path: root/arch/arm/kernel/setup.c
2009-09-15ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3Linus Walleij
This adds the TCM interface to Linux, when active, it will detect and report TCM memories and sizes early in boot if present, introduce generic TCM memory handling, provide a generic TCM memory pool and select TCM memory for the U300 platform. See the Documentation/arm/tcm.txt for documentation. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implementation of the unified start-up and exceptions codeCatalin Marinas
This patch implements the ARM/Thumb-2 unified kernel start-up and exception handling code. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-03-13Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into develRussell King
Conflicts: arch/arm/mach-at91/gpio.c
2009-03-03[ARM] 5417/1: Set the correct cacheid for ARMv6 CPUs with ARMv7 style MMUCatalin Marinas
The cacheid_init() function assumes that if cpu_architecture() returns 7, the caches are VIPT_NONALIASING. The cpu_architecture() function returns the version of the supported MMU features (e.g. TEX remapping) but it doesn't make any assumptions about the cache type. The patch adds the checking of the Cache Type Register for the ARMv7 format. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] 5383/2: unwind: Add core support for ARM stack unwindingCatalin Marinas
This patch adds the main functionality for parsing the stack unwinding information generated by the ARM EABI toolchains. The unwinding information consists of an index with a pair of words per function and a table with unwinding instructions. For more information, see "Exception Handling ABI for the ARM Architecture" at: http://infocenter.arm.com/help/topic/com.arm.doc.subset.swdev.abi/index.html Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-12[ARM] 5388/1: Add hwcap bits for VFPv3 and VFPv3D16Catalin Marinas
The VFPv3D16 is a VFPv3 CPU configuration where only 16 double registers are present, as the VFPv2 configuration. This patch adds the corresponding hwcap bits so that applications or debuggers have more information about the supported features. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-01[ARM] use asm/sections.hRussell King
Update to use the asm/sections.h header rather than declaring these symbols ourselves. Change __data_start to _data to conform with the naming found within asm/sections.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28Merge branch 'highmem' into develRussell King
Conflicts: arch/arm/mach-clps7500/include/mach/memory.h
2008-11-28[ARM] rationalize memory configuration code some moreNicolas Pitre
Currently there are two instances of struct meminfo: one in kernel/setup.c marked __initdata, and another in mm/init.c with permanent storage. Let's keep only the later to directly populate the permanent version from arm_add_memory(). Also move common validation tests between the MMU and non-MMU cases into arm_add_memory() to remove some duplication. Protection against overflowing the membank array is also moved in there in order to cover the kernel cmdline parsing path as well. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-06Add HWCAP_NEON to the ARM hwcap.h fileCatalin Marinas
2008-11-06Add "thumbee" to the hwcap_str arrayCatalin Marinas
This part was missed in the initial patch adding ThumbEE support. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-10-02[ARM] 5274/1: simplify request_standard_resources()Nicolas Pitre
There is no point converting memory bank addresses from physical to virtual just to convert them back to physical addresses. Furthermore this isn't "right" for highmem even if in this case the end result is the correct one. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-30[ARM] mm: move vmalloc= parsing to arch/arm/mm/mmu.cRussell King
There's no point scattering this around the tree, the parsing of the parameter might as well live beside the code which uses it. That also means we can make vmalloc_reserve a static variable. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-25[ARM] Print details relevant to how we handle the cacheRussell King
This replaces the original cache type decoding printks. We now indicate how we're treating the cache which we found, rather than what we found. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-25[ARM] Introduce new bitmask based cache type macrosRussell King
