path: root/arch/arm/mach-at91/board-usb-a9260.c
2011-07-28at91: factorize at91 interrupts init to socJean-Christophe PLAGNIOL-VILLARD
they are the same except the default priority Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-07-28at91: introduce commom AT91_BASE_SYSJean-Christophe PLAGNIOL-VILLARD
On all at91 except rm9200 and x40 have the System Controller starts at address 0xffffc000 and has a size of 16KiB. On rm9200 it's start at 0xfffe4000 of 111KiB with non reserved data starting at 0xfffff000 This patch removes the individual definitions of AT91_BASE_SYS and replaces them with a common version at base 0xfffffc000 and size 16KiB and map the same memory space Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: drop boot_params and PLAT_PHYS_OFFSETJean-Christophe PLAGNIOL-VILLARD
select ARM_PATCH_PHYS_VIRT as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent bootloader will provide a valid atags pointer in r2 as point out by Russell on AT91 we never use XIP so se do not need PLAT_PHYS_OFFSET Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2009-09-21trivial: fix typos in comments s/DGBU/DBGU/Samuel R. C. Vale
DBGU means Debug Unit, was refered as "DGBU" in some files. Fixed to "DBGU". Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-12-01[ARM] 5289/1: [AT91] Convert boards to use sam9_smc_configure()Andrew Victor
Convert the SAM9 and CAP9 board-specific files to make use of the sam9_smc_configure() method to configure the memory-controller for external peripherals. The following boards have been modified: cam60 : NAND cap9adk : NAND, NOR qil-a9260 : NAND sam9-l9260 : NAND sam9260ek : NAND sam9261ek : DM9000 Ethernet, NAND sam9263 : NAND sam9g20ek : NAND sam9rlek : NAND usb-a9260 : NAND usb-a9263 .: NAND Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-21[ARM] 5257/2: [AT91] Use SZ_ definitions and MTDPART_OFS_NXTBLK instead of ↵Andrew Victor
hex-values In the various AT91 board files, replace hard-coded size values (eg, 0x800000) with the SZ_ size definitions (eg, SZ_8M) from sizes.h Also replace MTD partition offsets with MTDPART_OFS_NXTBLK. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesRussell King
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-01Fix rename of at91_nand -> atmel_nandPieter du Preez
Structs called at91_nand_data where renamed to atmel_nand_data and configs called *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL*. This was unfortunately not done consistently, causing NAND chips not being initialised on several ARM boards. I am aware that the author of the original change did not rename MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example. All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order to keep naming consistency. This patch was only tested on a MACH_SAM9_L9260, as this is the only ARM board I have to my disposal. Before this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 105 $ git-ls-files |xargs grep at91_nand |wc -l 4 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 8 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 47 After this patch: $ git-ls-files |xargs grep atmel_nand |wc -l 109 $ git-ls-files |xargs grep at91_nand |wc -l 0 $ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l 55 $ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l 0 Signed-off-by: Pieter du Preez <pdupreez@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-28[ARM] 5180/1: at91: Fix at91_nand -> atmel_nand rename falloutHaavard Skinnemoen
struct at91_nand has been renamed atmel_nand. Fix the four boards that were added since the patch was created. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5057/1: [AT91] Calao Systems - board filesAndrew Victor
Add support for three AT91-based boards available from Calao Systems: USB_A9260, USB_A9263 and QIL_A9260. Signed-off-by: Grégory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
