commit 9c698bff66ab4914bb3d71da7dc6112519bde23e upstream.
Ensure that the signal page contains our poison instruction to increase
the protection against ROP attacks and also contains well defined
contents.
Acked-by: Will Deacon <will@kernel.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
Commit 18ea66bd6e7a95bdc598223d72757190916af28b upstream.
With Spectre-v1.1 mitigations, __put_user_error is pointless. In an attempt
to remove it, replace its references in frame setups with __put_user.
Signed-off-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: David A. Long <dave.long@linaro.org>
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Commit 3aa2df6ec2ca6bc143a65351cca4266d03a8bc41 upstream.
Use __copy_to_user() rather than __put_user_error() for individual
members when saving VFP state.
This has the benefit of disabling/enabling PAN once per copied struct
intead of once per write.
Commit 5ca451cf6ed04443774bbb7ee45332dafa42e99f upstream.
When saving the ARM integer registers, use __copy_to_user() to
copy them into user signal frame, rather than __put_user_error().
This has the benefit of disabling/enabling PAN once for the whole copy
Commit 42019fc50dfadb219f9e6ddf4c354f3837057d80 upstream.
__get_user_error() is used as a fast accessor to make copying structure
members in the signal handling path as efficient as possible. However,
with software PAN and the recent Spectre variant 1, the efficiency is
reduced as these are no longer fast accessors.
In the case of software PAN, it has to switch the domain register around
each access, and with Spectre variant 1, it would have to repeat the
access_ok() check for each access.
Use __copy_from_user() rather than __get_user_err() for individual
members when restoring VFP state.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Commit c32cd419d6650e42b9cdebb83c672ec945e6bd7e upstream.
It becomes much more efficient to use __copy_from_user() instead, so
let's use this for the ARM integer registers.
Pull ARM fixes from Russell King:
"Three fixes and a resulting cleanup for -rc2:
- Andre Przywara reported that he was seeing a warning with the new
cast inside DMA_ERROR_CODE's definition, and fixed the incorrect
use.
- Doug Anderson noticed that kgdb causes a "scheduling while atomic"
bug.
- OMAP5 folk noticed that their Thumb-2 compiled X servers crashed
when enabling support to cover ARMv6 CPUs due to a kernel bug
leaking some conditional context into the signal handler"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8425/1: kgdb: Don't try to stop the machine when setting breakpoints
ARM: 8437/1: dma-mapping: fix build warning with new DMA_ERROR_CODE definition
ARM: get rid of needless #if in signal handling code
ARM: fix Thumb2 signal handling when ARMv6 is enabled
Remove the #if statement which caused trouble for kernels that support
both ARMv6 and ARMv7. Older architectures do not implement these bits,
so it should be safe to always clear them.
When a kernel is built covering ARMv6 to ARMv7, we omit to clear the
IT state when entering a signal handler. This can cause the first
few instructions to be conditionally executed depending on the parent
context.
In any case, the original test for >= ARMv7 is broken - ARMv6 can have
Thumb-2 support as well, and an ARMv6T2 specific build would omit this
code too.
Relax the test back to ARMv6 or greater. This results in us always
clearing the IT state bits in the PSR, even on CPUs where these bits
are reserved. However, they're reserved for the IT state, so this
should cause no harm.
Cc: <stable@vger.kernel.org>
Fixes: d71e1352e240 ("Clear the IT state when invoking a Thumb-2 signal handler")
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Make the "fast" syscall return path fast again. The addition of IRQ
tracing and context tracking has made this path grossly inefficient.
We can do much better if these options are enabled if we save the
syscall return code on the stack - we then don't need to save a bunch
of registers around every single callout to C code.
Acked-by: Will Deacon <will.deacon@arm.com>
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
This patch remove clear_thread_flag(TIF_UPROBE) in do_work_pending(),
because uprobe_notify_resume() have do this.
Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com>
Using Rabin Vincent's ARM uprobes patches as a base, enable uprobes
support on ARM.
