path: root/arch/arm/lib/setbit.S
2011-02-02ARM: bitops: switch set/clear/change bitops to use ldrex/strexRussell King
Switch the set/clear/change bitops to use the word-based exclusive operations, which are only present in a wider range of ARM architectures than the byte-based exclusive operations. Tested record: - Nicolas Pitre: ext3,rw,le - Sourav Poddar: nfs,le - Will Deacon: ext3,rw,le - Tony Lindgren: ext3+nfs,le Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-17[PATCH] ARM: bitopsRussell King
Convert ARM bitop assembly to a macro. All bitops follow the same format, so it's silly duplicating the code when only one or two instructions are different. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
