path: root/arch/arm/kernel/fiqasm.S
2011-05-26ARM: 6938/1: fiq: Refactor {get,set}_fiq_regs() for Thumb-2Dave Martin
* To remove the risk of inconvenient register allocation decisions by the compiler, these functions are separated out as pure assembler. * The apcs frame manipulation code is not applicable for Thumb-2 (and also not easily compatible). Since it's not essential to have a full frame on these leaf assembler functions, the frame manipulation is removed, in the interests of simplicity. * Split up ldm/stm instructions to be compatible with Thumb-2, as well as avoiding instruction forms deprecated on >= ARMv7. Signed-off-by: Dave Martin <dave.martin@linaro.org> Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
