Otherwise power_machine_power_off() returns and e.g. unexpected interrupts
create stack traces.
(cherry picked from commit 8d35764ee16976d81ac7dd0b75b3c0b11f977ad1)
(cherry picked from commit e00c5466cc726653fa07a6fd42b39759a5a45bd3)
[ Upstream commit f18aef742c8fbd68e280dff0a63ba0ca6ee8ad85 ]
On at least x86 and ARM64, and as documented in the ptrace man page
a skipped system call will still cause a syscall exit ptrace stop.
Previous to this commit 32-bit ARM did not, resulting in strace
being confused when seccomp skips system calls.
This change also impacts programs that use ptrace to skip system calls.
Fixes: ad75b51459ae ("ARM: 7579/1: arch/allow a scno of -1 to not cause a SIGILL")
Signed-off-by: Timothy E Baldwin <T.E.Baldwin99@members.leeds.ac.uk>
Signed-off-by: Eugene Syromyatnikov <evgsyr@gmail.com>
Tested-by: Kees Cook <keescook@chromium.org>
Tested-by: Eugene Syromyatnikov <evgsyr@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit be167862ae7dd85c56d385209a4890678e1b0488 ]
Patch series "compiler: allow all arches to enable
CONFIG_OPTIMIZE_INLINING", v3.
This patch (of 11):
When function tracing for IPIs is enabled, we get a warning for an
overflow of the ipi_types array with the IPI_CPU_BACKTRACE type as
triggered by raise_nmi():
arch/arm/kernel/smp.c: In function 'raise_nmi':
arch/arm/kernel/smp.c:489:2: error: array subscript is above array bounds [-Werror=array-bounds]
trace_ipi_raise(target, ipi_types[ipinr]);
This is a correct warning as we actually overflow the array here.
This patch raise_nmi() to call __smp_cross_call() instead of
smp_cross_call(), to avoid calling into ftrace. For clarification, I'm
also adding a two new code comments describing how this one is special.
The warning appears to have shown up after commit e7273ff49acf ("ARM:
8488/1: Make IPI_CPU_BACKTRACE a "non-secure" SGI"), which changed the
number assignment from '15' to '8', but as far as I can tell has existed
since the IPI tracepoints were first introduced. If we decide to
backport this patch to stable kernels, we probably need to backport
e7273ff49acf as well.
[yamada.masahiro@socionext.com: rebase on v5.1-rc1]
Link: http://lkml.kernel.org/r/20190423034959.13525-2-yamada.masahiro@socionext.com
Fixes: e7273ff49acf ("ARM: 8488/1: Make IPI_CPU_BACKTRACE a "non-secure" SGI")
Fixes: 365ec7b17327 ("ARM: add IPI tracepoints") # v3.17
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Mathieu Malaterre <malat@debian.org>
Cc: Stefan Agner <stefan@agner.ch>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Borislav Petkov <bp@suse.de>
Cc: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit 143c2a89e0e5fda6c6fd08d7bc1126438c19ae90 ]
When running kprobe on -rt kernel, the below bug is caught:
|BUG: sleeping function called from invalid context at kernel/locking/rtmutex.c:931
|in_atomic(): 1, irqs_disabled(): 128, pid: 14, name: migration/0
|Preemption disabled at:[<802f2b98>] cpu_stopper_thread+0xc0/0x140
|CPU: 0 PID: 14 Comm: migration/0 Tainted: G O 4.8.3-rt2 #1
|Hardware name: Freescale LS1021A
|[<8025a43c>] (___might_sleep)
|[<80b5b324>] (rt_spin_lock)
|[<80b5c31c>] (__patch_text_real)
|[<80b5c3ac>] (patch_text_stop_machine)
|[<802f2920>] (multi_cpu_stop)
Since patch_text_stop_machine() is called in stop_machine() which
disables IRQ, sleepable lock should be not used in this atomic context,
so replace patch_lock to raw lock.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[ Upstream commit 5388a5b82199facacd3d7ac0d05aca6e8f902fed ]
machine_crash_nonpanic_core() does this:
while (1)
cpu_relax();
because the kernel has crashed, and we have no known safe way to deal
with the CPU. So, we place the CPU into an infinite loop which we
expect it to never exit - at least not until the system as a whole is
reset by some method.
