Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- Move generic-y of exported headers to uapi/asm/Kbuild for complete
de-coupling of UAPI
- Clean up scripts/Makefile.headersinst
- Fix host programs for 32 bit machine with XFS file system
* tag 'kbuild-v4.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (29 commits)
kbuild: Enable Large File Support for hostprogs
kbuild: remove wrapper files handling from Makefile.headersinst
kbuild: split exported generic header creation into uapi-asm-generic
kbuild: do not include old-kbuild-file from Makefile.headersinst
xtensa: move generic-y of exported headers to uapi/asm/Kbuild
unicore32: move generic-y of exported headers to uapi/asm/Kbuild
tile: move generic-y of exported headers to uapi/asm/Kbuild
sparc: move generic-y of exported headers to uapi/asm/Kbuild
sh: move generic-y of exported headers to uapi/asm/Kbuild
parisc: move generic-y of exported headers to uapi/asm/Kbuild
openrisc: move generic-y of exported headers to uapi/asm/Kbuild
nios2: move generic-y of exported headers to uapi/asm/Kbuild
nios2: remove unneeded arch/nios2/include/(generated/)asm/signal.h
microblaze: move generic-y of exported headers to uapi/asm/Kbuild
metag: move generic-y of exported headers to uapi/asm/Kbuild
m68k: move generic-y of exported headers to uapi/asm/Kbuild
m32r: move generic-y of exported headers to uapi/asm/Kbuild
ia64: remove redundant generic-y += kvm_para.h from asm/Kbuild
hexagon: move generic-y of exported headers to uapi/asm/Kbuild
h8300: move generic-y of exported headers to uapi/asm/Kbuild
asmlinkage is either 'extern "C"' or blank.
Move the uses of asmlinkage before the return types to be similar
to the rest of the kernel.
Link: http://lkml.kernel.org/r/005b8e120650c6a13b541e420f4e3605603fe9e6.1499284835.git.joe@perches.com
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Radim Krcmar <rkrcmar@redhat.com>
Cc: Russell King <linux@armlinux.org.uk>
Now that explicitly executed loaders are loaded in the mmap region, we
have more freedom to decide where we position PIE binaries in the
address space to avoid possible collisions with mmap or stack regions.
4MB is chosen here mainly to have parity with x86, where this is the
traditional minimum load location, likely to avoid historically
requiring a 4MB page table entry when only a portion of the first 4MB
would be used (since the NULL address is avoided).
For ARM the position could be 0x8000, the standard ET_EXEC load address,
but that is needlessly close to the NULL address, and anyone running PIE
on 32-bit ARM will have an MMU, so the tight mapping is not needed.
Link: http://lkml.kernel.org/r/1498154792-49952-2-git-send-email-keescook@chromium.org
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Pratyush Anand <panand@redhat.com>
Cc: Daniel Micay <danielmicay@gmail.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Grzegorz Andrejczuk <grzegorz.andrejczuk@intel.com>
Cc: Qualys Security Advisory <qsa@qualys.com>
Cc: <stable@vger.kernel.org>
Since commit fcc8487d477a ("uapi: export all headers under uapi
directories"), all (and only) headers under uapi directories are
exported, but asm-generic wrappers are still exceptions.
To complete de-coupling the uapi from kernel headers, move generic-y
of exported headers to uapi/asm/Kbuild.
With this change, "make headers_install" will just need to parse
uapi/asm/Kbuild to build up exported headers.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add sysfs max_link_speed/width, current_link_speed/width (Wong Vee
Khee)
- make host bridge IRQ mapping much more generic (Matthew Minter,
Lorenzo Pieralisi)
- convert most drivers to pci_scan_root_bus_bridge() (Lorenzo
Pieralisi)
- mutex sriov_configure() (Jakub Kicinski)
- mutex pci_error_handlers callbacks (Christoph Hellwig)
- split ->reset_notify() into ->reset_prepare()/reset_done()
(Christoph Hellwig)
- support multiple PCIe portdrv interrupts for MSI as well as MSI-X
(Gabriele Paoloni)
- allocate MSI/MSI-X vector for Downstream Port Containment (Gabriele
Paoloni)
- fix MSI IRQ affinity pre/post/min_vecs issue (Michael Hernandez)
- test INTx masking during enumeration, not at run-time (Piotr Gregor)
- avoid using device_may_wakeup() for runtime PM (Rafael J. Wysocki)
- restore the status of PCI devices across hibernation (Chen Yu)
- keep parent resources that start at 0x0 (Ard Biesheuvel)
- enable ECRC only if device supports it (Bjorn Helgaas)
- restore PRI and PASID state after Function-Level Reset (CQ Tang)
- skip DPC event if device is not present (Keith Busch)
- check domain when matching SMBIOS info (Sujith Pandel)
- mark Intel XXV710 NIC INTx masking as broken (Alex Williamson)
- avoid AMD SB7xx EHCI USB wakeup defect (Kai-Heng Feng)
- work around long-standing Macbook Pro poweroff issue (Bjorn Helgaas)