Rather than trying to (inaccurately) decode the cache type from the registers each time we need to decide what type of cache we have, use a bitmask initialized early during boot. Since the setup is a one-off initialization, we can be a little more clever and take account of the CPU architecture as well. Note that we continue to achieve the compactness on optimised kernels by forcing tests to always-false or always-true as appropriate, thereby allowing the compiler to do build-time code elimination. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-25[ARM] Remove cache type printksRussell King
The cache type register found in ARMv5 and later CPUs changes format and meaning depending on the CPU architecture version. Currently, this code: a) doesn't work for everything - Xscale's are identified as 'unknown 5'. b) is not able to tell whether the caches are VIVT or VIPT from the cache type. c) prints rubbish on some ARMv6 and ARMv7+ CPUs. The two solutions to this are: 1. Add yet more code to decode and print the various different register formats. 2. Remove the code altogther. The code only exists to decode and print the cache parameters. Increasing the complexity of it just for the sake of a few prinks isn't worth it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] clean up a load of old declarationsRussell King
... some of which are now in linux/*.h headers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] move initrd code from kernel/setup.c to mm/init.cRussell King
This quietens some sparse warnings about phys_initrd_start and phys_initrd_size. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-05[ARM] sparse: fix several warningsRussell King
arch/arm/kernel/process.c:270:6: warning: symbol 'show_fpregs' was not declared. Should it be static? This function isn't used, so can be removed. arch/arm/kernel/setup.c:532:9: warning: symbol 'len' shadows an earlier one arch/arm/kernel/setup.c:524:6: originally declared here A function containing two 'len's. arch/arm/mm/fault-armv.c:188:13: warning: symbol 'check_writebuffer_bugs' was not declared. Should it be static? arch/arm/mm/mmap.c:122:5: warning: symbol 'valid_phys_addr_range' was not declared. Should it be static? arch/arm/mm/mmap.c:137:5: warning: symbol 'valid_mmap_phys_addr_range' was not declared. Should it be static? Missing includes. arch/arm/kernel/traps.c:71:77: warning: Using plain integer as NULL pointer arch/arm/mm/ioremap.c:355:46: error: incompatible types in comparison expression (different address spaces) Sillies. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] cachetype: move definitions to separate headerRussell King
Rather than pollute asm/cacheflush.h with the cache type definitions, move them to asm/cachetype.h, and include this new header where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] cputype: separate definitions, use themRussell King
Add asm/cputype.h, moving functions and definitions from asm/system.h there. Convert all users of 'processor_id' to the more efficient read_cpuid_id() function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-09[ARM] prevent crashing when too much RAM installedLennert Buytenhek
This patch will truncate and/or ignore memory banks if their kernel direct mappings would (partially) overlap with the vmalloc area or the mappings between the vmalloc area and the address space top, to prevent crashing during early boot if there happens to be more RAM installed than we are expecting. Since the start of the vmalloc area is not at a fixed address (but the vmalloc end address is, via the per-platform VMALLOC_END define), a default area of 128M is reserved for vmalloc mappings, which can be shrunk or enlarged by passing an appropriate vmalloc= command line option as it is done on x86. On a board with a 3:1 user:kernel split, VMALLOC_END at 0xfe000000, two 512M RAM banks and vmalloc=128M (the default), this patch gives: Truncating RAM at 20000000-3fffffff to -35ffffff (vmalloc region overlap). Memory: 512MB 352MB = 864MB total On a board with a 3:1 user:kernel split, VMALLOC_END at 0xfe800000, two 256M RAM banks and vmalloc=768M, this patch gives: Truncating RAM at 00000000-0fffffff to -0e7fffff (vmalloc region overlap). Ignoring RAM at 10000000-1fffffff (vmalloc region overlap). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Riku Voipio <riku.voipio@iki.fi>