In the absence of erratum 754327, this code assembles to:
b .
In other words, an infinite loop. When erratum 754327 is enabled,
this becomes:
1: dmb
b 1b
It has been observed that on some systems (eg, OMAP4) where, if a
crash is triggered, the system tries to kexec into the panic kernel,
but fails after taking the secondary CPU down - placing it into one
of these loops. This causes the system to livelock, and the most
noticable effect is the system stops after issuing:
Loading crashdump kernel...
to the system console.
The tested as working solution I came up with was to add wfe() to
these infinite loops thusly:
while (1) {
cpu_relax();
wfe();
which, without 754327 builds to:
1: wfe
b 1b
or with 754327 is enabled:
1: dmb
wfe
b 1b
Adding "wfe" does two things depending on the environment we're running
under:
- where we're running on bare metal, and the processor implements
"wfe", it stops us spinning endlessly in a loop where we're never
going to do any useful work.
- if we're running in a VM, it allows the CPU to be given back to the
hypervisor and rescheduled for other purposes (maybe a different VM)
rather than wasting CPU cycles inside a crashed VM.
However, in light of erratum 794072, Will Deacon wanted to see 10 nops
as well - which is reasonable to cover the case where we have erratum
754327 enabled _and_ we have a processor that doesn't implement the
wfe hint.
So, we now end up with:
1: wfe
b 1b
when erratum 754327 is disabled, or:
1: dmb
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
wfe
b 1b
when erratum 754327 is enabled. We also get the dmb + 10 nop
sequence elsewhere in the kernel, in terminating loops.
This is reasonable - it means we get the workaround for erratum
794072 when erratum 754327 is enabled, but still relinquish the dead
processor - either by placing it in a lower power mode when wfe is
implemented as such or by returning it to the hypervisior, or in the
case where wfe is a no-op, we use the workaround specified in erratum
794072 to avoid the problem.
These as two entirely orthogonal problems - the 10 nops addresses
erratum 794072, and the wfe is an optimisation that makes the system
more efficient when crashed either in terms of power consumption or
by allowing the host/other VMs to make use of the CPU.
I don't see any reason not to use kexec() inside a VM - it has the
potential to provide automated recovery from a failure of the VMs
kernel with the opportunity for saving a crashdump of the failure.
A panic() with a reboot timeout won't do that, and reading the
libvirt documentation, setting on_reboot to "preserve" won't either
(the documentation states "The preserve action for an on_reboot event
is treated as a destroy".) Surely it has to be a good thing to
avoiding having CPUs spinning inside a VM that is doing no useful
work.
Acked-by: Will Deacon <will.deacon@arm.com>
[ Upstream commit 72cd4064fccaae15ab84d40d4be23667402df4ed ]
ARMv8M introduces support for Security extension to M class, among
other things it affects exception handling, especially, encoding of
EXC_RETURN.
The new bits have been added:
Bit [6] Secure or Non-secure stack
Bit [5] Default callee register stacking
Bit [0] Exception Secure
which conflicts with hard-coded value of EXC_RETURN:
In fact, we only care of few bits:
Bit [3] Mode (0 - Handler, 1 - Thread)
Bit [2] Stack pointer selection (0 - Main, 1 - Process)
We can toggle only those bits and left other bits as they were on
exception entry.
It is basically, what patch does - saves EXC_RETURN when we do
transition form Thread to Handler mode (it is first svc), so later
saved value is used instead of EXC_RET_THREADMODE_PROCESSSTACK.
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
[ Upstream commit 74ffe79ae538283bbf7c155e62339f1e5c87b55a ]
Mostly unwind is done with irqs enabled however SLUB may call it with
irqs disabled while creating a new SLUB cache.
I had system freeze while loading a module which called
kmem_cache_create() on init. That means SLUB's __slab_alloc() disabled
interrupts and then
->new_slab_objects()
->new_slab()
->setup_object()
->setup_object_debug()
->init_tracking()
->set_track()
->save_stack_trace()
->save_stack_trace_tsk()
->walk_stackframe()
->unwind_frame()
->unwind_find_idx()
=>spin_lock_irqsave(&unwind_lock);
[ Upstream commit 1b5ba350784242eb1f899bcffd95d2c7cff61e84 ]
Arm TC2 fails cpu hotplug stress test.
