if appropriate
- proxying of GICV access at EL2 if guest mappings are unsafe
- GICv3 on AArch32 on ARMv8
- preparations for GICv3 save/restore, including ABI docs
- cleanups and a bit of optimizations
MIPS:
- A couple of fixes in preparation for supporting MIPS EVA host
kernels
- MIPS SMP host & TLB invalidation fixes
PPC:
- Fix the bug which caused guests to falsely report lockups
- other minor fixes
- a small optimization
s390:
- Lazy enablement of runtime instrumentation
- up to 255 CPUs for nested guests
- rework of machine check deliver
- cleanups and fixes
x86:
- IOMMU part of AMD's AVIC for vmexit-less interrupt delivery
- Hyper-V TSC page
- per-vcpu tsc_offset in debugfs
- accelerated INS/OUTS in nVMX
- cleanups and fixes"
* tag 'kvm-4.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (140 commits)
KVM: MIPS: Drop dubious EntryHi optimisation
KVM: MIPS: Invalidate TLB by regenerating ASIDs
KVM: MIPS: Split kernel/user ASID regeneration
KVM: MIPS: Drop other CPU ASIDs on guest MMU changes
KVM: arm/arm64: vgic: Don't flush/sync without a working vgic
KVM: arm64: Require in-kernel irqchip for PMU support
KVM: PPC: Book3s PR: Allow access to unprivileged MMCR2 register
KVM: PPC: Book3S PR: Support 64kB page size on POWER8E and POWER8NVL
KVM: PPC: Book3S: Remove duplicate setting of the B field in tlbie
KVM: PPC: BookE: Fix a sanity check
KVM: PPC: Book3S HV: Take out virtual core piggybacking code
KVM: PPC: Book3S: Treat VTB as a per-subcore register, not per-thread
ARM: gic-v3: Work around definition of gic_write_bpr1
KVM: nVMX: Fix the NMI IDT-vectoring handling
KVM: VMX: Enable MSR-BASED TPR shadow even if APICv is inactive
KVM: nVMX: Fix reload apic access page warning
kvmconfig: add virtio-gpu to config fragment
config: move x86 kvm_guest.config to a common location
arm64: KVM: Remove duplicating init code for setting VMID
ARM: KVM: Support vgic-v3
vgic-v3 driver uses architecture specific MPIDR_LEVEL_SHIFT macro to
encode the affinity in a form compatible with ICC_SGI* registers.
Unfortunately, that macro is missing on ARM, so let's add it.
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
With the addition of caches to the V7M Architecture a new Cache Type
Register (CTR) is defined at 0xE000ED7C. This register serves the same
purpose as the V7A/R version and accessed via the read_cpuid_cachetype.
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Tested-by: Andras Szemzo <sza@esh.hu>
Tested-by: Joachim Eastwood <manabian@gmail.com>
Tested-by: Alexandre TORGUE <alexandre.torgue@st.com>
Move the StrongARM CPU ID checks out of the platform's hardware.h
file into asm/cputype.h
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Commit b8c9592 "ARM: 8318/1: treat CPU feature register fields as signed
quantities" introduced helper to extract signed quantities of 4-bit
blocks. However, with a current code feature with value 0b1000 isn't
rejected as negative. So fix the "if" condition.
Reported-by: Jonathan Brawn <Jon.Brawn@arm.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
In a multiplatform configuration, we may end up building a kernel for
both Marvell PJ1 and an ARMv4 CPU implementation. In that case, the
xscale-cp0 code is built with gcc -march=armv4{,t}, which results in a
build error from the coprocessor instructions.
Since we know this code will only have to run on an actual xscale
processor, we can simply build the entire file for ARMv5TE.
Related to this, we need to handle the iWMMXT initialization sequence
differently during boot, to ensure we don't try to touch xscale
specific registers on other CPUs from the xscale_cp0_init initcall.
cpu_is_xscale() used to be hardcoded to '1' in any configuration that
enables any XScale-compatible core, but this breaks once we can have a
combined kernel with MMP1 and something else.
In this patch, I replace the existing cpu_is_xscale() macro with a new
cpu_is_xscale_family() macro that evaluates true for xscale, xsc3 and
mohawk, which makes the behavior more deterministic.
The two existing users of cpu_is_xscale() are modified accordingly,
but slightly change behavior for kernels that enable CPU_MOHAWK without
also enabling CPU_XSCALE or CPU_XSC3. Previously, these would leave leave
PMD_BIT4 in the page tables untouched, now they clear it as we've always
done for kernels that enable both MOHAWK and the support for the older
CPU types.
Since the previous behavior was inconsistent, I assume it was
unintentional.
The various CPU feature registers consist of 4-bit blocks that
represent signed quantities, whose positive values represent
incremental features, and whose negative values are reserved.
