Avoid multiple mappings with DMA coherent/writecombine allocator by pre-
allocating the mappings, and removing that memory from the system memory
mapping. (See previous discussions on linux-arm-kernel as to why this
is bad.)
NB1: By default, we preallocate 2MB for DMA coherent, and 2MB for write
combine memory, rather than 1MB for each in case 1MB is not sufficient
for existing platform usage. Platforms have the option of shrinking
this down to 1MB DMA / 1MB WC (or even 2MB DMA / 0MB WC) if they so wish.
The DMA memory must be a multiple of 1MB, the write combine memory must
also be a multiple of 1MB, and the two together must be a multiple of
2MB.
NB2: On ARMv6/7 where we use 'normal uncacheable' memory for both DMA
and WC, the two pools are combined into one, as was the case with the
previous implementation.
The down side to this change is that the memory is permanently set aside
for DMA purposes, but I believe that to be unavoidable if we are to
avoid the possibility of the cache getting in the way on VIPT CPUs.
This removes the last known offender (at this time) from the kernel.
Given that DMA memory is fully coherent by this patch, cache
invalidation/clean is not required and so, we skip cache related
activities for the memory managed by the DMA layer. The bus
address -> virtual address conversion normally used in the calling
path and the fact that we remove kernel static mapping corresponding
to the DMA buffers leads to exceptions otherwise.
bug 876019
bug 965047
bug 987589
Change-Id: I72beb386605aafe1a301494a95a67d094ea6b2e4
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/106212
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
ISA_DMA_THRESHOLD has been unused by non-arch code, so lets now get
rid of it from ARM by replacing it with arm_dma_zone_mask. Move
dma_supported() and dma_set_mask() out of line, and have
dma_supported() check this new variable instead.
Simplify the dmabounce specific code in dma_set_mask(). We can just
omit setting the dma mask if dmabounce is enabled (we will have already
set dma mask via callbacks when the device is created in that case.)
Pass the device type specific needs_bounce function in at dmabounce
register time, avoiding the need for a platform specific global
function to do this.
Use dma_map_page()/dma_unmap_page() internals to handle dma_map_single()
and dma_unmap_single().
Add ARM support for the DMA debug infrastructure, which allows the
DMA API usage to be debugged.
Replace the page_to_dma() and dma_to_page() macros with their PFN
equivalents. This allows us to map parts of memory which do not have
a struct page allocated to them to bus addresses. This will be used
internally by dma_alloc_coherent()/dma_alloc_writecombine().
Build tested on Versatile, OMAP1, IOP13xx and KS8695.
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
This reverts commit 4fa5518, which causes a compilation regression for
IXP4xx platforms.
Reported-by: Richard Cochran <richardcochran@gmail.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
With a correct dev->dma_mask before calling dmabounce_register_dev(),
dma_needs_bounce() is not necessary.
The sa1111, though, is a bit complicated. Until it's fully understood
and fixed, dma_needs_bounce() for sa1111 is kept if CONFIG_SA1111 is
enabled with no side effect (with the condition of machine_is_*)
Thanks for Mike Rapoport to fix one error in the original version of
the patch and get this tested.
Acked-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
This converts arm to the generic pci_set_dma_mask and
pci_set_consistent_dma_mask (removes HAVE_ARCH_PCI_SET_DMA_MASK for
dmabounce).
Looked-over-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
The DMA API has the notion of buffer ownership; make it explicit in the
ARM implementation of this API. This gives us a set of hooks to allow
us to deal with CPU cache issues arising from non-cache coherent DMA.
Tested-By: Jamie Iles <jamie@jamieiles.com>
We will need to treat dma_unmap_page() differently from dma_unmap_single()
The non-highmem() and the __pfn_to_bus() based page_to_dma() both
compile to the same code, so its pointless having these two different
approaches. Use the __pfn_to_bus() based version.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
If a machine class has a custom __virt_to_bus() implementation then it
must provide a __arch_page_to_dma() implementation as well which is
_not_ based on page_address() to support highmem.
This patch fixes existing __arch_page_to_dma() and provide a default
implementation otherwise. The default implementation for highmem is
based on __pfn_to_bus() which is defined only when no custom
__virt_to_bus() is provided by the machine class.
That leaves only ebsa110 and footbridge which cannot support highmem
until they provide their own __arch_page_to_dma() implementation.
But highmem support on those legacy platforms with limited memory is
certainly not a priority.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
This is a helper to be used by the DMA mapping API to handle cache
maintenance for memory identified by a page structure instead of a
virtual address. Those pages may or may not be highmem pages, and
when they're highmem pages, they may or may not be virtually mapped.
When they're not mapped then there is no L1 cache to worry about. But
even in that case the L2 cache must be processed since unmapped highmem
pages can still be L2 cached.
dma_supported() is supposed to indicate whether the system can support
the DMA mask it was passed, which depends on the maximal address which
can be returned for DMA allocations. If the mask is smaller than that,
we are unable to guarantee that the driver can reliably obtain suitable
memory.
arch/arm/mm/dma-mapping.c: In function `dma_sync_sg_for_cpu':
arch/arm/mm/dma-mapping.c:588: warning: statement with no effect
... to prevent people being mislead.
As per the dma_unmap_* calls, we don't touch the cache when a DMA
buffer transitions from device to CPU ownership. Presently, no
problems have been identified with speculative cache prefetching
which in itself is a new feature in later architectures. We may
have to revisit the DMA API later for these architectures anyway.
Validate the direction argument like x86 does. In addition,
validate the dma_unmap_* parameters against those passed to
dma_map_* when using the DMA bounce code.
The dmabounce dma_sync_xxx() implementation have been broken for
quite some time; they all copy data between the DMA buffer and
the CPU visible buffer no irrespective of the change of ownership.
(IOW, a DMA_FROM_DEVICE mapping copies data from the DMA buffer
to the CPU buffer during a call to dma_sync_single_for_device().)
Fix it by getting rid of sync_single(), moving the contents into
the recently created dmabounce_sync_for_xxx() functions and adjusting
appropriately.
This also makes it possible to properly support the DMA range sync
functions.
We can translate a struct page directly to a DMA address using
page_to_dma(). No need to use page_address() followed by
virt_to_dma().
Update the ARM DMA scatter gather APIs for the scatterlist changes.
Convert the existing dma_sync_single_for_* APIs to the new range based
APIs, and make the dma_sync_single_for_* API a superset of it.
OMAP at least gets the return type(s) for the DMA translation functions
wrong, which can lead to subtle errors. Avoid this by moving the DMA
translation functions to asm/dma-mapping.h, and converting them to
inline functions.
Fix the OMAP DMA translation macros to use the correct argument and
result types.
Also, remove the unnecessary casts in dmabounce.c.
[ARM] 5182/1: pxa: Fix pcm990 compilation
[ARM] Fix explicit asm(-arm)?/arch-foo references
[ARM] move include/asm-arm to arch/arm/include/asm
[ARM] Remove explicit dependency for misc.o from compressed/Makefile
[ARM] initrd: claim initrd memory exclusively
[ARM] pxa: add support for L2 outer cache on XScale3 (attempt 2)
[ARM] 5180/1: at91: Fix at91_nand -> atmel_nand rename fallout
[ARM] add Sascha Hauer as Freescale i.MX Maintainer
[ARM] i.MX: add missing clock functions exports
[ARM] i.MX: remove set_imx_fb_info() export
[ARM] mx1ads: make mmc platform data available for modules
[ARM] mx2: add missing Kconfig dependency
Move platform independent header files to arch/arm/include/asm, leaving
those in asm/arch* and asm/plat* alone.