Caveats:
- Thumb is not supported
Signed-off-by: Rabin Vincent <rabin@rab.in>
The ARM architecture reference specifies that the IT state bits in the
PSR must be all zeros in ARM mode or behavior is unspecified. On the
Qualcomm Snapdragon S4/Krait architecture CPUs the processor continues
to consider the IT state bits while in ARM mode. This makes it so
that some instructions are skipped by the CPU.
Signed-off-by: T.J. Purtell <tj@mobisocial.us>
[rmk+kernel@arm.linux.org.uk: fixed whitespace formatting in patch]
In case of BE8 kernel data is in BE order whereas code stays in LE
order. Move sigreturn_codes to separate .S file and use proper
assembler mnemonics for these code snippets. In this case compiler
will take care of proper instructions byteswaps for BE8 case.
Change assumes that sufficiently Thumb-capable tools are used to
build kernel.
Problem was discovered during ltp testing of BE system: all rt_sig*
tests failed. Tested against the same tests in both BE and LE modes.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
vdso-like page)
Olof reports that noMMU builds error out with:
arch/arm/kernel/signal.c: In function 'setup_return':
arch/arm/kernel/signal.c:413:25: error: 'mm_context_t' has no member named 'sigpage'
This shows one of the evilnesses of IS_ENABLED(). Get rid of it here
and replace it with #ifdef's - and as no noMMU platform can make use
of sigpage, depend on CONIFG_MMU not CONFIG_ARM_MPU.
Reported-by: Olof Johansson <olof@lixom.net>
Unfortunately, I never committed the fix to a nasty oops which can
occur as a result of that commit:
kernel BUG at /home/olof/work/batch/include/linux/mm.h:414!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 490 Comm: killall5 Not tainted 3.11.0-rc3-00288-gabe0308 #53
task: e90acac0 ti: e9be8000 task.ti: e9be8000
PC is at special_mapping_fault+0xa4/0xc4
LR is at __do_fault+0x68/0x48c
This doesn't show up unless you do quite a bit of testing; a simple
boot test does not do this, so all my nightly tests were passing fine.
The reason for this is that install_special_mapping() expects the
page array to stick around, and as this was only inserting one page
which was stored on the kernel stack, that's why this was blowing up.
Tested-by: Olof Johansson <olof@lixom.net>
Move the signal handlers into a VDSO page rather than keeping them in
the vectors page. This allows us to place them randomly within this
page, and also map the page at a random location within userspace
further protecting these code fragments from ROP attacks. The new
VDSO page is also poisoned in the same way as the vector page.
Without an MMU it is possible for userspace programs to start executing code
in places that they have no business executing. The MPU allows some level of
protection against this.
This patch protects the vectors page from access by userspace processes.
Userspace tasks that dereference a null pointer are already protected by an
svc at 0x0 that kills them. However when tasks use an offset from a null
pointer (eg a function in a null struct) they miss this carefully placed svc
and enter the exception vectors in user mode, ending up in the kernel.
This patch causes programs that do this to receive a SEGV instead of happily
entering the kernel in user-mode, and hence avoid a 'Bad Mode' panic.
As part of this change it is necessary to make sigreturn happen via the
stack when there is not an sa_restorer function. This change is invisible to
userspace, and irrelevant to code compiled using a uClibc toolchain, which
always uses an sa_restorer function.
Because we don't get to remap the vectors in !MMU kuser_helpers are not
in a defined location, and hence aren't usable. This means we don't need to
worry about keeping them accessible from PL0
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
CC: Nicolas Pitre <nico@linaro.org>
CC: Catalin Marinas <catalin.marinas@arm.com>
This include is no longer needed.
(seems to be a leftover from try_to_freeze())
just let do_work_pending() return 1 on normal local restarts and
-1 on those that had been caused by ERESTART_RESTARTBLOCK (and 0
is still "all done, sod off to userland now"). And let the asm
glue flip scno to restart_syscall(2) one if it got negative from
us...
[will: resolved conflicts with audit fixes]
This reverts commit 3b0c06226783ffc836217eb34f7eca311b1e63f7.
We no longer require the restart trampoline for syscall restarting.
