On some platforms, there are multiple SRAM nodes defined in the device tree but
some of them are disabled, leading to allocation failure. Try to find the first
enabled SRAM node and allocate from it.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Tested-by: Wenyou Yang <wenyou.yang@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
at91rm9200 standby and suspend to ram has been broken since
00482a4078f4. It is wrongly using AT91_BASE_SYS which is a physical address
and actually doesn't correspond to any register on at91rm9200.
Use the correct at91_ramc_base[0] instead.
Fixes: 00482a4078f4 (ARM: at91: implement the standby function for pm/cpuidle)
The DDRSDR controller fails miserably to put LPDDR1 memories in
self-refresh. Force the controller to think it has DDR2 memories
during the self-refresh period, as the DDR2 self-refresh spec is
equivalent to LPDDR1, and is correctly implemented in the
controller.
Assume that the second controller has the same fault, but that is
untested.
Signed-off-by: Peter Rosin <peda@axentia.se>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Removed timeout on XTAL, PLL lock and Master Clock Ready, hang if
something went wrong instead of continuing in unknown condition. There
is not much we can do if a PLL lock never ends, we are running in SRAM
and we will not be able to connect back the sdram or ddram in order to
be able to fire up a message or just panic.
As a bonus, not decounting the timeout register in slow clock mode
reduce cumulated suspend time and resume time from ~17ms to ~15ms.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Acked-by: Wenyou.Yang <wenyou.yang@atmel.com>
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const structs in arch/arm as const, too.
While at it also add some __initconst annotations.
Acked-by: Jason Cooper <jason@lakedameon.net>
Commit 20e783e39e55 ("ARM: 8296/1: cache-l2x0: clean up aurora cache
handling") removed the only user of the Kconfig symbol CACHE_PL310.
Setting CACHE_PL310 is now pointless. Remove its Kconfig entry, and one
select of this symbol.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
In a recent rearrangement of the at91 pm initialization code, a broken
set of declarations was added for the !CONFIG_PM-case, leading to
this link error:
arch/arm/mach-at91/board-dt-sama5.o: In function `at91_rm9200_pm_init':
arch/arm/mach-at91/generic.h:40: multiple definition of `at91_rm9200_pm_init'
arch/arm/mach-at91/setup.o:arch/arm/mach-at91/generic.h:40: first defined here
arch/arm/mach-at91/board-dt-sama5.o: In function `at91_sam9260_pm_init':
arch/arm/mach-at91/generic.h:41: multiple definition of `at91_sam9260_pm_init'
arch/arm/mach-at91/setup.o:arch/arm/mach-at91/generic.h:41: first defined here
arch/arm/mach-at91/board-dt-sama5.o: In function `at91_sam9g45_pm_init':
arch/arm/mach-at91/generic.h:42: multiple definition of `at91_sam9g45_pm_init'
arch/arm/mach-at91/setup.o:arch/arm/mach-at91/generic.h:42: first defined here
This adds the missing 'static inline' to the declarations to avoid
creating a copy of the functions in each file that includes the
header.
Fixes: 4db0ba22da9 ("ARM: at91: pm: prepare for multiplatform")
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Remove the string "(Device Tree)" after the machine name because all AT91
machines use the DT nowadays.
Also change some function names to unify following the convention:
- at91sam9xxx aren't named sam9, 9xxx but with the full name
- sama5 are the ones that don't have the at91 prefix anymore.
Move the ramc initialization to pm.c as it is the only user left.
This allows us to get rid of at91_dt_initialize() that was the only one called
by the init_early() function pointer of struct machine_desc.
[nicolas.ferre@atmel.com: adapt patch to newer series]
As board files are now DT only and can address all aspects of the SoC family,
we can rename them so that the mach-at91 directory looks cleaner.
at91_boot_soc and at91_init_soc structures are not used by any SoC, remove
their use. Also remove all the now empty SoC files.
[nicolas.ferre@atmel.com: different organization of the patches]
For sama5d4, remove an indirection and the remaining need for at91_boot_soc
structure.
This will allow further cleanup.
Only use SOC_AT91SAM9 for all the at91sam9 SoCs. It removes all the empty
at91sam9xxx.c SoC files. It also removes the useless at91_init_soc affectation
procedure and its "init" function pointer.
Only the SoC detection and display are kept for the at91sam9:
at91_soc_is_enabled() and at91_boot_soc.map_io() function calls are also
removed.
It enables HAVE_AT91_SMD and HAVE_AT91_UTMI for all the sam9 SoCs but this only
represents 96 bytes of uncompressed kernel code.
