path: root/arch/arm/lib/backtrace.S
2010-04-21ARM: fix build error in arch/arm/kernel/process.cRussell King
/tmp/ccJ3ssZW.s: Assembler messages: /tmp/ccJ3ssZW.s:1952: Error: can't resolve `.text' {.text section} - `.LFB1077' This is caused because: .section .data .section .text .section .text .previous does not return us to the .text section, but the .data section; this makes use of .previous dangerous if the ordering of previous sections is not known. Fix up the other users of .previous; .pushsection and .popsection are a safer pairing to use than .section and .previous. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implement the unified arch/arm/lib functionsCatalin Marinas
This patch adds the ARM/Thumb-2 unified support for the arch/arm/lib/* files. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Add ability to dump exception stacks to kernel backtracesRussell King
2006-06-28[ARM] nommu: backtrace code must not reference a discarded sectionRussell King
The code in "1007:" is in the .fixup section, which in the mmuless case is discarded. Since this code is referenced from the .text section, it causes an link error. Move this code into the .text section instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove LOADREGS macroRussell King
As for RETINSTR, LOADREGS is a left-over from the 26-bit days. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-16[ARM] 3524/1: ARM EABI: more 64-bit aligned stack fixesNicolas Pitre
Patch from Nicolas Pitre Assembly code that calls C code must ensure the C code sees a 64-bit aligned stack pointer. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25[ARM] 3399/1: Fix link problem when CONFIG_PRINTK is disabledMalcolm Parsons
Patch from Malcolm Parsons Printking a backtrace requires printk, so disable backtrace code when printk is disabled. Without this patch, a kernel with CONFIG_PRINTK disabled does not link: arch/arm/lib/lib.a(backtrace.o): In function `c_backtrace': arch/arm/lib/backtrace.S:(.text+0x108): undefined reference to `printk' arch/arm/lib/backtrace.S:(.text+0x11c): undefined reference to `printk' arch/arm/lib/lib.a(backtrace.o):(.fixup+0x8): undefined reference to `printk' Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
