Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The PM code wrongly uses virt_to_phys() instead of __pa_symbol() and was
not updated by commit 64fc2a947a98 ("ARM: 8641/1: treewide: Replace uses of
virt_to_phys with __pa_symbol") because it was not yet in tree.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"The diff is dominated by the Allwinner A10/A20 SoCs getting converted
to the sunxi-ng framework. Otherwise, the heavy hitters are various
drivers for SoCs like AT91, Amlogic, Renesas, and Rockchip. There are
some other new clk drivers in here too but overall this is just a
bunch of clk drivers for various different pieces of hardware and a
collection of non-critical fixes for clk drivers.
New Drivers:
- Allwinner R40 SoCs
- Renesas R-Car Gen3 USB 2.0 clock selector PHY
- Atmel AT91 audio PLL
- Uniphier PXs3 SoCs
- ARC HSDK Board PLLs
- AXS10X Board PLLs
- STMicroelectronics STM32H743 SoCs
Removed Drivers:
- Non-compiling mb86s7x support
Updates:
- Allwinner A10/A20 SoCs converted to sunxi-ng framework
- Allwinner H3 CPU clk fixes
- Renesas R-Car D3 SoC
- Renesas V2H and M3-W modules
- Samsung Exynos5420/5422/5800 audio fixes
- Rockchip fractional clk approximation fixes
- Rockchip rk3126 SoC support within the rk3128 driver
- Amlogic gxbb CEC32 and sd_emmc clks
- Amlogic meson8b reset controller support
- IDT VersaClock 5P49V5925/5P49V6901 support
- Qualcomm MSM8996 SMMU clks
- Various 'const' applications for struct clk_ops
- si5351 PLL reset bugfix
- Uniphier audio on LD11/LD20 and ethernet support on LD11/LD20/Pro4/PXs2
- Assorted Tegra clk driver fixes"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (120 commits)
clk: si5351: fix PLL reset
ASoC: atmel-classd: remove aclk clock
ASoC: atmel-classd: remove aclk clock from DT binding
clk: at91: clk-generated: make gclk determine audio_pll rate
clk: at91: clk-generated: create function to find best_diff
clk: at91: add audio pll clock drivers
dt-bindings: clk: at91: add audio plls to the compatible list
clk: at91: clk-generated: remove useless divisor loop
clk: mb86s7x: Drop non-building driver
clk: ti: check for null return in strrchr to avoid null dereferencing
clk: Don't write error code into divider register
clk: uniphier: add video input subsystem clock
clk: uniphier: add audio system clock
clk: stm32h7: Add stm32h743 clock driver
clk: gate: expose clk_gate_ops::is_enabled
clk: nxp: clk-lpc32xx: rename clk_gate_is_enabled()
clk: uniphier: add PXs3 clock data
clk: hi6220: change watchdog clock source
clk: Kconfig: Name RK805 in Kconfig for COMMON_CLK_RK808
clk: cs2000: Add cs2000_set_saved_rate
This new clock driver set allows to have a fractional divided clock that
would generate a precise clock particularly suitable for audio
applications.
The main audio pll clock has two children clocks: one that is connected
to the PMC, the other that can directly drive a pad. As these two routes
have different enable bits and different dividers and divider formulas,
they are handled by two different drivers. Each of them could modify the
rate of the main audio pll parent.
The main audio pll clock can output 620MHz to 700MHz.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
My previous patch fixed a link error for all at91 platforms when
CONFIG_ARM_CPU_SUSPEND was not set, however this caused another
problem on a configuration that enabled CONFIG_ARCH_AT91 but none
of the individual SoCs, and that also enabled CPU_ARM720 as
the only CPU:
warning: (ARCH_AT91 && SOC_IMX23 && SOC_IMX28 && ARCH_PXA && MACH_MVEBU_V7 && SOC_IMX6 && ARCH_OMAP3 && ARCH_OMAP4 && SOC_OMAP5 && SOC_AM33XX && SOC_DRA7XX && ARCH_EXYNOS3 && ARCH_EXYNOS4 && EXYNOS5420_MCPM && EXYNOS_CPU_SUSPEND && ARCH_VEXPRESS_TC2_PM && ARM_BIG_LITTLE_CPUIDLE && ARM_HIGHBANK_CPUIDLE && QCOM_PM) selects ARM_CPU_SUSPEND which has unmet direct dependencies (ARCH_SUSPEND_POSSIBLE)
arch/arm/kernel/sleep.o: In function `cpu_resume':
(.text+0xf0): undefined reference to `cpu_arm720_suspend_size'
arch/arm/kernel/suspend.o: In function `__cpu_suspend_save':
suspend.c:(.text+0x134): undefined reference to `cpu_arm720_do_suspend'
This improves the hack some more by only selecting ARM_CPU_SUSPEND
for the part that requires it, and changing pm.c to drop the
contents of unused init functions so we no longer refer to
cpu_resume on at91 platforms that don't need it.