- add Switchtec "running" status flag (Logan Gunthorpe)
- fix dra7xx incorrect RW1C IRQ register usage (Arvind Yadav)
- modify xilinx-nwl IRQ chip for legacy interrupts (Bharat Kumar
Gogada)
- move VMD SRCU cleanup after bus, child device removal (Jon Derrick)
- add Faraday clock handling (Linus Walleij)
- configure Rockchip MPS and reorganize (Shawn Lin)
- limit Qualcomm TLP size to 2K (hardware issue) (Srinivas Kandagatla)
- support Tegra MSI 64-bit addressing (Thierry Reding)
- use Rockchip normal (not privileged) register bank (Shawn Lin)
- add HiSilicon Kirin SoC PCIe controller driver (Xiaowei Song)
- add Sigma Designs Tango SMP8759 PCIe controller driver (Marc
Gonzalez)
- add MediaTek PCIe host controller support (Ryder Lee)
- add Qualcomm IPQ4019 support (John Crispin)
- add HyperV vPCI protocol v1.2 support (Jork Loeser)
- add i.MX6 regulator support (Quentin Schulz)
* tag 'pci-v4.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (113 commits)
PCI: tango: Add Sigma Designs Tango SMP8759 PCIe host bridge support
PCI: Add DT binding for Sigma Designs Tango PCIe controller
PCI: rockchip: Use normal register bank for config accessors
dt-bindings: PCI: Add documentation for MediaTek PCIe
PCI: Remove __pci_dev_reset() and pci_dev_reset()
PCI: Split ->reset_notify() method into ->reset_prepare() and ->reset_done()
PCI: xilinx: Make of_device_ids const
PCI: xilinx-nwl: Modify IRQ chip for legacy interrupts
PCI: vmd: Move SRCU cleanup after bus, child device removal
PCI: vmd: Correct comment: VMD domains start at 0x10000, not 0x1000
PCI: versatile: Add local struct device pointers
PCI: tegra: Do not allocate MSI target memory
PCI: tegra: Support MSI 64-bit addressing
PCI: rockchip: Use local struct device pointer consistently
PCI: rockchip: Check for clk_prepare_enable() errors during resume
MAINTAINERS: Remove Wenrui Li as Rockchip PCIe driver maintainer
PCI: rockchip: Configure RC's MPS setting
PCI: rockchip: Reconfigure configuration space header type
PCI: rockchip: Split out rockchip_pcie_cfg_configuration_accesses()
PCI: rockchip: Move configuration accesses into rockchip_pcie_cfg_atu()
Pull ARM updates from Russell King:
- add support for ftrace-with-registers, which is needed for kgraft and
other ftrace tools
- support for mremap() for the sigpage/vDSO so that checkpoint/restore
can work
- add timestamps to each line of the register dump output
- remove the unused KTHREAD_SIZE from nommu
- align the ARM bitops APIs with the generic API (using unsigned long
pointers rather than void pointers)
- make the configuration of userspace Thumb support an expert option so
that we can default it on, and avoid some hard to debug userspace
crashes
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8684/1: NOMMU: Remove unused KTHREAD_SIZE definition
ARM: 8683/1: ARM32: Support mremap() for sigpage/vDSO
ARM: 8679/1: bitops: Align prototypes to generic API
ARM: 8678/1: ftrace: Adds support for CONFIG_DYNAMIC_FTRACE_WITH_REGS
ARM: make configuration of userspace Thumb support an expert option
ARM: 8673/1: Fix __show_regs output timestamps
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from Juergen Gross:
"Other than fixes and cleanups it contains:
- support > 32 VCPUs at domain restore
- support for new sysfs nodes related to Xen
- some performance tuning for Linux running as Xen guest"
* tag 'for-linus-4.13-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
x86/xen: allow userspace access during hypercalls
x86: xen: remove unnecessary variable in xen_foreach_remap_area()
xen: allocate page for shared info page from low memory
xen: avoid deadlock in xenbus driver
xen: add sysfs node for hypervisor build id
xen: sync include/xen/interface/version.h
xen: add sysfs node for guest type
doc,xen: document hypervisor sysfs nodes for xen
xen/vcpu: Handle xen_vcpu_setup() failure at boot
xen/vcpu: Handle xen_vcpu_setup() failure in hotplug
xen/pv: Fix OOPS on restore for a PV, !SMP domain
xen/pvh*: Support > 32 VCPUs at domain restore
xen/vcpu: Simplify xen_vcpu related code
xen-evtchn: Bind dyn evtchn:qemu-dm interrupt to next online VCPU
xen: avoid type warning in xchg_xen_ulong
xen: fix HYPERVISOR_dm_op() prototype
xen: don't print error message in case of missing Xenstore entry
arm/xen: Adjust one function call together with a variable assignment
arm/xen: Delete an error message for a failed memory allocation in __set_phys_to_machine_multi()
arm/xen: Improve a size determination in __set_phys_to_machine_multi()
Pull KVM updates from Paolo Bonzini:
"PPC:
- Better machine check handling for HV KVM
- Ability to support guests with threads=2, 4 or 8 on POWER9
- Fix for a race that could cause delayed recognition of signals
- Fix for a bug where POWER9 guests could sleep with interrupts pending.
