path: root/arch/arm/kernel/entry-common.S
2011-06-06ARM: 6952/1: fix lockdep warning of "unannotated irqs-off"Ming Lei
This patch fixes the lockdep warning of "unannotated irqs-off"[1]. After entering __irq_usr, arm core will disable interrupt automatically, but __irq_usr does not annotate the irq disable, so lockdep may complain the warning if it has chance to check this in irq handler. This patch adds trace_hardirqs_off in __irq_usr before entering irq_handler to handle the irq, also calls ret_to_user_from_irq to avoid calling disable_irq again. This is also a fix for irq off tracer. [1], lockdep warning log of "unannotated irqs-off" [ 13.804687] ------------[ cut here ]------------ [ 13.809570] WARNING: at kernel/lockdep.c:3335 check_flags+0x78/0x1d0() [ 13.816467] Modules linked in: [ 13.819732] Backtrace: [ 13.822357] [<c01cb42c>] (dump_backtrace+0x0/0x100) from [<c06abb14>] (dump_stack+0x20/0x24) [ 13.831268] r6:c07d8c2c r5:00000d07 r4:00000000 r3:00000000 [ 13.837280] [<c06abaf4>] (dump_stack+0x0/0x24) from [<c01ffc04>] (warn_slowpath_common+0x5c/0x74) [ 13.846649] [<c01ffba8>] (warn_slowpath_common+0x0/0x74) from [<c01ffc48>] (warn_slowpath_null+0x2c/0x34) [ 13.856781] r8:00000000 r7:00000000 r6:c18b8194 r5:60000093 r4:ef182000 [ 13.863708] r3:00000009 [ 13.866485] [<c01ffc1c>] (warn_slowpath_null+0x0/0x34) from [<c0237d84>] (check_flags+0x78/0x1d0) [ 13.875823] [<c0237d0c>] (check_flags+0x0/0x1d0) from [<c023afc8>] (lock_acquire+0x4c/0x150) [ 13.884704] [<c023af7c>] (lock_acquire+0x0/0x150) from [<c06af638>] (_raw_spin_lock+0x4c/0x84) [ 13.893798] [<c06af5ec>] (_raw_spin_lock+0x0/0x84) from [<c01f9a44>] (sched_ttwu_pending+0x58/0x8c) [ 13.903320] r6:ef92d040 r5:00000003 r4:c18b8180 [ 13.908233] [<c01f99ec>] (sched_ttwu_pending+0x0/0x8c) from [<c01f9a90>] (scheduler_ipi+0x18/0x1c) [ 13.917663] r6:ef183fb0 r5:00000003 r4:00000000 r3:00000001 [ 13.923645] [<c01f9a78>] (scheduler_ipi+0x0/0x1c) from [<c01bc458>] (do_IPI+0x9c/0xfc) [ 13.932006] [<c01bc3bc>] (do_IPI+0x0/0xfc) from [<c06b0888>] (__irq_usr+0x48/0xe0) [ 13.939971] Exception stack(0xef183fb0 to 0xef183ff8) [ 13.945281] 3fa0: ffffffc3 0001500c 00000001 0001500c [ 13.953948] 3fc0: 00000050 400b45f0 400d9000 00000000 00000001 400d9600 6474e552 bea05b3c [ 13.962585] 3fe0: 400d96c0 bea059c0 400b6574 400b65d8 20000010 ffffffff [ 13.969573] r6:00000403 r5:fa240100 r4:ffffffff r3:20000010 [ 13.975585] ---[ end trace efc4896ab0fb62cb ]--- [ 13.980468] possible reason: unannotated irqs-off. [ 13.985534] irq event stamp: 1610 [ 13.989044] hardirqs last enabled at (1610): [<c01c703c>] no_work_pending+0x8/0x2c [ 13.997131] hardirqs last disabled at (1609): [<c01c7024>] ret_slow_syscall+0xc/0x1c [ 14.005371] softirqs last enabled at (0): [<c01fe5e4>] copy_process+0x2cc/0xa24 [ 14.013183] softirqs last disabled at (0): [< (null)>] (null) Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2010-12-24ARM: 6540/1: Stop irqsoff trace on return to userTodd Android Poynor
