path: root/arch/arm/kernel/xscale-cp0.c
2014-11-21ARM: convert printk(KERN_* to pr_*Russell King
Convert many (but not all) printk(KERN_* to pr_* to simplify the code. We take the opportunity to join some printk lines together so we don't split the message across several lines, and we also add a few levels to some messages which were previously missing them. Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-31arm: remove several unnecessary module.h include instancesPaul Gortmaker
Building these files does not reveal a hidden need for any of these. Since module.h brings in the whole kitchen sink, it just needlessly adds 30k+ lines to the cpp burden. There are probably lots more, but ARM files of mach-* and plat-* don't get coverage via a simple yesconfig build. They will have to be cleaned up and tested via using their respective configs. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-12-18ARM: Convert VFP/Crunch/XscaleCP thread_release() to exit_thread()Russell King
This avoids races in the VFP code where the dead thread may have state on another CPU. By moving this code to exit_thread(), we will be running as the thread, and therefore be running on the current CPU. This means that we can ensure that the only local state is accessed in the thread notifiers. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2006-12-03[ARM] 3881/4: xscale: clean up cp0/cp1 handlingLennert Buytenhek
XScale cores either have a DSP coprocessor (which contains a single 40 bit accumulator register), or an iWMMXt coprocessor (which contains eight 64 bit registers.) Because of the small amount of state in the DSP coprocessor, access to the DSP coprocessor (CP0) is always enabled, and DSP context switching is done unconditionally on every task switch. Access to the iWMMXt coprocessor (CP0/CP1) is enabled only when an iWMMXt instruction is first issued, and iWMMXt context switching is done lazily. CONFIG_IWMMXT is supposed to mean 'the cpu we will be running on will have iWMMXt support', but boards are supposed to select this config symbol by hand, and at least one pxa27x board doesn't get this right, so on that board, proc-xscale.S will incorrectly assume that we have a DSP coprocessor, enable CP0 on boot, and we will then only save the first iWMMXt register (wR0) on context switches, which is Bad. This patch redefines CONFIG_IWMMXT as 'the cpu we will be running on might have iWMMXt support, and we will enable iWMMXt context switching if it does.' This means that with this patch, running a CONFIG_IWMMXT=n kernel on an iWMMXt-capable CPU will no longer potentially corrupt iWMMXt state over context switches, and running a CONFIG_IWMMXT=y kernel on a non-iWMMXt capable CPU will still do DSP context save/restore. These changes should make iWMMXt work on PXA3xx, and as a side effect, enable proper acc0 save/restore on non-iWMMXt capable xsc3 cores such as IOP13xx and IXP23xx (which will not have CONFIG_CPU_XSCALE defined), as well as setting and using HWCAP_IWMMXT properly. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
