they are the same except the default priority
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
On all at91 except rm9200 and x40 have the System Controller starts
at address 0xffffc000 and has a size of 16KiB.
On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting
at 0xfffff000
This patch removes the individual definitions of AT91_BASE_SYS and
replaces them with a common version at base 0xfffffc000 and size 16KiB
and map the same memory space
The recently modified nand buswitth configuration is not aligned with
board reality: the double footprint on boards is always populated with 8bits
buswidth nand flashes.
So we have to consider that without particular configuration the 8bits
buswidth is selected by default.
Moreover, the previous logic was always using !board_have_nand_8bit(), we
change it to a simpler: board_have_nand_16bit().
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com>
select ARM_PATCH_PHYS_VIRT
as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent
bootloader will provide a valid atags pointer in r2
as point out by Russell on AT91 we never use XIP
so se do not need PLAT_PHYS_OFFSET
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
switch early init to init_early and introduce soc map_io
with this Patch we will not do any more early device setup during the map io
tks to Russell to point the new call back
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Andrew Victor <linux@maxim.org.za>
no board configure it as 'n' and it's an issue to merge all defconfigs
in one
On AT91SAM926x boards both types of NAND flash can be present
(8 and 16 bit data bus width).
so will pass it via system_rev
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
The sd/mmc data structure is not used if SPI is selected. The configuration
of PIO on the board prevent from using both interfaces at the same time
(board dependent).
Remove the warnings at compilation time adding a preprocessor condition.
Add information in dm9000 mac/phy chip initialization:
- irq resource details
- platform data details
DBGU means Debug Unit, was refered as "DGBU" in some files. Fixed to "DBGU".
Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com>
Here are the modification to at91sam9261 files dedicated to the support of
at91sam9g10. This direction has been adopted to minimize code duplication.
All at91sam9261 drivers are enabled in _devices and board- files. Modificaton
to peripherals that support at91sam9g10 will be added in future patches.
Signed-off-by: Hong Xu <hong.xu@atmel.com>
Convert the SAM9 and CAP9 board-specific files to make use of the
sam9_smc_configure() method to configure the memory-controller for
external peripherals.
The following boards have been modified:
cam60 : NAND
cap9adk : NAND, NOR
qil-a9260 : NAND
sam9-l9260 : NAND
sam9260ek : NAND
sam9261ek : DM9000 Ethernet, NAND
sam9263 : NAND
sam9g20ek : NAND
sam9rlek : NAND
usb-a9260 : NAND
usb-a9263 .: NAND
Signed-off-by: Andrew Victor <linux@maxim.org.za>
Allow the various GPIO-connected buttons to be used as wakeup sources.
Also enable the internal GPIO pullup.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
hex-values
In the various AT91 board files, replace hard-coded size values (eg,
0x800000) with the SZ_ size definitions (eg, SZ_8M) from sizes.h
Also replace MTD partition offsets with MTDPART_OFS_NXTBLK.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
This is basically s/at91_nand/atmel_nand/g with some manual inspection.
Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com>
Add support for the GPIO-driven LEDs (using NEW_LEDS) on the Atmel
SAM9260-EK and SAM9261-EK boards.
Add support for AT73C213 audio DAC on the Atmel SAM9260-EK and
SAM9261-EK boards.
Convert the Atmel SAM9260-EK, SAM9261-EK, SAM9263-EK and SAM9RL-EK
boards to use the new-style UART initialization.
The AT91CAP9 processor includes the same Static Memory Controller
(SMC) peripheral as the SAM9 processors, but replaces the SDRAM
Controller with a DDR/SDR Controller (DDRSDRC).
This patch splits the existing
include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and
at91sam9_smc.h.
It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller.
On the sam9 EK boards, the LCD backlight is hooked up to a PWM output from
the LCD controller. It's controlled by "contrast" registers though.
This patch lets boards declare that they have that kind of backlight
control. The driver can then export this control, letting screenblank and
other operations actually take effect ... reducing the typically
substantial power drain from the backlight.
Note that it's not fully cooked
- doesn't force backlight off during system suspend
- the "power" and "blank" events may not be done right
This should be easily added in the future.
[nicolas.ferre@atmel.com: remove unneeded inline and rename functions]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
On the at92sam9263ek board, tell the input subsystem about the buttons.
This patch is taken from Andrew Victor's at91 patchset, then updated to
match the latest kernel code and to use labels printed on the board.
Also update the at91sam9261ek buttons to cope with input changes.