If the irqsoff tracer is in use, stop tracing the interrupt disable interval when returning to userspace. Tracing userspace execution time as interrupts disabled time is not helpful for kernel performance analysis purposes. Only do so if the irqsoff tracer is enabled, to avoid overhead for lockdep, which doesn't care. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-19ARM: ftrace: graph tracer + dynamic ftraceRabin Vincent
Support the graph tracer + dynamic ftrace combination on ARM. Signed-off-by: Rabin Vincent <rabin@rab.in>
2010-11-19ARM: ftrace: function graph tracer supportTim Bird
Cc: Tim Bird <tim.bird@am.sony.com> [rabin@rab.in: rebase on top of latest code, keep code in ftrace.c instead of separate file, check for ftrace_graph_entry also] Signed-off-by: Rabin Vincent <rabin@rab.in>
2010-11-19ARM: ftrace: use gas macros to avoid code duplicationRabin Vincent
Use assembler macros to avoid copy/pasting code between the implementations of the two variants of the mcount call. Signed-off-by: Rabin Vincent <rabin@rab.in>
2010-10-19Merge branch 'devel-stable' into develRussell King
2010-10-18Merge branches 'at91', 'dcache', 'ftrace', 'hwbpt', 'misc', 'mmci', 's3c', ↵Russell King
'st-ux' and 'unwind' into devel
2010-10-01ARM: SECCOMP supportNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-09-27Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits) ARM: 6411/1: vexpress: set RAM latencies to 1 cycle for PL310 on ct-ca9x4 tile ARM: 6409/1: davinci: map sram using MT_MEMORY_NONCACHED instead of MT_DEVICE ARM: 6408/1: omap: Map only available sram memory ARM: 6407/1: mmu: Setup MT_MEMORY and MT_MEMORY_NONCACHED L1 entries ARM: pxa: remove pr_<level> uses of KERN_<level> ARM: pxa168fb: clear enable bit when not active ARM: pxa: fix cpu_is_pxa*() not expanding to zero when not configured ARM: pxa168: fix corrected reset vector ARM: pxa: Use PIO for PI2C communication on Palm27x ARM: pxa: Fix Vpac270 gpio_power for MMC ARM: 6401/1: plug a race in the alignment trap handler ARM: 6406/1: at91sam9g45: fix i2c bus speed leds: leds-ns2: fix locking ARM: dove: fix __io() definition to use bus based offset dmaengine: fix interrupt clearing for mv_xor ARM: kirkwood: Unbreak PCIe I/O port ARM: Fix build error when using KCONFIG_CONFIG ARM: 6383/1: Implement phys_mem_access_prot() to avoid attributes aliasing ARM: 6400/1: at91: fix arch_gettimeoffset fallout ARM: 6398/1: add proc info for ARM11MPCore/Cortex-A9 from ARM ...