ARM:
- VCPU request overhaul
- allow timer and PMU to have their interrupt number selected from userspace
- workaround for Cavium erratum 30115
- handling of memory poisonning
- the usual crop of fixes and cleanups
s390:
- initial machine check forwarding
- migration support for the CMMA page hinting information
- cleanups and fixes
x86:
- nested VMX bugfixes and improvements
- more reliable NMI window detection on AMD
- APIC timer optimizations
Generic:
- VCPU request overhaul + documentation of common code patterns
- kvm_stat improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (124 commits)
Update my email address
kvm: vmx: allow host to access guest MSR_IA32_BNDCFGS
x86: kvm: mmu: use ept a/d in vmcs02 iff used in vmcs12
kvm: x86: mmu: allow A/D bits to be disabled in an mmu
x86: kvm: mmu: make spte mmio mask more explicit
x86: kvm: mmu: dead code thanks to access tracking
KVM: PPC: Book3S: Fix typo in XICS-on-XIVE state saving code
KVM: PPC: Book3S HV: Close race with testing for signals on guest entry
KVM: PPC: Book3S HV: Simplify dynamic micro-threading code
KVM: x86: remove ignored type attribute
KVM: LAPIC: Fix lapic timer injection delay
KVM: lapic: reorganize restart_apic_timer
KVM: lapic: reorganize start_hv_timer
kvm: nVMX: Check memory operand to INVVPID
KVM: s390: Inject machine check into the nested guest
KVM: s390: Inject machine check into the guest
tools/kvm_stat: add new interactive command 'b'
tools/kvm_stat: add new command line switch '-i'
tools/kvm_stat: fix error on interactive command 'g'
KVM: SVM: suppress unnecessary NMI singlestep on GIF=0 and nested exit
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- RAS reporting via GHES/APEI (ACPI)
- Indirect ftrace trampolines for modules
- Improvements to kernel fault reporting
- Page poisoning
- Sigframe cleanups and preparation for SVE context
- Core dump fixes
- Sparse fixes (mainly relating to endianness)
- xgene SoC PMU v3 driver
- Misc cleanups and non-critical fixes
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (75 commits)
arm64: fix endianness annotation for 'struct jit_ctx' and friends
arm64: cpuinfo: constify attribute_group structures.
arm64: ptrace: Fix incorrect get_user() use in compat_vfp_set()
arm64: ptrace: Remove redundant overrun check from compat_vfp_set()
arm64: ptrace: Avoid setting compat FP[SC]R to garbage if get_user fails
arm64: fix endianness annotation for __apply_alternatives()/get_alt_insn()
arm64: fix endianness annotation in get_kaslr_seed()
arm64: add missing conversion to __wsum in ip_fast_csum()
arm64: fix endianness annotation in acpi_parking_protocol.c
arm64: use readq() instead of readl() to read 64bit entry_point
arm64: fix endianness annotation for reloc_insn_movw() & reloc_insn_imm()
arm64: fix endianness annotation for aarch64_insn_write()
arm64: fix endianness annotation in aarch64_insn_read()
arm64: fix endianness annotation in call_undef_hook()
arm64: fix endianness annotation for debug-monitors.c
ras: mark stub functions as 'inline'
arm64: pass endianness info to sparse
arm64: ftrace: fix !CONFIG_ARM64_MODULE_PLTS kernels
arm64: signal: Allow expansion of the signal frame
acpi: apei: check for pending errors when probing GHES entries
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull GCC plugin updates from Kees Cook:
"The big part is the randstruct plugin infrastructure.
This is the first of two expected pull requests for randstruct since
there are dependencies in other trees that would be easier to merge
once those have landed. Notably, the IPC allocation refactoring in
-mm, and many trivial merge conflicts across several trees when
applying the __randomize_layout annotation.
As a result, it seemed like I should send this now since it is
relatively self-contained, and once the rest of the trees have landed,
send the annotation patches. I'm expecting the final phase of
randstruct (automatic struct selection) will land for v4.14, but if
its other tree dependencies actually make it for v4.13, I can send
that merge request too.
