path: root/arch/arm/lib/io-readsw-armv3.S
2011-07-12ARM: remove unnecessary mach/hardware.h includesRob Herring
Remove some includes of mach/hardware.h which are not needed. hardware.h will be removed completely for tegra and cns3xxx in follow on patch. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove LOADREGS macroRussell King
As for RETINSTR, LOADREGS is a left-over from the 26-bit days. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[ARM] Remove RETINSTR macroRussell King
RETINSTR is a left-over from the days when we had 26-bit and 32-bit CPU support integrated into the same tree. Since this is no longer the case, we can now remove RETINSTR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-11[ARM] 3151/1: make various assembly local labels actually local (io-*.S)Nicolas Pitre
Patch from Nicolas Pitre For assembly labels to actually be local they must start with ".L" and not only "." otherwise they still remain visible in the final link and clutter kallsyms needlessly, and possibly make for unclear symbolic backtrace. This patch simply inserts a"L" where appropriate. The code itself is unchanged. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
