path: root/arch/arm/include/asm/system_info.h
2013-04-17ARM: Add base support for ARMv7-MCatalin Marinas
This patch adds the base support for the ARMv7-M architecture. It consists of the corresponding arch/arm/mm/ files and various #ifdef's around the kernel. Exception handling is implemented by a subsequent patch. [ukleinek: squash in some changes originating from commit b5717ba (Cortex-M3: Add support for the Microcontroller Prototyping System) from the v2.6.33-arm1 patch stack, port to post 3.6, drop zImage support, drop reorganisation of pt_regs, assert CONFIG_CPU_V7M doesn't leak into installed headers and a few cosmetic changes] Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Jonathan Austin <jonathan.austin@arm.com> Tested-by: Jonathan Austin <jonathan.austin@arm.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
