Do flush and clear by set/way instead of by-way by enabling
errata 727915 for pl310 revision R3P1_50.
By-way maintenance doesn't work with enabled lp2_in_idle on
Tegra3 platform using R3P1_50 revision of pl310.
Debug register access causes hang when
CONFIG_TRUSTED_FOUNDATIONS is defined. Don't access those
regeisters if CONFIG_TRUSTED_FOUNDATIONS is defined.
bug 983964
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Change-Id: I76a3a9ef9dbcf86140ee26752202bf25542144e6
Reviewed-on: http://git-master/r/125153
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Every DMA engine implementation declares a last completed dma cookie
in their private dma channel structures. This is pointless, and
forces driver specific code. Move this out into the common dma_chan
structure.
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Jassi Brar <jassisinghbrar@gmail.com>
[imx-sdma.c & mxs-dma.c]
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline
4d4e58de32a192fea65ab84509d17d199bd291c8
Change-Id: Ib653bcfa5f492986946fd34006a8de3090db0441
Reviewed-on: http://git-master/r/93778
arch/arm/mm/cache-l2x0.c
drivers/misc/Kconfig
drivers/misc/Makefile
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
ARM errata 727915 for PL310 has been updated to include a new
workaround required for PL310 r2p0 for l2x0_flush_all, which also
affects l2x0_clean_all in my testing. For r2p0, clean or flush
each set/way individually. For r3p0 or greater, use the debug
register for cleaning and flushing.
Requires exporting the cache_id, sets and ways detected in the
init function for later use.
Change-Id: I215055cbe5dc7e4e8184fb2befc4aff672ef0a12
Signed-off-by: Colin Cross <ccross@android.com>
If more than one ETM or PTM are present, configure all of them
and enable the formatter in the ETB. This allows tracing on dual
core systems (e.g. omap4).
Change-Id: I028657d5cf2bee1b23f193d4387b607953b35888
Signed-off-by: Arve Hjønnevåg <arve@android.com>
The old code enabled data tracing, but did not configure the
range. We now configure it to trace all data addresses by default,
and add a trace_data_range attribute to change the range or disable
data tracing.
Change-Id: I9d04e3e1ea0d0b4d4d5bcb93b1b042938ad738b2
Remove __init annotation from l2x0_init so it can be used to
reinitialize the l2x0 after it has been reset during suspend.
Only print the init messages the first time l2x0_init is called.
Add l2x0_enable to re-enable the l2x0 after l2x0_disable if
the l2x0 was not reset.
l2x0_disable cannot use writel, as writel calls wmb(), and wmb()
may call outer_cache_sync, which takes the same spinlock as
l2x0_disable.
Change-Id: Iaddedb4f582c7eeaef3cbe2a1e463787f0f809a4
Fighting unfixed U-Boots and other beasts that may the cache in
a locked-down state when starting the kernel, we make sure to
disable all cache lock-down when initializing the l2x0 so we
are in a known state.
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Adrian Bunk <adrian.bunk@movial.com>
Cc: Rob Herring <robherring2@gmail.com>
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reported-by: Jan Rinze <janrinze@gmail.com>
Tested-by: Robert Marklund <robert.marklund@stericsson.com>
This patch fixes L2 Cache size calculations for L2C-210, L2C-310 and
PL310, by changing the L2X0_AUX_CTRL_WAY_SIZE_MASK from 2 bits to 3
bits.
The Auxiliary Control Register for L2C-210, L2C-310 and PL310 has 3bits
[19:17] for Way size, however the existing code only uses 2 bits to
get this value. This results in incorrect cachesize calculations.
It also results in performing operations on the whole cache when we
erroneously decide that the range is big enough (due to l2x0_size being
too small) and also prints incorrect cachesize.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: remove printks about disabled bridge windows
PCI: fold pci_calc_resource_flags() into decode_bar()
PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR
PCI: correct pcie_set_readrq write size
PCI: pciehp: change wait time for valid configuration access
x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems
PCI: ARI is a PCIe v2 feature
x86/PCI: quirks: Use pci_dev->revision
PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.
PCI hotplug: cpqphp: use pci_dev->vendor
PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device}
x86/PCI: config space accessor functions should not ignore the segment argument
PCI: Assign values to 'pci_obff_signal_type' enumeration constants
x86/PCI: reduce severity of host bridge window conflict warnings
PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI
PCI: PCIe AER: add aer_recover_queue
x86/PCI: select direct access mode for mmconfig option
PCI hotplug: Rename is_ejectable which also exists in dock.c
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Since Samsung EXYNOS4210 cannot support register banking in GIC,
so needs to update CPU interface base address.
