Wolfram Sang reported an unannotated irqs-off warning from lockdep:
WARNING: CPU: 0 PID: 282 at kernel/locking/lockdep.c:3557 check_flags+0x84/0x1f4()
DEBUG_LOCKS_WARN_ON(current->hardirqs_enabled)
CPU: 0 PID: 282 Comm: rcS Tainted: G W 4.1.0-00002-g5b076054611833 #179
Hardware name: Generic Emma Mobile EV2 (Flattened Device Tree)
Backtrace:
[<c0012c94>] (dump_backtrace) from [<c0012e3c>] (show_stack+0x18/0x1c)
r6:c02dcc67 r5:00000009 r4:00000000 r3:00400000
[<c0012e24>] (show_stack) from [<c02510c8>] (dump_stack+0x20/0x28)
[<c02510a8>] (dump_stack) from [<c0022c44>] (warn_slowpath_common+0x8c/0xb4)
[<c0022bb8>] (warn_slowpath_common) from [<c0022cd8>] (warn_slowpath_fmt+0x38/0x40)
r8:c780f470 r7:00000000 r6:00000000 r5:c03b0570 r4:c0b7ec04
[<c0022ca4>] (warn_slowpath_fmt) from [<c004cd38>] (check_flags+0x84/0x1f4)
r3:c02e13d8 r2:c02dceaa
[<c004ccb4>] (check_flags) from [<c0050e50>] (lock_acquire+0x4c/0xbc)
r5:00000000 r4:60000193
[<c0050e04>] (lock_acquire) from [<c0256000>] (_raw_spin_lock+0x34/0x44)
r9:000a8d5c r8:00000001 r7:c7806000 r6:c780f460 r5:c03b06a0 r4:c780f460
[<c0255fcc>] (_raw_spin_lock) from [<c005a8cc>] (handle_fasteoi_irq+0x20/0x11c)
r4:c780f400
[<c005a8ac>] (handle_fasteoi_irq) from [<c0057a4c>] (generic_handle_irq+0x28/0x38)
r6:00000000 r5:c03b038c r4:00000012 r3:c005a8ac
[<c0057a24>] (generic_handle_irq) from [<c0057ae4>] (__handle_domain_irq+0x88/0xa8)
r4:00000000 r3:00000026
[<c0057a5c>] (__handle_domain_irq) from [<c000a3cc>] (gic_handle_irq+0x40/0x58)
r8:10c5347d r7:10c5347d r6:c35b1fb0 r5:c03a6304 r4:c8802000 r3:c35b1fb0
[<c000a38c>] (gic_handle_irq) from [<c0013bc8>] (__irq_usr+0x48/0x60)
Exception stack(0xc35b1fb0 to 0xc35b1ff8)
1fa0: 00000061 00000000 000ab736 00000066
1fc0: 00000061 000aa1f0 000a8d54 000a8d54 000a8d88 000a8d5c 000a8cc8 000a8d68
1fe0: 72727272 bef8a528 000398c0 00031334 20000010 ffffffff
r6:ffffffff r5:20000010 r4:00031334 r3:00000061
---[ end trace cb88537fdc8fa202 ]---
possible reason: unannotated irqs-off.
irq event stamp: 769
hardirqs last enabled at (769): [<c000f82c>] ret_fast_syscall+0x2c/0x54
hardirqs last disabled at (768): [<c000f80c>] ret_fast_syscall+0xc/0x54
softirqs last enabled at (0): [<c0020ec4>] copy_process.part.65+0x2e8/0x11dc
softirqs last disabled at (0): [< (null)>] (null)
His kernel configuration had:
CONFIG_PROVE_LOCKING=y
CONFIG_TRACE_IRQFLAGS=y
but no IRQSOFF_TRACER, which means entry from userspace can result in the
kernel seeing IRQs off without being notified of that change of state.
Change the IRQSOFF ifdef in the usr_entry macro to TRACE_IRQFLAGS instead.
Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
(cherry picked from commit 11b8b25ce4f8acfd3b438683c0c9ade27756c6e8)
commit 7ae85dc7687c7e7119053d83d02c560ea217b772 upstream.
In (23a4e40 arm: kgdb: Handle read-only text / modules) we moved to
using patch_text() to set breakpoints so that we could handle the case
when we had CONFIG_DEBUG_RODATA. That patch used patch_text().
Unfortunately, patch_text() assumes that we're not in atomic context
when it runs since it needs to grab a mutex and also wait for other
CPUs to stop (which it does with a completion).
This would result in a stack crawl if you had
CONFIG_DEBUG_ATOMIC_SLEEP and tried to set a breakpoint in kgdb. The
crawl looked something like:
BUG: scheduling while atomic: swapper/0/0/0x00010007
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.2.0-rc7-00133-geb63b34 #1073
Hardware name: Rockchip (Device Tree)
(unwind_backtrace) from [<c00133d4>] (show_stack+0x20/0x24)
(show_stack) from [<c05400e8>] (dump_stack+0x84/0xb8)
(dump_stack) from [<c004913c>] (__schedule_bug+0x54/0x6c)
(__schedule_bug) from [<c054065c>] (__schedule+0x80/0x668)
(__schedule) from [<c0540cfc>] (schedule+0xb8/0xd4)
(schedule) from [<c0543a3c>] (schedule_timeout+0x2c/0x234)
(schedule_timeout) from [<c05417c0>] (wait_for_common+0xf4/0x188)
(wait_for_common) from [<c0541874>] (wait_for_completion+0x20/0x24)
(wait_for_completion) from [<c00a0104>] (__stop_cpus+0x58/0x70)
(__stop_cpus) from [<c00a0580>] (stop_cpus+0x3c/0x54)
(stop_cpus) from [<c00a06c4>] (__stop_machine+0xcc/0xe8)
(__stop_machine) from [<c00a0714>] (stop_machine+0x34/0x44)
(stop_machine) from [<c00173e8>] (patch_text+0x28/0x34)
(patch_text) from [<c001733c>] (kgdb_arch_set_breakpoint+0x40/0x4c)
(kgdb_arch_set_breakpoint) from [<c00a0d68>] (kgdb_validate_break_address+0x2c/0x60)
(kgdb_validate_break_address) from [<c00a0e90>] (dbg_set_sw_break+0x1c/0xdc)
(dbg_set_sw_break) from [<c00a2e88>] (gdb_serial_stub+0x9c4/0xba4)
(gdb_serial_stub) from [<c00a11cc>] (kgdb_cpu_enter+0x1f8/0x60c)
(kgdb_cpu_enter) from [<c00a18cc>] (kgdb_handle_exception+0x19c/0x1d0)
(kgdb_handle_exception) from [<c0016f7c>] (kgdb_compiled_brk_fn+0x30/0x3c)
(kgdb_compiled_brk_fn) from [<c00091a4>] (do_undefinstr+0x1a4/0x20c)
(do_undefinstr) from [<c001400c>] (__und_svc_finish+0x0/0x34)
It turns out that when we're in kgdb all the CPUs are stopped anyway
so there's no reason we should be calling patch_text(). We can
instead directly call __patch_text() which assumes that CPUs have
already been stopped.