2008-07-23kgdb: support for ARCH=armJason Wessel
This patch adds the ARCH=arm specific a kgdb backend, originally written by Deepak Saxena <dsaxena@plexity.net> and George Davis <gdavis@mvista.com>. Geoff Levand <geoffrey.levand@am.sony.com>, Nicolas Pitre, Manish Lachwani, and Jason Wessel have contributed various fixups here as well. The KGDB patch makes one change to the core ARM architecture such that the traps are initialized early for use with the debugger or other subsystems. [ mingo@elte.hu: small cleanups. ] [ ben-linux@fluff.org: fixed early_trap_init ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Deepak Saxena <dsaxena@plexity.net>
2008-02-09[ARM] constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04Merge branches 'at91', 'ixp', 'master', 'misc', 'pxa' and 'realview' into develRussell King
* at91: [ARM] 4802/1: Fix typo and remove vague comment [ARM] 4660/3: at91: allow selecting UART for early kernel messages [ARM] 4739/1: at91sam9263: make gpio bank C and D irqs work * ixp: [ARM] 4809/2: ixp4xx: Merge dsmg600-power.c into dsmg600-setup.c [ARM] 4808/2: ixp4xx: Merge nas100d-power.c into nas100d-setup.c [ARM] 4807/2: ixp4xx: Merge nslu2-power.c into nslu2-setup.c [ARM] 4806/1: ixp4xx: Ethernet support for the nslu2 and nas100d boards [ARM] 4805/1: ixp4xx: Use leds-gpio driver instead of IXP4XX-GPIO-LED driver [ARM] 4715/2: Ethernet support for IXDP425 boards [ARM] 4714/2: Headers for IXP4xx built-in Ethernet and WAN drivers [ARM] 4713/3: Adds drivers for IXP4xx QMgr and NPE features [ARM] 4712/2: Adds functions to read and write IXP4xx "feature" bits [ARM] 4774/2: ixp4xx: Register dsmg600 rtc i2c_board_info [ARM] 4773/2: ixp4xx: Register nas100d rtc i2c_board_info [ARM] 4772/2: ixp4xx: Register nslu2 rtc i2c_board_info [ARM] 4769/2: ixp4xx: Button updates for the dsmg600 board [ARM] 4768/2: ixp4xx: Button and LED updates for the nas100d board [ARM] 4767/2: ixp4xx: Add bitops.h include to io.h [ARM] 4766/2: ixp4xx: Update ixp4xx_defconfig, enabling all supported boards * master: [ARM] 4810/1: - Fix 'section mismatch' building warnings [ARM] xtime_seqlock: fix more ARM machines for xtime deadlocking [ARM] 21285 serial: fix build error * misc: [ARM] 4736/1: Export atags to userspace and allow kexec to use customised atags * pxa: [ARM] 4798/1: pcm027: fix missing header file [ARM] 4803/1: pxa: fix building issue of poodle.c caused by patch 4737/1 [ARM] 4801/1: pxa: fix building issues of missing pxa2xx-regs.h [ARM] pxa: introduce sysdev for pxa3xx static memory controller [ARM] pxa: add preliminary suspend/resume code for pxa3xx [ARM] pxa: introduce sysdev for GPIO register saving/restoring [ARM] pxa: introduce sysdev for IRQ register saving/restoring [ARM] pxa: fix the warning of undeclared "struct pxaohci_platform_data" [ARM] pxa: change set_kset_name() to direct name assignment for MFP sysclass * realview: [ARM] 4822/1: RealView: Change the REALVIEW_MPCORE configuration option [ARM] 4821/1: RealView: Remove the platform dependencies from localtimer.c [ARM] 4820/1: RealView: Select the timer IRQ at run-time [ARM] 4819/1: RealView: Fix entry-macro.S to work with multiple platforms [ARM] 4818/1: RealView: Add core-tile detection [ARM] 4817/1: RealView: Move the AMBA resource definitions to realview_eb.c [ARM] 4816/1: RealView: Move the platform-specific definitions into board-eb.h [ARM] 4815/1: RealView: Add clockevents suport for the local timers [ARM] 4814/1: RealView: Add broadcasting clockevents support for ARM11MPCore [ARM] 4813/1: Add SMP helper functions for clockevents support [ARM] 4812/1: RealView: clockevents support for the RealView platforms [ARM] 4811/1: RealView: clocksource support for the RealView platforms
2008-02-04[ARM] 4736/1: Export atags to userspace and allow kexec to use customised atagsRichard Purdie