The 'gic_chip_data' is used for it, this patch moves gic_chip_data
structure declaraton to arch/arm/include/asm/hardware/gic.h to use
it.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Changhwan Youn <chaos.youn@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
A pcmcia_init callback isn't used on any of the platforms. Drop it.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
This allows platforms to specify the clcokevent name upon registration.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This allows platforms to specify the clocksource name upon
registration, which is necessary should they wish to register more
than one sp804 clocksource.
arch/arm/Kconfig
Few architectures combine the GIC with an external interrupt
controller. On such systems it may be necessary to update both
the GIC registers and the external controller's registers to control
IRQ behavior.
This can be addressed in couple of possible methods.
1. Export common GIC routines along with 'struct irq_chip gic_chip'
and allow architectures to have custom function by override.
2. Provide architecture specific function pointer hooks
within GIC library and leave platforms to add the necessary
code as part of these hooks.
First one might be non-intrusive but have few shortcomings like arch
needs to have there own custom gic library. Locks used should be
common since it caters to same IRQs etc. Maintenance point of view
also it leads to multiple file fixes.
The second probably is cleaner and portable. It ensures that all the
common GIC infrastructure is not touched and also provides archs to
address their specific issue.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Colin Cross <ccross@android.com>
Tested-by: Colin Cross <ccross@android.com>
In sysctl_soft_reset(), switch to slow mode before resetting the system
via the system controller. This is required.
Reviewed-by: Stanley Miao <stanley.miao@windriver.com>
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
The effect of cache sync operation is to drain the store buffer and
wait for all internal buffers to be empty. In normal conditions, store
buffer is able to merge the normal memory writes within its 32-byte
data buffers. Due to this erratum present in r3p0, the effect of cache
sync operation on the store buffer still remains when the operation
completes. This means that the store buffer is always asked to drain
and this prevents it from merging any further writes.
This can severely affect performance on the write traffic esp. on
Normal memory NC one.
The proposed workaround is to replace the normal offset of cache sync
operation(0x730) by another offset targeting an unmapped PL310
register 0x740.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Timers on Versatile Express mainboard are used as system clock/event
sources. Driver assumes that they are clocked with 1MHz signal.
Old V2M firmware apparently configured it by default, but on newer
boards one can observe that "sleep 1" command takes over 30 seconds
to finish, as the timers are fed with 32kHz instead...
This patch performs required magic and also removes code clearing
timer's control registers, as exactly the same operations are
performed by the timer driver few jiffies later.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Tested-by: Will Deacon <will.deacon@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (243 commits)
omap2: Make OMAP2PLUS select OMAP_DM_TIMER
OMAP4: hwmod data: Fix alignment and end of line in structurefields
OMAP4: hwmod data: Move the DMA structures
OMAP4: hwmod data: Move the smartreflex structures
OMAP4: hwmod data: Fix missing SIDLE_SMART_WKUP in smartreflexsysc
arm: omap: tusb6010: add name for MUSB IRQ
arm: omap: craneboard: Add USB EHCI support
omap2+: Initialize serial port for dynamic remuxing for n8x0
omap2+: Add struct omap_board_data and use it for platform level serial init
omap2+: Allow hwmod state changes to mux pads based on the state changes
omap2+: Add support for hwmod specific muxing of devices
omap2+: Add omap_mux_get_by_name
OMAP2: PM: fix compile error when !CONFIG_SUSPEND
MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainership
OMAP4: Smartreflex framework extensions
OMAP4: hwmod: Add inital data for smartreflex modules.