Fixes: cc7a938f5f30 ("ARM: at91: select CONFIG_ARM_CPU_SUSPEND")
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux into next/soc
Bring in the fixes branch to avoid a merge conflict between new SoC options and
the build fix adding CONFIG_AMR_CPU_SUSPEND.
Fixes for 4.12:
Fix two compilation issues
* tag 'at91-4.12-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux:
memory: atmel-ebi: mark PM ops as __maybe_unused
SoC for 4.13:
- New suspend/resume mode for sama5d2
- Initial support for armv7m based SoCs
* tag 'at91-ab-4.13-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux:
ARM: at91: remove atmel_nand_data
ARM: at91: fix at91_suspend_entering_slow_clock link error
ARM: at91: debug: add samv7x support
ARM: at91: add armv7m SoC detection
ARM: at91: handle CONFIG_PM for armv7m configurations
ARM: at91: Add armv7m support
ARM: at91: Document armv7m compatibles
ARM: at91: Documentation: add armv7m families
ARM: at91: pm: fallback to slowclock when backup mode fails
ARM: at91: pm: allow selecting standby and suspend modes
ARM: at91: pm: Add sama5d2 backup mode
When CONFIG_ARCH_AT91 is enabled, but none of the specific SoC support
is in use, some at91 specific drivers fail to link:
drivers/tty/serial/atmel_serial.o: In function `atmel_serial_suspend':
atmel_serial.c:(.text.atmel_serial_suspend+0x1e): undefined reference to `at91_suspend_entering_slow_clock'
drivers/usb/host/ohci-at91.o: In function `ohci_hcd_at91_drv_suspend':
ohci-at91.c:(.text.ohci_hcd_at91_drv_suspend+0x12): undefined reference to `at91_suspend_entering_slow_clock'
drivers/usb/gadget/udc/at91_udc.o: In function `at91udc_suspend':
at91_udc.c:(.text.at91udc_suspend+0x26): undefined reference to `at91_suspend_entering_slow_clock'
This changes the at91_suspend_entering_slow_clock hack once more, adding
an alternative inline implementation that is used exactly in those cases
that don't provide the normal implementation.
Fixes: c1892c2379d2 ("ARM: at91: handle CONFIG_PM for armv7m configurations")
There is currently no PM support for samx7 but the symbol can still be
selected. This avoids compilation issues.
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Add Atmel SAME70/SAMS70/SAMV71 SoC support.
Signed-off-by: Szemző András <sza@esh.hu>
The reference to cpu_resume requires the corresponding
generic code to be enabled when CONFIG_PM is set:
arch/arm/mach-at91/pm.o: In function `sama5d2_pm_init':
pm.c:(.init.text+0x5e8): undefined reference to `cpu_resume'
Fixes: 24a0f5c539f9 ("ARM: at91: pm: Add sama5d2 backup mode")
gcc-7 warns about some declarations that are more 'const' than necessary:
arch/arm/mach-at91/pm.c:338:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const ramc_ids[] __initconst = {
arch/arm/mach-bcm/bcm_kona_smc.c:36:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const bcm_kona_smc_ids[] __initconst = {
arch/arm/mach-spear/time.c:207:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const timer_of_match[] __initconst = {
arch/arm/mach-omap2/prm_common.c:714:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct of_device_id const omap_prcm_dt_match_table[] __initconst = {
arch/arm/mach-omap2/vc.c:562:35: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const struct i2c_init_data const omap4_i2c_timing_data[] __initconst = {
The ones in arch/arm were apparently all introduced accidentally by one
commit that correctly marked a lot of variables as __initconst.
Fixes: 19c233b79d1a ("ARM: appropriate __init annotation for const data")
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Krzysztof Hałasa <khalasa@piap.pl>
If the backup sram allocation fails, ensure we can suspend by falling back
to the usual slow clock mode.
Acked-by: Wenyou Yang <wenyou.yang@atmel.com>
While we can only select between "standby" and "mem" states for power
management, the atmel platforms can actually support more modes.
For both standby and mem, allow selecting which mode will be used using the
atmel.pm_modes kernel parameter.
By default, keep the current modes.
The sama5d2 has a mode were it is possible to cut power to the SoC while
keeping the RAM in self refresh.
Resuming from that mode needs support in the firmware/bootloader.
To simplify machine init and as the soc_device struct is not used as the
parent for on-chip devices anymore, move SoC detection to its own driver.