This issue was tracked down to a missing copy of the new affinity
cpumask for the vexpress-spc interrupt into struct
irq_common_data.affinity when the interrupt is migrated in
migrate_one_irq().
Fix it by replacing the arm specific hotplug cpu migration with the
generic irq code.
This is the counterpart implementation to commit 217d453d473c ("arm64:
fix a migrating irq bug when hotplug cpu").
Tested with cpu hotplug stress test on Arm TC2 (multi_v7_defconfig plus
CONFIG_ARM_BIG_LITTLE_CPUFREQ=y and CONFIG_ARM_VEXPRESS_SPC_CPUFREQ=y).
The vexpress-spc interrupt (irq=22) on this board is affine to CPU0.
Its affinity cpumask now changes correctly e.g. from 0 to 1-4 when
CPU0 is hotplugged out.
Suggested-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Dietmar Eggemann <dietmar.eggemann@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
[ Upstream commit afc9f65e01cd114cb2cedf544d22239116ce0cc6 ]
When building the kernel as Thumb-2 with binutils 2.29 or newer, if the
assembler has seen the .type directive (via ENDPROC()) for a symbol, it
automatically handles the setting of the lowest bit when the symbol is
used with ADR. The badr macro on the other hand handles this lowest bit
manually. This leads to a jump to a wrong address in the wrong state
in the syscall return path:
Internal error: Oops - undefined instruction: 0 [#2] SMP THUMB2
Modules linked in:
CPU: 0 PID: 652 Comm: modprobe Tainted: G D 4.18.0-rc3+ #8
PC is at ret_fast_syscall+0x4/0x62
LR is at sys_brk+0x109/0x128
pc : [<80101004>] lr : [<801c8a35>] psr: 60000013
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 50c5387d Table: 9e82006a DAC: 00000051
Process modprobe (pid: 652, stack limit = 0x(ptrval))
80101000 <ret_fast_syscall>:
80101000: b672 cpsid i
80101002: f8d9 2008 ldr.w r2, [r9, #8]
80101006: f1b2 4ffe cmp.w r2, #2130706432 ; 0x7f000000
80101184 <local_restart>:
80101184: f8d9 a000 ldr.w sl, [r9]
80101188: e92d 0030 stmdb sp!, {r4, r5}
8010118c: f01a 0ff0 tst.w sl, #240 ; 0xf0
80101190: d117 bne.n 801011c2 <__sys_trace>
80101192: 46ba mov sl, r7
80101194: f5ba 7fc8 cmp.w sl, #400 ; 0x190
80101198: bf28 it cs
8010119a: f04f 0a00 movcs.w sl, #0
8010119e: f3af 8014 nop.w {20}
801011a2: f2af 1ea2 subw lr, pc, #418 ; 0x1a2
To fix this, add a new symbol name which doesn't have ENDPROC used on it
and use that with badr. We can't remove the badr usage since that would
would cause breakage with older binutils.
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Commit 383fb3ee8024d596f488d2dbaf45e572897acbdb upstream.
In big.Little systems, some CPUs require the Spectre workarounds in
paths such as the context switch, but other CPUs do not. In order
to handle these differences, we need per-CPU vtables.
We are unable to use the kernel's per-CPU variables to support this
as per-CPU is not initialised at times when we need access to the
vtables, so we have to use an array indexed by logical CPU number.
We use an array-of-pointers to avoid having function pointers in
the kernel's read/write .data section.
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: David A. Long <dave.long@linaro.org>
Tested-by: Julien Thierry <julien.thierry@arm.com>
Commit e209950fdd065d2cc46e6338e47e52841b830cba upstream.
Allow the way we access members of the processor vtable to be changed
at compile time. We will need to move to per-CPU vtables to fix the
Spectre variant 2 issues on big.Little systems.
However, we have a couple of calls that do not need the vtable
treatment, and indeed cause a kernel warning due to the (later) use
of smp_processor_id(), so also introduce the PROC_TABLE macro for
these which always use CPU 0's function pointers.