Fixes: 23a4e4050ba9 ("arm: kgdb: Handle read-only text / modules")
Reported-by: Aapo Vienamo <avienamo@nvidia.com>
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
commit 9b55613f42e8d40d5c9ccb8970bde6af4764b2ab upstream.
When a kernel is built covering ARMv6 to ARMv7, we omit to clear the
IT state when entering a signal handler. This can cause the first
few instructions to be conditionally executed depending on the parent
context.
In any case, the original test for >= ARMv7 is broken - ARMv6 can have
Thumb-2 support as well, and an ARMv6T2 specific build would omit this
code too.
Relax the test back to ARMv6 or greater. This results in us always
clearing the IT state bits in the PSR, even on CPUs where these bits
are reserved. However, they're reserved for the IT state, so this
should cause no harm.
Fixes: d71e1352e240 ("Clear the IT state when invoking a Thumb-2 signal handler")
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
commit 398f74569cebbf06bc6b069442bcd0e9616ca465 upstream.
John Stultz reports an RCU splat on boot with ARM ipi trace
events enabled.
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-00033-gb5bed2f #153 Not tainted
include/trace/events/ipi.h:68 suspicious rcu_dereference_check() usage!
RCU used illegally from idle CPU!
rcu_scheduler_active = 1, debug_locks = 0
RCU used illegally from extended quiescent state!
no locks held by swapper/0/0.
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.1.0-rc7-00033-gb5bed2f #153
Hardware name: Qualcomm (Flattened Device Tree)
[<c0216b08>] (unwind_backtrace) from [<c02136e8>] (show_stack+0x10/0x14)
[<c02136e8>] (show_stack) from [<c075e678>] (dump_stack+0x70/0xbc)
[<c075e678>] (dump_stack) from [<c0215a80>] (handle_IPI+0x428/0x604)
[<c0215a80>] (handle_IPI) from [<c020942c>] (gic_handle_irq+0x54/0x5c)
[<c020942c>] (gic_handle_irq) from [<c0766604>] (__irq_svc+0x44/0x7c)
Exception stack(0xc09f3f48 to 0xc09f3f90)
3f40: 00000001 00000001 00000000 c09f73b8 c09f4528 c0a5de9c
3f60: c076b4f0 00000000 00000000 c09ef108 c0a5cec1 00000001 00000000 c09f3f90
3f80: c026bf60 c0210ab8 20000113 ffffffff
[<c0766604>] (__irq_svc) from [<c0210ab8>] (arch_cpu_idle+0x20/0x3c)
[<c0210ab8>] (arch_cpu_idle) from [<c02647f0>] (cpu_startup_entry+0x2c0/0x5dc)
[<c02647f0>] (cpu_startup_entry) from [<c099bc1c>] (start_kernel+0x358/0x3c4)
[<c099bc1c>] (start_kernel) from [<8020807c>] (0x8020807c)
At this point in the IPI handling path we haven't called
irq_enter() yet, so RCU doesn't know that we're about to exit
idle and properly warns that we're using RCU from an idle CPU.
Use trace_ipi_entry_rcuidle() instead of trace_ipi_entry() so
that RCU is informed about our exit from idle.
Fixes: 365ec7b17327 ("ARM: add IPI tracepoints")
Reported-by: John Stultz <john.stultz@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Commit 338d9dd3e2ae ("ARM: 8351/1: perf: don't warn about missing
interrupt-affinity property for PPIs") added a check for PPIs so that
we avoid parsing the interrupt-affinity property for these naturally
affine interrupts.
Unfortunately, this check can trigger an early (successful) return and
we will leak the irqs array. This patch fixes the issue by reordering
the code so that the check is performed before any independent
allocation.
Reported-by: David Binderman <dcb314@hotmail.com>
Josh Stone reports:
I've discovered a case where both arm and arm64 will miss a ptrace
syscall-exit that they should report. If the syscall is entered
without TIF_SYSCALL_TRACE set, then it goes on the fast path. It's
then possible to have TIF_SYSCALL_TRACE added in the middle of the
syscall, but ret_fast_syscall doesn't check this flag again.
Fix this by always checking for a syscall trace in the fast exit path.
Reported-by: Josh Stone <jistone@redhat.com>
With commit 9fd85eb502a7 ("ARM: pmu: add support for interrupt-affinity
property"), we print a warning when we find a PMU SPI with a missing
missing interrupt-affinity property in a pmu node. Unfortunately, we
pass the wrong (NULL) device node to of_node_full_name, resulting in
unhelpful messages such as:
hw perfevents: Failed to parse <no-node>/interrupt-affinity[0]
This patch fixes the name to that of the pmu node.
Fixes: 9fd85eb502a7 (ARM: pmu: add support for interrupt-affinity property)
Acked-by: Mark Rutland <mark.rutland@arm.com>
PPIs are affine by nature, so the interrupt-affinity property is not
used and therefore we shouldn't print a warning in its absence.
Reported-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Pull ARM fixes from Russell King:
"A few fixes for the recently merged development updates:
- the update to convert a code branch in the procinfo structure
forgot to update the nommu code.
- VDSO only supported for V7 CPUs and later.
- VDSO build creates files which should be ignored by git but are not.
- ensure that make arch/arm/vdso/ doesn't build if it isn't enabled"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8344/1: VDSO: honor CONFIG_VDSO in Makefile
ARM: 8343/1: VDSO: add build artifacts to .gitignore
ARM: Fix nommu booting
ARM: 8342/1: VDSO: depend on CPU_V7
Commit bf35706f3d09 ("ARM: 8314/1: replace PROCINFO embedded branch with
relative offset") broke booting on nommu platforms as it didn't update
the nommu boot code. This patch fixes that oversight.