Add STN LCD support on the Atmel AT91SAM9261-EK board.
Uses a black and white screen from Hitachi: SP06Q002.
Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com>
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
The incorrect GPIO pins are being initialized for the buttons on the
Atmel AT91SAM9261-EK board. This buggy configuration turns LCD screen
blue...
The AT91 I2C driver is currently marked as "broken" due to hardware
issues. This patch enables AT91-based platforms to also use the
bitbanged GPIO for I2C.
This updates platform setup logic (setting up an i2c-gpio device
using the same pins as the i2c-at91 device, unless only the BROKEN
driver is enabled).
Also make use of the new-style initialization of I2C devices using
i2c_register_board_info().
Register the GPIO-connected buttons on the SAM9261-EK board as a
"gpio-keys" platform device.
Add board-specific setup for the LCD on the Atmel AT91SAM9261-EK and
AT91SAM9263-EK boards.
The following patch fixes these section mismatch warnings:
WARNING: arch/arm/mach-at91/built-in.o(.text+0xdf4): Section mismatch: reference to .init.data:dk_nand_partition (between 'nand_partitions' and 'at91_leds_event')
WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions')
WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (between 'nand_partitions' and 'ads7843_pendown_state')
WARNING: arch/arm/mach-at91/built-in.o(.text+0xc28): Section mismatch: reference to .init.data:kb9202_nand_partition (after 'nand_partitions')
WARNING: arch/arm/mach-footbridge/built-in.o(.text+0xaa4): Section mismatch: reference to .init.data:cats_pci (between 'cats_pci_init' and 'ebsa285_leds_event')WARNING: arch/arm/mach-ixp2000/built-in.o(.text+0xb54): Section mismatch: reference to .init.text:ixp2000_init_irq (between 'ixdp2x00_init_irq' and 'ixdp2x00_irq_handler')
WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x670): Section mismatch: reference to .init.text:ixp23xx_pci_common_init (between 'ixp23xx_pci_slave_init' and 'ixp23xx_pci_scan_bus')
WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x890): Section mismatch: reference to .init.text:ixp23xx_init_irq (between 'ixdp2351_init_irq' and 'roadrunner_pci_preinit')
WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x9a8): Section mismatch: reference to .init.text:ixp23xx_pci_preinit (after 'roadrunner_pci_preinit')
WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x80): Section mismatch: reference to .init.text:imx_set_mmc_info (between '__ksymtab_imx_set_mmc_info' and '__ksymtab_set_imx_fb_info')
WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x88): Section mismatch: reference to .init.text:set_imx_fb_info (after '__ksymtab_set_imx_fb_info')
WARNING: arch/arm/mach-sa1100/built-in.o(.text+0x1930): Section mismatch: reference to .init.data:neponset_port_fns (between 'neponset_probe' and 'assabet_leds_event')
WARNING: drivers/built-in.o(.text+0x3f100): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted')
WARNING: drivers/built-in.o(.text+0x3f1c8): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted')
WARNING: drivers/built-in.o(.text+0x4f988): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted')
WARNING: drivers/built-in.o(.text+0x4fa50): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted')
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
Attached you can find a patch needed to make the LEDS for 'CPU-Idle'
and 'Timer' work on the AT91SAM9261-EK board. The kernel configuration
options are already there, but the implementation is not available.
Signed-off-by: Remy Bohmer <l.pinguin@gmail.com>
Add support for the ADS7846 Touchscreen found on the Atmel
Original patch by Morten Larsen.
The Atmel AT91SAM9263 processor includes many more integrated
peripherals than Atmel's previous ARM9-based AT91 processors, so this
has necessitated a few changes to the core AT91 support.
These changes are:
* The system peripheral I/O region we remap has increased from
0xFFFA0000..0xFFFFFFFF to 0xFFF78000..0xFFFFFFFF.
* The increased I/O region forces changes to entry-macro.S and
debug-macro.S due to ARM's limited immediate offset addressing
modes.
* Maximum number of GPIO banks increases to 5.
* 2 MMC controllers so the board-setup code needs to specify which
controller it wishes to use when calling at91_add_device_mmc().
Original patch from Nicolas Ferre.
Now that Linux includes support for the Atmel AT91SAM9260 and
AT91SAM9261 processors in addition to the original Atmel AT91RM9200
(with support for more AT91 processors pending), the "mach-at91rm9200"
and "arch-at91rm9200" directories should be renamed to indicate their
more generic nature.
The following git commands should be run BEFORE applying this patch:
git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91
git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91