Commit 945aceb1db8885d3a35790cf2e810f681db52756 upstream.
Call the per-processor type check_bugs() method in the same way as we
do other per-processor functions - move the "processor." detail into
proc-fns.h.
Commit 65987a8553061515b5851b472081aedb9837a391 upstream.
Split out the lookup of the processor type and associated error handling
from the rest of setup_processor() - we will need to use this in the
secondary CPU bringup path for big.Little Spectre variant 2 mitigation.
Commit 899a42f836678a595f7d2bc36a5a0c2b03d08cbc upstream.
Move lookup_processor_type() out of the __init section so it is callable
from (eg) the secondary startup code during hotplug.
Commit 18ea66bd6e7a95bdc598223d72757190916af28b upstream.
With Spectre-v1.1 mitigations, __put_user_error is pointless. In an attempt
to remove it, replace its references in frame setups with __put_user.
Signed-off-by: Julien Thierry <julien.thierry@arm.com>
Commit 319508902600c2688e057750148487996396e9ca upstream.
Copy events to user using __copy_to_user() rather than copy members of
individually with __put_user_error().
This has the benefit of disabling/enabling PAN once per event intead of
once per event member.
Commit 3aa2df6ec2ca6bc143a65351cca4266d03a8bc41 upstream.
Use __copy_to_user() rather than __put_user_error() for individual
members when saving VFP state.
This has the benefit of disabling/enabling PAN once per copied struct
intead of once per write.
Commit 73839798af7ebc6c8d0c9271ebbbc148700e521f upstream.
When setting a dummy iwmmxt context, create a local instance and
use __copy_to_user both cases whether iwmmxt is being used or not.
This has the benefit of disabling/enabling PAN once for the whole copy
Commit 5ca451cf6ed04443774bbb7ee45332dafa42e99f upstream.
When saving the ARM integer registers, use __copy_to_user() to
copy them into user signal frame, rather than __put_user_error().
[ Upstream commit 82c08c3e7f171aa7f579b231d0abbc1d62e91974 ]
In case panic() and panic() called at the same time on different CPUS.
For example:
CPU 0:
panic()
__crash_kexec
machine_crash_shutdown
crash_smp_send_stop
machine_kexec
BUG_ON(num_online_cpus() > 1);
CPU 1:
panic()
local_irq_disable
panic_smp_self_stop
If CPU 1 calls panic_smp_self_stop() before crash_smp_send_stop(), kdump
fails. CPU1 can't receive the ipi irq, CPU1 will be always online.
To fix this problem, this patch split out the panic_smp_self_stop()
and add set_cpu_online(smp_processor_id(), false).
Signed-off-by: Yufen Wang <wangyufen@huawei.com>
Commit 8c8484a1c18e3231648f5ba7cc5ffb7fd70b3ca4 upstream.
__get_user_error() is used as a fast accessor to make copying structure
members as efficient as possible. However, with software PAN and the
recent Spectre variant 1, the efficiency is reduced as these are no
longer fast accessors.
In the case of software PAN, it has to switch the domain register around
each access, and with Spectre variant 1, it would have to repeat the
access_ok() check for each access.
Rather than using __get_user_error() to copy each semops element member,
copy each semops element in full using __copy_from_user().
Acked-by: Mark Rutland <mark.rutland@arm.com>
Commit 42019fc50dfadb219f9e6ddf4c354f3837057d80 upstream.
members in the signal handling path as efficient as possible. However,
with software PAN and the recent Spectre variant 1, the efficiency is
reduced as these are no longer fast accessors.
Use __copy_from_user() rather than __get_user_err() for individual
members when restoring VFP state.
Commit c32cd419d6650e42b9cdebb83c672ec945e6bd7e upstream.
It becomes much more efficient to use __copy_from_user() instead, so
let's use this for the ARM integer registers.
Commit 10573ae547c85b2c61417ff1a106cffbfceada35 upstream.
Prevent speculation at the syscall table decoding by clamping the index
used to zero on invalid system call numbers, and using the csdb
speculative barrier.
