There is already implemented full outer clean routine in
arch/arm/mm/cache-l2x0.c.
Make it possible to use it through outer_cache interface,
like other outer maintenance functions.
bug 983964
Change-Id: I47f1fad536c151c255e6a42d6517114c334ddfef
Reviewed-on: http://git-master/r/116074
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Tested-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Justin Paver <jpaver@nvidia.com>
PL310 implements the Clean & Invalidate by Way L2 cache maintenance
operation (offset 0x7FC). This operation runs in background so that
PL310 can handle normal accesses while it is in progress. Under very
rare circumstances, due to this erratum, write data can be lost when
PL310 treats a cacheable write transaction during a Clean & Invalidate
by Way operation.
Workaround:
Disable Write-Back and Cache Linefill (Debug Control Register)
Clean & Invalidate by Way (0x7FC)
Re-enable Write-Back and Cache Linefill (Debug Control Register)
This patch also removes any OMAP dependency on PL310 Errata's
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
functions
The unsigned long datatype is not sufficient for mapping physical addresses
>= 4GB.
This patch ensures that the phys_addr_t datatype is used to represent
physical addresses when passed to the outer cache functions. Note that the
definitions in struct outer_cache_fns remain as unsigned long because there
are currently no outer cache implementations supporting physical addresses
wider than 32-bits.
kexec does not disable the outer cache before disabling the inner
caches in cpu_proc_fin(). So L2 is enabled across the kexec jump. When
the new kernel enables chaches again, it randomly crashes.
Disabling L2 before calling cpu_proc_fin() cures the problem.
Disabling L2 requires the following new functions: flush_all(),
inv_all() and disable(). Add them to outer_cache_fns and call them
from the kexec code.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
This patch introduces the outer_cache_fns.sync function pointer together
with the OUTER_CACHE_SYNC config option that can be used to drain the
write buffer of the outer cache.
To avoid #include collisions with subsequent patches in the series, this
patch moves the outer_cache definitions to a separate asm/outercache.h
file.