Fixes: bf35706f3d09 ("ARM: 8314/1: replace PROCINFO embedded branch with relative offset")
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"Here are the core arm64 updates for 4.1.
Highlights include a significant rework to head.S (allowing us to boot
on machines with physical memory at a really high address), an AES
performance boost on Cortex-A57 and the ability to run a 32-bit
userspace with 64k pages (although this requires said userspace to be
built with a recent binutils).
The head.S rework spilt over into KVM, so there are some changes under
arch/arm/ which have been acked by Marc Zyngier (KVM co-maintainer).
In particular, the linker script changes caused us some issues in
-next, so there are a few merge commits where we had to apply fixes on
top of a stable branch.
Other changes include:
- AES performance boost for Cortex-A57
- AArch32 (compat) userspace with 64k pages
- Cortex-A53 erratum workaround for #845719
- defconfig updates (new platforms, PCI, ...)"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (39 commits)
arm64: fix midr range for Cortex-A57 erratum 832075
arm64: errata: add workaround for cortex-a53 erratum #845719
arm64: Use bool function return values of true/false not 1/0
arm64: defconfig: updates for 4.1
arm64: Extract feature parsing code from cpu_errata.c
arm64: alternative: Allow immediate branch as alternative instruction
arm64: insn: Add aarch64_insn_decode_immediate
ARM: kvm: round HYP section to page size instead of log2 upper bound
ARM: kvm: assert on HYP section boundaries not actual code size
arm64: head.S: ensure idmap_t0sz is visible
arm64: pmu: add support for interrupt-affinity property
dt: pmu: extend ARM PMU binding to allow for explicit interrupt affinity
arm64: head.S: ensure visibility of page tables
arm64: KVM: use ID map with increased VA range if required
arm64: mm: increase VA range of identity map
ARM: kvm: implement replacement for ld's LOG2CEIL()
arm64: proc: remove unused cpu_get_pgd macro
arm64: enforce x1|x2|x3 == 0 upon kernel entry as per boot protocol
arm64: remove __calc_phys_offset
arm64: merge __enable_mmu and __turn_mmu_on
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
Pull ARM updates from Russell King:
"Included in this update are both some long term fixes and some new
features.
Fixes:
- An integer overflow in the calculation of ELF_ET_DYN_BASE.
- Avoiding OOMs for high-order IOMMU allocations
- SMP requires the data cache to be enabled for synchronisation
primitives to work, so prevent the CPU_DCACHE_DISABLE option being
visible on SMP builds.
- A bug going back 10+ years in the noMMU ARM94* CPU support code,
where it corrupts registers. Found by folk getting Linux running
on their cameras.
- Versatile Express needs an errata workaround enabled for CPU
hot-unplug to work.
Features:
- Clean up module linker by handling out of range relocations
separately from relocation cases we don't handle.
- Fix a long term bug in the pci_mmap_page_range() code, which we
hope won't impact userspace (we hope there's no users of the
existing broken interface.)
- Don't map DMA coherent allocations when we don't have a MMU.
- Drop experimental status for SMP_ON_UP.
- Warn when DT doesn't specify ePAPR mandatory cache properties.
- Add documentation concerning how we find the start of physical
memory for AUTO_ZRELADDR kernels, detailing why we have chosen the
mask and the implications of changing it.
- Updates from Ard Biesheuvel to address some issues with large
kernels (such as allyesconfig) failing to link.
- Allow hibernation to work on modern (ARMv7) CPUs - this appears to
have never worked in the past on these CPUs.
- Enable IRQ_SHOW_LEVEL, which changes the /proc/interrupts output
format (hopefully without userspace breaking... let's hope that if
it causes someone a problem, they tell us.)
- Fix tegra-ahb DT offsets.
- Rework ARM errata 643719 code (and ARMv7 flush_cache_louis()/
flush_dcache_all()) code to be more efficient, and enable this
errata workaround by default for ARMv7+SMP CPUs. This complements
the Versatile Express fix above.
- Rework ARMv7 context code for errata 430973, so that only Cortex A8
CPUs are impacted by the branch target buffer flush when this
errata is enabled. Also update the help text to indicate that all
r1p* A8 CPUs are impacted.
- Switch ARM to the generic show_mem() implementation, it conveys all
the information which we were already reporting.
- Prevent slow timer sources being used for udelay() - timers running
at less than 1MHz are not useful for this, and can cause udelay()
to return immediately, without any wait. Using such a slow timer
is silly.
- VDSO support for 32-bit ARM, mainly for gettimeofday() using the
ARM architected timer.
- Perf support for Scorpion performance monitoring units"
vdso semantic conflict fixed up as per linux-next.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (52 commits)
ARM: update errata 430973 documentation to cover Cortex A8 r1p*
ARM: ensure delay timer has sufficient accuracy for delays
ARM: switch to use the generic show_mem() implementation
ARM: proc-v7: avoid errata 430973 workaround for non-Cortex A8 CPUs
ARM: enable ARM errata 643719 workaround by default
ARM: cache-v7: optimise test for Cortex A9 r0pX devices
ARM: cache-v7: optimise branches in v7_flush_cache_louis
ARM: cache-v7: consolidate initialisation of cache level index
ARM: cache-v7: shift CLIDR to extract appropriate field before masking
ARM: cache-v7: use movw/movt instructions
ARM: allow 16-bit instructions in ALT_UP()
ARM: proc-arm94*.S: fix setup function
ARM: vexpress: fix CPU hotplug with CT9x4 tile.
ARM: 8276/1: Make CPU_DCACHE_DISABLE depend on !SMP
ARM: 8335/1: Documentation: DT bindings: Tegra AHB: document the legacy base address
ARM: 8334/1: amba: tegra-ahb: detect and correct bogus base address
ARM: 8333/1: amba: tegra-ahb: fix register offsets in the macros
ARM: 8339/1: Enable CONFIG_GENERIC_IRQ_SHOW_LEVEL
ARM: 8338/1: kexec: Relax SMP validation to improve DT compatibility
ARM: 8337/1: mm: Do not invoke OOM for higher order IOMMU DMA allocations
Pull power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups all over, although there are a few
items that sort of fall into the new feature category.