Boot-tested-by: Tony Lindgren <tony@atomide.com>
Reviewed-by: Tony Lindgren <tony@atomide.com>
Commit 9d3a04925deeabb97c8e26d940b501a2873e8af3 upstream.
Add support for per-processor bug checking - each processor function
descriptor gains a function pointer for this check, which must not be
an __init function. If non-NULL, this will be called whenever a CPU
enters the kernel via which ever path (boot CPU, secondary CPU startup,
CPU resuming, etc.)
This allows processor specific bug checks to validate that workaround
bits are properly enabled by firmware via all entry paths to the kernel.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Commit 26602161b5ba795928a5a719fe1d5d9f2ab5c3ef upstream.
Check for CPU bugs when secondary processors are being brought online,
and also when CPUs are resuming from a low power mode. This gives an
opportunity to check that processor specific bug workarounds are
correctly enabled for all paths that a CPU re-enters the kernel.
Commit a5b9177f69329314721aa7022b7e69dab23fa1f0 upstream.
Prepare the processor bug infrastructure so that it can be expanded to
check for per-processor bugs.
[ Upstream commit 2d7b3c64431245c95b05a441669c074da10db943 ]
When a panic() occurs, the kexec code uses smp_send_stop() to stop
the other CPUs, but this results in the CPU register state not being
saved, and gdb is unable to inspect the state of other CPUs.
Commit 0ee59413c967 ("x86/panic: replace smp_send_stop() with kdump
friendly version in panic path") addressed the issue on x86, but
ignored other architectures. Address the issue on ARM by splitting
out the crash stop implementation to crash_smp_send_stop() and
adding the necessary protection.
[ Upstream commit 73b9160d0dfe44dfdaffd6465dc1224c38a4a73c ]
Define vdso_start, vdso_end as array to avoid compile-time analysis error
for the case of built with CONFIG_FORTIFY_SOURCE.
and, since vdso_start, vdso_end are used in vdso.c only,
move extern-declaration from vdso.h to vdso.c.
If kernel is built with CONFIG_FORTIFY_SOURCE,
compile-time error happens at this code.
- if (memcmp(&vdso_start, "177ELF", 4))
The size of "&vdso_start" is recognized as 1 byte, but n is 4,
So that compile-time error is reported.
Signed-off-by: Jinbum Park <jinb.park7@gmail.com>
commit eb0146daefdde65665b7f076fbff7b49dade95b9 upstream.
Prohibit kprobes on do_undefinstr because kprobes on
arm is implemented by undefined instruction. This means
if we probe do_undefinstr(), it can cause infinit
recursive exception.
Fixes: 24ba613c9d6c ("ARM kprobes: core code")
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: stable@vger.kernel.org
commit dc8635b78cd8669c37e230058d18c33af7451ab1 upstream.
gcc -fisolate-erroneous-paths-dereference can generate calls to abort()
from modular code too.
[arnd@arndb.de: drop duplicate exports of abort()]
Link: http://lkml.kernel.org/r/20180102103311.706364-1-arnd@arndb.de
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Jose Abreu <Jose.Abreu@synopsys.com>
Cc: Evgeniy Didin <Evgeniy.Didin@synopsys.com>
commit 3aaf33bebda8d4ffcc0fc8ef39e6c1ac68823b11 upstream.
When qemu starts a kernel in a bare environment, the default SCR has
the AW and FW bits clear, which means that the kernel can't modify
the PSR A or PSR F bits, and means that FIQs and imprecise aborts are
always masked.
When running uboot under qemu, the AW and FW SCR bits are set, and the
kernel functions normally - and this is how real hardware behaves.
Fix this for qemu by ignoring the FIQ bit.
Fixes: 8bafae202c82 ("ARM: BUG if jumping to usermode address in kernel mode")
Cc: Alex Shi <alex.shi@linaro.org>
commit 8bafae202c82dc257f649ea3c275a0f35ee15113 upstream.
Detect if we are returning to usermode via the normal kernel exit paths
but the saved PSR value indicates that we are in kernel mode. This
could occur due to corrupted stack state, which has been observed with
"ftracetest".
This ensures that we catch the problem case before we get to user code.
Pull ARM fix from Russell King:
"Last ARM fix for 4.14.