Summary:
- typo fix in Kconfig (Jean Delvare)
- randstruct infrastructure"
* tag 'gcc-plugins-v4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
ARM: Prepare for randomized task_struct
randstruct: Whitelist NIU struct page overloading
randstruct: Whitelist big_key path struct overloading
randstruct: Whitelist UNIXCB cast
randstruct: Whitelist struct security_hook_heads cast
gcc-plugins: Add the randstruct plugin
Fix English in description of GCC_PLUGIN_STRUCTLEAK
compiler: Add __designated_init annotation
gcc-plugins: Detail c-common.h location for GCC 4.6
Pull timer updates from Thomas Gleixner:
"A rather large update for timers/timekeeping:
- compat syscall consolidation (Al Viro)
- Posix timer consolidation (Christoph Helwig / Thomas Gleixner)
- Cleanup of the device tree based initialization for clockevents and
clocksources (Daniel Lezcano)
- Consolidation of the FTTMR010 clocksource/event driver (Linus
Walleij)
- The usual set of small fixes and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (93 commits)
timers: Make the cpu base lock raw
clocksource/drivers/mips-gic-timer: Fix an error code in 'gic_clocksource_of_init()'
clocksource/drivers/fsl_ftm_timer: Unmap region obtained by of_iomap
clocksource/drivers/tcb_clksrc: Make IO endian agnostic
clocksource/drivers/sun4i: Switch to the timer-of common init
clocksource/drivers/timer-of: Fix invalid iomap check
Revert "ktime: Simplify ktime_compare implementation"
clocksource/drivers: Fix uninitialized variable use in timer_of_init
kselftests: timers: Add test for frequency step
kselftests: timers: Fix inconsistency-check to not ignore first timestamp
time: Add warning about imminent deprecation of CONFIG_GENERIC_TIME_VSYSCALL_OLD
time: Clean up CLOCK_MONOTONIC_RAW time handling
posix-cpu-timers: Make timespec to nsec conversion safe
itimer: Make timeval to nsec conversion range limited
timers: Fix parameter description of try_to_del_timer_sync()
clocksource/drivers/fttmr010: Factor out clock read code
clocksource/drivers/fttmr010: Implement delay timer
clocksource/drivers: Add timer-of common init routine
clocksource/drivers/tcb_clksrc: Save timer context on suspend/resume
no users left
on MMU targets EFAULT is possible here. Make both return 0 or error,
passing what used to be the return value of flat_get_addr_from_rp()
by reference.
Pull EFI updates from Ingo Molnar:
"The main changes in this cycle were:
- Rework the EFI capsule loader to allow for workarounds for
non-compliant firmware (Ard Biesheuvel)
- Implement a capsule loader quirk for Quark X102x (Jan Kiszka)
- Enable SMBIOS/DMI support for the ARM architecture (Ard Biesheuvel)
- Add CONFIG_EFI_PGT_DUMP=y support for x86-32 and kexec (Sai
Praneeth)
- Fixes for EFI support for Xen dom0 guests running under x86-64
hosts (Daniel Kiper)"
* 'efi-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/xen/efi: Initialize only the EFI struct members used by Xen
efi: Process the MEMATTR table only if EFI_MEMMAP is enabled
efi/arm: Enable DMI/SMBIOS
x86/efi: Extend CONFIG_EFI_PGT_DUMP support to x86_32 and kexec as well
efi/efi_test: Use memdup_user() helper
efi/capsule: Add support for Quark security header
efi/capsule-loader: Use page addresses rather than struct page pointers
efi/capsule-loader: Redirect calls to efi_capsule_setup_info() via weak alias
efi/capsule: Remove NULL test on kmap()
efi/capsule-loader: Use a cached copy of the capsule header
efi/capsule: Adjust return type of efi_capsule_setup_info()
efi/capsule: Clean up pr_err/_info() messages
efi/capsule: Remove pr_debug() on ENOMEM or EFAULT
efi/capsule: Fix return code on failing kmap/vmap
With the new task struct randomization, we can run into a build
failure for certain random seeds, which will place fields beyond
the allow immediate size in the assembly:
arch/arm/kernel/entry-armv.S: Assembler messages:
arch/arm/kernel/entry-armv.S:803: Error: bad immediate value for offset (4096)
Only two constants in asm-offset.h are affected, and I'm changing
both of them here to work correctly in all configurations.
One more macro has the problem, but is currently unused, so this
removes it instead of adding complexity.
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[kees: Adjust commit log slightly]
R/M classes of cpus can have memory covered by MPU which in turn might
configure RAM as Normal i.e. bufferable and cacheable. It breaks
dma_alloc_coherent() and friends, since data can stuck in caches now
or be buffered.
This patch factors out DMA support for NOMMU configuration into
separate entity which provides dedicated dma_ops. We have to handle
there several cases:
- configurations with MMU/MPU setup
- configurations without MMU/MPU setup
- special case for M-class, since caches and MPU there are optional
In general we rely on default DMA area for coherent allocations or/and
per-device memory reserves suitable for coherent DMA, so if such
regions are set coherent allocations go from there.
In case MMU/MPU was not setup we fallback to normal page allocator for
DMA memory allocation.
In case we run M-class cpus, for configuration without cache support
(like Cortex-M3/M4) dma operations are forced to be coherent and wired
with dma-noop (such decision is made based on cacheid global
variable); however, if caches are detected there and no DMA coherent
region is given (either default or per-device), dma is disallowed even
MPU is not set - it is because M-class implement system memory map
which defines part of address space as Normal memory.
Reported-by: Alexandre Torgue <alexandre.torgue@st.com>
Reported-by: Andras Szemzo <sza@esh.hu>
Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Tested-by: Andras Szemzo <sza@esh.hu>
Tested-by: Alexandre TORGUE <alexandre.torgue@st.com>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
[hch: removed the dma_supported() implementation that isn't required anymore]
The introduction of pci_scan_root_bus_bridge() provides a PCI core API to
scan a PCI root bus backed by an already initialized struct pci_host_bridge
object, which simplifies the bus scan interface and makes the PCI scan root
bus interface easier to generalize as members are added to the struct
pci_host_bridge.