First off, we have new callbacks for PM domains that should help us to
handle some issues related to device initialization in a better way.
There also is some consolidation in the unified device properties API
area allowing us to use that inferface for accessing data coming from
platform initialization code in addition to firmware-provided data.
We have some new device/CPU IDs in a few drivers, support for new
chips and a new cpufreq driver too.
Specifics:
- Generic PM domains support update including new PM domain callbacks
to handle device initialization better (Russell King, Rafael J
Wysocki, Kevin Hilman)
- Unified device properties API update including a new mechanism for
accessing data provided by platform initialization code (Rafael J
Wysocki, Adrian Hunter)
- ARM cpuidle update including ARM32/ARM64 handling consolidation
(Daniel Lezcano)
- intel_idle update including support for the Silvermont Core in the
Baytrail SOC and for the Airmont Core in the Cherrytrail and
Braswell SOCs (Len Brown, Mathias Krause)
- New cpufreq driver for Hisilicon ACPU (Leo Yan)
- intel_pstate update including support for the Knights Landing chip
(Dasaratharaman Chandramouli, Kristen Carlson Accardi)
- QorIQ cpufreq driver update (Tang Yuantian, Arnd Bergmann)
- powernv cpufreq driver update (Shilpasri G Bhat)
- devfreq update including Tegra support changes (Tomeu Vizoso,
MyungJoo Ham, Chanwoo Choi)
- powercap RAPL (Running-Average Power Limit) driver update including
support for Intel Broadwell server chips (Jacob Pan, Mathias Krause)
- ACPI device enumeration update related to the handling of the
special PRP0001 device ID allowing DT-style 'compatible' property
to be used for ACPI device identification (Rafael J Wysocki)
- ACPI EC driver update including limited _DEP support (Lan Tianyu,
Lv Zheng)
- ACPI backlight driver update including a new mechanism to allow
native backlight handling to be forced on non-Windows 8 systems and
a new quirk for Lenovo Ideapad Z570 (Aaron Lu, Hans de Goede)
- New Windows Vista compatibility quirk for Sony VGN-SR19XN (Chen Yu)
- Assorted ACPI fixes and cleanups (Aaron Lu, Martin Kepplinger,
Masanari Iida, Mika Westerberg, Nan Li, Rafael J Wysocki)
- Fixes related to suspend-to-idle for the iTCO watchdog driver and
the ACPI core system suspend/resume code (Rafael J Wysocki, Chen Yu)
- PM tracing support for the suspend phase of system suspend/resume
transitions (Zhonghui Fu)
- Configurable delay for the system suspend/resume testing facility
(Brian Norris)
- PNP subsystem cleanups (Peter Huewe, Rafael J Wysocki)"
* tag 'pm+acpi-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (74 commits)
ACPI / scan: Fix NULL pointer dereference in acpi_companion_match()
ACPI / scan: Rework modalias creation when "compatible" is present
intel_idle: mark cpu id array as __initconst
powercap / RAPL: mark rapl_ids array as __initconst
powercap / RAPL: add ID for Broadwell server
intel_pstate: Knights Landing support
intel_pstate: remove MSR test
cpufreq: fix qoriq uniprocessor build
ACPI / scan: Take the PRP0001 position in the list of IDs into account
ACPI / scan: Simplify acpi_match_device()
ACPI / scan: Generalize of_compatible matching
device property: Introduce firmware node type for platform data
device property: Make it possible to use secondary firmware nodes
PM / watchdog: iTCO: stop watchdog during system suspend
cpufreq: hisilicon: add acpu driver
ACPI / EC: Call acpi_walk_dep_device_list() after installing EC opregion handler
cpufreq: powernv: Report cpu frequency throttling
intel_idle: Add support for the Airmont Core in the Cherrytrail and Braswell SOCs
intel_idle: Update support for Silvermont Core in Baytrail SOC
PM / devfreq: tegra: Register governor on module init
Pull perf changes from Ingo Molnar:
"Core kernel changes:
- One of the more interesting features in this cycle is the ability
to attach eBPF programs (user-defined, sandboxed bytecode executed
by the kernel) to kprobes.
This allows user-defined instrumentation on a live kernel image
that can never crash, hang or interfere with the kernel negatively.
(Right now it's limited to root-only, but in the future we might
allow unprivileged use as well.)
(Alexei Starovoitov)
- Another non-trivial feature is per event clockid support: this
allows, amongst other things, the selection of different clock
sources for event timestamps traced via perf.
This feature is sought by people who'd like to merge perf generated
events with external events that were measured with different
clocks:
- cluster wide profiling
- for system wide tracing with user-space events,
- JIT profiling events
etc. Matching perf tooling support is added as well, available via
the -k, --clockid <clockid> parameter to perf record et al.
(Peter Zijlstra)
Hardware enablement kernel changes:
- x86 Intel Processor Trace (PT) support: which is a hardware tracer
on steroids, available on Broadwell CPUs.
The hardware trace stream is directly output into the user-space
ring-buffer, using the 'AUX' data format extension that was added
to the perf core to support hardware constraints such as the
necessity to have the tracing buffer physically contiguous.
This patch-set was developed for two years and this is the result.
A simple way to make use of this is to use BTS tracing, the PT
driver emulates BTS output - available via the 'intel_bts' PMU.
More explicit PT specific tooling support is in the works as well -
will probably be ready by 4.2.
(Alexander Shishkin, Peter Zijlstra)
- x86 Intel Cache QoS Monitoring (CQM) support: this is a hardware
feature of Intel Xeon CPUs that allows the measurement and
allocation/partitioning of caches to individual workloads.
These kernel changes expose the measurement side as a new PMU
driver, which exposes various QoS related PMU events. (The
partitioning change is work in progress and is planned to be merged
as a cgroup extension.)
(Matt Fleming, Peter Zijlstra; CPU feature detection by Peter P
Waskiewicz Jr)
- x86 Intel Haswell LBR call stack support: this is a new Haswell
feature that allows the hardware recording of call chains, plus
tooling support. To activate this feature you have to enable it
via the new 'lbr' call-graph recording option:
perf record --call-graph lbr
perf report
or:
perf top --call-graph lbr
This hardware feature is a lot faster than stack walk or dwarf
based unwinding, but has some limitations:
- It reuses the current LBR facility, so LBR call stack and
branch record can not be enabled at the same time.