2010-09-17arm: fix really nasty sigreturn bugAl Viro
If a signal hits us outside of a syscall and another gets delivered when we are in sigreturn (e.g. because it had been in sa_mask for the first one and got sent to us while we'd been in the first handler), we have a chance of returning from the second handler to location one insn prior to where we ought to return. If r0 happens to contain -513 (-ERESTARTNOINTR), sigreturn will get confused into doing restart syscall song and dance. Incredible joy to debug, since it manifests as random, infrequent and very hard to reproduce double execution of instructions in userland code... The fix is simple - mark it "don't bother with restarts" in wrapper, i.e. set r8 to 0 in sys_sigreturn and sys_rt_sigreturn wrappers, suppressing the syscall restart handling on return from these guys. They can't legitimately return a restart-worthy error anyway. Testcase: #include <unistd.h> #include <signal.h> #include <stdlib.h> #include <sys/time.h> #include <errno.h> void f(int n) { __asm__ __volatile__( "ldr r0, [%0]\n" "b 1f\n" "b 2f\n" "1:b .\n" "2:\n" : : "r"(&n)); } void handler1(int sig) { } void handler2(int sig) { raise(1); } void handler3(int sig) { exit(0); } main() { struct sigaction s = {.sa_handler = handler2}; struct itimerval t1 = { .it_value = {1} }; struct itimerval t2 = { .it_value = {2} }; signal(1, handler1); sigemptyset(&s.sa_mask); sigaddset(&s.sa_mask, 1); sigaction(SIGALRM, &s, NULL); signal(SIGVTALRM, handler3); setitimer(ITIMER_REAL, &t1, NULL); setitimer(ITIMER_VIRTUAL, &t2, NULL); f(-513); /* -ERESTARTNOINTR */ write(1, "buggered\n", 9); return 1; } Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-17ARM: prevent multiple syscall restartsRussell King
Al Viro reports that calling "sys_sigsuspend(-ERESTARTNOHAND, 0, 0)" with two signals coming and being handled in kernel space results in the syscall restart being done twice. Avoid this by clearing the 'why' flag when we call the signal handling code to prevent further syscall restarts after the first. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02ARM: 6318/1: ftrace: fix and update dynamic ftraceRabin Vincent
This adds mcount recording and updates dynamic ftrace for ARM to work with the new ftrace dyamic tracing implementation. It also adds support for the mcount format used by newer ARM compilers. With dynamic tracing, mcount() is implemented as a nop. Callsites are patched on startup with nops, and dynamically patched to call to the ftrace_caller() routine as needed. Acked-by: Steven Rostedt <rostedt@goodmis.org> [recordmcount.pl change] Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02ARM: 6316/1: ftrace: add Thumb-2 supportRabin Vincent
Fix the mcount routines to build and run on a kernel built with the Thumb-2 instruction set by correcting the following errors using the fixes suggested by Catalin Marinas: - Problem: The following assembler errors appear at the "adr r0, ftrace_stub" instruction: entry-common.S: Assembler messages: entry-common.S:179: Error: invalid immediate for address calculation (value = 0x00000004) Fix: The errors don't occur with a non-global symbol, so use one. - Problem: The "mov lr, pc" does not set the lsb when storing the pc in lr. The called function returns with "bx lr", and the mode changes to ARM. Fix: Add a label on the return address and use "adr lr, BSYM(label)". We don't modify the old mcount because it won't be built when using Thumb-2. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02ARM: 6315/1: ftrace: add ENDPROC annotationsRabin Vincent
When building as Thumb-2, the ".type foo, %function" annotation in ENDPROC seems to be required in order for the assembly routines to be recognized as Thumb-2 code. If the ENDPROC annotations are not present, calls to these routines are generated as BLX instead of BL. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02ARM: 6314/1: ftrace: allow build without frame pointers on ARMRabin Vincent
With a new enough GCC, ARM function tracing can be supported without the need for frame pointers. This is essential for Thumb-2 support, since frame pointers aren't available then. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-10ARM: 6288/1: ftrace: document mcount formatsRabin Vincent
Add a comment describing the mcount variants and how the callsites look like. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-10ARM: 6287/1: ftrace: clean up mcount assembly indentationRabin Vincent