Convert ARM bios32 code to pci_scan_root_bus_bridge() to improve the PCI
root bus scanning interface.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[bhelgaas: fold in warning fix from Arnd Bergmann <arnd@arndb.de>:
http://lkml.kernel.org/r/20170621215323.3921382-1-arnd@arndb.de]
[bhelgaas: set bridge->ops for mv78xx0]
[bhelgaas: fold in fixes from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>:
http://lkml.kernel.org/r/20170701135457.GB8977@red-moon]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
And instead wire it up as method for all the dma_map_ops instances.
Note that the code seems a little fishy for dmabounce and iommu, but
for now I'd like to preserve the existing behavior 1:1.
DMA_ERROR_CODE is going to go away, so don't rely on it.
I didn't find any use of this macro in the current kernel tree (with git
grep). KTHREAD_SIZE is no longer used for a very very long time. So
let's remove this definition.
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Reviewed-by: Vladimir Murzin <vladimir.murzin@arm.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Currently external aborts are unsupported by the guest abort
handling. Add handling for SEAs so that the host kernel reports
SEAs which occur in the guest kernel.
When an SEA occurs in the guest kernel, the guest exits and is
routed to kvm_handle_guest_abort(). Prior to this patch, a print
message of an unsupported FSC would be printed and nothing else
would happen. With this patch, the code gets routed to the APEI
handling of SEAs in the host kernel to report the SEA information.
Signed-off-by: Tyler Baicar <tbaicar@codeaurora.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Christoffer Dall <cdall@linaro.org>
Pick up dependent changes.
include/asm-generic/bitops/find.h declares:
extern unsigned long
find_first_zero_bit(const unsigned long *addr, unsigned long size);
while arch/arm/include/asm/bitops.h declares:
#define find_first_zero_bit(p,sz) _find_first_zero_bit_le(p,sz)
extern int _find_first_zero_bit_le(const void * p, unsigned size);
Align the arm prototypes to the generic API, to have gcc report
inadequate arguments, such as pointer to u32.
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
The DYNAMIC_FTRACE_WITH_REGS configuration makes it possible for a
ftrace operation to specify if registers need to saved/restored by
the ftrace handler. This is needed by kgraft and possibly other
ftrace-based tools, and the ARM architecture is currently lacking
this feature. It would also be the first step to support the
"Kprobes-on-ftrace" optimization on ARM.
This patch introduces a new ftrace handler that stores the registers
on the stack before calling the next stage. The registers are restored
from the stack before going back to the instrumented function.
A side-effect of this patch is to activate the support for
ftrace_modify_call() as it defines ARCH_SUPPORTS_FTRACE_OPS for the
ARM architecture.
Signed-off-by: Abel Vesa <abelvesa@linux.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU fixes from Joerg Roedel:
- another compile-fix for my header cleanup
- a couple of fixes for the recently merged IOMMU probe deferal code
- fixes for ACPI/IORT code necessary with IOMMU probe deferal
* tag 'iommu-fixes-v4.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
arm: dma-mapping: Reset the device's dma_ops
ACPI/IORT: Move the check to get iommu_ops from translated fwspec
ARM: dma-mapping: Don't tear down third-party mappings
ACPI/IORT: Ignore all errors except EPROBE_DEFER
iommu/of: Ignore all errors except EPROBE_DEFER
iommu/of: Fix check for returning EPROBE_DEFER
iommu/dma: Fix function declaration
The improved type-checking version of container_of() triggers a warning for
xchg_xen_ulong, pointing out that 'xen_ulong_t' is unsigned, but atomic64_t
contains a signed value:
drivers/xen/events/events_2l.c: In function 'evtchn_2l_handle_events':
drivers/xen/events/events_2l.c:187:1020: error: call to '__compiletime_assert_187' declared with attribute error: pointer type mismatch in container_of()
This adds a cast to work around the warning.
Cc: Ian Abbott <abbotti@mev.co.uk>
Fixes: 85323a991d40 ("xen: arm: mandate EABI and use generic atomic operations.")
Fixes: daa2ac80834d ("kernel.h: handle pointers to arrays better in container_of()")
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Acked-by: Ian Abbott <abbotti@mev.co.uk>
As we are about to support VCPU attributes to set the timer IRQ numbers
in guest.c, move the static inlines for the VCPU attributes handlers
from the header file to guest.c.
Signed-off-by: Christoffer Dall <cdall@linaro.org>
Pull ARM fixes from Russell King:
"Three fixes this time around:
- Two fixes for noMMU, fixing the decompressor header layout, and
preventing a build error with some configurations.
- Fixing the hyp-stub updates that went in during the merge window
for platforms that use MCPM"
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8677/1: boot/compressed: fix decompressor header layout for v7-M
ARM: 8676/1: NOMMU: provide pgprot_device() macro
ARM: 8675/1: MCPM: ensure not to enter __hyp_soft_restart from loopback and cpu_power_down
Wire up the existing arm64 support for SMBIOS tables (aka DMI) for ARM as
well, by moving the arm64 init code to drivers/firmware/efi/arm-runtime.c
(which is shared between ARM and arm64), and adding a asm/dmi.h header to
ARM that defines the mapping routines for the firmware tables.