Setup arm_pm_idle and arm_pm_restart function pointers from
rm9200_dt_device_init() function to simplify the at91rm9200 initialization
process.
This same move is already done for the sam9s.
The SOC_AT91SAM9263 is being removed, stop using it.
mach/system_rev.h is not used, remove it.
In order to remove SOC_SAM9xxx options, stop using HAVE_AT91_DBGUx.
The PM initialization needs internal SRAM for allocating a gen_pool and
use it to store its PM code. So we need to have of_platform_populate() before
this code.
Suggested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
As all sam9 SoCs are setting arm_pm_idle to at91sam9_idle(), do it from
sam9_dt_device_init().
Suggested-by: Arnd Bergmann <arnd@arndb.de>
sam9n12 and sam9x5 don't set arm_pm_idle because of an oversight, fix that.
As long as there is no other non-const variable marked __initdata in the
same compilation unit it doesn't hurt. If there were one however
compilation would fail with
error: $variablename causes a section type conflict
because a section containing const variables is marked read only and so
cannot contain non-const variables.
[nicolas.ferre@atmel.com: update the paths after having re-arranged the patches]
Newer SoCs: at91sam9x5, at91sam9n12, sama5d3 and sama5d4 embed a DDR controller
and have a different PMC status register layout than the at91sam9g45. Create
another at91_sam9x5_pm_init() function to match this compatibility.
Move at91rm9200_idle() along with at91sam9_idle() in clk/at91/pmc.c.
Acked-by: Michael Turquette <mturquette@linaro.org>
SRAM initialization is now done through the mmio-sram driver and
at91_init_sram() is not called anymore, remove it.
Now that the SRAM is initialized by the mmio-sram driver, .map_io is useless.
remove it.
Split at91_pm_init() in three variants that are called by the respective SoCs
.init_machine. This allows to remove the of_machine_is_compatible() calls and
move at91_pm_init() out of arch_initcall() which is required for multiplatform.
Check UDP and UHP on sam9x5, sam9n12 and the sama5 series.
Check UHP on the sam9g45.
Now that the SRAM is part of a genpool, use it to allocate memory to use for the
slowclock implementation.
Store SoC differences in a struct to remove cpu_is_* usage.
Since all rm9200 board files have been removed, there is no user of
at91rm9200_set_type() left. Remove it
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
at91rm9200_dt_initialize() is doing the same as at91_dt_initialize(), use that
one instead.
Move debug-macro.S from include/mach/ to include/debug where all other common
debug macros are.
The irq fixup from at91_sysirq_mask_rtc and at91_sysirq_mask_rtt is now handled
by aic_common_rtc_irq_fixup and aic_common_rtt_irq_fixup. Remove those useless
functions.
Also remove the now unused mach/at91_rtt.h header.
Now that at91sam9 SoCs are only supported through DT, remove
CONFIG_MACH_AT91SAM9_DT and use CONFIG_SOC_AT91SAM9 instead.
Now that rm9200 is only supported through DT, remove CONFIG_MACH_AT91RM9200_DT
and use CONFIG_SOC_AT91RM9200 instead.
CONFIG_NEED_MACH_MEMORY_H is not set by any at91 platform, remove mach/memory.h
Since removal of !DT boards, asm/irq.h inclusion is not needed in these product
files.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
These GPIO pin descriptions are now moved with the pinctrl driver. We can
safely remove this useless header file.
Appearance: On some SAMA5D4EK boards, after power up, the Eth1 doesn't work.
Reason: The PIOE2 pin is connected to the NAND_Tree# of KSZ8081,
But it outputs LOW during the reset period, which cause the NAND_Tree# enabled.
Add phy_fixup() to disable NAND_Tree by overriding the Operation
Mode Strap Override register(i.e. Register 16h) to clear the NAND_Tree bit.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Pull ARM SoC cleanups from Arnd Bergmann:
"The remaining cleanups for 3.19 are to a large part result of
devicetree conversion nearing completion on two other platforms
besides AT91:
- Like AT91, Renesas shmobile is in the process to migrate to DT and
multiplatform, but using a different approach of doing it one SoC
at a time. For 3.19, the r8a7791 platform and associated "Koelsch"
board are considered complete and we remove the non-DT
non-multiplatform support for this.
- The ARM Versatile Express has supported DT and multiplatform for a
long time, but we have still kept the legacy board files around,
because not all drivers were fully working before. We have finally
taken the last step to remove the board files.
Other changes in this branch are preparation for the later branches or
just unrelated to the more interesting changes:
- The dts files for arm64 get moved into per-vendor directories for a
clearer structure.