OMAP4: PM: Program correct init voltages for scalable VDDs
OMAP4: Adding voltage driver support
OMAP4: Register voltage PMIC parameters with the voltage layer
OMAP3: PM: Program correct init voltages for VDD1 and VDD2
Fix up trivial conflict in arch/arm/plat-omap/Kconfig
'versatile' into devel
The commit 6ac6b817f3f4c23c5febd960d8deb343e13af5f3 (ARM: pxa: encode
IRQ number into .nr_irqs) removed definition of ITE_LAST_IRQ which
caused the following build error:
CC arch/arm/common/it8152.o
arch/arm/common/it8152.c: In function 'it8152_init_irq':
arch/arm/common/it8152.c:86: error: 'IT8152_LAST_IRQ' undeclared (first use in this function)
arch/arm/common/it8152.c:86: error: (Each undeclared identifier is reported only once
arch/arm/common/it8152.c:86: error: for each function it appears in.)
make[2]: *** [arch/arm/common/it8152.o] Error 1
Defining the IT8152_LAST_IRQ in the arch/arm/include/hardware/it8152.c
fixes the build.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This patch adds the PL310 Auxiliary Control Register bitfields
so that SOC's can use these bit fields to construct the AUXCTRL
value to be passed/programmed instead of hardcoding it.
Avoid adding nasty genirq-specific code to local timers to enable PPI
interrupts. Instead, provide a gic function to do this.
Provide a standard get_irqnr_preamble assembler macro for platforms
to use, which retrieves the base address of the GIC CPU interface
from gic_cpu_base_addr. Allow platforms to override this by defining
HAVE_GET_IRQNR_PREAMBLE.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
Every architecture using the GIC has a gic_cpu_base_addr pointer for
GIC 0 for their entry assembly code to use to decode the cause of the
current interrupt. Move this into the common GIC code.
We don't need to re-pass the base address for the CPU interfaces to the
GIC for secondary CPUs, as it will never be different from the boot CPU
- and even if it was, we'd overwrite the boot CPU's base address.
Get rid of this argument, and rename to gic_secondary_init().
Provide gic_init() which initializes the GIC distributor and current
CPU's GIC interface for the boot (or single) CPU.
This patch is the identical GIC demux implementation
merge V3. Instead of implementing same code over and
over simply share it in entry-macro-gic.S. The shared
code is based on the realview implementation.
Each GIC demux instance still has to setup the base address
of the controller using the get_irqnr_preamble macro. The
rest of the GIC specific code can be shared.
Signed-off-by: Magnus Damm <damm@opensource.se>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
The timer-sp h/w used on versatile platforms can also be used for other
platforms, so move it to a common location.
Signed-off-by: Rob Herring <rob.herring@smooth-stone.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Mike Rapoport <mike@compulab.co.il>
git://dev.omapzoom.org/pub/scm/santosh/kernel-omap4-base into devel-stable
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
arch/arm/mach-s3c64xx/dev-audio.c
The cache size is needed for to optimise range based
maintainance operations
Replace tab with space after #define to be consisten with other
define in the file. Also move the bit mask below the register offsets.
This patch adds L2X0 Prefetch and Power control register.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the arch directory.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
Use BIT() macro whenever it is sensible to do so.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
This is done so as to be able to make use of the coresight components'
registers in assembler code (like omap sleep code). Also, there shouldn't
be any users of this structure outside the etm driver.
* 'for-linus/samsung-2635' of git://git.fluff.org/bjdooks/linux:
DMAENGINE: correct PL080 register header file
ARM: SAMSUNG: Fix on build warning about dependency in Kconfig
ARM: SMDK6410: Make virtual screen twice depth of real
ARM: S3C64XX: Update consistent DMA size to 8MiB
ARM: S3C64XX: Add audio support to SmartQ
ARM: S3C64XX: Framebuffer fix for SmartQ5
ARM: S3C64XX: Set wifi and iNAND as permanently connected SD devices on SmartQ boards
ARM: S3C64XX: Move SmartQ LCD control platform definition to shared file
ARM: mach-real6410: add sdhc device support
ARM: mach-real6410: add dm9000 ethernet support for mach-real6410
ARM: S3C64XX: Support for Real6410
Fix up trivial conflicts in arch/arm/mach-s3c64xx/mach-smartq5.c
("remove pixclock" vs "Framebuffer fix for SmartQ5")
This PL008 among all other variables named PL080 doesn't seem
right. Fix it. Also add some missing defined that I use in the
new PL08x driver.
Acked-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
arch/arm/Kconfig
arch/arm/mm/Kconfig
Add notion of ETM OS lock, save and restore registers.
Add bit definitions of the CPR register of the SCOOP chip into scoop.h. Also,
cleanup the GPCR definitions to match coding style.
'omap', 'pxa', 'spear' and 'versatile' into devel
arch/arm/Makefile
arch/arm/common/Makefile
arch/arm/mm/Kconfig
