path: root/arch/arm/include/asm/memblock.h
2010-10-27ARM: fix memblock breakageRussell King
Will says: | Commit e63075a3 removed the explicit MEMBLOCK_REAL_LIMIT #define | and introduced the requirement that arch code calls | memblock_set_current_limit to ensure that the __va macro can | be used on physical addresses returned from memblock_alloc. Unfortunately, ARM was missed out of this change. Fix this. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: Convert platform reservations to use LMB rather than bootmemRussell King
2010-07-27ARM: initial LMB trialRussell King
Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