- Some dead code removal (zynq, exynos, davinci, imx)
- Using pr_*() macros more consistently instead of printk(KERN_*) in
some platform code"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (71 commits)
ARM: zynq: Remove secondary_startup() declaration from header
ARM: vexpress: Enable regulator framework when MMCI is in use
ARM: vexpress: Remove non-DT code
ARM: imx: Remove unneeded .map_io initialization
ARM: dts: imx6qdl-sabresd: Fix the microphone route
ARM: imx: refactor mxc_iomux_mode()
ARM: imx: simplify clk_pllv3_prepare()
ARM: imx6q: drop unnecessary semicolon
ARM: imx: clean up machine mxc_arch_reset_init_dt reset init
ARM: dts: imx6qdl-rex: Remove unneeded 'fsl,mode' property
ARM: dts: imx6qdl-gw5x: Remove unneeded 'fsl,mode' property
ARM: dts: imx6qdl-sabresd: Use IMX6QDL_CLK_CKO define
ARM: at91: remove useless init_time for DT-only SoCs
ARM: davinci: Remove redundant casts
ARM: davinci: Use standard logging styles
ARM: shmobile: r8a7779: Spelling/grammar s/entity/identity/, s/map/mapping/
ARM: shmobile: sh7372: Spelling/grammar s/entity map/identity mapping/
ARM: shmobile: sh73a0: Spelling/grammar s/entity map/identity mapping/
ARM: EXYNOS: Remove unused static iomapping
ARM: at91: fix build breakage due to legacy board removals
Pull ARM SoC cleanup on mach-at91 from Arnd Bergmann:
"On Atmel AT91, the conversion to device tree is now considered
complete, and all machines that were not already converted in 3.18 are
assumed to be unused and dropped by the maintainer.
All remaining board files that were written in C are dropped, and the
ancient at91x40 sub-platform (based on an MMU-less ARM7) is removed
altogether. Cleaning up the last pieces was great fun, so I took the
time to do some of the coding myself and removed several hundred code
lines that ended up unused after the board files were done.
There are still a couple of AT91 specific device drivers that are not
converted to DT (CF, USB-OTG) and currently not working, and the
platform itself is not "multiplatform"-enabled, but both issues are
going to be taken care of in the 3.20 cycle.
This is split out from the other cleanups purely based on the size of
the branch"
* tag 'at91-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits)
ARM: at91: remove unused board.h file
ARM: at91: remove unneeded header files
ARM: at91/clocksource: remove !DT PIT initializations
ARM: at91: at91rm9200 ST initialization is now DT only
ARM: at91: remove old AT91-specific drivers
ARM: at91: cleanup initilisation code by removing dead code
ARM: at91/Kconfig: select board files automatically
ARM: at91: remove unused IRQ function declarations
ARM: at91: remove legacy IRQ driver and related code
ARM: at91: remove old at91-specific clock driver
ARM: at91: remove clock data in at91sam9n12.c and at91sam9x5.c files
ARM: at91: remove all !DT related configuration options
ARM: at91/trivial: update Kconfig comment to mention SAMA5
ARM: at91: always USE_OF from now on
ARM: at91/Kconfig: remove ARCH_AT91RM9200 option for drivers
ARM: at91: switch configuration option to SOC_AT91RM9200
ARM: at91: remove at91rm9200 legacy board support
ARM: at91: remove at91rm9200 legacy boards files
ARM: at91/Kconfig: remove useless fbdev Kconfig options
ARM: at91: remove at91sam9261/at91sam9g10 legacy board support
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into next/cleanup
Pull "Fifth batch of cleanup/SoC for 3.19" from Nicolas Ferre:
- removal of now dead code and AT91-specific driver
- removal of !DT initialization in some core AT91 drivers
- simplification of Kconfig DT board file selection: now automatic
* tag 'at91-cleanup5' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91:
All functions declared in this file are gone.
[nicolas.ferre@atmel.com: re-order patches so modify board-dt-sam9]
These files were left behind with no reason. Remove them.
As AT91 !DT code is now removed, cleanup the PIT clocksource driver.
[nicolas.ferre@atmel.com: split patch]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Boris BREZILLON <boris.brezillon@free-electrons.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
As at91rm9200 is now DT only, there is no need to keep old entry point in this
at91rm9200 System Timer (ST) driver.
GPIO and LED drivers were replaced by generic ones for DT boards. These drivers
were remaining: delete them now. Modifications are also done on the
corresponding header files.
The AT91-specific SoC strucutre "struct at91_init_soc" was filled with specific
!DT initilisation functions. Now that we got rid of the !DT board file
description, remove unneeded functions.