- It is only available for user-space callchains.
(Yan, Zheng)
- x86 Intel Broadwell CPU support and various event constraints and
event table fixes for earlier models.
(Andi Kleen)
- x86 Intel HT CPUs event scheduling workarounds. This is a complex
CPU bug affecting the SNB,IVB,HSW families that results in counter
value corruption. The mitigation code is automatically enabled and
is transparent.
(Maria Dimakopoulou, Stephane Eranian)
The perf tooling side had a ton of changes in this cycle as well, so
I'm only able to list the user visible changes here, in addition to
the tooling changes outlined above:
User visible changes affecting all tools:
- Improve support of compressed kernel modules (Jiri Olsa)
- Save DSO loading errno to better report errors (Arnaldo Carvalho de Melo)
- Bash completion for subcommands (Yunlong Song)
- Add 'I' event modifier for perf_event_attr.exclude_idle bit (Jiri Olsa)
- Support missing -f to override perf.data file ownership. (Yunlong Song)
- Show the first event with an invalid filter (David Ahern, Arnaldo Carvalho de Melo)
User visible changes in individual tools:
'perf data':
New tool for converting perf.data to other formats, initially
for the CTF (Common Trace Format) from LTTng (Jiri Olsa,
Sebastian Siewior)
'perf diff':
Add --kallsyms option (David Ahern)
'perf list':
Allow listing events with 'tracepoint' prefix (Yunlong Song)
Sort the output of the command (Yunlong Song)
'perf kmem':
Respect -i option (Jiri Olsa)
Print big numbers using thousands' group (Namhyung Kim)
Allow -v option (Namhyung Kim)
Fix alignment of slab result table (Namhyung Kim)
'perf probe':
Support multiple probes on different binaries on the same command line (Masami Hiramatsu)
Support unnamed union/structure members data collection. (Masami Hiramatsu)
Check kprobes blacklist when adding new events. (Masami Hiramatsu)
'perf record':
Teach 'perf record' about perf_event_attr.clockid (Peter Zijlstra)
Support recording running/enabled time (Andi Kleen)
'perf sched':
Improve the performance of 'perf sched replay' on high CPU core count machines (Yunlong Song)
'perf report' and 'perf top':
Allow annotating entries in callchains in the hists browser (Arnaldo Carvalho de Melo)
Indicate which callchain entries are annotated in the
TUI hists browser (Arnaldo Carvalho de Melo)
Add pid/tid filtering to 'report' and 'script' commands (David Ahern)
Consider PERF_RECORD_ events with cpumode == 0 in 'perf top', removing one
cause of long term memory usage buildup, i.e. not processing PERF_RECORD_EXIT
events (Arnaldo Carvalho de Melo)
'perf stat':
Report unsupported events properly (Suzuki K. Poulose)
Output running time and run/enabled ratio in CSV mode (Andi Kleen)
'perf trace':
Handle legacy syscalls tracepoints (David Ahern, Arnaldo Carvalho de Melo)
Only insert blank duration bracket when tracing syscalls (Arnaldo Carvalho de Melo)
Filter out the trace pid when no threads are specified (Arnaldo Carvalho de Melo)
Dump stack on segfaults (Arnaldo Carvalho de Melo)
No need to explicitely enable evsels for workload started from perf, let it
be enabled via perf_event_attr.enable_on_exec, removing some events that take
place in the 'perf trace' before a workload is really started by it.
Allow mixing with tracepoints and suppressing plain syscalls. (Arnaldo Carvalho de Melo)
There's also been a ton of infrastructure work done, such as the
split-out of perf's build system into tools/build/ and other changes -
see the shortlog and changelog for details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (358 commits)
perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init()
perf evlist: Fix type for references to data_head/tail
perf probe: Check the orphaned -x option
perf probe: Support multiple probes on different binaries
perf buildid-list: Fix segfault when show DSOs with hits
perf tools: Fix cross-endian analysis
perf tools: Fix error path to do closedir() when synthesizing threads
perf tools: Fix synthesizing fork_event.ppid for non-main thread
perf tools: Add 'I' event modifier for exclude_idle bit
perf report: Don't call map__kmap if map is NULL.
perf tests: Fix attr tests
perf probe: Fix ARM 32 building error
perf tools: Merge all perf_event_attr print functions
perf record: Add clockid parameter
perf sched replay: Use replay_repeat to calculate the runavg of cpu usage instead of the default value 10
perf sched replay: Support using -f to override perf.data file ownership
perf sched replay: Fix the EMFILE error caused by the limitation of the maximum open files
perf sched replay: Handle the dead halt of sem_wait when create_tasks() fails for any task
perf sched replay: Fix the segmentation fault problem caused by pr_err in threads
perf sched replay: Realloc the memory of pid_to_task stepwise to adapt to the different pid_max configurations
arch/arm/mm/proc-macros.S
Pull timer updates from Ingo Molnar:
"The main changes in this cycle were:
- clockevents state machine cleanups and enhancements (Viresh Kumar)
- clockevents broadcast notifier horror to state machine conversion
and related cleanups (Thomas Gleixner, Rafael J Wysocki)
- clocksource and timekeeping core updates (John Stultz)
- clocksource driver updates and fixes (Ben Dooks, Dmitry Osipenko,
Hans de Goede, Laurent Pinchart, Maxime Ripard, Xunlei Pang)
- y2038 fixes (Xunlei Pang, John Stultz)
- NMI-safe ktime_get_raw_fast() and general refactoring of the clock
code, in preparation to perf's per event clock ID support (Peter
Zijlstra)
- generic sched/clock fixes, optimizations and cleanups (Daniel
Thompson)
- clockevents cpu_down() race fix (Preeti U Murthy)"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (94 commits)
timers/PM: Drop unnecessary braces from tick_freeze()
timers/PM: Fix up tick_unfreeze()
timekeeping: Get rid of stale comment
clockevents: Cleanup dead cpu explicitely
clockevents: Make tick handover explicit
clockevents: Remove broadcast oneshot control leftovers
sched/idle: Use explicit broadcast oneshot control function
ARM: Tegra: Use explicit broadcast oneshot control function
ARM: OMAP: Use explicit broadcast oneshot control function
intel_idle: Use explicit broadcast oneshot control function
ACPI/idle: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast oneshot control function
x86/amd/idle, clockevents: Use explicit broadcast oneshot control functions
clockevents: Provide explicit broadcast oneshot control functions
clockevents: Remove the broadcast control leftovers
ARM: OMAP: Use explicit broadcast control function
intel_idle: Use explicit broadcast control function
cpuidle: Use explicit broadcast control function
ACPI/processor: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast control function
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.1
The most interesting bit here is irqfd/ioeventfd support for ARM and
ARM64.