To improve forward compatibility, update the feature detection
code to take possible future higher values into account, but
ignore negative values.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Commit af040ffc9ba1 ("ARM: make it easier to check the CPU part number
correctly") changed ARM_CPU_PART_X masks, and the way they are returned and
checked against. Usage of read_cpuid_part_number() is now deprecated, and
calling places updated accordingly. This actually broke cpuidle-big_little
initialization, as bl_idle_driver_init() performs a check using an hardcoded
mask on cpu_id.
Create an interface to perform the check (that is now even easier to read).
Define also a proper mask (ARM_CPU_PART_MASK) that makes this kind of checks
cleaner and helps preventing bugs in the future. Update usage accordingly.
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Ensure that platform maintainers check the CPU part number in the right
manner: the CPU part number is meaningless without also checking the
CPU implement(e|o)r (choose your preferred spelling!) Provide an
interface which returns both the implementer and part number together,
and update the definitions to include the implementer.
Mark the old function as being deprecated... indeed, using the old
function with the definitions will now always evaluate as false, so
people must update their un-merged code to the new function. While
this could be avoided by adding new definitions, we'd also have to
create new names for them which would be awkward.
Acked-by: Nicolas Pitre <nico@linaro.org>
Cortex-A17 has identical initialisation requirements to Cortex-A12, so
hook it up in proc-v7.S in the same way.
Commit fdb487f5c961b94486a78fa61fa28b8eff1954ab
("ARM: 8015/1: Add cpu_is_pj4 to distinguish PJ4 because it
has some differences with V7")
introduced a cpuid check for Marvell PJ4 processors to fix a
regression caused by adding PJ4 based Marvell Dove into
multi_v7.
Unfortunately, this check is too narrow to catch PJ4 used on
Dove itself and breaks iWMMXt support.
This patch therefore relaxes the cpuid mask to match both PJ4
and PJ4B. Also, rework the given comment about PJ4/PJ4B
modifications to be a little bit more specific about the
differences.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
differences with V7
The patch add cpu_is_pj4 at arch/arm/include/asm/cputype.h
PJ4 has some differences with V7, for example the coprocessor.
To disinguish this kind of situation. cpu_is_pj4 is needed.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Matt Porter <mporter@linaro.org>
The A12 behaves as the A7/A15 does with respect to setting the SMP bit, and
doesn't require TLB ops broadcasting to be explicitly enabled like the A9 does.
Note that as the ACTLR cannot (usually) be written from non-secure, it is the
responsibility of the bootloader/firmware to set this bit per core - it is
done here in Linux as last resort in case of bad firmware.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The work-around for A15 errata 798181 is not needed if appropriate ECO
fixes have been applied to r3p2 and earlier core revisions. This can be
checked by reading REVIDR register bits 4 and 9. If only bit 4 is set,
then the IPI broadcast can be skipped.
Reviewed-by: Will Deacon <will.deacon@arm.com>
is_smp() test
Commit 621a0147d5c921f4cc33636ccd0602ad5d7cbfbc ("ARM: 7757/1: mm:
don't flush icache in switch_mm with hardware broadcasting") breaks
the boot on OMAP2430SDP with omap2plus_defconfig. Tracked to an
undefined instruction abort from the CP15 read in
cache_ops_need_broadcast(). It turns out that gcc 4.5 reorders the
extended CP15 read above the is_smp() test. This breaks ARM1136 r0
cores, since they don't support several CP15 registers that later ARM
cores do. ARM1136JF-S TRM section 3.2.1 "Register allocation" has the
details.
So mark the extended CP15 read as clobbering memory, which prevents
the compiler from reordering it before the is_smp() test. Russell
states that the code generated from this approach is preferable to
marking the inline asm as volatile. Remove the existing condition
code clobber as it's obsolete, per Nico's post:
http://www.spinics.net/lists/arm-kernel/msg261208.html
This patch is a collaboration with Will Deacon and Russell King.
Comments from Paul Walmsley:
Russell, if you accept this one, might you also add Will's ack from the lists:
I'd also be obliged if you could add a Cc: line for Jonathan Austin, since he helped test:
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Jonathan Austin <jonathan.austin@arm.com>
arch/arm/Makefile
arch/arm/include/asm/glue-proc.h
The __cpu_logical_map array is statically initialized to 0, which is a valid
MPIDR value. To prevent issues with the current implementation, this patch
defines an MPIDR_INVALID value, and statically initializes the
__cpu_logical_map[] array to it. Entries in the arm_dt_init_cpu_maps()
tmp_map array used to stash DT reg properties while parsing DT are initialized
with the MPIDR_INVALID value as well for consistency.
This patch adds the following definitions relevant to the PMSA:
Add SCTLR bit 17, (CR_BR - Background Region bit) to the list of CR_*
bitfields. This bit determines whether to use the architecturally defined
memory map
Add the MPUIR to the available registers when using read_cpuid macro. The
MPUIR is the MPU type register.