This plugs a hole in dump_instr(), which, with certain conditions
satisfied, can dump instructions from kernel space"
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8720/1: ensure dump_instr() checks addr_limit
When CONFIG_DEBUG_USER is enabled, it's possible for a user to
deliberately trigger dump_instr() with a chosen kernel address.
Let's avoid problems resulting from this by using get_user() rather than
__get_user(), ensuring that we don't erroneously access kernel memory.
So that we can use the same code to dump user instructions and kernel
instructions, the common dumping code is factored out to __dump_instr(),
with the fs manipulated appropriately in dump_instr() around calls to
this.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull ARM fixes from Russell King:
"Three fixes this time around:
- ensure sparse realises that we're building for a 32-bit arch on
64-bit hosts.
- use the correct instruction for semihosting on v7m (nommu) CPUs.
- reserve address 0 to prevent the first page of memory being used on
nommu systems"
ARM: 8704/1: semihosting: use proper instruction on v7m processors
ARM: 8701/1: fix sparse flags for build on 64bit machines
ARM: 8700/1: nommu: always reserve address 0 away
The svc instruction doesn't exist on v7m processors. Semihosting ops are
invoked with the bkpt instruction instead.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Disable the generic address limit check in favor of an architecture
specific optimized implementation. The generic implementation using
pending work flags did not work well with ARM and alignment faults.
The address limit is checked on each syscall return path to user-mode
path as well as the irq user-mode return function. If the address limit
was changed, a function is called to report data corruption (stopping
the kernel or process based on configuration).
The address limit check has to be done before any pending work because
they can reset the address limit and the process is killed using a
SIGKILL signal. For example the lkdtm address limit check does not work
because the signal to kill the process will reset the user-mode address
limit.
Signed-off-by: Thomas Garnier <thgarnie@google.com>
Tested-by: Leonard Crestez <leonard.crestez@nxp.com>
Cc: Pratyush Anand <panand@redhat.com>
Cc: Dave Martin <Dave.Martin@arm.com>
Cc: Will Drewry <wad@chromium.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-api@vger.kernel.org
Cc: Yonghong Song <yhs@fb.com>
Link: http://lkml.kernel.org/r/1504798247-48833-4-git-send-email-keescook@chromium.org
This reverts commit 73ac5d6a2b6ac3ae8d1e1818f3e9946f97489bc9.
The work pending loop can call set_fs after addr_limit_user_check
removed the _TIF_FSCHECK flag. This may happen at anytime based on how
ARM handles alignment exceptions. It leads to an infinite loop condition.
After discussion, it has been agreed that the generic approach is not
tailored to the ARM architecture and any fix might not be complete. This
patch will be replaced by an architecture specific implementation. The
work flag approach will be kept for other architectures.
Reported-by: Leonard Crestez <leonard.crestez@nxp.com>
Link: http://lkml.kernel.org/r/1504798247-48833-3-git-send-email-keescook@chromium.org
Pull ARM updates from Russell King:
"Low priority fixes and updates for ARM:
- add some missing includes
- efficiency improvements in system call entry code when tracing is
enabled
- ensure ARMv6+ is always built as EABI
- export save_stack_trace_tsk()
- fix fatal signal handling during mm fault
- build translation table base address register from scratch
- appropriately align the .data section to a word boundary where we
rely on that data being word aligned"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8691/1: Export save_stack_trace_tsk()
ARM: 8692/1: mm: abort uaccess retries upon fatal signal
ARM: 8690/1: lpae: build TTB control register value from scratch in v7_ttb_setup
ARM: align .data section
ARM: always enable AEABI for ARMv6+
ARM: avoid saving and restoring registers unnecessarily
ARM: move PC value into r9
ARM: obtain thread info structure later
ARM: use aliases for registers in entry-common
ARM: 8689/1: scu: add missing errno include
ARM: 8688/1: pm: add missing types include
Pull ARM/arm64 SoC platform updates from Olof Johansson: "This branch
contains platform updates for 32- and 64-bit ARM, including defconfig
updates to enable new options, drivers and platforms. There are also a
few fixes and cleanups for some existing vendors.