Summary:
ARM/ARM64:
fixes for live migration, irqfd and ioeventfd support (enabling
vhost, too), page aging
s390:
interrupt handling rework, allowing to inject all local interrupts
via new ioctl and to get/set the full local irq state for migration
and introspection. New ioctls to access memory by virtual address,
and to get/set the guest storage keys. SIMD support.
MIPS:
FPU and MIPS SIMD Architecture (MSA) support. Includes some
patches from Ralf Baechle's MIPS tree.
x86:
bugfixes (notably for pvclock, the others are small) and cleanups.
Another small latency improvement for the TSC deadline timer"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
KVM: use slowpath for cross page cached accesses
kvm: mmu: lazy collapse small sptes into large sptes
KVM: x86: Clear CR2 on VCPU reset
KVM: x86: DR0-DR3 are not clear on reset
KVM: x86: BSP in MSR_IA32_APICBASE is writable
KVM: x86: simplify kvm_apic_map
KVM: x86: avoid logical_map when it is invalid
KVM: x86: fix mixed APIC mode broadcast
KVM: x86: use MDA for interrupt matching
kvm/ppc/mpic: drop unused IRQ_testbit
KVM: nVMX: remove unnecessary double caching of MAXPHYADDR
KVM: nVMX: checks for address bits beyond MAXPHYADDR on VM-entry
KVM: x86: cache maxphyaddr CPUID leaf in struct kvm_vcpu
KVM: vmx: pass error code with internal error #2
x86: vdso: fix pvclock races with task migration
KVM: remove kvm_read_hva and kvm_read_hva_atomic
KVM: x86: optimize delivery of TSC deadline timer interrupt
KVM: x86: extract blocking logic from __vcpu_run
kvm: x86: fix x86 eflags fixed bit
KVM: s390: migrate vcpu interrupt state
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
The RISC OS personality seems to be unused and untested for a long time.
It is doubtful whether this personality worked ever as expected.
Let's rip it out.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
read_persistent_clock64() and use them
As part of addressing "y2038 problem" for in-kernel uses, this
patch converts read_boot_clock() to read_boot_clock64() and
read_persistent_clock() to read_persistent_clock64() using
timespec64 by converting clock_access_fn to use timespec64.
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Thierry Reding <treding@nvidia.com> (for tegra part)
Cc: Russell King <rmk@dyn-67.arm.linux.org.uk>
Link: http://lkml.kernel.org/r/1427945681-29972-7-git-send-email-john.stultz@linaro.org
When trying to kexec into a new kernel on a platform where multiple CPU
cores are present, but no SMP bringup code is available yet, the
kexec_load system call fails with:
kexec_load failed: Invalid argument
The SMP test added to machine_kexec_prepare() in commit 2103f6cba61a8b8b
("ARM: 7807/1: kexec: validate CPU hotplug support") wants to prohibit
kexec on SMP platforms where it cannot disable secondary CPUs.
However, this test is too strict: if the secondary CPUs couldn't be
enabled in the first place, there's no need to disable them later at
kexec time. Hence skip the test in the absence of SMP bringup code.
This allows to add all CPU cores to the DTS from the beginning, without
having to implement SMP bringup first, improving DT compatibility.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Move shutdown and reboot related code to a separate file, out of
process.c. This helps to avoid polluting process.c with non-process
related code.
Normally, when a CPU wants to clear a cache line to zero in the external
L2 cache, it would generate bus cycles to write each word as it would do
with any other data access.
However, a Cortex A9 connected to a L2C-310 has a specific feature where
the CPU can detect this operation, and signal that it wants to zero an
entire cache line. This feature, known as Full Line of Zeros (FLZ),
involves a non-standard AXI signalling mechanism which only the L2C-310
can properly interpret.
There are separate enable bits in both the L2C-310 and the Cortex A9 -
the L2C-310 needs to be enabled and have the FLZ enable bit set in the
auxiliary control register before the Cortex A9 has this feature
enabled.
Unfortunately, the suspend code was not respecting this - it's not
obvious from the code:
swsusp_arch_suspend()
cpu_suspend() /* saves the Cortex A9 auxiliary control register */
arch_save_image()
soft_restart() /* turns off FLZ in Cortex A9, and disables L2C */
cpu_resume() /* restores the Cortex A9 registers, inc auxcr */
At this point, we end up with the L2C disabled, but the Cortex A9 with
FLZ enabled - which means any memset() or zeroing of a full cache line
will fail to take effect.
A similar issue exists in the resume path, but it's slightly more
complex:
arch_save_image() /* image with A9 auxcr saved */
swsusp_arch_resume()
call_with_stack()
arch_restore_image() /* restores image with A9 auxcr saved above */
Again, here we end up with the L2C disabled, but Cortex A9 FLZ enabled.
There's no need to turn off the L2C in either of these two paths; there
are benefits from not doing so - for example, the page copies will be
faster with the L2C enabled.
Hence, fix this by providing a variant of soft_restart() which can be
used without turning the L2 cache controller off, and use it in both
of these paths to keep the L2C enabled across the respective resume
transitions.
Fixes: 8ef418c7178f ("ARM: l2c: trial at enabling some Cortex-A9 optimisations")
Reported-by: Sean Cross <xobs@kosagi.com>
Tested-by: Sean Cross <xobs@kosagi.com>
Move cpu_resume() to the .text section where it belongs. Change
the adr reference to sleep_save_sp to an explicit PC relative
reference so sleep_save_sp itself can remain in .data.
This helps prevent linker failure on large kernels, as the code
in the .data section may be too far away to be in range for normal
b/bl instructions.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This moves all fixup snippets to the .text.fixup section, which is
a special section that gets emitted along with the .text section
for each input object file, i.e., the snippets are kept much closer
to the code they refer to, which helps prevent linker failure on
large kernels.
