path: root/arch/arm/lib/muldi3.S
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-08[ARM] Fix muldi3.SRussell King
When shifting the low-parts of signed numbers, a logical shift should be used to avoid sign-extending a bit which isn't a sign bit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-14[ARM] 3104/1: ARM EABI: new helper function namesNicolas Pitre
Patch from Nicolas Pitre The ARM EABI defines new names for GCC helper functions. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-30[ARM] 3049/1: More optimized libgcc functionsNicolas Pitre
Patch from Nicolas Pitre This patch gets rid of the last C implementations of needed libgcc functions for the kernel, replacing them with optimized assembly versions. Those functions are: __ashldi3 __ashrdi3 __lshrdi3 __muldi3 __ucmpdi2 The first 3 were lifted from gcc, the other two were written from scratch. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