The mcount implementation currently uses a different indentation style from the rest of the file (and the rest of the ARM assembly in the kernel). Clean it up. Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-01ARM: 5734/1: arm: fix compilation of entry-common.S for older CPUsDmitry Artamonow
Commit 181f817eaaca4c1f introduced some new code to entry-common.S Sadly, this new code uses 'bx' instruction which is available only on ARMv5 and higher CPUs. This causes following compilation errors when building kernel for StrongARM (ARMv4): arch/arm/kernel/entry-common.S: Assembler messages: arch/arm/kernel/entry-common.S:129: Error: selected processor does not support `bx ip' arch/arm/kernel/entry-common.S:138: Error: selected processor does not support `bx ip' Fix these errors by using 'mov pc' instead of 'bx'. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-14Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (257 commits) [ARM] Update mach-types ARM: 5636/1: Move vendor enum to AMBA include ARM: Fix pfn_valid() for sparse memory [ARM] orion5x: Add LaCie NAS 2Big Network support [ARM] pxa/sharpsl_pm: zaurus c3000 aka spitz: fix resume ARM: 5686/1: at91: Correct AC97 reset line in at91sam9263ek board ARM: 5640/1: This patch modifies the support of AC97 on the at91sam9263 ek board ARM: 5689/1: Update default config of HP Jornada 700-series machines ARM: 5691/1: fix cache aliasing issues between kmap() and kmap_atomic() with highmem ARM: 5688/1: ks8695_serial: disable_irq() lockup ARM: 5687/1: fix an oops with highmem ARM: 5684/1: Add nuc960 platform to w90x900 ARM: 5683/1: Add nuc950 platform to w90x900 ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platform ARM: 5626/1: add suspend/resume functions to amba-pl011 serial driver ARM: 5625/1: fix hard coded 4K resource size in amba bus detection MMC: MMCI: convert realview MMC to use gpiolib ARM: 5685/1: Make MMCI driver compile without gpiolib ARM: implement highpte ARM: Show FIQ in /proc/interrupts on CONFIG_FIQ ... Fix up trivial conflict in arch/arm/kernel/signal.c. It was due to the TIF_NOTIFY_RESUME addition in commit d0420c83f ("KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures") and follow-ups.
2009-09-12Merge branch 'master' into develRussell King
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-08-15Merge branch 'for-rmk-2.6.32' of git://git.pengutronix.de/git/ukl/linux-2.6 ↵Russell King
into devel-stable
2009-08-15ARM: 5677/1: ARM support for TIF_RESTORE_SIGMASK/pselect6/ppoll/epoll_pwaitMikael Pettersson
This patch adds support for TIF_RESTORE_SIGMASK to ARM's signal handling, which allows to hook up the pselect6, ppoll, and epoll_pwait syscalls on ARM. Tested here with eabi userspace and a test program with a deliberate race between a child's exit and the parent's sigprocmask/select sequence. Using sys_pselect6() instead of sigprocmask/select reliably prevents the race. The other arch's support for TIF_RESTORE_SIGMASK has evolved over time: In 2.6.16: - add TIF_RESTORE_SIGMASK which parallels TIF_SIGPENDING - test both when checking for pending signal [changed later] - reimplement sys_sigsuspend() to use current->saved_sigmask, TIF_RESTORE_SIGMASK [changed later], and -ERESTARTNOHAND; ditto for sys_rt_sigsuspend(), but drop private code and use common code via __ARCH_WANT_SYS_RT_SIGSUSPEND; - there are now no "extra" calls to do_signal() so its oldset parameter is always &current->blocked so need not be passed, also its return value is changed to void - change handle_signal() to return 0/-errno - change do_signal() to honor TIF_RESTORE_SIGMASK: + get oldset from current->saved_sigmask if TIF_RESTORE_SIGMASK is set + if handle_signal() was successful then clear TIF_RESTORE_SIGMASK + if no signal was delivered and TIF_RESTORE_SIGMASK is set then clear it and restore the sigmask - hook up sys_pselect6() and sys_ppoll() In 2.6.19: - hook up sys_epoll_pwait() In 2.6.26: - allow archs to override how TIF_RESTORE_SIGMASK is implemented; default set_restore_sigmask() sets both TIF_RESTORE_SIGMASK and TIF_SIGPENDING; archs need now just test TIF_SIGPENDING again when checking for pending signal work; some archs now implement TIF_RESTORE_SIGMASK as a secondary/non-atomic thread flag bit - call set_restore_sigmask() in sys_sigsuspend() instead of setting TIF_RESTORE_SIGMASK In 2.6.29-rc: - kill sys_pselect7() which no arch wanted So for 2.6.31-rc6/ARM this patch does the following: - Add TIF_RESTORE_SIGMASK. Use the generic set_restore_sigmask() which sets both TIF_SIGPENDING and TIF_RESTORE_SIGMASK, so