path: root/arch/arm/mach-at91/at91sam9261.c
2011-08-24at91: at91sam9261.c: fix typo in t2_clk alias for atmel_tcb.0Jean-Christophe PLAGNIOL-VILLARD
This was a typo in clockdev declaration for at91sam9261 SoC. Fix the kernel hanging when switching clocksource to TC (tcb_clksrc). Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Remy Bohmer <linux@bohmer.net> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-07-28at91: factorize sram initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: move register clocks to soc generic initJean-Christophe PLAGNIOL-VILLARD
2011-07-28at91: move clock subsystem init to soc generic initJean-Christophe PLAGNIOL-VILLARD
2011-07-28at91: use structure to store the current socJean-Christophe PLAGNIOL-VILLARD
instead of reading the registers everytime the current implementation respect the following constrain: - allow 1 to n soc to be enabled - allow to have a virtual cpu type and subtype - always detect the cpu type and subtype and report it - detect if the soc support is enabled - prepare for sysfs export support - drop soc specific code via compiler when the soc not enabled (via cpu_is_xxx) Today if we read the exid we will have the same value for 9g35 and 9m11 and we will need to check the cidr too with the new implementation we just need to check the soc subtype this will also allow to have specific virtual subtype for rm9200 which the board will have to specify via at91rm9200_set_type(int) as we have no way to detect it. this implementation is inspired by the SH cpu detection support Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: switch to CLKDEV_LOOKUPJean-Christophe PLAGNIOL-VILLARD
we do not change the clock naming convention so does not need to switch the AVR32 yet Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-26AT91: reset: extend alternate reset procedure to several chipsNicolas Ferre
Several at91sam9 chips need the alternate reset procedure to be sure to halt SDRAM smoothly before resetting the chip. This is an extension of previous patch "Fix AT91SAM9G20 reset" to all chips affected. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2009-07-02[ARM] 5570/1: at91: Support for at91sam9g10: core chip & board supportNicolas Ferre
From: Hong Xu <hong.xu@atmel.com> Here are the modification to at91sam9261 files dedicated to the support of at91sam9g10. This direction has been adopted to minimize code duplication. All at91sam9261 drivers are enabled in _devices and board- files. Modificaton to peripherals that support at91sam9g10 will be added in future patches. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4903/1: [AT91] SAM9/CAP9 system shutdownAndrew Victor
Enable system shutdown/power-off on AT91SAM9 and AT91CAP9 based boards. This does not require power-management to be enabled, and the pm_power_off method can be overridden in board-specific files if necessary. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4656/1: AT91: Tweak interrupt prioritiesAndrew Victor
Slight tweaking of the default interrupt priorities (AIC) for the integrated peripherals on the AT91RM9200, AT91SAM9260, AT91SAM9261 and AT91SAM9263 processors. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4351/1: AT91: Define rest of peripheral clocksAndrew Victor
Define and register the remaining peripheral clocks for the AT91 processors. AT91SAM9261 clocks patch by Ivan Zhakov. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-16[ARM] at91: correct value for AT91_RSTC_KEYJan Altenberg
- Remove a duplicated define for AT91_RSTC_KEY - Set AT91_RSTC_KEY to the correct value - Replace the hardcoded keys in at91sam9620.c and at91sam9261.c by AT91_RSTC_KEY Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4147/1: AT91: Define Timer/Counter clocks.Andrew Victor
Define the Timer/Counter Unit clocks on the AT91RM9200, AT91SAM9260 and AT91SAM9261 processors. Original patch from David Brownell. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