Change in dmesg:
- before:
DMA: preallocated 256 KiB pool for atomic coherent allocations
AT91: Detected SoC family: sama5d2
AT91: Detected SoC: sama5d27, revision 0
No ATAGs?
clocksource: tcb_clksrc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 184217874325 ns
at_xdmac f0010000.dma-controller: 16 channels, mapped at 0xe085b000
SCSI subsystem initialized
- after:
No ATAGs?
at_xdmac f0010000.dma-controller: 16 channels, mapped at 0xe0859000
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Add a missing bracket at the end of Anti's email
Merge at91_pm_set_standby() in at91_dt_ramc as this is the only callsite.
That moves it to the init section.
The PM initialization is now identical for all at91sam9. Merge the
functions.
The USB clocks mask (uhp_udp_mask) depends on the pmc. Tie it to the pmc id
instead of the SoC.
Instead of relying on the SoC type to select the memory controller type,
use the device tree ids as they are parsed anyway.
As already explained for pm_suspend.S, the DDRSDR controller fails to put
LPDDR1 memories in self-refresh. Force the controller to think it has DDR2
memories during the self-refresh period, as the DDR2 self-refresh spec is
equivalent to LPDDR1, and is correctly implemented in the controller.
Since 2008, AT91_MC_SDRAMC_LPR is set to 0 at kernel initialization. There
is no use saving, changing and restoring it.
The number of register we can safely pass to at91_pm_suspend_in_sram is
limited. Instead, pass the address to the at91_pm_data structure.
The offsets are automatically generated to avoid hardcoding them.
Instead of having separate global variables to hold IP addresses, move them
to struct at91_pm_data.
Those macros are only used in pm.c, move them there so we can remove the
test on __ASSEMBLY__.
Remove unnecessary header inclusions and reorder the remaining ones.
On some DDR controllers, compatible with the sama5d3 one,
the sequence to enter/exit/re-enter the self-refresh mode adds
more constrains than what is currently written in the at91_idle
driver. An actual access to the DDR chip is needed between exit
and re-enter of this mode which is somehow difficult to implement.
This sequence can completely hang the SoC. It is particularly
experienced on parts which embed a L2 cache if the code run
between IDLE calls fits in it...
Moreover, as the intention is to enter and exit pretty rapidly
from IDLE, the power-down mode is a good candidate.
So now we use power-down instead of self-refresh. As we can
simplify the code for sama5d3 compatible DDR controllers,
we instantiate a new sama5d3_ddr_standby() function.
Cc: <stable@vger.kernel.org> # v4.1+
Fixes: 017b5522d5e3 ("ARM: at91: Add new binding for sama5d3-ddramc")
at91_ramc_base is local to pm.c, remove its definition in pm.h
*MIGHT_HAVE_PCI* config is already selected in ARCH_MULTIPLATFORM.
Don't select it redundantly in all ARCH_MULTIPLATFORM based machines.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
* commit '5c34a4e89c743339f78cafb2f2a826a010f0746a':
ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB
ARM: uniphier: drop code for old DT binding
These cause a harmless conflict with the clps711x multiplatform
support, and it's easy to resolve.
Use helper of_platform_default_populate() in linux/of_platform
when possible, instead of calling of_platform_populate() with
the default match table.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Fix a pair of missing statics on un-exported functions and
include <linux/platform_data/atmel.h> to provide the declaration
of at91_suspend_entering_slow_clock() to fix the following
sparse warnings:
arch/arm/mach-at91/pm.c:127:5: warning: symbol 'at91_suspend_entering_slow_clock' was not declared. Should it be static?
arch/arm/mach-at91/pm.c:358:6: warning: symbol 'at91rm9200_idle' was not declared. Should it be static?
arch/arm/mach-at91/pm.c:367:6: warning: symbol 'at91sam9_idle' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
Add EXID of all SoCs of the SAMA5D2 family.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
So far, the CIDR and EXID registers were in the DBGU interface. This device
has disappeared with the SAMA5D2 family. These registers are exposed
through a new device called chipid.
[nicolas.ferre@atmel.com: remove useless warnings]
Acked-by: Rob Herring <robh@kernel.org>
[arnd@arndb.de: suggest to use static functions to reduce scope]
Remove leftover from the previous cleanup
Avoid using code from clk/at91 for PM.
This also has the bonus effect of setting arm_pm_idle for sama5 platforms.
To avoid relying on at91_pmc_read(), find the pmc node and remap it
locally.
at91_pm_init() doesn't return a value, as is the case for its callers,
simply call it instead of returning its non-existent return value.