This allows userspace to access these tables to discover system information
exposed by the firmware. It also sets the hardware name used in crash
dumps, e.g.:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ed3c0000
[00000000] *pgd=bf1f3835
Internal error: Oops: 817 [#1] SMP THUMB2
Modules linked in:
CPU: 0 PID: 759 Comm: bash Not tainted 4.10.0-09601-g0e8f38792120-dirty #112
Hardware name: QEMU KVM Virtual Machine, BIOS 0.0.0 02/06/2015
NOTE: This does *NOT* enable or encourage the use of DMI quirks, i.e., the
the practice of identifying the platform via DMI to decide whether
certain workarounds for buggy hardware and/or firmware need to be
enabled. This would require the DMI subsystem to be enabled much
earlier than we do on ARM, which is non-trivial.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/20170602135207.21708-14-ard.biesheuvel@linaro.org
NOMMU build leads to the following error:
CC drivers/pci/mmap.o
drivers/pci/mmap.c: In function 'pci_mmap_resource_range':
drivers/pci/mmap.c:60:3: error: implicit declaration of function 'pgprot_device' [-Werror=implicit-function-declaration]
vma->vm_page_prot = pgprot_device(vma->vm_page_prot);
cc1: some warnings being treated as errors
scripts/Makefile.build:302: recipe for target 'drivers/pci/mmap.o' failed
make[2]: *** [drivers/pci/mmap.o] Error 1
scripts/Makefile.build:561: recipe for target 'drivers/pci' failed
make[1]: *** [drivers/pci] Error 2
Makefile:1016: recipe for target 'drivers' failed
make: *** [drivers] Error 2
Fix it with support of pgprot_device() macro for NOMMU.
Fixes: 00d2904ffeac ("ARM/PCI: Use generic pci_mmap_resource_range()")
Don't use request-less VCPU kicks when injecting IRQs, as a VCPU
kick meant to trigger the interrupt injection could be sent while
the VCPU is outside guest mode, which means no IPI is sent, and
after it has called kvm_vgic_flush_hwstate(), meaning it won't see
the updated GIC state until its next exit some time later for some
other reason. The receiving VCPU only needs to check this request
in VCPU RUN to handle it. By checking it, if it's pending, a
memory barrier will be issued that ensures all state is visible.
See "Ensuring Requests Are Seen" of
Documentation/virtual/kvm/vcpu-requests.rst
Signed-off-by: Andrew Jones <drjones@redhat.com>
Reviewed-by: Christoffer Dall <cdall@linaro.org>
A request called EXIT is too generic. All requests are meant to cause
exits, but different requests have different flags. Let's not make
it difficult to decide if the EXIT request is correct for some case
by just always providing unique requests for each case. This patch
changes EXIT to SLEEP, because that's what the request is asking the
VCPU to do.
Marc Zyngier suggested that we define the arch specific VCPU request
base, rather than requiring each arch to remember to start from 8.
That suggestion, along with Radim Krcmar's recent VCPU request flag
addition, snowballed into defining something of an arch VCPU request
defining API.
No functional change.
(Looks like x86 is running out of arch VCPU request bits. Maybe
someday we'll need to extend to 64.)
By moving the kernel side __SI_* defintions right next to the userspace
ones we can kill the non-uapi versions of <asm/siginfo.h> include
include/asm-generic/siginfo.h and untangle the unholy mess of includes.
[ tglx: Removed uapi/asm/siginfo.h from m32r, microblaze, mn10300 and score ]
Cc: linux-ia64@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20170603190102.28866-6-hch@lst.de
arch_setup_dma_ops() is used in device probe code paths to create an
IOMMU mapping and attach it to the device. The function assumes that the
device is attached to a device-specific IOMMU instance (or at least a
device-specific TLB in a shared IOMMU instance) and thus creates a
separate mapping for every device.
On several systems (Renesas R-Car Gen2 being one of them), that
assumption is not true, and IOMMU mappings must be shared between
multiple devices. In those cases the IOMMU driver knows better than the
generic ARM dma-mapping layer and attaches mapping to devices manually
with arm_iommu_attach_device(), which sets the DMA ops for the device.
The arch_setup_dma_ops() function takes this into account and bails out
immediately if the device already has DMA ops assigned. However, the
corresponding arch_teardown_dma_ops() function, called from driver
unbind code paths (including probe deferral), will tear the mapping down
regardless of who created it. When the device is reprobed
arch_setup_dma_ops() will be called again but won't perform any
operation as the DMA ops will still be set.
We need to reset the DMA ops in arch_teardown_dma_ops() to fix this.
However, we can't do so unconditionally, as then a new mapping would be
created by arch_setup_dma_ops() when the device is reprobed, regardless
of whether the device needs to share a mapping or not. We must thus keep
track of whether arch_setup_dma_ops() created the mapping, and only in
that case tear it down in arch_teardown_dma_ops().
Keep track of that information in the dev_archdata structure. As the
structure is embedded in all instances of struct device let's not grow
it, but turn the existing dma_coherent bool field into a bitfield that
can be used for other purposes.
Fixes: 09515ef5ddad ("of/acpi: Configure dma operations at probe time for platform/amba/pci bus devices")
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
We don't need to stop a specific VCPU when changing the active state,
because private IRQs can only be modified by a running VCPU for the
VCPU itself and it is therefore already stopped.
