path: root/arch/arm/mach-at91/at91sam926x_time.c
2014-09-15ARM: at91: PIT: Move the driver to drivers/clocksourceMaxime Ripard
Now that we don't depend on anyting in the mach-at91 directory, we can just move the driver to where it belongs. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Conflicts: arch/arm/mach-at91/Kconfig arch/arm/mach-at91/Makefile
2014-09-15ARM: at91: Give the PIT irq as an argument of at91sam926x_pit_initMaxime Ripard
This allows to remove the dependency of the timer driver on mach/hardware.h and having an hardcoded interrupt number in the driver itself. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-03ARM: at91: PIT: (Almost) remove the global variablesMaxime Ripard
The timer driver is using some global variables to define some variables it has to use in most of its functions, like the base address. Use some container_of calls to have a single dynamic (and local) variable to hold this content. The only exception is in the !DT case, where the call chain to at91sam926x_ioremap_pit and then at91sam926x_pit_init as init_time makes it hard for the moment to pass the physical address of the timer. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-03ARM: at91: PIT: use request_irq instead of setup_irqMaxime Ripard
We can use the generic request_irq now to register a timer interrupt handler, instead of the more complex setup_irq. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-03ARM: at91: PIT: Use pr_fmtMaxime Ripard
All the panic messages hardcode the same prefix. Define the pr_fmt macro to unify its definition. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-03ARM: at91: PIT: Use consistent exit path in probeMaxime Ripard
The current probe code is, whenever it fails to retrieve a resource, either panicing, silently returning, or returning and displaying an error. Make the code consistent by always panicing whenever it fails to grab any resource. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-03ARM: at91: PIT: Rework probe functionsMaxime Ripard
The PIT timer driver until now had a single probe function, disregarding wether it was probed through DT or in the old-style way. This code later on was calling some DT function to retrieve the proper values for its base address, interrupts and clocks. While this was working, it was preventing the usage of CLOCKSOURCE_OF_DECLARE, and the two different probe path were not as clearly separated as they could be. Rework the probe path to take this into account, and switch to CLOCKSOURCE_OF_DECLARE. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-02ARM: at91: PIT: Use of_have_populated_dt instead of CONFIG_OFMaxime Ripard
Until now, the machines, even when CONFIG_OF was enabled, were calling at91sam926x_ioremap_pit to try to map the PIT address using the defined physical address. Obviously, with DT, it's not appropriate anymore, and some code was added to the function to deal with this case. Unfortunately, this code was conditionned on CONFIG_OF, which can be enabled, even though no DT was actually used, which would result in such a case, to this code being executed, without any reason. Moreover, the logic that was here before to bail out of the function just check in the DT to see if the PIT node is there, which is the case in all our DTSI. All this can be made much more straightforward just by using of_have_populated_dt to bail out. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-02ARM: at91: PIT: Use DIV_ROUND_CLOSEST to compute the cyclesMaxime Ripard
Until now, the pit_cycle computation was dividing the rate by HZ, rounding to the closest integer, but without using the appropriate macro. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-02ARM: at91: PIT: Follow the general coding rulesMaxime Ripard
Replace all masks and bits definitions by matching calls to BIT and GENMASK. While we're at it, also fix a few style issues. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-20ARM: at91: don't use <mach/timex.h>Uwe Kleine-König
The platform specific <mach/timex.h> will be removed in a later patch. So move its only still used symbol to a different header specific for the only machine still using it. Also add a few explicit includes of <mach/hardware.h> that are implicitly available through <mach/timex.h>. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-12-02ARM: at91: move pit timer to common clk frameworkBoris BREZILLON
Use device tree to get the source clock of the PIT (Periodic Interval Timer). If the clock is not found in device tree (or dt is not enabled) we'll try to get it using clk_lookup definitions. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-09-19ARM: at91: remove IRQF_DISABLEDMichael Opdenacker
This flag is a NOOP since 2.6.36 and can be removed. This is an update for 3.11 of a patch already sent for 3.10 Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-24ARM: at91: convert timer suspend/resume to clock_event_deviceStephen Warren
Move at91's timer suspend/resume functions from struct sys_timer at91sam926x_timer into struct clock_event_device pit_clkevt. This will allow the sys_timer suspend/resume fields to be removed, and eventually lead to a complete removal of struct sys_timer. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-06arm: at91: move pit define to the driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-07-02ARM: at91: sparse irq supportLudovic Desroches
Enable sparse irq support for multisoc image. It involves to add the NR_IRQS_LEGACY offset to static SoC irq number definitions since NR_IRQS_LEGACY irq descs are allocated before AIC requests irq descs allocation. Move NR_AIC_IRQS macro to a more appropiate place with the purpose to remove mach/irqs.h later. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-03-01ARM: at91/pit: add traces in case of errorNicolas Ferre
Traces related to IRQ management are useful for timers in case of non-working IRQ subsystem (switch to irq_domain for instance). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-03-01ARM: at91: pit add DT supportJean-Christophe PLAGNIOL-VILLARD
Retreive registers address and IRQ from device tree entry. Called from at91_dt_init_irq() so that timers are up-n-running when timers initialization will occur. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> [nicolas.ferre@atmel.com: change error path and interrupts property handling] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-11-28ARM: at91: make pit register base soc independentJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-12-19ARM: AT91: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-22arm/at91: Don't disable irqs in set_next_event and set_mode callbacksUwe Kleine-König
on AT91 the timer irq is shared, so the handler might be entered without irqs being disabled. Though this should not happen as the timer irq is registered early, there have been some reports on the mailing list. To make debugging that problem easier next time it pops up a WARN_ON_ONCE is added to the handler if irqs are not off. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4989/1: [AT91] SAM9 ClockSource / ClockEventsAndrew Victor
Update AT91SAM9/CAP9 PIT driver to use generic time and clockevent infrastructure: - Clocksource gives sub-microsecond timestamp precision, assuming memory is clocked at over 16 MHz. It's less than a 32 bit counter, unless it's is also generating IRQs. - Clockevent device supports periodic mode only; no oneshot support from this hardware. No IRQs generated unless it's the active clocksource. Later, another timer (probably from a TC module) can provide a oneshot clockevent device to get NO_HZ and High-Res-Timer behavior. This also updates the timekeeping to use the actual master clock rate on the system, instead of compile-time <asm/arch/timex.h> constants matching what Atmel's EK boards use. (Product boards may well differ!) Plus cleanup: rename "*_timer*" symbols to "*_pit*" (there are other timers, but only one PIT); shorter lines; remove needless CPP stuff; make several symbols static; etc. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] xtime_seqlock: fix more ARM machines for xtime deadlockingPeter Zijlstra
move update_process_times() out from under xtime_lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[ARM] 4149/1: AT91: Overrun in SAM9 gettimeoffset().Andrew Victor
Fix an overrun in the AT91SAM9 gettimeoffset() function. This causes the time value returned by gettimeofday() to jump "backwards". Original patch from Michel Benoit. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
