This patch contains the hooks and instrumentation into kernel which
live outside the kernel/debug directory, which the kdb core
will call to run commands like lsmod, dmesg, bt etc...
CC: linux-arch@vger.kernel.org
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Martin Hicks <mort@sgi.com>
The VIVT cache of a highmem page is always flushed before the page
is unmapped. This cache flush is explicit through flush_cache_kmaps()
in flush_all_zero_pkmaps(), or through __cpuc_flush_dcache_area() in
kunmap_atomic(). There is also an implicit flush of those highmem pages
that were part of a process that just terminated making those pages free
as the whole VIVT cache has to be flushed on every task switch. Hence
unmapped highmem pages need no cache maintenance in that case.
However unmapped pages may still be cached with a VIPT cache because the
cache is tagged with physical addresses. There is no need for a whole
cache flush during task switching for that reason, and despite the
explicit cache flushes in flush_all_zero_pkmaps() and kunmap_atomic(),
some highmem pages that were mapped in user space end up still cached
even when they become unmapped.
So, we do have to perform cache maintenance on those unmapped highmem
pages in the context of DMA when using a VIPT cache. Unfortunately,
it is not possible to perform that cache maintenance using physical
addresses as all the L1 cache maintenance coprocessor functions accept
virtual addresses only. Therefore we have no choice but to set up a
temporary virtual mapping for that purpose.
And of course the explicit cache flushing when unmapping a highmem page
on a system with a VIPT cache now can go, which should increase
performance.
While at it, because the code in __flush_dcache_page() has to be modified
anyway, let's also make sure the mapped highmem pages are pinned with
kmap_high_get() for the duration of the cache maintenance operation.
Because kunmap() does unmap highmem pages lazily, it was reported by
Gary King <GKing@nvidia.com> that those pages ended up being unmapped
during cache maintenance on SMP causing segmentation faults.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
d451564 broke ARM by requiring KM_IRQ_PTE, KM_NMI and KM_NMI_PTE to
always be defined. Solve this by providing invalid definitions for
these constants, but only if CONFIG_DEBUG_HIGHMEM is enabled.
The choice is between looping over the physical range and performing
single cache line operations, or to map highmem pages somewhere, as
cache range ops are possible only on virtual addresses.
Because L2 range ops are much faster, we go with the later by factoring
the physical-to-virtual address conversion and use a fixmap entry for it
in the HIGHMEM case.
Possible future optimizations to avoid the pte setup cost:
- do the pte setup for highmem pages only
- determine a threshold for doing a line-by-line processing on physical
addresses when the range is small
Move platform independent header files to arch/arm/include/asm, leaving
those in asm/arch* and asm/plat* alone.