Some of the things worth highlighting here are:
- Enabling new crypt drivers on arm64 defconfig
- QCOM IPQ8074 clocks and pinctrl drivers on arm64 defconfig
- Debug support enabled for Renesas r8a7743
- Various config updates for Renesas platforms (sound, USB, other
drivers)
- Platform support (including SMP) for TI dra762
- OMAP cleanups: Move to use generic 8250 debug_ll, removal of stale
DMA code"
* tag 'armsoc-platforms' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: multi_v7_defconfig: make eSDHC driver built-in
arm64: defconfig: enable rockchip graphics
MAINTAINERS: Update Cavium ThunderX2 entry
ARM: config: aspeed: Add I2C, VUART, LPC Snoop
ARM: configs: aspeed: Update Aspeed G4 with VMSPLIT_2G
ARM: s3c24xx: Fix NAND ECC mode for mini2440 board
ARM: davinci_all_defconfig: enable tinydrm and ST7586
arm64: defconfig: Enable QCOM IPQ8074 clock and pinctrl
ARM: defconfig: tegra: Enable ChipIdea UDC driver
ARM: configs: Add Tegra I2S interfaces to multi_v7_defconfig
ARM: tegra: Add Tegra I2S interfaces to defconfig
ARM: tegra: Update default configuration for v4.13-rc1
MAINTAINERS: update ARM/ZTE entry
soc: versatile: remove unnecessary static in realview_soc_probe()
ARM: Convert to using %pOF instead of full_name
ARM: hisi: Fix typo in comment
ARM: multi_v7_defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add recently added crypto drivers as modules
arm64: defconfig: enable CONFIG_UNIPHIER_WATCHDOG
The kernel watchdog is a great debugging tool for finding tasks that
consume a disproportionate amount of CPU time in contiguous chunks. One
can imagine building a similar watchdog for arbitrary driver threads
using save_stack_trace_tsk() and print_stack_trace(). However, this is
not viable for dynamically loaded driver modules on ARM platforms
because save_stack_trace_tsk() is not exported for those architectures.
Export save_stack_trace_tsk() for the ARM architecture to align with
x86 and support various debugging use cases such as arbitrary driver
thread watchdog timers.
Signed-off-by: Dustin Brown <dustinb@codeaurora.org>
Reuse the existing optimised memset implementation to implement an
optimised memset32 and memset64.
Link: http://lkml.kernel.org/r/20170720184539.31609-5-willy@infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: Russell King <rmk+kernel@armlinux.org.uk>
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Pull syscall updates from Ingo Molnar:
"Improve the security of set_fs(): we now check the address limit on a
number of key platforms (x86, arm, arm64) before returning to
user-space - without adding overhead to the typical system call fast
path"
* 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arm64/syscalls: Check address limit on user-mode return
arm/syscalls: Check address limit on user-mode return
x86/syscalls: Check address limit on user-mode return
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Robert Jarzmik reports that his PXA25x system fails to boot with 4.12,
failing at __flush_whole_cache in arch/arm/mm/proc-xscale.S:215:
0xc0019e20 <+0>: ldr r1, [pc, #788]
0xc0019e24 <+4>: ldr r0, [r1] <== here
with r1 containing 0xc06f82cd, which is the address of "clean_addr".
Examination of the System.map shows:
c06f22c8 D user_pmd_table
c06f22cc d __warned.19178
c06f22cd d clean_addr
indicating that a .data.unlikely section has appeared just before the
.data section from proc-xscale.S. According to objdump -h, it appears
that our assembly files default their .data alignment to 2**0, which
is bad news if the preceding .data section size is not power-of-2
aligned at link time.
Add the appropriate .align directives to all assembly files in arch/arm
that are missing them where we require an appropriate alignment.
Reported-by: Robert Jarzmik <robert.jarzmik@free.fr>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Avoid repeatedly saving and restoring registers around the calls to
trace_hardirqs_on() and context_tracking_user_exit(). With the
previous changes, we no longer need to preserve "lr" across these
calls, and if we re-load r0-r3 later, we can avoid preserving these
regsiters too.
Move the saved PC value into r9, thereby moving it into a caller-saved
register for functions that we may call during the entry to a syscall.