However, it is also possible for two VCPUs to be modifying the active
state of SPIs at the same time, which can cause the thread being stuck
in the loop that checks other VCPU threads for a potentially very long
time, or to modify the active state of a running VCPU. Fix this by
serializing all accesses to setting and clearing the active state of
interrupts using the KVM mutex.
Reported-by: Andrew Jones <drjones@redhat.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
no callers, no consistent semantics, no sane way to use it...
Hardware debugging in guests is not intercepted currently, it means
that a malicious guest can bring down the entire machine by writing
to the debug registers.
This patch enable trapping of all debug registers, preventing the
guests to access the debug registers. This includes access to the
debug mode(DBGDSCR) in the guest world all the time which could
otherwise mess with the host state. Reads return 0 and writes are
ignored (RAZ_WI).
The result is the guest cannot detect any working hardware based debug
support. As debug exceptions are still routed to the guest normal
debug using software based breakpoints still works.
To support debugging using hardware registers we need to implement a
debug register aware world switch as well as special trapping for
registers that may affect the host state.
Cc: stable@vger.kernel.org
Signed-off-by: Zhichao Huang <zhichao.huang@linaro.org>
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Pull ARM SoC driver updates from Olof Johansson:
"Driver updates for ARM SoCs:
Reset subsystem, merged through arm-soc by tradition:
- Make bool drivers explicitly non-modular
- New support for i.MX7 and Arria10 reset controllers
PATA driver for Palmchip BK371 (acked by Tejun)
Power domain drivers for i.MX (GPC, GPCv2)
- Moved out of mach-imx for GPC
- Bunch of tweaks, fixes, etc
PMC support for Tegra186
SoC detection support for Renesas RZ/G1H and RZ/G1N
Move Tegra flow controller driver from mach directory to drivers/soc
- (Power management / CPU power driver)
Misc smaller tweaks for other platforms"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits)
soc: pm-domain: Fix the mangled urls
soc: renesas: rcar-sysc: Add support for R-Car H3 ES2.0
soc: renesas: rcar-sysc: Add support for fixing up power area tables
soc: renesas: Register SoC device early
soc: imx: gpc: add workaround for i.MX6QP to the GPC PD driver
dt-bindings: imx-gpc: add i.MX6 QuadPlus compatible
soc: imx: gpc: add defines for domain index
soc: imx: Add GPCv2 power gating driver
dt-bindings: Add GPCv2 power gating driver
ARM/clk: move the ICST library to drivers/clk
ARM: plat-versatile: remove stale clock header
ARM: keystone: Drop PM domain support for k2g
soc: ti: Add ti_sci_pm_domains driver
dt-bindings: Add TI SCI PM Domains
PM / Domains: Do not check if simple providers have phandle cells
PM / Domains: Add generic data pointer to genpd data struct
soc/tegra: Add initial flowctrl support for Tegra132/210
soc/tegra: flowctrl: Add basic platform driver
soc/tegra: Move Tegra flowctrl driver
ARM: tegra: Remove unnecessary inclusion of flowctrl header
- add framework for supporting PCIe devices in Endpoint mode (Kishon
Vijay Abraham I)
- use non-postable PCI config space mappings when possible (Lorenzo
Pieralisi)
- clean up and unify mmap of PCI BARs (David Woodhouse)
- export and unify Function Level Reset support (Christoph Hellwig)
- avoid FLR for Intel 82579 NICs (Sasha Neftin)
- add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig)
- short-circuit config access failures for disconnected devices (Keith
Busch)
- remove D3 sleep delay when possible (Adrian Hunter)
- freeze PME scan before suspending devices (Lukas Wunner)
- stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava)
- disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann)
- add arch-specific alignment control to improve device passthrough by
avoiding multiple BARs in a page (Yongji Xie)
- add sysfs sriov_drivers_autoprobe to control VF driver binding
(Bodong Wang)
- allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas)
- fix crashes when unbinding host controllers that don't support
removal (Brian Norris)
- add driver for MicroSemi Switchtec management interface (Logan
Gunthorpe)
- add driver for Faraday Technology FTPCI100 host bridge (Linus
Walleij)
- add i.MX7D support (Andrey Smirnov)
- use generic MSI support for Aardvark (Thomas Petazzoni)
- make Rockchip driver modular (Brian Norris)
- advertise 128-byte Read Completion Boundary support for Rockchip
(Shawn Lin)
- advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin)
- convert atomic_t to refcount_t in HV driver (Elena Reshetova)
- add CPU IRQ affinity in HV driver (K. Y. Srinivasan)
- fix PCI bus removal in HV driver (Long Li)
- add support for ThunderX2 DMA alias topology (Jayachandran C)
- add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki)
- add ITE 8893 bridge DMA alias quirk (Jarod Wilson)
- restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices
(Manish Jaggi)
* tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits)
PCI: Don't allow unbinding host controllers that aren't prepared
ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP
MAINTAINERS: Add PCI Endpoint maintainer
Documentation: PCI: Add userguide for PCI endpoint test function
tools: PCI: Add sample test script to invoke pcitest
tools: PCI: Add a userspace tool to test PCI endpoint
Documentation: misc-devices: Add Documentation for pci-endpoint-test driver
misc: Add host side PCI driver for PCI test function device
PCI: Add device IDs for DRA74x and DRA72x
dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access
PCI: dwc: dra7xx: Workaround for errata id i870
dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode
PCI: dwc: dra7xx: Add EP mode support
PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently
dt-bindings: PCI: Add DT bindings for PCI designware EP mode
PCI: dwc: designware: Add EP mode support
Documentation: PCI: Add binding documentation for pci-test endpoint function
ixgbe: Use pcie_flr() instead of duplicating it
IB/hfi1: Use pcie_flr() instead of duplicating it
PCI: imx6: Fix spelling mistake: "contol" -> "control"
Merge more updates from Andrew Morton:
- the rest of MM
- various misc things
- procfs updates
- lib/ updates
- checkpatch updates
- kdump/kexec updates
- add kvmalloc helpers, use them
- time helper updates for Y2038 issues. We're almost ready to remove
current_fs_time() but that awaits a btrfs merge.