Currently, the atags used by kexec are fixed to the ones originally used to boot the kernel. This is less than ideal as changing the commandline, initrd and other options would be a useful feature. This patch exports the atags used for the current kernel to userspace through an "atags" file in procfs. The presence of the file is controlled by its own Kconfig option and cleans up several ifdef blocks into a separate file. The tags for the new kernel are assumed to be at a fixed location before the kernel image itself. The location of the tags used to boot the original kernel is unimportant and no longer saved. Based on a patch from Uli Luckas <u.luckas@road.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Uli Luckas <u.luckas@road.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4712/2: Adds functions to read and write IXP4xx "feature" bitsKrzysztof Halasa
Adds functions to read and write IXP4xx "feature" (aka "fuse") bits, containing information about available/enabled CPU features. The uncompress.h included by boot/compressed/misc.c resides in a different space than rest of the kernel and thus can't use asm/hardware.h (including asm/arch/cpu.h - which, in turn, may use EXPORTed symbol "processor_id"). Posted to linux-arm-kernel on 2 Dec 2007 and revised. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4599/1: Preserve ATAG list for use with kexec (2.6.23)Mike Westerhof
This patch resolves a kexec boot failure that can occur because no ATAGs are passed in to the kexec'd kernel. Currently the newly-kexec'd kernel may fail if it requires specific ATAGs, or it may fail because the fixed memory location at which it expects to find the ATAGs may contain random data instead of ATAGs. The patch ensures that any ATAGs passed to the current kernel at boot time are copied to a static buffer, and are copied back when kexec copies the new kernel into place. Thus the new kernel sees the same ATAGs from kexec and the boot loader. The boot parameters are copied without regard to type, content, or length -- this patch's scope is limited soley to saving and restoring a fixed-size block of memory containing the kernel's boot parameters. Additional functionality to examine, alter, or replace the ATAGs (using kexec, for example) can be implemented by manipulating the static buffer containing the preserved ATAGs. Note: the size of the buffer (1.5KB) is selected to comfortably hold one of each ATAG type, including a maximum-length command line and the maximum number of ATAG_MEM structures currently supported by the kernel. Should an ATAG list exceed that limit, the list will be silently truncated to that limit (to do other- wise at that point in the boot process would make a simple problem exceedingly complicated). [Note: this is the same patch as 4579, modified to accomodate the ATAG changes introduced in 2.6.23] Signed-off-by: Mike Westerhof <mwester at dls.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4585/1: Correctly identify the CPU architecture versionCatalin Marinas
The cpu_architecture() function in arch/arm/kernel/setup.c only works with cores produced by ARM Ltd. The more generic approach is to read the ID_MMFR0 register and check for the VMSA or PMSA version supported. With this patch, the ARM11MPCore would be reported as ARMv7 since its MMU is compatible with ARMv7. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-29Remove fs.h from mm.hAlexey Dobriyan
Remove fs.h from mm.h. For this, 1) Uninline vma_wants_writenotify(). It's pretty huge anyway. 2) Add back fs.h or less bloated headers (err.h) to files that need it. As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files rebuilt down to 3444 (-12.3%). Cross-compile tested without regressions on my two usual configs and (sigh): alpha arm-mx1ads mips-bigsur powerpc-ebony alpha-allnoconfig arm-neponset mips-capcella powerpc-g5 alpha-defconfig arm-netwinder mips-cobalt powerpc-holly alpha-up arm-netx mips-db1000 powerpc-iseries arm arm-ns9xxx mips-db1100 powerpc-linkstation arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200 arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2 arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads arm-ep93xx i386-up mips-pb1100 powerpc-pasemi arm-footbridge ia64 mips-pb1500 powerpc-pmac32 arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64 arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800 arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3 arm-h7202 ia64-gensparse mips-qemu powerpc-pseries arm-hackkit ia64-sim mips-rbhma4200 powerpc-up arm-integrator