they are the same except the default priority
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
On all at91 except rm9200 and x40 have the System Controller starts
at address 0xffffc000 and has a size of 16KiB.
On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting
at 0xfffff000
This patch removes the individual definitions of AT91_BASE_SYS and
replaces them with a common version at base 0xfffffc000 and size 16KiB
and map the same memory space
as we can not detect it
by defaut the type will be bga
introduce cpu_is_at91rm9200_bga and cpu_is_at91rm9200_pqfp
select ARM_PATCH_PHYS_VIRT
as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent
bootloader will provide a valid atags pointer in r2
as point out by Russell on AT91 we never use XIP
so se do not need PLAT_PHYS_OFFSET
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
switch early init to init_early and introduce soc map_io
with this Patch we will not do any more early device setup during the map io
tks to Russell to point the new call back
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Andrew Victor <linux@maxim.org.za>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
CPUAT91 is based on Atmel's AT91RM9200 with up to 16MB Strataflash,
up to 128MB SDRAM and an ethernet PHY in RMII mode.
Signed-off-by: Eric Benard <ebenard@eukrea.com>