CC:"Uwe Kleine-König" <u.kleine-koenig@pengutronix.de>
On v7-M the extended cpuid registers are not available from CP15 but they
are memory mapped in the System Control Space.
There isn't an equivalent available for CPUID_{CACHETYPE,TCM,TLBTYPE,MPIDR}.
This patch adds the base support for the ARMv7-M
architecture. It consists of the corresponding arch/arm/mm/ files and
various #ifdef's around the kernel. Exception handling is implemented by
a subsequent patch.
[ukleinek: squash in some changes originating from commit
b5717ba (Cortex-M3: Add support for the Microcontroller Prototyping System)
from the v2.6.33-arm1 patch stack, port to post 3.6, drop zImage
support, drop reorganisation of pt_regs, assert CONFIG_CPU_V7M doesn't
leak into installed headers and a few cosmetic changes]
Reviewed-by: Jonathan Austin <jonathan.austin@arm.com>
Tested-by: Jonathan Austin <jonathan.austin@arm.com>
devel-stable
Traditionally for !CPU_CP15 read_cpuid and read_cpuid_ext returned the
processor id independent of the parameter passed in. This is wrong of
course but theoretically this doesn't harm because it's only called on
machines having a cp15.
Instead return 0 unconditionally which might make unused code paths be
better optimizable and so smaller and warn about unexpected usage.
Message-Id: 1359646587-1788-2-git-send-email-u.kleine-koenig@pengutronix.de
Define implementor IDs, part numbers and Xscale architecture versions in
cputype.h. Also create accessor functions for reading the implementor,
part number, and Xscale architecture versions from the CPUID regiser.
Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
Kernel subsystems other than the topology layer need the MPIDR
mask definitions to access the MPIDR without relying on hardcoded
masks. This patch moves the MPIDR register masks definition to
a header file and defines a macro to simplify access to MPIDR bit fields
representing affinity levels.
The affinity between ARM processors is defined in the MPIDR register.
We can identify which processors are in the same cluster,
and which ones have performance interdependency. We can define the
cpu topology of ARM platform, that is then used by sched_mc and sched_smt.
The default state of sched_mc and sched_smt config is disable.
When enabled, the behavior of the scheduler can be modified with
sched_mc_power_savings and sched_smt_power_savings sysfs interfaces.
Changes since v4 :
* Remove unnecessary parentheses and blank lines
Changes since v3 :
* Update the format of printk message
* Remove blank line
Changes since v2 :
* Update the commit message and some comments
Changes since v1 :
* Add read_cpuid_mpidr in arch/arm/include/asm/cputype.h
* Modify header of arch/arm/kernel/topology.c
* Modify tests and manipulation of MPIDR's bitfields
* Modify the place and dependancy of the config
* Modify Noop functions
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Reviewed-by: Amit Kucheria <amit.kucheria@linaro.org>
kernel.h
Issue manifests as:
In file included from arch/arm/mach-pxa/include/mach/hardware.h:62,
from arch/arm/mach-pxa/include/mach/gpio.h:28,
from /home/jic23/src/kernel/temp-remove/arch/arm/include/asm/gpio.h:5,
from include/linux/gpio.h:7,
from drivers/staging/iio/gyro/adis16080_core.c:8:
/home/jic23/src/kernel/temp-remove/arch/arm/include/asm/cputype.h:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'read_cpuid_id'
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
arch/arm/kernel/return_address.c:37:6: warning: symbol 'return_address' was not declared. Should it be static?
arch/arm/kernel/setup.c:76:14: warning: symbol 'processor_id' was not declared. Should it be static?
arch/arm/kernel/traps.c:259:1: warning: symbol 'die_lock' was not declared. Should it be static?
arch/arm/vfp/vfpmodule.c:156:6: warning: symbol 'vfp_raise_sigfpe' was not declared. Should it be static?
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
This adds the TCM interface to Linux, when active, it will
detect and report TCM memories and sizes early in boot if
present, introduce generic TCM memory handling, provide a
generic TCM memory pool and select TCM memory for the U300
platform.
See the Documentation/arm/tcm.txt for documentation.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
CPU id is changed in Marvell chip. So update the code in cpu_is_xsc3().
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
ARMv7 SMP hardware can handle the TLB maintenance operations
broadcasting in hardware so that the software can avoid the costly IPIs.
This patch adds the necessary checks (the MMFR3 CPUID register) to avoid
the broadcasting if already supported by the hardware.
(this patch is based on the work done by Tony Thompson @ ARM)
Add asm/cputype.h, moving functions and definitions from asm/system.h
there. Convert all users of 'processor_id' to the more efficient
read_cpuid_id() function.