Acked-by: Nicolas Pitre <nico@linaro.org>
arm64 builds with GCC 5 have caused the __asmeq assertions in the PSCI
calling code to fire, so move the ARM PSCI calls out of line into their
own assembly file for consistency and to safeguard against the same
issue occuring with the 32-bit toolchain.
[will: brought into line with arm64 implementation]
Reported-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
When the patch for e16343c47e42 (ARM: 8160/1: drop warning about
return_address not using unwind tables) was created there was still more
code in said branch. Probably this simplification was just missed during
conflict resolution when the patch was applied.
When running the 32-bit ARM kernel on ARMv8 capable bare metal (e.g.,
32-bit Android userland and kernel on a Cortex-A53), or as a KVM guest
on a 64-bit host, we should advertise the availability of the Crypto
instructions, so that userland libraries such as OpenSSL may use them.
(Support for the v8 Crypto instructions in the 32-bit build was added
to OpenSSL more than six months ago)
This adds the ID feature bit detection, and sets elf_hwcap2 accordingly.
The various CPU feature registers consist of 4-bit blocks that
represent signed quantities, whose positive values represent
incremental features, and whose negative values are reserved.
To improve forward compatibility, update the feature detection
code to take possible future higher values into account, but
ignore negative values.
This moves the .idmap.text section closer to .head.text, so that
relative branches are less likely to go out of range if the kernel
text gets bigger.
This patch replaces the 'branch to setup()' instructions embedded
in the PROCINFO structs with the offset to that setup function
relative to the base of the struct. This preserves the position
independent nature of that field, but uses a data item rather
than an instruction.
This is mainly done to prevent linker failures on large kernels,
where the setup function is out of reach for the branch.
Allow users to enable the vdso in Kconfig; include the vdso in the
build if CONFIG_VDSO is enabled. Add 'vdso_install' target.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
Initialize the VDSO page list at boot, install the VDSO mapping at
exec time, and update the data page during timer ticks. This code is
not built if CONFIG_VDSO is not enabled.
Account for the VDSO length when randomizing the offset from the
stack. The [vdso] and [vvar] pages are placed immediately following
the sigpage with separate _install_special_mapping calls.
We want to "penalize" systems lacking the arch timer as little
as possible. Previous versions of this code installed the VDSO
unconditionally and unmodified, making it a measurably slower way for
glibc to invoke the real syscalls on such systems. E.g. calling
gettimeofday via glibc goes from ~560ns to ~630ns on i.MX6Q.
If we can indicate to glibc that the time-related APIs in the VDSO are
not accelerated, glibc can continue to invoke the syscalls directly
instead of dispatching through the VDSO only to fall back to the slow
path.
Thus, if the architected timer is unusable for whatever reason, patch
the VDSO at boot time so that symbol lookups for gettimeofday and
clock_gettime return NULL. (This is similar to what powerpc does and
borrows code from there.) This allows glibc to perform the syscall
directly instead of passing control to the VDSO, which minimizes the
penalty. In my measurements the time taken for a gettimeofday call
via glibc goes from ~560ns to ~580ns (again on i.MX6Q), and this is
solely due to adding a test and branch to glibc's gettimeofday syscall
wrapper.
An alternative to patching the VDSO at boot would be to not install
the VDSO at all when the arch timer isn't usable. Another alternative
is to include a separate "dummy" vdso.so without gettimeofday and
clock_gettime, which would be selected at boot time. Either of these
would get cumbersome if the VDSO were to gain support for an API such
as getcpu which is unrelated to arch timer support.
Place VDSO-related user-space code in arch/arm/kernel/vdso/.
It is almost completely written in C with some assembly helpers to
load the data page address, sample the counter, and fall back to
system calls when necessary.
The VDSO can service gettimeofday and clock_gettime when
CONFIG_ARM_ARCH_TIMER is enabled and the architected timer is present
(and correctly configured). It reads the CP15-based virtual counter
to compute high-resolution timestamps.
Of particular note is that a post-processing step ("vdsomunge") is
necessary to produce a shared object which is architecturally allowed
to be used by both soft- and hard-float EABI programs.
The 2012 edition of the ARM ABI defines Tag_ABI_VFP_args = 3 "Code is
compatible with both the base and VFP variants; the user did not
permit non-variadic functions to pass FP parameters/results."
Unfortunately current toolchains do not support this tag, which is
ideally what we would use.
The best available option is to ensure that both EF_ARM_ABI_FLOAT_SOFT
and EF_ARM_ABI_FLOAT_HARD are unset in the ELF header's e_flags,
indicating that the shared object is "old" and should be accepted for
backward compatibility's sake. While binutils < 2.24 appear to
produce a vdso.so with both flags clear, 2.24 always sets
EF_ARM_ABI_FLOAT_SOFT, with no way to inhibit this behavior. So we
have to fix things up with a custom post-processing step.
In fact, the VDSO code in glibc does much less validation (including
checking these flags) than the code for handling conventional
file-backed shared libraries, so this is a bit moot unless glibc's
VDSO code becomes more strict.
Older binutils do not support expressions involving the values of
external symbols so just round up the HYP region to the page size.
Tested-by: Simon Horman <horms+renesas@verge.net.au>
[will: when will this ever end?!]
Using ASSERT() with an expression that involves a symbol that
is only supplied through a PROVIDE() definition in the linker
script itself is apparently not supported by some older versions
of binutils.
So instead, rewrite the expression so that only the section
boundaries __hyp_idmap_text_start and __hyp_idmap_text_end
are used. Note that this reverts the fix in 06f75a1f6200
("ARM, arm64: kvm: get rid of the bounce page") for the ASSERT()
being triggered erroneously when unrelated linker emitted veneers
happen to end up in the HYP idmap region.
Add kernel-doc format documentation in the code.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Historically, the PMU devicetree bindings have expected SPIs to be
listed in order of *logical* CPU number. This is problematic for
bootloaders, especially when the boot CPU (logical ID 0) isn't listed
first in the devicetree.
This patch adds a new optional property, interrupt-affinity, to the
PMU node which allows the interrupt affinity to be described using
a list of phandled to CPU nodes, with each entry in the list
corresponding to the SPI at the same index in the interrupts property.
Cc: Mark Rutland <mark.rutland@arm.com>
The current state of the different cpuidle drivers is the different PM
operations are passed via the platform_data using the platform driver
paradigm.
This approach allowed to split the low level PM code from the arch specific
and the generic cpuidle code.
