path: root/arch/arm/mach-at91/board-sam9rlek.c
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: drop boot_params and PLAT_PHYS_OFFSETJean-Christophe PLAGNIOL-VILLARD
select ARM_PATCH_PHYS_VIRT as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent bootloader will provide a valid atags pointer in r2 as point out by Russell on AT91 we never use XIP so se do not need PLAT_PHYS_OFFSET Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2009-11-20AT91: add platform parameters for atmel_tsadcc in at91sam9rlekNicolas Ferre
Setup platform parameters in at91sam9rl-ek board to be passed to atmel_tsadcc touchscreen. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
2009-09-21ARM: 5710/1: at91: add AC97 support to at91sam9rl and at91sam9rlek boardNicolas Ferre
Add the support of AC97 on the at91sam9rl chip and -ek board. It will share the code with AVR32 ac97c alsa driver "atmel_ac97c". Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-21trivial: fix typos in comments s/DGBU/DBGU/Samuel R. C. Vale
DBGU means Debug Unit, was refered as "DGBU" in some files. Fixed to "DBGU". Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-12Merge branches 'arm', 'at91', 'bcmring', 'ep93xx', 'mach-types', 'misc' and ↵Russell King
'w90x900' into devel
2009-06-27[ARM] 5564/1: at91: add gpio button and leds support for at91sam9rlekNicolas Ferre
This adds input keyboard gpio support on at91sam9rlek board. It adds button 1 and 2 (left and right click). It also adds gpio leds ds1, ds2 and ds3. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-27[ARM] 5563/1: at91: at91sam9rlek lcd interface correctionNicolas Ferre
Here is a little update to the at91sam9rlek lcd interface. This will correct the power pin of the LCD. It will also add precision to the struct atmel_lcdfb_info scructure: backlight enabling and wiring mode correction: RGB wiring on the -EK board. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-01[ARM] 5289/1: [AT91] Convert boards to use sam9_smc_configure()Andrew Victor
Convert the SAM9 and CAP9 board-specific files to make use of the sam9_smc_configure() method to configure the memory-controller for external peripherals. The following boards have been modified: cam60 : NAND cap9adk : NAND, NOR qil-a9260 : NAND sam9-l9260 : NAND sam9260ek : NAND sam9261ek : DM9000 Ethernet, NAND sam9263 : NAND sam9g20ek : NAND sam9rlek : NAND usb-a9260 : NAND usb-a9263 .: NAND Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-21[ARM] 5260/1: [AT91] Touchscreen on AT91SAM9RLAndrew Victor
This patch adds initialization of the Touchscreen controller for the AT91SAM9RL processor. Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Dan Liang <dan.liang@atmel.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-21[ARM] 5257/2: [AT91] Use SZ_ definitions and MTDPART_OFS_NXTBLK instead of ↵Andrew Victor
hex-values In the various AT91 board files, replace hard-coded size values (eg, 0x800000) with the SZ_ size definitions (eg, SZ_8M) from sizes.h Also replace MTD partition offsets with MTDPART_OFS_NXTBLK. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-25Merge branch 'linux-next' of git://git.infradead.org/~dedekind/ubi-2.6David Woodhouse
2008-06-07[MTD] [NAND] rename at91_nand -> atmel_nand: internal symbolsHåvard Skinnemoen
This is basically s/at91_nand/atmel_nand/g with some manual inspection. Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-02[ARM] 4940/1: AT91: UDPHS driver: SAM9RL board and cpu integration.Nicolas Ferre
Adds support for the USB High Speed Device Port on the AT91SAM9RL system on chip. The AT91SAM9RL uses the same UDPHS IP as the AVR32 and the AT91CAP9 (atmel_usba_udc driver). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4905/1: [AT91] Atmel SAM9 boards updated to new-style UART initializationAndrew Victor
Convert the Atmel SAM9260-EK, SAM9261-EK, SAM9263-EK and SAM9RL-EK boards to use the new-style UART initialization. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4902/1: [AT91] SAM9/CAP9 memory controller headerAndrew Victor
The AT91CAP9 processor includes the same Static Memory Controller (SMC) peripheral as the SAM9 processors, but replaces the SDRAM Controller with a DDR/SDR Controller (DDRSDRC). This patch splits the existing include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and at91sam9_smc.h. It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-26[ARM] 4650/1: AT91: New-style init of I2C, support for i2c-gpioAndrew Victor
The AT91 I2C driver is currently marked as "broken" due to hardware issues. This patch enables AT91-based platforms to also use the bitbanged GPIO for I2C. This updates platform setup logic (setting up an i2c-gpio device using the same pins as the i2c-at91 device, unless only the BROKEN driver is enabled). Also make use of the new-style initialization of I2C devices using i2c_register_board_info(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-30[ARM] Fix some section mismatch warningsRussell King
The following patch fixes these section mismatch warnings: WARNING: arch/arm/mach-at91/built-in.o(.text+0xdf4): Section mismatch: reference to .init.data:dk_nand_partition (between 'nand_partitions' and 'at91_leds_event') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (between 'nand_partitions' and 'ads7843_pendown_state') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xc28): Section mismatch: reference to .init.data:kb9202_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-footbridge/built-in.o(.text+0xaa4): Section mismatch: reference to .init.data:cats_pci (between 'cats_pci_init' and 'ebsa285_leds_event')WARNING: arch/arm/mach-ixp2000/built-in.o(.text+0xb54): Section mismatch: reference to .init.text:ixp2000_init_irq (between 'ixdp2x00_init_irq' and 'ixdp2x00_irq_handler') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x670): Section mismatch: reference to .init.text:ixp23xx_pci_common_init (between 'ixp23xx_pci_slave_init' and 'ixp23xx_pci_scan_bus') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x890): Section mismatch: reference to .init.text:ixp23xx_init_irq (between 'ixdp2351_init_irq' and 'roadrunner_pci_preinit') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x9a8): Section mismatch: reference to .init.text:ixp23xx_pci_preinit (after 'roadrunner_pci_preinit') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x80): Section mismatch: reference to .init.text:imx_set_mmc_info (between '__ksymtab_imx_set_mmc_info' and '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x88): Section mismatch: reference to .init.text:set_imx_fb_info (after '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-sa1100/built-in.o(.text+0x1930): Section mismatch: reference to .init.data:neponset_port_fns (between 'neponset_probe' and 'assabet_leds_event') WARNING: drivers/built-in.o(.text+0x3f100): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x3f1c8): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4f988): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4fa50): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4371/1: AT91: Support for Atmel AT91SAM9RL-EK development boardAndrew Victor
Add support for the Atmel AT91SAM9RL-EK development board. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