This reverts commit 433e2f307beff8adba241646ce9108544e0c5a03.
arch/arm/kernel/ptrace.c
Reintroduce the new syscall restart handling in preparation for further
patches from Al Viro.
This reverts commit 6b5c8045ecc7e726cdaa2a9d9c8e5008050e1252.
The new syscall restarting code can lead to problems if we take an
interrupt in userspace just before restarting the svc instruction. If
a signal is delivered when returning from the interrupt, the
TIF_SYSCALL_RESTARTSYS will remain set and cause any syscalls executed
from the signal handler to be treated as a restart of the previously
interrupted system call. This includes the final sigreturn call, meaning
that we may fail to exit from the signal context. Furthermore, if a
system call made from the signal handler requires a restart via the
restart_block, it is possible to clear the thread flag and fail to
restart the originally interrupted system call.
The right solution to this problem is to perform the restarting in the
kernel, avoiding the possibility of handling a further signal before the
restart is complete. Since we're almost at -rc6, let's revert the new
method for now and aim for in-kernel restarting at a later date.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This reverts commit fa18484d0947b976a769d15c83c50617493c81c1.
We need the restart trampoline back so that we can revert a related
problematic patch 6b5c8045ecc7e726cdaa2a9d9c8e5008050e1252 ("arm: new
way of handling ERESTART_RESTARTBLOCK").
Does block_sigmask() + tracehook_signal_handler(); called when
sigframe has been successfully built. All architectures converted
to it; block_sigmask() itself is gone now (merged into this one).
I'm still not too happy with the signature, but that's a separate
story (IMO we need a structure that would contain signal number +
siginfo + k_sigaction, so that get_signal_to_deliver() would fill one,
signal_delivered(), handle_signal() and probably setup...frame() -
take one).
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull second pile of signal handling patches from Al Viro:
"This one is just task_work_add() series + remaining prereqs for it.
There probably will be another pull request from that tree this
cycle - at least for helpers, to get them out of the way for per-arch
fixes remaining in the tree."
Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile
had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the
pr_foo() infrastructure to prefix printks") which changed one of the
pr_err() calls that this merge moves around.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
keys: kill task_struct->replacement_session_keyring
keys: kill the dummy key_replace_session_keyring()
keys: change keyctl_session_to_parent() to use task_work_add()
genirq: reimplement exit_irq_thread() hook via task_work_add()
task_work_add: generic process-context callbacks
avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers
parisc: need to check NOTIFY_RESUME when exiting from syscall
move key_repace_session_keyring() into tracehook_notify_resume()
TIF_NOTIFY_RESUME is defined on all targets now
Pull arm updates from Russell King:
"This contains both some fixes found when trying to get the
Assabet+neponset setup as a replacement firewall with a 3c589 PCMCIA
card, and a bunch of changes from Al to fix up the ARM signal
handling, particularly some of the restart behaviour."
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm:
ARM: neponset: make sure neponset_ncr_frob() is exported
ARM: fix out[bwl]()
arm: don't open-code ptrace_report_syscall()
arm: bury unused _TIF_RESTORE_SIGMASK
arm: remove unused restart trampoline
arm: new way of handling ERESTART_RESTARTBLOCK
arm: if we get into work_pending while returning to kernel mode, just go away
arm: don't call try_to_freeze() from do_signal()
arm: if there's no handler we need to restore sigmask, syscall or no syscall
arm: trim _TIF_WORK_MASK, get rid of useless test and branch...
arm: missing checks of __get_user()/__put_user() return values
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal.git into for-linus
guts of saved_sigmask-based sigsuspend/rt_sigsuspend. Takes
kernel sigset_t *.
Open-coded instances replaced with calling it.
new "syscall start" flag; handled in syscall_trace() by switching
syscall number to that of syscall_restart(2). Restarts of that
kind (ERESTART_RESTARTBLOCK) are handled by setting that bit;
syscall number is not modified until the actual call.
checking in do_signal() is pointless - if we get there with !user_mode(regs)
(and we might), we'll end up looping indefinitely. Check in work_pending
and break out of the loop if so.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
get_signal_to_deliver() will handle it itself