ia64-sn2 mips-rbhma4500 s390 arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig arm-iop33x ia64-zx1 mips-sead s390-up arm-ixp2000 m68k mips-tb0219 sparc arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig arm-jornada720 m68k-atari mips-workpad sparc-up arm-kafa m68k-bvme6000 mips-wrppmc sparc64 arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig arm-ks8695 m68k-mac parisc sparc64-defconfig arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64 arm-lpd7a400 m68k-q40 parisc-up x86_64 arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig arm-lusl7200 mips powerpc-celleb x86_64-up arm-mainstone mips-atlas powerpc-chrp32 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12[ARM] 4423/1: add ATAGS supportBill Gatliff
Examines the ATAGS pointer (r2) at boot, and interprets a nonzero value as a reference to an ATAGS structure. A suitable ATAGS structure replaces the kernel's command line. Signed-off-by: Bill Gatliff <bgat@billgatliff.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] 4387/1: fix /proc/cpuinfo formatting for pre-ARM7 partsGreg Ungerer
Fix the formating of the "CPU part" field to be consistent with the other fields for pre-ARM7 parts. One tab to many for them to all line up. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-13[ARM] Fix breakage caused by 72486f1f8f0a2bc828b9d30cf4690cf2dd6807fcRussell King
72486f1f8f0a2bc828b9d30cf4690cf2dd6807fc inverted the sense for enabling hotplug CPU controls without reference to any other architecture other than i386, ia64 and PowerPC. This left everyone else without hotplug CPU control. Fix ARM for this brain damage. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-19Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits) [ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports [ARM] 4140/1: AACI stability add ac97 timeout and retries [ARM] 4139/1: AACI record support [ARM] 4138/1: AACI: multiple channel support for IRQ handling [ARM] 4211/1: Provide a defconfig for ns9xxx [ARM] 4210/1: base for new machine type "NetSilicon NS9360" [ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM [ARM] 4221/1: S3C2443: DMA support [ARM] 4220/1: S3C24XX: DMA system initialised from sysdev [ARM] 4219/1: S3C2443: DMA source definitions [ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443 [ARM] 4217/1: S3C24XX: remove the dma channel show at startup [ARM] 4090/2: avoid clash between PXA and SA1111 defines [ARM] 4216/1: add .gitignore entries for ARM specific files [ARM] 4214/2: S3C2410: Add Armzone QT2410 [ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw [ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST [ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos [ARM] 4137/1: Add kexec support [ARM] 4201/1: SMP barriers pair needed for the secondary boot process ... Fix up conflict due to typedef removal in sound/arm/aaci.h
2007-02-12[PATCH] Dynamic kernel command-line: armAlon Bar-Lev
1. Rename saved_command_line into boot_command_line. 2. Set command_line as __initdata. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[ARM] 4134/1: Add generic support for outer cachesCatalin Marinas
The outer cache can be L2 as on RealView/EB MPCore platform or even L3 or further on ARMv7 cores. This patch adds the generic support for flushing the outer cache in the DMA operations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4054/1: ep93xx: add HWCAP_CRUNCHLennert Buytenhek
Add HWCAP_CRUNCH so that the dynamic linker knows whether it can use Crunch-optimised libraries or not. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-08[ARM] Handle HWCAP_VFP in VFP support codeRussell King
Don't set HWCAP_VFP in the processor support file; not only does it depend on the processor features, but it also depends on the support code being present. Therefore, only set it if the support code detects that we have a VFP coprocessor attached. Also, move the VFP handling of the coprocessor access register into the VFP support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] Merge individual ARM sub-treesRussell King
Merge: Atmel AT91RM9200 and AT91SAM9260 changes General ARM developments Disconfiguous memory cleanups 64-bit/32-bit division and sched_clock extension patches EP93xx support changes IOP support changes Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] Allow gcc to optimise arm_add_memory a little moreRussell King
