git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
Commit 8ec53663d2698076468b3e1edc4e1b418bd54de3 ("[ARM] Improve
non-executable support") added support for detecting non-executable
stack binaries. One of the things it does is to make READ_IMPLIES_EXEC
be set in ->personality if we are running on a CPU that doesn't support
the XN ("Execute Never") page table bit or if we are running a binary
that needs an executable stack.
This exposed a latent bug in ARM's asm/processor.h due to which we'll
end up placing the stack at a very low address, where it will bump into
the heap on any application that uses significant amount of stack or
heap or both, causing many interesting crashes.
Fix this by testing the ADDR_LIMIT_32BIT bit in ->personality instead
of testing for equality against PER_LINUX_32BIT.
Reviewed-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
As suggested by Andrew Morton, remove memzero() - it's not supported
on other architectures so use of it is a potential build breaking bug.
Since the compiler optimizes memset(x,0,n) to __memzero() perfectly
well, we don't miss out on the underlying benefits of memzero().
With gcc 4.3 and later, a pointer that has already been dereferenced is
assumed not to be null since it should have caused a segmentation fault
otherwise, hence any subsequent test against NULL is optimized away.
Current inline asm constraint used in the implementation of prefetch()
makes gcc believe that the pointer is dereferenced even though the PLD
instruction does not load any data and does not cause a segmentation
fault on null pointers, which causes all sorts of interesting results
when reaching the end of a linked lists for example.
Let's use a better constraint to properly represent the actual usage of
the pointer value.
Problem reported by Chris Steel.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Move platform independent header files to arch/arm/include/asm, leaving
those in asm/arch* and asm/plat* alone.