TIF_RESTORE_SIGMASK need not claim one of the scarce low thread flags, and existing TIF_SIGPENDING and _TIF_WORK_MASK tests need not be extended for TIF_RESTORE_SIGMASK. - sys_sigsuspend() is reimplemented to use current->saved_sigmask and set_restore_sigmask(), making it identical to most other archs - The private code for sys_rt_sigsuspend() is removed, instead generic code supplies it via __ARCH_WANT_SYS_RT_SIGSUSPEND. - sys_sigsuspend() and sys_rt_sigsuspend() no longer need a pt_regs parameter, so their assembly code wrappers are removed. - handle_signal() is changed to return 0 on success or -errno. - The oldset parameter to do_signal() is now redundant and removed, and the return value is now also redundant and changed to void. - do_signal() is changed to honor TIF_RESTORE_SIGMASK: + get oldset from current->saved_sigmask if TIF_RESTORE_SIGMASK is set + if handle_signal() was successful then clear TIF_RESTORE_SIGMASK + if no signal was delivered and TIF_RESTORE_SIGMASK is set then clear it and restore the sigmask - Hook up sys_pselect6, sys_ppoll, and sys_epoll_pwait. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-13[ARM] support tracing when using newer compilersUwe Kleine-König
Since gcc 4.4 the name and calling convention for function profiling on ARM changed. With this patch both types are supported. See http://sourceware.org/ml/libc-ports/2008-04/msg00009.html for some details. Lightly-Tested-by: Anand Gadiyar <gadiyar@ti.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2009-07-30ARM: 5627/1: Fix restoring of lr at the end of mcountUwe Kleine-König
After ftrace_trace_function is called r1 is probably clobbered so don't try to use its value for restoring. This was introduced in v2.6.29~38^2~7 Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implementation of the unified start-up and exceptions codeCatalin Marinas
This patch implements the ARM/Thumb-2 unified kernel start-up and exception handling code. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-05-30Add core support for ARMv6/v7 big-endianCatalin Marinas
Starting with ARMv6, the CPUs support the BE-8 variant of big-endian (byte-invariant). This patch adds the core support: - setting of the BE-8 mode via the CPSR.E register for both kernel and user threads - big-endian page table walking - REV used to rotate instructions read from memory during fault processing as they are still little-endian format - Kconfig and Makefile support for BE-8. The --be8 option must be passed to the final linking stage to convert the instructions to little-endian Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-03-19Merge branch 'master' of git://git.marvell.com/orion into develRussell King
Conflicts: arch/arm/mach-mx1/devices.c
2009-03-05[ARM] 5418/1: restore lr before leaving mcountUwe Kleine-König
gcc seems to expect that lr isn't clobbered by mcount, because for a function starting with: static int func(void) { void *ra = __builtin_return_address(0); printk(KERN_EMERG "__builtin_return_address(0) = %pS\n", ra) ... the following assembler is generated by gcc 4.3.2: 0: e1a0c00d mov ip, sp 4: e92dd810 push {r4, fp, ip, lr, pc} 8: e24cb004 sub fp, ip, #4 ; 0x4 c: ebfffffe bl 0 <mcount> 10: e59f0034 ldr r0, [pc, #52] 14: e1a0100e mov r1, lr 18: ebfffffe bl 0 <printk> Without this patch obviously __builtin_return_address(0) yields func+0x10 instead of the return address of the caller. Note this patch fixes a similar issue for the routines used with dynamic ftrace even though this isn't currently selectable for ARM. Cc: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] 5385/2: unwind: Add unwinding information to exception entry pointsCatalin Marinas
This is needed to allow or stop the unwinding at certain points in the kernel like exception entries. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-31annotate that [fp, #-4] is the saved lrUwe Kleine-König
2008-10-20ftrace: rename FTRACE to FUNCTION_TRACERSteven Rostedt
Due to confusion between the ftrace infrastructure and the gcc profiling tracer "ftrace", this patch renames the config options from FTRACE to FUNCTION_TRACER. The other two names that are offspring from FTRACE DYNAMIC_FTRACE and FTRACE_MCOUNT_RECORD will stay the same. This patch was generated mostly by script, and partially by hand. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-23ftrace: store mcount address in rec->ipAbhishek Sagar