For some reason, gcc was calculating meminfo.bank[meminfo.nr_banks] repeatedly. Use a pointer to it instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-03[ARM] 3881/4: xscale: clean up cp0/cp1 handlingLennert Buytenhek
XScale cores either have a DSP coprocessor (which contains a single 40 bit accumulator register), or an iWMMXt coprocessor (which contains eight 64 bit registers.) Because of the small amount of state in the DSP coprocessor, access to the DSP coprocessor (CP0) is always enabled, and DSP context switching is done unconditionally on every task switch. Access to the iWMMXt coprocessor (CP0/CP1) is enabled only when an iWMMXt instruction is first issued, and iWMMXt context switching is done lazily. CONFIG_IWMMXT is supposed to mean 'the cpu we will be running on will have iWMMXt support', but boards are supposed to select this config symbol by hand, and at least one pxa27x board doesn't get this right, so on that board, proc-xscale.S will incorrectly assume that we have a DSP coprocessor, enable CP0 on boot, and we will then only save the first iWMMXt register (wR0) on context switches, which is Bad. This patch redefines CONFIG_IWMMXT as 'the cpu we will be running on might have iWMMXt support, and we will enable iWMMXt context switching if it does.' This means that with this patch, running a CONFIG_IWMMXT=n kernel on an iWMMXt-capable CPU will no longer potentially corrupt iWMMXt state over context switches, and running a CONFIG_IWMMXT=y kernel on a non-iWMMXt capable CPU will still do DSP context save/restore. These changes should make iWMMXt work on PXA3xx, and as a side effect, enable proper acc0 save/restore on non-iWMMXt capable xsc3 cores such as IOP13xx and IXP23xx (which will not have CONFIG_CPU_XSCALE defined), as well as setting and using HWCAP_IWMMXT properly. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-02[ARM] 3912/1: Make PXA270 advertise HWCAP_IWMMXT capabilityPaul Gortmaker
ARM patch 3756/1 added HWCAP_IWMMXT. This patch adds support for broadcasting that info via /proc/cpuinfo and sets it for the CPU features of the PXA270. I've booted 19rc3 on a pxa270 and confirmed that the /proc/cpuinfo shows "iwmmxt" in the Features. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[ARM] Fix warnings in arch/arm/kernel/setup.cRussell King
cr_alignment is unsigned long, so should be the format string. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-29[ARM] Remove yucky ifdefs to print "id(wb)BRR" suffix on CPU nameRussell King
The "id(wb)BRR" suffix reports which CPU debugging options were (or were not) selected at kernel build time. Rather than have every proc-*.S file implement this, report the control register value, from which this information can be deduced. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-27[PATCH] node hotplug: register cpu: remove node structKAMEZAWA Hiroyuki
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now considering node-hot-add with cpu + memory on ACPI. I found acpi container, which describes node, could evaluate cpu before memory. This means cpu-hot-add occurs before memory hot add. In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(), which creates symbolic link from node to cpu, requires that node should be onlined before register_cpu(). When a node is onlined, its pgdat should be there. This patch-set holds off creating symbolic link from node to cpu until node is onlined. This removes node arguments from register_cpu(). Now, register_cpu() requires 'struct node' as its argument. But the array of struct node is now unified in driver/base/node.c now (By Goto's node hotplug patch). We can get struct node in generic way. So, this argument is not necessary now. This patch also guarantees add cpu under node only when node is onlined. It is necessary for node-hot-add vs. cpu-hot-add patch following this. Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard to its 'struct node *root' argument. This patch removes it. Also modify callers of register_cpu()/unregister_cpu, whose args are changed by register-cpu-remove-node-struct patch. [Brice.Goglin@ens-lyon.org: fix it] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