Unfortunately there are complaints about this approach as, in the context of the
single kernel image, we have multiple drivers loaded in memory for nothing and
the platform driver is not adequate for cpuidle.
This patch provides a common interface via cpuidle ops for all new cpuidle
driver and a definition for the device tree.
It will allow with the next patches to a have a common definition with ARM64
and share the same cpuidle driver.
The code is optimized to use the __init section intensively in order to reduce
the memory footprint after the driver is initialized and unify the function
names with ARM64.
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Rob Herring <robherring2@gmail.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
The cpu_do_idle() function is always used by the cpuidle drivers.
That led to have each driver including cpuidle.h and proc-fns.h, they are
always paired. That makes a lot of duplicate headers inclusion. Instead of
including both in each .c file, move the proc-fns.h header inclusion in the
cpuidle.h header file directly, so we can save some line of code.
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Commit 06f75a1f6200 ("ARM, arm64: kvm: get rid of the bounce
page") uses ld's builtin function LOG2CEIL() to align the
KVM init code to a log2 upper bound of its size. However,
this function turns out to be a fairly recent addition to
binutils, which breaks the build for older toolchains.
So instead, implement a replacement LOG2_ROUNDUP() using
the C preprocessor.
The only reason CQM had to use a hard-coded pmu type was so it could use
cqm_target in hw_perf_event.
Do away with the {tp,bp,cqm}_target pointers and provide a non type
specific one.
This allows us to do away with that silly pmu type as well.
Cc: Vince Weaver <vince@deater.net>
Cc: acme@kernel.org
Cc: acme@redhat.com
Cc: hpa@zytor.com
Cc: jolsa@redhat.com
Cc: kanaka.d.juvva@intel.com
Cc: matt.fleming@intel.com
Cc: tglx@linutronix.de
Cc: torvalds@linux-foundation.org
Cc: vikas.shivappa@linux.intel.com
Link: http://lkml.kernel.org/r/20150305211019.GU21418@twins.programming.kicks-ass.net
The perf core implicitly rejects events spanning multiple HW PMUs, as in
these cases the event->ctx will differ. However this validation is
performed after pmu::event_init() is called in perf_init_event(), and
thus pmu::event_init() may be called with a group leader from a
different HW PMU.
The ARM PMU driver does not take this fact into account, and when
validating groups assumes that it can call to_arm_pmu(event->pmu) for
any HW event. When the event in question is from another HW PMU this is
wrong, and results in dereferencing garbage.
This patch updates the ARM PMU driver to first test for and reject
events from other PMUs, moving the to_arm_pmu and related logic after
this test. Fixes a crash triggered by perf_fuzzer on Linux-4.0-rc2, with
a CCI PMU present:
CPU: 0 PID: 1527 Comm: perf_fuzzer Not tainted 4.0.0-rc2 #57
Hardware name: ARM-Versatile Express
task: bd8484c0 ti: be676000 task.ti: be676000
PC is at 0xbf1bbc90
LR is at validate_event+0x34/0x5c
pc : [<bf1bbc90>] lr : [<80016060>] psr: 00000013
[<80016060>] (validate_event) from [<80016198>] (validate_group+0x28/0x90)
[<80016198>] (validate_group) from [<80016398>] (armpmu_event_init+0x150/0x218)
[<80016398>] (armpmu_event_init) from [<800882e4>] (perf_try_init_event+0x30/0x48)
[<800882e4>] (perf_try_init_event) from [<8008f544>] (perf_init_event+0x5c/0xf4)
[<8008f544>] (perf_init_event) from [<8008f8a8>] (perf_event_alloc+0x2cc/0x35c)
[<8008f8a8>] (perf_event_alloc) from [<8009015c>] (SyS_perf_event_open+0x498/0xa70)
[<8009015c>] (SyS_perf_event_open) from [<8000e420>] (ret_fast_syscall+0x0/0x34)
Code: bf1be000 bf1bb380 802a2664 00000000 (00000002)
---[ end trace 01aff0ff00926a0a ]---
Also cleans up the code to use the arm_pmu only when we know that
we are dealing with an arm pmu event.
Acked-by: Peter Ziljstra (Intel) <peterz@infradead.org>
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
The HYP init bounce page is a runtime construct that ensures that the
HYP init code does not cross a page boundary. However, this is something
we can do perfectly well at build time, by aligning the code appropriately.
For arm64, we just align to 4 KB, and enforce that the code size is less
than 4 KB, regardless of the chosen page size.
For ARM, the whole code is less than 256 bytes, so we tweak the linker
script to align at a power of 2 upper bound of the code size
Note that this also fixes a benign off-by-one error in the original bounce
page code, where a bounce page would be allocated unnecessarily if the code
was exactly 1 page in size.
On ARM, it also fixes an issue with very large kernels reported by Arnd
Bergmann, where stub sections with linker emitted veneers could erroneously
trigger the size/alignment ASSERT() in the linker script.
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Replace inline asm statement in __get_cpu_architecture() with equivalent
macro invocation, i.e. read_cpuid_ext(CPUID_EXT_MMFR0);
As an added bonus, this squashes a potential bug, described by Paul
Walmsley in commit 067e710b9a98 ("ARM: 7801/1: prevent gcc 4.5 from
reordering extended CP15 reads above is_smp() test").
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Scorpion supports a set of local performance monitor event
selection registers (LPM) sitting behind a cp15 based interface
that extend the architected PMU events to include Scorpion CPU
and Venum VFP specific events. To use these events the user is
expected to program the lpm register with the event code shifted
into the group they care about and then point the PMNx event at
that region+group combo by writing a LPMn_GROUPx event. Add
support for this hardware.
Note: the raw event number is a pure software construct that
allows us to map the multi-dimensional number space of regions,
groups, and event codes into a flat event number space suitable
for use by the perf framework.
This is based on code originally written by Sheetal Sahasrabudhe,
Ashwin Chaugule, and Neil Leeder [1].
[1] https://www.codeaurora.org/cgit/quic/la/kernel/msm/tree/arch/arm/kernel/perf_event_msm.c?h=msm-3.4
Cc: Neil Leeder <nleeder@codeaurora.org>
Cc: Ashwin Chaugule <ashwinc@codeaurora.org>
Cc: Sheetal Sahasrabudhe <sheetals@codeaurora.org>
Cc: <devicetree@vger.kernel.org>