Record the address of the mcount call-site. Currently all archs except sparc64 record the address of the instruction following the mcount call-site. Some general cleanups are entailed. Storing mcount addresses in rec->ip enables looking them up in the kprobe hash table later on to check if they're kprobe'd. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: davem@davemloft.net Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-02ftrace: core support for ARMAbhishek Sagar
Core ftrace support for the ARM architecture, which includes support for dynamic function tracing. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18Add a prefetch abort handlerPaul Brook
This patch adds a prefetch abort handler similar to the data abort one and renames the latter for consistency. Initial implementation by Paul Brook with some renaming by Catalin Marinas. Signed-off-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-01-26[ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fixGeorge G. Davis
Make the comment match the code Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17[ARM] 4185/2: entry: introduce get_irqnr_preamble and arch_ret_to_userDan Williams
get_irqnr_preamble allows machines to take some action before entering the get_irqnr_and_base loop. On iop we enable cp6 access. arch_ret_to_user is added to the userspace return path to allow individual architectures to take actions, like disabling coprocessor access, before the final return to userspace. Per Nicolas Pitre's note, there is no need to cp_wait on the return to user as the latency to return is sufficient. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove RETINSTR macroRussell King
RETINSTR is a left-over from the days when we had 26-bit and 32-bit CPU support integrated into the same tree. Since this is no longer the case, we can now remove RETINSTR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3335/1: Old-abi Thumb sys_syscall brokenPaul Brook
Patch from Paul Brook The old-abi sys_syscall syscall is broken when called from Thumb mode. It assumes the syscall number is an Arm syscall number (ie. starts from __NR_OABI_SYSCALL_BASE). In thumb mode syscall numbers start from zero. The patch below fixes this by clearing the nigh bits of the syscall number instead of inverting them. Technically this means we accept some invalid syscall numbers, but I can't see how that could be a problem. The two sets of numbers far apart that unimplemented syscalls should still be rejected. Signed-off-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-19[ARM] safer handling of syscall table paddingAl Viro
ARM entry-common.S needs to know syscall table size; in itself that would not be a problem, but there's an additional constraint - some of the instructions using it want a constant that would be a multiple of 4. So we have to pad syscall table with sys_ni_syscall and that's where the trouble begins. .rept pseudo-op wants a constant expression for number of repetitions and subtraction of two labels (before and after syscall table) doesn't always get simplified to constant early enough for .rept. If labels end up in different frags, we lose. And while the frag size is large enough (slightly below 4Kb), the syscall table is about 1/3 of that. We used to get away with that, but the recent changes had been enough to trigger the breakage. Proper fix is simple: have a macro (CALL(x)) to populate the table instead of using explicit .long x and the first time we include calls.S have it defined to .equ NR_syscalls,NR_syscalls+1. Then we can find the proper amount of padding on the first inclusion simply by looking at NR_syscalls at that time. And that will be constant, no matter what. Moreover, the same trick kills the need of having an estimate of padded NR_syscalls - it will be calculated for free at the same time. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3262/4: allow ptraced syscalls to be overridenNicolas Pitre
Patch from Nicolas Pitre This is needed by strace to properly handle the tracing of some system calls. It could be useful for other applications as well. Based on an earlier patch from Daniel Jacobowitz. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Daniel Jacobowitz <dan@debian.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3110/5: old ABI compat: multi-ABI syscall entry supportNicolas Pitre
Patch from Nicolas Pitre This patch adds the required code to support both user space ABIs at the same time. A second syscall table is created to include legacy ABI syscalls that need an ABI compat wrapper. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