The PMC block is providing several functionnalities:
- system clk management
- cpuidle
- platform suspend
Replace the void __iomem *regs field by a regmap (retrieved using syscon)
so that we can later share the regmap across several drivers without
exporting a new specific API or a global void __iomem * variable.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
"A smallish number of general cleanup commits this release cycle. Some
of these are minor tweaks:
- shmobile change of binding for their GIC (using arm,pl390 now)
- ARCH_RENESAS introduction
- Misc other renesas updates
There's also a couple of treewide commits from Masahiro Yamada
cleaning up const/__initconst for SMP operation structs and a switch
to using "depends on" instead of if-constructs on most of the Kconfig
platform targets"
staging: board: armadillo800eva: Use "arm,pl390"
staging: board: kzm9d: Use "arm,pl390"
ARM: shmobile: r8a7778 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: emev2 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r8a7740 dtsi: Use "arm,pl390" for GIC
ARM: shmobile: r7s72100 dtsi: Use "arm,pl390" for GIC
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
ARM: mvebu: remove unused mach/gpio.h
ARM: shmobile: Remove legacy mach/irqs.h
ARM: shmobile: Introduce ARCH_RENESAS
MAINTAINERS: Remove link to oss.renesas.com which is closed
Move the selection of the pinctrl driver to SoC family level since we
have two pinctrl drivers. It is useless to select one which is not
compatible with the SoC.
[abelloni: fixed pm.c when only sama2d2 is selected]
Many ARM sub-architectures use prompts followed by "if" conditional,
but it is wrong.
Please notice the difference between
config ARCH_FOO
bool "Foo SoCs" if ARCH_MULTI_V7
and
config ARCH_FOO
bool "Foo SoCs"
depends on ARCH_MULTI_V7
These two are *not* equivalent!
In the former statement, it is not ARCH_FOO, but its prompt that
depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO
is selected by another, but ARCH_MULTI_V7 is still disabled. As it is
not unmet dependency, Kconfig never warns. This is probably not what
you want.
The former should be used only when you need to do so, and you really
understand what you are doing. (In most cases, it should be wrong!)
For enabling/disabling sub-architectures, the latter is always correct.
As a good side effect, this commit fixes some entries over 80 columns
(mach-imx, mach-integrator, mach-mbevu).
[Arnd: I note that there is not really a bug here, according to
the discussion that followed, but I can see value in being consistent
and in making the lines shorter]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: Jun Nie <jun.nie@linaro.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Krzysztof Halasa <khc@piap.pl>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
"New and/or improved SoC support for this release:
Marvell Berlin:
- Enable standard DT-based cpufreq
- Add CPU hotplug support
Freescale:
- Ethernet init for i.MX7D
- Suspend/resume support for i.MX6UL
Allwinner:
- Support for R8 chipset (used on NTC's $9 C.H.I.P board)
Mediatek:
- SMP support for some platforms
Uniphier:
- L2 support
- Cleaned up SMP support, etc.
plus a handful of other patches around above functionality, and a few
other smaller changes"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM: uniphier: rework SMP operations to use trampoline code
ARM: uniphier: add outer cache support
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: mvebu: add broken-idle option
ARM: orion5x: use mac_pton() helper
ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned
ARM: sunxi: Add R8 support
ARM: digicolor: select pinctrl/gpio driver
arm: berlin: add CPU hotplug support
arm: berlin: use non-self-cleared reset register to reset cpu
ARM: mediatek: add smp bringup code
ARM: mediatek: enable gpt6 on boot up to make arch timer working
soc: mediatek: Fix random hang up issue while kernel init
soc: ti: qmss: make acc queue support optional in the driver
soc: ti: add firmware file name as part of the driver
Documentation: dt: soc: Add description for knav qmss driver
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
fncpy() requires that the source and the destination are both 8-byte
aligned.
Signed-off-by: Patrick Doyle <pdoyle@irobot.com>
Fixes: d94e688cae56 ("ARM: at91/pm: move the copying the sram function to the sram initialization phase")
Cc: <stable@vger.kernel.org> # 4.1+
Add a new type of clocks that can be provided to a peripheral.
In addition to the peripheral clock, this new clock that can use several
input clocks as parents can generate divided rates.
This would allow a peripheral to have finer grained clocks for generating
a baud rate, clocking an asynchronous part or having more
options in frequency.
[sboyd@codeaurora.org: Transition to new clk_hw provider APIs]
This change modifies gen_pool_get() and devm_gen_pool_create() client
interfaces adding one more argument "name" of a gen_pool object.
Due to implementation gen_pool_get() is capable to retrieve only one
gen_pool associated with a device even if multiple gen_pools are created,
fortunately right at the moment it is sufficient for the clients, hence
provide NULL as a valid argument on both producer devm_gen_pool_create()
and consumer gen_pool_get() sides.
Because only one created gen_pool per device is addressable, explicitly
add a restriction to devm_gen_pool_create() to create only one gen_pool
per device, this implies two possible error codes returned by the
function, account it on client side (only misc/sram). This completes
client side changes related to genalloc updates.
[akpm@linux-foundation.org: gen_pool_get() cleanup]
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