- add tracepoints to DAX
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (114 commits)
drivers/staging/ccree/ssi_hash.c: fix build with gcc-4.4.4
selftests/vm: add a test for virtual address range mapping
dax: add tracepoint to dax_insert_mapping()
dax: add tracepoint to dax_writeback_one()
dax: add tracepoints to dax_writeback_mapping_range()
dax: add tracepoints to dax_load_hole()
dax: add tracepoints to dax_pfn_mkwrite()
dax: add tracepoints to dax_iomap_pte_fault()
mtd: nand: nandsim: convert to memalloc_noreclaim_*()
treewide: convert PF_MEMALLOC manipulations to new helpers
mm: introduce memalloc_noreclaim_{save,restore}
mm: prevent potential recursive reclaim due to clearing PF_MEMALLOC
mm/huge_memory.c: deposit a pgtable for DAX PMD faults when required
mm/huge_memory.c: use zap_deposited_table() more
time: delete CURRENT_TIME_SEC and CURRENT_TIME
gfs2: replace CURRENT_TIME with current_time
apparmorfs: replace CURRENT_TIME with current_time()
lustre: replace CURRENT_TIME macro
fs: ubifs: replace CURRENT_TIME_SEC with current_time
fs: ufs: use ktime_get_real_ts64() for birthtime
Now that all call sites, completely decouple cacheflush.h and
set_memory.h
[sfr@canb.auug.org.au: kprobes/x86: merge fix for set_memory.h decoupling]
Link: http://lkml.kernel.org/r/20170418180903.10300fd3@canb.auug.org.au
Link: http://lkml.kernel.org/r/1488920133-27229-17-git-send-email-labbott@redhat.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Patch series "set_memory_* functions header refactor", v3.
The set_memory_* APIs came out of a desire to have a better way to
change memory attributes. Many of these attributes were linked to cache
functionality so the prototypes were put in cacheflush.h. These days,
the APIs have grown and have a much wider use than just cache APIs. To
support this growth, split off set_memory_* and friends into a separate
header file to avoid growing cacheflush.h for APIs that have nothing to
do with caches.
Link: http://lkml.kernel.org/r/1488920133-27229-2-git-send-email-labbott@redhat.com
"ARM:
- HYP mode stub supports kexec/kdump on 32-bit
- improved PMU support
- virtual interrupt controller performance improvements
- support for userspace virtual interrupt controller (slower, but
necessary for KVM on the weird Broadcom SoCs used by the Raspberry
Pi 3)
MIPS:
- basic support for hardware virtualization (ImgTec P5600/P6600/I6400
and Cavium Octeon III)
PPC:
- in-kernel acceleration for VFIO
s390:
- support for guests without storage keys
- adapter interruption suppression
x86:
- usual range of nVMX improvements, notably nested EPT support for
accessed and dirty bits
- emulation of CPL3 CPUID faulting
generic:
- first part of VCPU thread request API
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (227 commits)
kvm: nVMX: Don't validate disabled secondary controls
KVM: put back #ifndef CONFIG_S390 around kvm_vcpu_kick
Revert "KVM: Support vCPU-based gfn->hva cache"
tools/kvm: fix top level makefile
KVM: x86: don't hold kvm->lock in KVM_SET_GSI_ROUTING
KVM: Documentation: remove VM mmap documentation
kvm: nVMX: Remove superfluous VMX instruction fault checks
KVM: x86: fix emulation of RSM and IRET instructions
KVM: mark requests that need synchronization
KVM: return if kvm_vcpu_wake_up() did wake up the VCPU
KVM: add explicit barrier to kvm_vcpu_kick
KVM: perform a wake_up in kvm_make_all_cpus_request
KVM: mark requests that do not need a wakeup
KVM: remove #ifndef CONFIG_S390 around kvm_vcpu_wake_up
KVM: x86: always use kvm_make_request instead of set_bit
KVM: add kvm_{test,clear}_request to replace {test,clear}_bit
s390: kvm: Cpu model support for msa6, msa7 and msa8
KVM: x86: remove irq disablement around KVM_SET_CLOCK/KVM_GET_CLOCK
kvm: better MWAIT emulation for guests
KVM: x86: virtualize cpuid faulting
